--- ray/src/cv/lampcolor.c 1991/09/05 15:09:08 1.2 +++ ray/src/cv/lampcolor.c 2003/11/15 17:54:06 2.9 @@ -1,21 +1,18 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: lampcolor.c,v 2.9 2003/11/15 17:54:06 schorsch Exp $"; #endif - /* * Program to convert lamp color from table and compute radiance. */ #include +#include +#include -#define PI 3.14159265358979323846 +#include "rtmath.h" +#include "rtio.h" +#include "color.h" -extern char *gets(), *strcpy(); -extern double atof(); -extern float *matchlamp(); - /* lamp parameters */ #define LTYPE 0 #define LUNIT 1 @@ -23,11 +20,18 @@ extern float *matchlamp(); #define LOUTP 3 #define NPARAMS 4 -int typecheck(), unitcheck(), geomcheck(), outpcheck(); +static int typecheck(char *s); +static int unitcheck(char *s); +static int geomcheck(char *s); +static int outpcheck(char *s); +static void compute(void); +static int getpolygon(void), getsphere(void), getcylinder(void), getring(void); +static int getd(char *name, double *dp, char *help); + float *lampcolor; /* the lamp color (RGB) */ double unit2meter; /* conversion from units to meters */ -double projarea; /* projected area for this geometry */ +double area; /* radiating area for this geometry */ double lumens; /* total lamp lumens */ struct { @@ -36,9 +40,9 @@ struct { int (*check)(); char *help; } param[NPARAMS] = { - { "lamp type", "white", typecheck, + { "lamp type", "WHITE", typecheck, "The lamp type is a string which corresponds to one of the types registered\n\ -in the lamp table file. A value of \"white\" means an uncolored source,\n\ +in the lamp table file. A value of \"WHITE\" means an uncolored source,\n\ which may be preferable because it results in a color balanced image." }, { "length unit", "meter", unitcheck, "Unit must be one of: \"meter\", \"centimeter\", \"foot\", or \"inch\".\n\ @@ -49,14 +53,16 @@ or \"ring\". These may be abbreviated as a single let { "total lamp lumens", "0", outpcheck, "This is the overall light output of the lamp and its fixture. If you do\n\ not know this value explicitly, you can compute the approximate lumens\n\ -by multiplying the input wattage by 15 for incandescent fixtures or 40\n\ +by multiplying the input wattage by 14 for incandescent fixtures or 70\n\ for fluorescent fixtures." }, }; -main(argc, argv) -int argc; -char *argv[]; +int +main( + int argc, + char *argv[] +) { char *lamptab = "lamp.tab"; char buf[64]; @@ -73,7 +79,7 @@ char *argv[]; while (i < NPARAMS) { printf("Enter %s [%s]: ", param[i].name, param[i].value); - if (gets(buf) == NULL) + if (fgets(buf, sizeof(buf), stdin) == NULL) exit(0); if (buf[0] == '?') { puts(param[i].help); @@ -93,16 +99,20 @@ char *argv[]; } -typecheck(s) /* check lamp type */ -char *s; +static int +typecheck( /* check lamp type */ + char *s +) { lampcolor = matchlamp(s); return(lampcolor != NULL); } -unitcheck(s) /* compute conversion to meters */ -char *s; +static int +unitcheck( /* compute conversion to meters */ + char *s +) { int len = strlen(s); @@ -132,8 +142,10 @@ char *s; } -geomcheck(s) /* check/set lamp geometry */ -char *s; +static int +geomcheck( /* check/set lamp geometry */ + char *s +) { int len = strlen(s); @@ -159,8 +171,10 @@ char *s; } -outpcheck(s) /* check lumen output value */ -register char *s; +static int +outpcheck( /* check lumen output value */ + register char *s +) { if ((*s < '0' || *s > '9') && *s != '.') return(0); @@ -169,11 +183,12 @@ register char *s; } -compute() /* compute lamp radiance */ +static void +compute(void) /* compute lamp radiance */ { double whiteval; - whiteval = lumens/470./projarea; + whiteval = lumens/area/(WHTEFFICACY*PI); printf("Lamp color (RGB) = %f %f %f\n", lampcolor[0]*whiteval, @@ -182,13 +197,22 @@ compute() /* compute lamp radiance */ } -getd(dp) /* get a positive double from stdin */ -double *dp; +static int +getd( /* get a positive double from stdin */ + char *name, + double *dp, + char *help +) { char buf[32]; - - if (gets(buf) == NULL) +again: + printf("%s [%g]: ", name, *dp); + if (fgets(buf, sizeof(buf), stdin) == NULL) return(0); + if (buf[0] == '?') { + puts(help); + goto again; + } if ((buf[0] < '0' || buf[0] > '9') && buf[0] != '.') return(0); *dp = atof(buf); @@ -196,55 +220,52 @@ double *dp; } -getpolygon() /* get projected area for a polygon */ +static int +getpolygon(void) /* get projected area for a polygon */ { - printf("Enter area of polygon: "); - if (!getd(&projarea)) - return(0); - projarea *= unit2meter*unit2meter; - projarea *= PI; + static double parea = 1.0; + + getd("Polygon area", &parea, + "Enter the total radiating area of the polygon."); + area = unit2meter*unit2meter * parea; return(1); } -getsphere() /* get projected area for a sphere */ +static int +getsphere(void) /* get projected area for a sphere */ { - double radius; + static double radius = 1.0; - printf("Enter sphere radius: "); - if (!getd(&radius)) - return(0); - radius *= unit2meter; - projarea = 4.*PI*PI*radius*radius; + getd("Sphere radius", &radius, + "Enter the distance from the sphere's center to its surface."); + area = 4.*PI*unit2meter*unit2meter * radius*radius; return(1); } -getcylinder() /* get projected area for a cylinder */ +static int +getcylinder(void) /* get projected area for a cylinder */ { - double length, radius; + static double length = 1.0, radius = 0.1; - printf("Enter cylinder length: "); - if (!getd(&length)) - return(0); - length *= unit2meter; - printf("Enter cylinder radius: "); - if (!getd(&radius)) - return(0); - radius *= unit2meter; - projarea = PI*PI*2.*PI*radius*length; + getd("Cylinder length", &length, + "Enter the length of the cylinder."); + getd("Cylinder radius", &radius, + "Enter the distance from the cylinder's axis to its surface."); + area = 2.*PI*unit2meter*unit2meter * radius*length; return(1); } -getring() /* get projected area for a ring */ +static int +getring(void) /* get projected area for a ring */ { - double radius; + static double radius = 1.0; - printf("Enter disk radius: "); - if (!getd(&radius)) - return(0); - radius *= unit2meter; - projarea = PI*PI*radius*radius; + getd("Disk radius", &radius, +"Enter the distance from the ring's center to its outer edge.\n\ +The inner radius must be zero."); + area = PI*unit2meter*unit2meter * radius*radius; return(1); }
