root/radiance/ray/src/cv/lampcolor.c
Revision: 2.4
Committed: Fri Jun 4 14:32:44 1993 UTC (30 years, 11 months ago) by greg
Changes since 2.3: +2 -3 lines
Removed unnecessary declaration of atof()
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Program to convert lamp color from table and compute radiance.
9 */
10
11 #include <stdio.h>
12
13 #include <math.h>
14
15 #include "color.h"
16
17 #define PI 3.14159265358979323846
18
19 extern char *gets(), *strcpy();
20 extern float *matchlamp();
21
22 /* lamp parameters */
23 #define LTYPE 0
24 #define LUNIT 1
25 #define LGEOM 2
26 #define LOUTP 3
27 #define NPARAMS 4
28
29 int typecheck(), unitcheck(), geomcheck(), outpcheck();
30
31 float *lampcolor; /* the lamp color (RGB) */
32 double unit2meter; /* conversion from units to meters */
33 double area; /* radiating area for this geometry */
34 double lumens; /* total lamp lumens */
35
36 struct {
37 char *name;
38 char value[64];
39 int (*check)();
40 char *help;
41 } param[NPARAMS] = {
42 { "lamp type", "D65WHITE", typecheck,
43 "The lamp type is a string which corresponds to one of the types registered\n\
44 in the lamp table file. A value of \"D65WHITE\" means an uncolored source,\n\
45 which may be preferable because it results in a color balanced image." },
46 { "length unit", "meter", unitcheck,
47 "Unit must be one of: \"meter\", \"centimeter\", \"foot\", or \"inch\".\n\
48 These may be abbreviated as a single letter." },
49 { "lamp geometry", "polygon", geomcheck,
50 "The lamp geometry must be one of: \"polygon\", \"sphere\", \"cylinder\"\n\
51 or \"ring\". These may be abbreviated as a single letter." },
52 { "total lamp lumens", "0", outpcheck,
53 "This is the overall light output of the lamp and its fixture. If you do\n\
54 not know this value explicitly, you can compute the approximate lumens\n\
55 by multiplying the input wattage by 14 for incandescent fixtures or 70\n\
56 for fluorescent fixtures." },
57 };
58
59
60 main(argc, argv)
61 int argc;
62 char *argv[];
63 {
64 char *lamptab = "lamp.tab";
65 char buf[64];
66 int i;
67
68 if (argc > 1) lamptab = argv[1];
69 if (loadlamps(lamptab) == 0) {
70 fprintf(stderr, "%s: no such lamp table\n", lamptab);
71 exit(1);
72 }
73 printf("Program to compute lamp radiance. Enter '?' for help.\n");
74 for ( ; ; ) {
75 i = 0;
76 while (i < NPARAMS) {
77 printf("Enter %s [%s]: ", param[i].name,
78 param[i].value);
79 if (gets(buf) == NULL)
80 exit(0);
81 if (buf[0] == '?') {
82 puts(param[i].help);
83 continue;
84 }
85 if (buf[0])
86 strcpy(param[i].value, buf);
87 if (!(*param[i].check)(param[i].value)) {
88 fprintf(stderr, "%s: bad value for %s\n",
89 param[i].value, param[i].name);
90 continue;
91 }
92 i++;
93 }
94 compute();
95 }
96 }
97
98
99 typecheck(s) /* check lamp type */
100 char *s;
101 {
102 lampcolor = matchlamp(s);
103 return(lampcolor != NULL);
104 }
105
106
107 unitcheck(s) /* compute conversion to meters */
108 char *s;
109 {
110 int len = strlen(s);
111
112 switch (*s) {
113 case 'm':
114 if (strncmp(s, "meters", len))
115 return(0);
116 unit2meter = 1.0;
117 return(1);
118 case 'c':
119 if (strncmp(s, "centimeters", len) && strncmp(s, "cms", len))
120 return(0);
121 unit2meter = 0.01;
122 return(1);
123 case 'f':
124 if (strncmp(s, "foot", len) && strncmp(s, "feet", len))
125 return(0);
126 unit2meter = 0.3048;
127 return(1);
128 case 'i':
129 if (strncmp(s, "inches", len))
130 return(0);
131 unit2meter = 0.0254;
132 return(1);
133 }
134 return(0);
135 }
136
137
138 geomcheck(s) /* check/set lamp geometry */
139 char *s;
140 {
141 int len = strlen(s);
142
143 switch (*s) {
144 case 'p':
145 if (strncmp(s, "polygonal", len))
146 return(0);
147 return(getpolygon());
148 case 's':
149 if (strncmp(s, "sphere", len) && strncmp(s, "spherical", len))
150 return(0);
151 return(getsphere());
152 case 'c':
153 if (strncmp(s,"cylinder",len) && strncmp(s,"cylindrical",len))
154 return(0);
155 return(getcylinder());
156 case 'r':
157 if (strncmp(s, "ring", len) && strncmp(s, "disk", len))
158 return(0);
159 return(getring());
160 }
161 return(0);
162 }
163
164
165 outpcheck(s) /* check lumen output value */
166 register char *s;
167 {
168 if ((*s < '0' || *s > '9') && *s != '.')
169 return(0);
170 lumens = atof(s);
171 return(1);
172 }
173
174
175 compute() /* compute lamp radiance */
176 {
177 double whiteval;
178
179 whiteval = lumens/area/(WHTEFFICACY*PI);
180
181 printf("Lamp color (RGB) = %f %f %f\n",
182 lampcolor[0]*whiteval,
183 lampcolor[1]*whiteval,
184 lampcolor[2]*whiteval);
185 }
186
187
188 getd(name, dp, help) /* get a positive double from stdin */
189 char *name;
190 double *dp;
191 char *help;
192 {
193 char buf[32];
194 again:
195 printf("%s [%g]: ", name, *dp);
196 if (gets(buf) == NULL)
197 return(0);
198 if (buf[0] == '?') {
199 puts(help);
200 goto again;
201 }
202 if ((buf[0] < '0' || buf[0] > '9') && buf[0] != '.')
203 return(0);
204 *dp = atof(buf);
205 return(1);
206 }
207
208
209 getpolygon() /* get projected area for a polygon */
210 {
211 static double parea = 1.0;
212
213 getd("Polygon area", &parea,
214 "Enter the total radiating area of the polygon.");
215 area = unit2meter*unit2meter * parea;
216 return(1);
217 }
218
219
220 getsphere() /* get projected area for a sphere */
221 {
222 static double radius = 1.0;
223
224 getd("Sphere radius", &radius,
225 "Enter the distance from the sphere's center to its surface.");
226 area = 4.*PI*unit2meter*unit2meter * radius*radius;
227 return(1);
228 }
229
230
231 getcylinder() /* get projected area for a cylinder */
232 {
233 static double length = 1.0, radius = 0.1;
234
235 getd("Cylinder length", &length,
236 "Enter the length of the cylinder.");
237 getd("Cylinder radius", &radius,
238 "Enter the distance from the cylinder's axis to its surface.");
239 area = 2.*PI*unit2meter*unit2meter * radius*length;
240 return(1);
241 }
242
243
244 getring() /* get projected area for a ring */
245 {
246 static double radius = 1.0;
247
248 getd("Disk radius", &radius,
249 "Enter the distance from the ring's center to its outer edge.\n\
250 The inner radius must be zero.");
251 area = PI*unit2meter*unit2meter * radius*radius;
252 return(1);
253 }
