--- ray/src/cv/lampcolor.c 1994/07/05 15:49:51 2.5 +++ ray/src/cv/lampcolor.c 2003/06/08 12:03:09 2.7 @@ -1,24 +1,19 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: lampcolor.c,v 2.7 2003/06/08 12:03:09 schorsch Exp $"; #endif - /* * Program to convert lamp color from table and compute radiance. */ #include - +#include #include +#include "standard.h" #include "color.h" #define PI 3.14159265358979323846 -extern char *gets(), *strcpy(); -extern float *matchlamp(); - /* lamp parameters */ #define LTYPE 0 #define LUNIT 1 @@ -26,8 +21,14 @@ extern float *matchlamp(); #define LOUTP 3 #define NPARAMS 4 -int typecheck(), unitcheck(), geomcheck(), outpcheck(); +static int typecheck(char *s); +static int unitcheck(char *s); +static int geomcheck(char *s); +static int outpcheck(char *s); +static void compute(void); +static int getpolygon(void), getsphere(void), getcylinder(void), getring(void); + float *lampcolor; /* the lamp color (RGB) */ double unit2meter; /* conversion from units to meters */ double area; /* radiating area for this geometry */ @@ -96,16 +97,20 @@ char *argv[]; } -typecheck(s) /* check lamp type */ -char *s; +static int +typecheck( /* check lamp type */ +char *s +) { lampcolor = matchlamp(s); return(lampcolor != NULL); } -unitcheck(s) /* compute conversion to meters */ -char *s; +static int +unitcheck( /* compute conversion to meters */ +char *s +) { int len = strlen(s); @@ -135,8 +140,10 @@ char *s; } -geomcheck(s) /* check/set lamp geometry */ -char *s; +static int +geomcheck( /* check/set lamp geometry */ +char *s +) { int len = strlen(s); @@ -162,8 +169,10 @@ char *s; } -outpcheck(s) /* check lumen output value */ -register char *s; +static int +outpcheck( /* check lumen output value */ +register char *s +) { if ((*s < '0' || *s > '9') && *s != '.') return(0); @@ -172,7 +181,8 @@ register char *s; } -compute() /* compute lamp radiance */ +static void +compute(void) /* compute lamp radiance */ { double whiteval; @@ -206,7 +216,8 @@ again: } -getpolygon() /* get projected area for a polygon */ +static int +getpolygon(void) /* get projected area for a polygon */ { static double parea = 1.0; @@ -217,7 +228,8 @@ getpolygon() /* get projected area for a polygon */ } -getsphere() /* get projected area for a sphere */ +static int +getsphere(void) /* get projected area for a sphere */ { static double radius = 1.0; @@ -228,7 +240,8 @@ getsphere() /* get projected area for a sphere */ } -getcylinder() /* get projected area for a cylinder */ +static int +getcylinder(void) /* get projected area for a cylinder */ { static double length = 1.0, radius = 0.1; @@ -241,7 +254,8 @@ getcylinder() /* get projected area for a cylinder * } -getring() /* get projected area for a ring */ +static int +getring(void) /* get projected area for a ring */ { static double radius = 1.0;
