--- ray/src/cv/lampcolor.c 1991/03/14 13:55:03 1.1 +++ ray/src/cv/lampcolor.c 1991/10/22 09:38:17 1.7 @@ -5,35 +5,246 @@ static char SCCSid[] = "$SunId$ LBL"; #endif /* - * Do dah program to convert lamp color from table. + * Program to convert lamp color from table and compute radiance. */ #include +#define PI 3.14159265358979323846 + +extern char *gets(), *strcpy(); +extern double atof(); extern float *matchlamp(); + /* lamp parameters */ +#define LTYPE 0 +#define LUNIT 1 +#define LGEOM 2 +#define LOUTP 3 +#define NPARAMS 4 +int typecheck(), unitcheck(), geomcheck(), outpcheck(); + +float *lampcolor; /* the lamp color (RGB) */ +double unit2meter; /* conversion from units to meters */ +double area; /* radiating area for this geometry */ +double lumens; /* total lamp lumens */ + +struct { + char *name; + char value[64]; + int (*check)(); + char *help; +} param[NPARAMS] = { + { "lamp type", "white", typecheck, +"The lamp type is a string which corresponds to one of the types registered\n\ +in the lamp table file. A value of \"white\" means an uncolored source,\n\ +which may be preferable because it results in a color balanced image." }, + { "length unit", "meter", unitcheck, +"Unit must be one of: \"meter\", \"centimeter\", \"foot\", or \"inch\".\n\ +These may be abbreviated as a single letter." }, + { "lamp geometry", "polygon", geomcheck, +"The lamp geometry must be one of: \"polygon\", \"sphere\", \"cylinder\"\n\ +or \"ring\". These may be abbreviated as a single letter." }, + { "total lamp lumens", "0", outpcheck, +"This is the overall light output of the lamp and its fixture. If you do\n\ +not know this value explicitly, you can compute the approximate lumens\n\ +by multiplying the input wattage by 14 for incandescent fixtures or 70\n\ +for fluorescent fixtures." }, +}; + + main(argc, argv) int argc; char *argv[]; { char *lamptab = "lamp.tab"; - float *lcol; - char buf[80]; + char buf[64]; + int i; if (argc > 1) lamptab = argv[1]; if (loadlamps(lamptab) == 0) { - perror(lamptab); + fprintf(stderr, "%s: no such lamp table\n", lamptab); exit(1); } + printf("Program to compute lamp radiance. Enter '?' for help.\n"); for ( ; ; ) { - printf("Enter lamp type: "); - buf[0] = '\0'; - gets(buf); - if (!buf[0]) exit(0); - if ((lcol = matchlamp(buf)) == NULL) - printf("No match in table\n"); - else - printf("RGB = (%f,%f,%f)\n", lcol[0], lcol[1], lcol[2]); + i = 0; + while (i < NPARAMS) { + printf("Enter %s [%s]: ", param[i].name, + param[i].value); + if (gets(buf) == NULL) + exit(0); + if (buf[0] == '?') { + puts(param[i].help); + continue; + } + if (buf[0]) + strcpy(param[i].value, buf); + if (!(*param[i].check)(param[i].value)) { + fprintf(stderr, "%s: bad value for %s\n", + param[i].value, param[i].name); + continue; + } + i++; + } + compute(); } +} + + +typecheck(s) /* check lamp type */ +char *s; +{ + lampcolor = matchlamp(s); + return(lampcolor != NULL); +} + + +unitcheck(s) /* compute conversion to meters */ +char *s; +{ + int len = strlen(s); + + switch (*s) { + case 'm': + if (strncmp(s, "meters", len)) + return(0); + unit2meter = 1.0; + return(1); + case 'c': + if (strncmp(s, "centimeters", len) && strncmp(s, "cms", len)) + return(0); + unit2meter = 0.01; + return(1); + case 'f': + if (strncmp(s, "foot", len) && strncmp(s, "feet", len)) + return(0); + unit2meter = 0.3048; + return(1); + case 'i': + if (strncmp(s, "inches", len)) + return(0); + unit2meter = 0.0254; + return(1); + } + return(0); +} + + +geomcheck(s) /* check/set lamp geometry */ +char *s; +{ + int len = strlen(s); + + switch (*s) { + case 'p': + if (strncmp(s, "polygonal", len)) + return(0); + return(getpolygon()); + case 's': + if (strncmp(s, "sphere", len) && strncmp(s, "spherical", len)) + return(0); + return(getsphere()); + case 'c': + if (strncmp(s,"cylinder",len) && strncmp(s,"cylindrical",len)) + return(0); + return(getcylinder()); + case 'r': + if (strncmp(s, "ring", len) && strncmp(s, "disk", len)) + return(0); + return(getring()); + } + return(0); +} + + +outpcheck(s) /* check lumen output value */ +register char *s; +{ + if ((*s < '0' || *s > '9') && *s != '.') + return(0); + lumens = atof(s); + return(1); +} + + +compute() /* compute lamp radiance */ +{ + double whiteval; + + whiteval = lumens/470./PI/area; + + printf("Lamp color (RGB) = %f %f %f\n", + lampcolor[0]*whiteval, + lampcolor[1]*whiteval, + lampcolor[2]*whiteval); +} + + +getd(name, dp, help) /* get a positive double from stdin */ +char *name; +double *dp; +char *help; +{ + char buf[32]; +again: + printf("%s [%g]: ", name, *dp); + if (gets(buf) == NULL) + return(0); + if (buf[0] == '?') { + puts(help); + goto again; + } + if ((buf[0] < '0' || buf[0] > '9') && buf[0] != '.') + return(0); + *dp = atof(buf); + return(1); +} + + +getpolygon() /* get projected area for a polygon */ +{ + static double area = 1.0; + + getd("Polygon area", &area, + "Enter the total radiating area of the polygon."); + area = unit2meter*unit2meter * area; + return(1); +} + + +getsphere() /* get projected area for a sphere */ +{ + static double radius = 1.0; + + getd("Sphere radius", &radius, + "Enter the distance from the sphere's center to its surface."); + area = 4.*PI*unit2meter*unit2meter * radius*radius; + return(1); +} + + +getcylinder() /* get projected area for a cylinder */ +{ + static double length = 1.0, radius = 0.1; + + getd("Cylinder length", &length, + "Enter the length of the cylinder."); + getd("Cylinder radius", &radius, + "Enter the distance from the cylinder's axis to its surface."); + area = 2.*PI*unit2meter*unit2meter * radius*length; + return(1); +} + + +getring() /* get projected area for a ring */ +{ + static double radius = 1.0; + + getd("Disk radius", &radius, +"Enter the distance from the ring's center to its outer edge.\n\ +The inner radius must be zero."); + area = PI*unit2meter*unit2meter * radius*radius; + return(1); }
