root/radiance/ray/src/cv/iso2klems.pl
Revision: 2.3
Committed: Thu Mar 10 17:26:04 2022 UTC (2 years, 2 months ago) by greg
Changes since 2.2: +9 -9 lines
style(iso2klems): Improvements to quoting for Windows and Unix
1 #!/usr/bin/perl -w
2 # RCSid $Id: iso2klems.pl,v 2.2 2022/03/08 19:50:06 greg Exp $
3 #
4 # Convert tabulated isotropic direct-hemispherical and direct-direct to Klems XML
5 #
6 # G. Ward
7 #
8 use strict;
9 my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
10 use File::Temp qw/ :mktemp /;
11 sub userror {
12 print STDERR "Usage: iso2klems [-t][-f \"x=string;y=string\"][-u unit] [input.dat]\n";
13 exit 1;
14 }
15 my ($td,$rmtmp,$cmd);
16 if ($windoz) {
17 my $tmploc = `echo \%TMP\%`;
18 chomp $tmploc;
19 $td = mkdtemp("$tmploc\\iso2klems.XXXXXX");
20 $rmtmp = "rd /S /Q $td";
21 } else {
22 $td = mkdtemp("/tmp/iso2klems.XXXXXX");
23 chomp $td;
24 $rmtmp = "rm -rf $td";
25 }
26 my $wrapper = 'wrapBSDF -W -a kf -C "Generated by iso2klems"';
27 my $reverse = 0;
28 # Get options
29 while ($#ARGV >= 0) {
30 if ("$ARGV[0]" eq "-t") {
31 $reverse = ! $reverse;
32 } elsif ("$ARGV[0]" =~ /^-[fs]$/) {
33 $wrapper .= " -f \"$ARGV[1]\"";
34 shift @ARGV;
35 } elsif ("$ARGV[0]" eq "-u") {
36 $wrapper .= " -u $ARGV[1]";
37 shift @ARGV;
38 } elsif ("$ARGV[0]" =~ /^-./) {
39 userror();
40 } else {
41 last;
42 }
43 shift @ARGV;
44 }
45 my $funcfile = "$td/isofuncs.cal";
46 my @vnm = ("Tspec","Tdiff","Rspec","Rdiff");
47 system "cat @ARGV | tabfunc -i @vnm > $funcfile";
48 die "Invalid input data, requires 5 columns\n" if ( $? );
49 open (MYFH, ">> $funcfile");
50 print MYFH "DEG : PI/180;\n";
51 print MYFH "and(a,b) : if(a,b,a);\n";
52 print MYFH "eq(a,b) : min(a-b+1e-5,b-a+1e-5);\n";
53 print MYFH "rtheta(i) : select(i,5,15,25,35,45,55,65,75,90);\n";
54 print MYFH "nphis(i) : select(i,1,8,16,20,24,24,24,16,12);\n";
55 print MYFH "tdeg1(tb) : if(tb-1.5, (rtheta(tb)+rtheta(tb-1))/2, 0);\n";
56 print MYFH "omega1(tb) : 2*PI*if(tb-1.5, (cos(rtheta(tb-1)*DEG)-cos(rtheta(tb)*DEG))/nphis(tb),";
57 print MYFH "\t(1 - cos(rtheta(1)*DEG)));\n";
58 print MYFH "tbin(b,cnt) : if(nphis(b)-cnt-.5, b, tbin(b+1,cnt-nphis(b)));\n";
59 print MYFH "tdeg(b) : tdeg1(tbin(1,b-1));\n";
60 print MYFH "omega(b) : omega1(tbin(1,b-1));\n";
61 close MYFH;
62 # Compute front and back diffuse hemispherical integrals
63 my $hsamps = 26;
64 my $nsamps = $hsamps * 2;
65 if ($windoz) {
66 $cmd = qq{cnt $nsamps } .
67 qq{| rcalc -f $funcfile -w -e "tdeg=180/$nsamps*(\$1+.5);abs(x):if(x,x,-x)" } .
68 qq{-e "theta=tdeg*DEG;ifact=2*PI*abs(cos(theta))*sin(theta)" } .
69 q{-e "$1=ifact*Tdiff(tdeg);$2=ifact*Rdiff(tdeg)" } .
70 qq{| total -$hsamps -m};
71 } else {
72 $cmd = qq{cnt $nsamps } .
73 qq{| rcalc -f $funcfile -w -e 'tdeg=180/$nsamps*(\$1+.5);abs(x):if(x,x,-x)' } .
