root/radiance/ray/src/cv/lampcolor.c
Thu Mar 18 05:22:00 2004 UTC (20 years, 2 months ago) by greg
Fixed bug caused by substituting fgets() for gets() -- now calls fgetline()
Sat Nov 15 17:54:06 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 2.8: +21 -15 lines
Sat Jun 21 15:05:01 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.7: +1 -3 lines
Fixed some conflicting definitions
Sun Jun 8 12:03:09 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.6: +36 -19 lines
Changes since 2.5: +1 -4 lines
Tue Jul 5 15:49:51 1994 UTC (29 years, 11 months ago) by saba
added WHITE to replace D65WHITE for previous color conversion
Fri Jun 4 14:32:44 1993 UTC (31 years ago) by greg
Changes since 2.3: +2 -3 lines
Removed unnecessary declaration of atof()
Fri Jan 10 11:17:13 1992 UTC (32 years, 4 months ago) by greg
change white to D65WHITE to match lamp.tab
Thu Dec 19 15:06:15 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 2.1
Tue Nov 12 17:02:10 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.9
Mon Oct 28 08:04:23 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.8
Thu Oct 24 12:17:38 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.7: +3 -1 lines
Diff to previous 1.7
fixed conversion between lumens and watts
Tue Oct 22 09:38:17 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.6: +6 -6 lines
Diff to previous 1.6
fixed area calculations
Thu Sep 12 13:36:43 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.5: +20 -12 lines
Diff to previous 1.5
added help to geometry entries
Thu Sep 12 13:26:16 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.4: +19 -27 lines
Diff to previous 1.4
added defaults to geometries
Thu Sep 5 15:36:34 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.3: +5 -5 lines
Diff to previous 1.3
changed prompting for geometries
Thu Sep 5 15:28:46 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.2
fixed comment on luminous efficacy
Thu Sep 5 15:09:08 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.1: +223 -12 lines
Diff to previous 1.1
changed program to calculate lamp radiance for diffuse sources
Thu Mar 14 13:55:03 1991 UTC (33 years, 2 months ago) by greg
