root/radiance/ray/src/cv/lampcolor.c
Revision: 1.2
Committed: Thu Sep 5 15:09:08 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.1: +223 -12 lines
changed program to calculate lamp radiance for diffuse sources
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Program to convert lamp color from table and compute radiance.
9 */
10
11 #include <stdio.h>
12
13 #define PI 3.14159265358979323846
14
15 extern char *gets(), *strcpy();
16 extern double atof();
17 extern float *matchlamp();
18
19 /* lamp parameters */
20 #define LTYPE 0
21 #define LUNIT 1
22 #define LGEOM 2
23 #define LOUTP 3
24 #define NPARAMS 4
25
26 int typecheck(), unitcheck(), geomcheck(), outpcheck();
27
28 float *lampcolor; /* the lamp color (RGB) */
29 double unit2meter; /* conversion from units to meters */
30 double projarea; /* projected area for this geometry */
31 double lumens; /* total lamp lumens */
32
33 struct {
34 char *name;
35 char value[64];
36 int (*check)();
37 char *help;
38 } param[NPARAMS] = {
39 { "lamp type", "white", typecheck,
40 "The lamp type is a string which corresponds to one of the types registered\n\
41 in the lamp table file. A value of \"white\" means an uncolored source,\n\
42 which may be preferable because it results in a color balanced image." },
43 { "length unit", "meter", unitcheck,
44 "Unit must be one of: \"meter\", \"centimeter\", \"foot\", or \"inch\".\n\
45 These may be abbreviated as a single letter." },
46 { "lamp geometry", "polygon", geomcheck,
47 "The lamp geometry must be one of: \"polygon\", \"sphere\", \"cylinder\"\n\
48 or \"ring\". These may be abbreviated as a single letter." },
49 { "total lamp lumens", "0", outpcheck,
50 "This is the overall light output of the lamp and its fixture. If you do\n\
51 not know this value explicitly, you can compute the approximate lumens\n\
52 by multiplying the input wattage by 15 for incandescent fixtures or 40\n\
53 for fluorescent fixtures." },
54 };
55
56
57 main(argc, argv)
58 int argc;
59 char *argv[];
60 {
61 char *lamptab = "lamp.tab";
62 char buf[64];
63 int i;
64
65 if (argc > 1) lamptab = argv[1];
66 if (loadlamps(lamptab) == 0) {
67 fprintf(stderr, "%s: no such lamp table\n", lamptab);
68 exit(1);
69 }
70 printf("Program to compute lamp radiance. Enter '?' for help.\n");
71 for ( ; ; ) {
72 i = 0;
73 while (i < NPARAMS) {
74 printf("Enter %s [%s]: ", param[i].name,
75 param[i].value);
76 if (gets(buf) == NULL)
77 exit(0);
78 if (buf[0] == '?') {
79 puts(param[i].help);
80 continue;
81 }
82 if (buf[0])
83 strcpy(param[i].value, buf);
84 if (!(*param[i].check)(param[i].value)) {
85 fprintf(stderr, "%s: bad value for %s\n",
86 param[i].value, param[i].name);
87 continue;
88 }
89 i++;
90 }
91 compute();
92 }
93 }
94
95
96 typecheck(s) /* check lamp type */
97 char *s;
98 {
99 lampcolor = matchlamp(s);
100 return(lampcolor != NULL);
101 }
102
103
104 unitcheck(s) /* compute conversion to meters */
105 char *s;
106 {
107 int len = strlen(s);
108
109 switch (*s) {
110 case 'm':
111 if (strncmp(s, "meters", len))
112 return(0);
113 unit2meter = 1.0;
114 return(1);
115 case 'c':
116 if (strncmp(s, "centimeters", len) && strncmp(s, "cms", len))
117 return(0);
118 unit2meter = 0.01;
119 return(1);
120 case 'f':
121 if (strncmp(s, "foot", len) && strncmp(s, "feet", len))
122 return(0);
123 unit2meter = 0.3048;
124 return(1);
125 case 'i':
126 if (strncmp(s, "inches", len))
127 return(0);
128 unit2meter = 0.0254;
129 return(1);
130 }
131 return(0);
132 }
133
134
135 geomcheck(s) /* check/set lamp geometry */
136 char *s;
137 {
138 int len = strlen(s);
139
140 switch (*s) {
141 case 'p':
142 if (strncmp(s, "polygonal", len))
143 return(0);
144 return(getpolygon());
145 case 's':
146 if (strncmp(s, "sphere", len) && strncmp(s, "spherical", len))
147 return(0);
148 return(getsphere());
149 case 'c':
150 if (strncmp(s,"cylinder",len) && strncmp(s,"cylindrical",len))
151 return(0);
152 return(getcylinder());
153 case 'r':
154 if (strncmp(s, "ring", len) && strncmp(s, "disk", len))
155 return(0);
156 return(getring());
157 }
158 return(0);
159 }
160
161
162 outpcheck(s) /* check lumen output value */
163 register char *s;
164 {
165 if ((*s < '0' || *s > '9') && *s != '.')
166 return(0);
167 lumens = atof(s);
168 return(1);
169 }
170
171
172 compute() /* compute lamp radiance */
173 {
174 double whiteval;
175
176 whiteval = lumens/470./projarea;
177
178 printf("Lamp color (RGB) = %f %f %f\n",
179 lampcolor[0]*whiteval,
180 lampcolor[1]*whiteval,
181 lampcolor[2]*whiteval);
182 }
183
184
185 getd(dp) /* get a positive double from stdin */
186 double *dp;
187 {
188 char buf[32];
189
190 if (gets(buf) == NULL)
191 return(0);
192 if ((buf[0] < '0' || buf[0] > '9') && buf[0] != '.')
193 return(0);
194 *dp = atof(buf);
195 return(1);
196 }
197
198
199 getpolygon() /* get projected area for a polygon */
200 {
201 printf("Enter area of polygon: ");
202 if (!getd(&projarea))
203 return(0);
204 projarea *= unit2meter*unit2meter;
205 projarea *= PI;
206 return(1);
207 }
208
209
210 getsphere() /* get projected area for a sphere */
211 {
212 double radius;
213
214 printf("Enter sphere radius: ");
215 if (!getd(&radius))
216 return(0);
217 radius *= unit2meter;
218 projarea = 4.*PI*PI*radius*radius;
219 return(1);
220 }
221
222
223 getcylinder() /* get projected area for a cylinder */
224 {
225 double length, radius;
226
227 printf("Enter cylinder length: ");
228 if (!getd(&length))
229 return(0);
230 length *= unit2meter;
231 printf("Enter cylinder radius: ");
232 if (!getd(&radius))
233 return(0);
234 radius *= unit2meter;
235 projarea = PI*PI*2.*PI*radius*length;
236 return(1);
237 }
238
239
240 getring() /* get projected area for a ring */
241 {
242 double radius;
243
244 printf("Enter disk radius: ");
245 if (!getd(&radius))
246 return(0);
247 radius *= unit2meter;
248 projarea = PI*PI*radius*radius;
249 return(1);
250 }
