| 1 |
/* Copyright (c) 1991 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Program to convert lamp color from table and compute radiance.
| 9 |
| 10 |
| 11 |
#include <stdio.h>
| 12 |
| 13 |
#include "color.h"
| 14 |
| 15 |
#define PI 3.14159265358979323846
| 16 |
| 17 |
extern char *gets(), *strcpy();
| 18 |
extern double atof();
| 19 |
extern float *matchlamp();
| 20 |
| 21 |
/* lamp parameters */
| 22 |
#define LTYPE 0
| 23 |
#define LUNIT 1
| 24 |
#define LGEOM 2
| 25 |
#define LOUTP 3
| 26 |
#define NPARAMS 4
| 27 |
| 28 |
int typecheck(), unitcheck(), geomcheck(), outpcheck();
| 29 |
| 30 |
float *lampcolor; /* the lamp color (RGB) */
| 31 |
double unit2meter; /* conversion from units to meters */
| 32 |
double area; /* radiating area for this geometry */
| 33 |
double lumens; /* total lamp lumens */
| 34 |
| 35 |
struct {
| 36 |
char *name;
| 37 |
char value[64];
| 38 |
int (*check)();
| 39 |
char *help;
| 40 |
} param[NPARAMS] = {
| 41 |
{ "lamp type", "white", typecheck,
| 42 |
"The lamp type is a string which corresponds to one of the types registered\n\
| 43 |
in the lamp table file. A value of \"white\" means an uncolored source,\n\
| 44 |
which may be preferable because it results in a color balanced image." },
| 45 |
{ "length unit", "meter", unitcheck,
| 46 |
"Unit must be one of: \"meter\", \"centimeter\", \"foot\", or \"inch\".\n\
| 47 |
These may be abbreviated as a single letter." },
| 48 |
{ "lamp geometry", "polygon", geomcheck,
| 49 |
"The lamp geometry must be one of: \"polygon\", \"sphere\", \"cylinder\"\n\
| 50 |
or \"ring\". These may be abbreviated as a single letter." },
| 51 |
{ "total lamp lumens", "0", outpcheck,
| 52 |
"This is the overall light output of the lamp and its fixture. If you do\n\
| 53 |
not know this value explicitly, you can compute the approximate lumens\n\
| 54 |
by multiplying the input wattage by 14 for incandescent fixtures or 70\n\
| 55 |
for fluorescent fixtures." },
| 56 |
| 57 |
| 58 |
| 59 |
main(argc, argv)
| 60 |
int argc;
| 61 |
char *argv[];
| 62 |
| 63 |
char *lamptab = "lamp.tab";
| 64 |
char buf[64];
| 65 |
int i;
| 66 |
| 67 |
if (argc > 1) lamptab = argv[1];
| 68 |
if (loadlamps(lamptab) == 0) {
| 69 |
fprintf(stderr, "%s: no such lamp table\n", lamptab);
| 70 |
exit(1);
| 71 |
| 72 |
printf("Program to compute lamp radiance. Enter '?' for help.\n");
| 73 |
for ( ; ; ) {
| 74 |
i = 0;
| 75 |
while (i < NPARAMS) {
| 76 |
printf("Enter %s [%s]: ", param[i].name,
| 77 |
param[i].value);
| 78 |
if (gets(buf) == NULL)
| 79 |
exit(0);
| 80 |
if (buf[0] == '?') {
| 81 |
puts(param[i].help);
| 82 |
continue;
| 83 |
| 84 |
if (buf[0])
| 85 |
strcpy(param[i].value, buf);
| 86 |
if (!(*param[i].check)(param[i].value)) {
| 87 |
fprintf(stderr, "%s: bad value for %s\n",
| 88 |
param[i].value, param[i].name);
| 89 |
continue;
| 90 |
| 91 |
i++;
| 92 |
| 93 |
compute();
| 94 |
| 95 |
| 96 |
| 97 |
| 98 |
typecheck(s) /* check lamp type */
| 99 |
char *s;
| 100 |
| 101 |
lampcolor = matchlamp(s);
| 102 |
return(lampcolor != NULL);
| 103 |
| 104 |
| 105 |
| 106 |
unitcheck(s) /* compute conversion to meters */
| 107 |
char *s;
| 108 |
| 109 |
int len = strlen(s);
| 110 |
| 111 |
switch (*s) {
| 112 |
case 'm':
| 113 |
if (strncmp(s, "meters", len))
| 114 |
return(0);
| 115 |
unit2meter = 1.0;
| 116 |
return(1);
| 117 |
case 'c':
| 118 |
if (strncmp(s, "centimeters", len) && strncmp(s, "cms", len))