74 qq{-e 'theta=tdeg*DEG;ifact=2*PI*abs(cos(theta))*sin(theta)' } .
75 q{-e '$1=ifact*Tdiff(tdeg);$2=ifact*Rdiff(tdeg)' -od } .
76 qq{| total -id2 -$hsamps -m};
77 }
78 # Returns side 1 Th-h, side 1 Rh-h, side 2 Th-h, side 2 Rh-h
79 my @h2h = split /\s+/, `$cmd`;
80 die "Error running rcalc" if ( $? || $#h2h != 3 );
81 # Compute Klems matrices
82 my $TK1dataf = "$td/trans1m.txt";
83 my $RK1dataf = "$td/refl1m.txt";
84 my $TK2dataf = "$td/trans2m.txt";
85 my $RK2dataf = "$td/refl2m.txt";
86 if ($windoz) {
87 $cmd = qq{cnt 145 145 } .
88 qq{| rcalc -f $funcfile } .
89 q{-e "diag=eq($1,$2);tideg=tdeg($1+1);tsdeg=tdeg($2+1);om=omega($1+1);corr=PI/(PI-om)" } .
90 qq{-e "Td1=if($h2h[0]-.001,Tdiff(tideg)*Tdiff(tsdeg)/$h2h[0],0)" } .
91 qq{-e "Rd1=if($h2h[1]-.001,Rdiff(tideg)*Rdiff(tsdeg)/$h2h[1],0)" } .
92 qq{-e "Td2=if($h2h[2]-.001,Tdiff(180-tideg)*Tdiff(180-tsdeg)/$h2h[2],0)" } .
93 qq{-e "Rd2=if($h2h[3]-.001,Rdiff(180-tideg)*Rdiff(180-tsdeg)/$h2h[3],0)" } .
94 q{-e "$1=if(Tspec(0),if(diag,Tspec(tideg)/om,Td1*corr),Td1)" } .
95 q{-e "$2=if(Rspec(0),if(diag,Rspec(tideg)/om,Rd1*corr),Rd1)" } .
96 q{-e "$3=if(Tspec(180),if(diag,Tspec(180-tideg)/om,Td2*corr),Td2)" } .
97 q{-e "$4=if(Rspec(180),if(diag,Rspec(180-tideg)/om,Rd2*corr),Rd2)" };
98 } else {
99 $cmd = qq{cnt 145 145 } .
100 qq{| rcalc -f $funcfile } .
101 q{-e 'diag=eq($1,$2);tideg=tdeg($1+1);tsdeg=tdeg($2+1);om=omega($1+1);corr=PI/(PI-om)' } .
102 qq{-e 'Td1=if($h2h[0]-.001,Tdiff(tideg)*Tdiff(tsdeg)/$h2h[0],0)' } .
103 qq{-e 'Rd1=if($h2h[1]-.001,Rdiff(tideg)*Rdiff(tsdeg)/$h2h[1],0)' } .
104 qq{-e 'Td2=if($h2h[2]-.001,Tdiff(180-tideg)*Tdiff(180-tsdeg)/$h2h[2],0)' } .
105 qq{-e 'Rd2=if($h2h[3]-.001,Rdiff(180-tideg)*Rdiff(180-tsdeg)/$h2h[3],0)' } .
106 q{-e '$1=if(Tspec(0),if(diag,Tspec(tideg)/om,Td1*corr),Td1)' } .
107 q{-e '$2=if(Rspec(0),if(diag,Rspec(tideg)/om,Rd1*corr),Rd1)' } .
108 q{-e '$3=if(Tspec(180),if(diag,Tspec(180-tideg)/om,Td2*corr),Td2)' } .
109 q{-e '$4=if(Rspec(180),if(diag,Rspec(180-tideg)/om,Rd2*corr),Rd2)' };
110 }
111 system qq{$cmd | rsplit "-t " $TK1dataf $RK1dataf $TK2dataf $RK2dataf};
112 die "Error running rcalc or rsplit" if ( $? );
113 if ($reverse) {
114 $wrapper .= " -tf $TK2dataf -rf $RK2dataf -tb $TK1dataf -rb $RK1dataf";
115 } else {
116 $wrapper .= " -tf $TK1dataf -rf $RK1dataf -tb $TK2dataf -rb $RK2dataf";
117 }
118 system $wrapper;
119 die "Error running: $wrapper\n" if ( $? );
120 exec $rmtmp;
