root/radiance/ray/src/cv/iso2klems.pl
Revision: 2.6
Committed: Thu Oct 6 14:22:44 2022 UTC (2 years, 10 months ago) by greg
CVS Tags: rad6R0, rad5R4, HEAD
fix(iso2klems): fix to my last bug fix for Windows
# User Rev Content
1 greg 2.1 #!/usr/bin/perl -w
2 greg 2.6 # RCSid $Id: iso2klems.pl,v 2.5 2022/10/04 14:08:17 greg Exp $
3 greg 2.1 #
4     # Convert tabulated isotropic direct-hemispherical and direct-direct to Klems XML
5     #
6     # G. Ward
7     #
8     use strict;
9     my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
10     use File::Temp qw/ :mktemp /;
11     sub userror {
12 greg 2.2 print STDERR "Usage: iso2klems [-t][-f \"x=string;y=string\"][-u unit] [input.dat]\n";
13 greg 2.1 exit 1;
14     }
15     my ($td,$rmtmp,$cmd);
16     if ($windoz) {
17     my $tmploc = `echo \%TMP\%`;
18     chomp $tmploc;
19     $td = mkdtemp("$tmploc\\iso2klems.XXXXXX");
20     $rmtmp = "rd /S /Q $td";
21     } else {
22     $td = mkdtemp("/tmp/iso2klems.XXXXXX");
23     chomp $td;
24     $rmtmp = "rm -rf $td";
25     }
26     my $wrapper = 'wrapBSDF -W -a kf -C "Generated by iso2klems"';
27     my $reverse = 0;
28     # Get options
29     while ($#ARGV >= 0) {
30     if ("$ARGV[0]" eq "-t") {
31     $reverse = ! $reverse;
32 greg 2.2 } elsif ("$ARGV[0]" =~ /^-[fs]$/) {
33 greg 2.1 $wrapper .= " -f \"$ARGV[1]\"";
34     shift @ARGV;
35 greg 2.2 } elsif ("$ARGV[0]" eq "-u") {
36     $wrapper .= " -u $ARGV[1]";
37     shift @ARGV;
38 greg 2.1 } elsif ("$ARGV[0]" =~ /^-./) {
39     userror();
40     } else {
41     last;
42     }
43     shift @ARGV;
44     }
45 greg 2.6 userror() if ($#ARGV > 0);
46 greg 2.1 my $funcfile = "$td/isofuncs.cal";
47     my @vnm = ("Tspec","Tdiff","Rspec","Rdiff");
48 greg 2.5 if ($#ARGV == 0) {
49     system "tabfunc -i @vnm < \"$ARGV[0]\" > $funcfile";
50     } else {
51     system "tabfunc -i @vnm > $funcfile";
52     }
53 greg 2.1 die "Invalid input data, requires 5 columns\n" if ( $? );
54     open (MYFH, ">> $funcfile");
55     print MYFH "DEG : PI/180;\n";
56 greg 2.4 print MYFH "sq(x) : x*x;\n";
57 greg 2.1 print MYFH "eq(a,b) : min(a-b+1e-5,b-a+1e-5);\n";
58     print MYFH "rtheta(i) : select(i,5,15,25,35,45,55,65,75,90);\n";
59     print MYFH "nphis(i) : select(i,1,8,16,20,24,24,24,16,12);\n";
60     print MYFH "tdeg1(tb) : if(tb-1.5, (rtheta(tb)+rtheta(tb-1))/2, 0);\n";
61 greg 2.4 print MYFH "omega1(tb) : PI*if(tb-1.5, (sq(cos(rtheta(tb-1)*DEG))-sq(cos(rtheta(tb)*DEG)))/nphis(tb),";
62     print MYFH "\t(1 - sq(cos(rtheta(1)*DEG))));\n";
63 greg 2.1 print MYFH "tbin(b,cnt) : if(nphis(b)-cnt-.5, b, tbin(b+1,cnt-nphis(b)));\n";
64     print MYFH "tdeg(b) : tdeg1(tbin(1,b-1));\n";
65     print MYFH "omega(b) : omega1(tbin(1,b-1));\n";
66     close MYFH;
67     # Compute front and back diffuse hemispherical integrals
68     my $hsamps = 26;
69     my $nsamps = $hsamps * 2;
70     if ($windoz) {
71     $cmd = qq{cnt $nsamps } .
72     qq{| rcalc -f $funcfile -w -e "tdeg=180/$nsamps*(\$1+.5);abs(x):if(x,x,-x)" } .
73 greg 2.4 qq{-e "theta=tdeg*DEG;ifact=PI*PI*abs(cos(theta))*sin(theta)" } .
74 greg 2.1 q{-e "$1=ifact*Tdiff(tdeg);$2=ifact*Rdiff(tdeg)" } .
