--- ray/src/cv/lampcolor.c 1991/09/12 13:36:43 1.6 +++ ray/src/cv/lampcolor.c 1991/10/28 08:04:23 1.9 @@ -10,6 +10,8 @@ static char SCCSid[] = "$SunId$ LBL"; #include +#include "color.h" + #define PI 3.14159265358979323846 extern char *gets(), *strcpy(); @@ -27,7 +29,7 @@ int typecheck(), unitcheck(), geomcheck(), outpcheck() float *lampcolor; /* the lamp color (RGB) */ double unit2meter; /* conversion from units to meters */ -double projarea; /* projected area for this geometry */ +double area; /* radiating area for this geometry */ double lumens; /* total lamp lumens */ struct { @@ -173,7 +175,7 @@ compute() /* compute lamp radiance */ { double whiteval; - whiteval = lumens/470./projarea; + whiteval = lumens/area/(WHTEFFICACY*PI); printf("Lamp color (RGB) = %f %f %f\n", lampcolor[0]*whiteval, @@ -205,11 +207,11 @@ again: getpolygon() /* get projected area for a polygon */ { - static double area = 1.0; + static double parea = 1.0; - getd("Polygon area", &area, + getd("Polygon area", &parea, "Enter the total radiating area of the polygon."); - projarea = PI*unit2meter*unit2meter * area; + area = unit2meter*unit2meter * parea; return(1); } @@ -220,7 +222,7 @@ getsphere() /* get projected area for a sphere */ getd("Sphere radius", &radius, "Enter the distance from the sphere's center to its surface."); - projarea = 4.*PI*PI*unit2meter*unit2meter * radius*radius; + area = 4.*PI*unit2meter*unit2meter * radius*radius; return(1); } @@ -233,7 +235,7 @@ getcylinder() /* get projected area for a cylinder * "Enter the length of the cylinder."); getd("Cylinder radius", &radius, "Enter the distance from the cylinder's axis to its surface."); - projarea = PI*PI*2.*PI*unit2meter*unit2meter * radius*length; + area = 2.*PI*unit2meter*unit2meter * radius*length; return(1); } @@ -245,6 +247,6 @@ getring() /* get projected area for a ring */ getd("Disk radius", &radius, "Enter the distance from the ring's center to its outer edge.\n\ The inner radius must be zero."); - projarea = PI*PI*unit2meter*unit2meter * radius*radius; + area = PI*unit2meter*unit2meter * radius*radius; return(1); }