| 119 |
return(0);
| 120 |
unit2meter = 0.01;
| 121 |
return(1);
| 122 |
case 'f':
| 123 |
if (strncmp(s, "foot", len) && strncmp(s, "feet", len))
| 124 |
return(0);
| 125 |
unit2meter = 0.3048;
| 126 |
return(1);
| 127 |
case 'i':
| 128 |
if (strncmp(s, "inches", len))
| 129 |
return(0);
| 130 |
unit2meter = 0.0254;
| 131 |
return(1);
| 132 |
| 133 |
return(0);
| 134 |
| 135 |
| 136 |
| 137 |
geomcheck(s) /* check/set lamp geometry */
| 138 |
char *s;
| 139 |
| 140 |
| 141 |
| 142 |
switch (*s) {
| 143 |
case 'p':
| 144 |
if (strncmp(s, "polygonal", len))
| 145 |
return(0);
| 146 |
return(getpolygon());
| 147 |
case 's':
| 148 |
if (strncmp(s, "sphere", len) && strncmp(s, "spherical", len))
| 149 |
return(0);
| 150 |
return(getsphere());
| 151 |
case 'c':
| 152 |
if (strncmp(s,"cylinder",len) && strncmp(s,"cylindrical",len))
| 153 |
return(0);
| 154 |
return(getcylinder());
| 155 |
case 'r':
| 156 |
if (strncmp(s, "ring", len) && strncmp(s, "disk", len))
| 157 |
return(0);
| 158 |
return(getring());
| 159 |
| 160 |
return(0);
| 161 |
| 162 |
| 163 |
| 164 |
outpcheck(s) /* check lumen output value */
| 165 |
register char *s;
| 166 |
| 167 |
if ((*s < '0' || *s > '9') && *s != '.')
| 168 |
return(0);
| 169 |
lumens = atof(s);
| 170 |
return(1);
| 171 |
| 172 |
| 173 |
| 174 |
compute() /* compute lamp radiance */
| 175 |
| 176 |
double whiteval;
| 177 |
| 178 |
whiteval = lumens/area/(WHTEFFICACY*PI);
| 179 |
| 180 |
printf("Lamp color (RGB) = %f %f %f\n",
| 181 |
lampcolor[0]*whiteval,
| 182 |
lampcolor[1]*whiteval,
| 183 |
lampcolor[2]*whiteval);
| 184 |
| 185 |
| 186 |
| 187 |
getd(name, dp, help) /* get a positive double from stdin */
| 188 |
char *name;
| 189 |
double *dp;
| 190 |
char *help;
| 191 |
| 192 |
char buf[32];
| 193 |
again:
| 194 |
printf("%s [%g]: ", name, *dp);
| 195 |
| 196 |
return(0);
| 197 |
| 198 |
puts(help);
| 199 |
goto again;
| 200 |
| 201 |
if ((buf[0] < '0' || buf[0] > '9') && buf[0] != '.')
| 202 |
return(0);
| 203 |
*dp = atof(buf);
| 204 |
return(1);
| 205 |
| 206 |
| 207 |
| 208 |
getpolygon() /* get projected area for a polygon */
| 209 |
| 210 |
static double area = 1.0;
| 211 |
| 212 |
getd("Polygon area", &area,
| 213 |
"Enter the total radiating area of the polygon.");
| 214 |
area = unit2meter*unit2meter * area;
| 215 |
return(1);
| 216 |
| 217 |
| 218 |
| 219 |
getsphere() /* get projected area for a sphere */
| 220 |
| 221 |
static double radius = 1.0;
| 222 |
| 223 |
getd("Sphere radius", &radius,
| 224 |
"Enter the distance from the sphere's center to its surface.");
| 225 |
area = 4.*PI*unit2meter*unit2meter * radius*radius;
| 226 |
return(1);
| 227 |
| 228 |
| 229 |
| 230 |
getcylinder() /* get projected area for a cylinder */
| 231 |
| 232 |
static double length = 1.0, radius = 0.1;
| 233 |
| 234 |
getd("Cylinder length", &length,
| 235 |
"Enter the length of the cylinder.");
| 236 |
getd("Cylinder radius", &radius,
| 237 |
"Enter the distance from the cylinder's axis to its surface.");
| 238 |
area = 2.*PI*unit2meter*unit2meter * radius*length;
| 239 |
return(1);
| 240 |
| 241 |
| 242 |
| 243 |
getring() /* get projected area for a ring */
| 244 |
| 245 |
| 246 |
| 247 |
getd("Disk radius", &radius,
| 248 |
"Enter the distance from the ring's center to its outer edge.\n\
| 249 |
The inner radius must be zero.");
| 250 |
area = PI*unit2meter*unit2meter * radius*radius;
| 251 |
return(1);
| 252 |