75     qq{| total -$hsamps -m};
76     } else {
77     $cmd = qq{cnt $nsamps } .
78     qq{| rcalc -f $funcfile -w -e 'tdeg=180/$nsamps*(\$1+.5);abs(x):if(x,x,-x)' } .
79 greg 2.4 qq{-e 'theta=tdeg*DEG;ifact=PI*PI*abs(cos(theta))*sin(theta)' } .
80 greg 2.1 q{-e '$1=ifact*Tdiff(tdeg);$2=ifact*Rdiff(tdeg)' -od } .
81     qq{| total -id2 -$hsamps -m};
82     }
83     # Returns side 1 Th-h, side 1 Rh-h, side 2 Th-h, side 2 Rh-h
84     my @h2h = split /\s+/, `$cmd`;
85     die "Error running rcalc" if ( $? || $#h2h != 3 );
86     # Compute Klems matrices
87     my $TK1dataf = "$td/trans1m.txt";
88     my $RK1dataf = "$td/refl1m.txt";
89     my $TK2dataf = "$td/trans2m.txt";
90     my $RK2dataf = "$td/refl2m.txt";
91     if ($windoz) {
92     $cmd = qq{cnt 145 145 } .
93     qq{| rcalc -f $funcfile } .
94     q{-e "diag=eq($1,$2);tideg=tdeg($1+1);tsdeg=tdeg($2+1);om=omega($1+1);corr=PI/(PI-om)" } .
95     qq{-e "Td1=if($h2h[0]-.001,Tdiff(tideg)*Tdiff(tsdeg)/$h2h[0],0)" } .
96     qq{-e "Rd1=if($h2h[1]-.001,Rdiff(tideg)*Rdiff(tsdeg)/$h2h[1],0)" } .
97     qq{-e "Td2=if($h2h[2]-.001,Tdiff(180-tideg)*Tdiff(180-tsdeg)/$h2h[2],0)" } .
98     qq{-e "Rd2=if($h2h[3]-.001,Rdiff(180-tideg)*Rdiff(180-tsdeg)/$h2h[3],0)" } .
99 greg 2.3 q{-e "$1=if(Tspec(0),if(diag,Tspec(tideg)/om,Td1*corr),Td1)" } .
100     q{-e "$2=if(Rspec(0),if(diag,Rspec(tideg)/om,Rd1*corr),Rd1)" } .
101     q{-e "$3=if(Tspec(180),if(diag,Tspec(180-tideg)/om,Td2*corr),Td2)" } .
102     q{-e "$4=if(Rspec(180),if(diag,Rspec(180-tideg)/om,Rd2*corr),Rd2)" };
103 greg 2.1 } else {
104     $cmd = qq{cnt 145 145 } .
105     qq{| rcalc -f $funcfile } .
106     q{-e 'diag=eq($1,$2);tideg=tdeg($1+1);tsdeg=tdeg($2+1);om=omega($1+1);corr=PI/(PI-om)' } .
107     qq{-e 'Td1=if($h2h[0]-.001,Tdiff(tideg)*Tdiff(tsdeg)/$h2h[0],0)' } .
108     qq{-e 'Rd1=if($h2h[1]-.001,Rdiff(tideg)*Rdiff(tsdeg)/$h2h[1],0)' } .
109     qq{-e 'Td2=if($h2h[2]-.001,Tdiff(180-tideg)*Tdiff(180-tsdeg)/$h2h[2],0)' } .
110     qq{-e 'Rd2=if($h2h[3]-.001,Rdiff(180-tideg)*Rdiff(180-tsdeg)/$h2h[3],0)' } .
111 greg 2.3 q{-e '$1=if(Tspec(0),if(diag,Tspec(tideg)/om,Td1*corr),Td1)' } .
112     q{-e '$2=if(Rspec(0),if(diag,Rspec(tideg)/om,Rd1*corr),Rd1)' } .
113     q{-e '$3=if(Tspec(180),if(diag,Tspec(180-tideg)/om,Td2*corr),Td2)' } .
114     q{-e '$4=if(Rspec(180),if(diag,Rspec(180-tideg)/om,Rd2*corr),Rd2)' };
115 greg 2.1 }
116     system qq{$cmd | rsplit "-t " $TK1dataf $RK1dataf $TK2dataf $RK2dataf};
117     die "Error running rcalc or rsplit" if ( $? );
118     if ($reverse) {
119     $wrapper .= " -tf $TK2dataf -rf $RK2dataf -tb $TK1dataf -rb $RK1dataf";
120     } else {
121     $wrapper .= " -tf $TK1dataf -rf $RK1dataf -tb $TK2dataf -rb $RK2dataf";
122     }
123     system $wrapper;
124     die "Error running: $wrapper\n" if ( $? );
125     exec $rmtmp;
