--- ray/src/cv/lampcolor.c 1991/10/24 12:17:38 1.8 +++ ray/src/cv/lampcolor.c 2003/02/22 02:07:23 2.6 @@ -1,21 +1,19 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: lampcolor.c,v 2.6 2003/02/22 02:07:23 greg Exp $"; #endif - /* * Program to convert lamp color from table and compute radiance. */ #include +#include + #include "color.h" #define PI 3.14159265358979323846 extern char *gets(), *strcpy(); -extern double atof(); extern float *matchlamp(); /* lamp parameters */ @@ -38,9 +36,9 @@ struct { int (*check)(); char *help; } param[NPARAMS] = { - { "lamp type", "white", typecheck, + { "lamp type", "WHITE", typecheck, "The lamp type is a string which corresponds to one of the types registered\n\ -in the lamp table file. A value of \"white\" means an uncolored source,\n\ +in the lamp table file. A value of \"WHITE\" means an uncolored source,\n\ which may be preferable because it results in a color balanced image." }, { "length unit", "meter", unitcheck, "Unit must be one of: \"meter\", \"centimeter\", \"foot\", or \"inch\".\n\ @@ -207,11 +205,11 @@ again: getpolygon() /* get projected area for a polygon */ { - static double area = 1.0; + static double parea = 1.0; - getd("Polygon area", &area, + getd("Polygon area", &parea, "Enter the total radiating area of the polygon."); - area = unit2meter*unit2meter * area; + area = unit2meter*unit2meter * parea; return(1); }
