| 1 |
/* Copyright (c) 1992 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Convert IES luminaire data to Radiance description
| 9 |
| 10 |
* 07Apr90 Greg Ward
| 11 |
| 12 |
| 13 |
#include <stdio.h>
| 14 |
#include <ctype.h>
| 15 |
#include "color.h"
| 16 |
#include "paths.h"
| 17 |
| 18 |
#define PI 3.14159265358979323846
| 19 |
/* floating comparisons */
| 20 |
#define FTINY 1e-6
| 21 |
#define FEQ(a,b) ((a)<=(b)+FTINY&&(a)>=(b)-FTINY)
| 22 |
/* tilt specs */
| 23 |
#define TLTSTR "TILT="
| 24 |
#define TLTSTRLEN 5
| 25 |
#define TLTNONE "NONE"
| 26 |
#define TLTINCL "INCLUDE"
| 27 |
#define TLT_VERT 1
| 28 |
#define TLT_H0 2
| 29 |
#define TLT_H90 3
| 30 |
/* photometric types */
| 31 |
#define PM_C 1
| 32 |
#define PM_B 2
| 33 |
/* unit types */
| 34 |
#define U_FEET 1
| 35 |
#define U_METERS 2
| 36 |
/* string lengths */
| 37 |
#define MAXLINE 132
| 38 |
#define MAXWORD 76
| 39 |
/* file types */
| 40 |
#define T_RAD ".rad"
| 41 |
#define T_DST ".dat"
| 42 |
#define T_TLT "+.dat"
| 43 |
/* shape types */
| 44 |
#define RECT 1
| 45 |
#define DISK 2
| 46 |
#define SPHERE 3
| 47 |
| 48 |
#define MINDIM .001 /* minimum dimension (point source) */
| 49 |
| 50 |
#define F_M .3048 /* feet to meters */
| 51 |
| 52 |
#define abspath(p) (ISDIRSEP((p)[0]) || (p)[0] == '.')
| 53 |
| 54 |
static char default_name[] = "default";
| 55 |
| 56 |
char *libdir = NULL; /* library directory location */
| 57 |
char *prefdir = NULL; /* subdirectory */
| 58 |
char *lampdat = "lamp.tab"; /* lamp data file */
| 59 |
| 60 |
double meters2out = 1.0; /* conversion from meters to output */
| 61 |
char *lamptype = NULL; /* selected lamp type */
| 62 |
char *deflamp = NULL; /* default lamp type */
| 63 |
float defcolor[3] = {1.,1.,1.}; /* default lamp color */
| 64 |
float *lampcolor = defcolor; /* pointer to current lamp color */
| 65 |
double multiplier = 1.0; /* multiplier for all light sources */
| 66 |
char units[64] = "meters"; /* output units */
| 67 |
double illumrad = 0.0; /* radius for illum sphere */
| 68 |
| 69 |
typedef struct {
| 70 |
int type; /* RECT, DISK, SPHERE */
| 71 |
double w, l, h; /* width, length, height */
| 72 |
double area; /* max. projected area */
| 73 |
} SHAPE; /* a source shape */
| 74 |
| 75 |
int gargc; /* global argc (minus filenames) */
| 76 |
char **gargv; /* global argv */
| 77 |
| 78 |
extern char *strcpy(), *strcat(), *stradd(), *tailtrunc(), *filetrunc(),
| 79 |
*filename(), *libname(), *fullname(), *malloc();
| 80 |
extern float *matchlamp();
| 81 |
| 82 |
| 83 |
main(argc, argv)
| 84 |
int argc;
| 85 |
char *argv[];
| 86 |
| 87 |
char *outfile = NULL;
| 88 |
int status;
| 89 |
char outname[MAXWORD];
| 90 |
double d1;
| 91 |
int i;
| 92 |
| 93 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 94 |
switch (argv[i][1]) {
| 95 |
case 'd': /* dimensions */
| 96 |
if (argv[i][2] == '\0')
| 97 |
goto badopt;
| 98 |
if (argv[i][3] == '\0')
| 99 |
d1 = 1.0;
| 100 |
else if (argv[i][3] == '/') {
| 101 |
d1 = atof(argv[i]+4);
| 102 |
if (d1 <= FTINY)
| 103 |
goto badopt;
| 104 |
} else
| 105 |
goto badopt;
| 106 |
switch (argv[i][2]) {
| 107 |
case 'c': /* centimeters */
| 108 |
if (FEQ(d1,10.))
| 109 |
strcpy(units,"millimeters");
| 110 |
else {
| 111 |
strcpy(units,"centimeters");
| 112 |
strcat(units,argv[i]+3);
| 113 |
| 114 |
meters2out = 100.*d1;
| 115 |
break;
| 116 |
case 'm': /* meters */
| 117 |
if (FEQ(d1,1000.))
| 118 |
| 119 |
else if (FEQ(d1,100.))
| 120 |
| 121 |
else {
| 122 |
strcpy(units,"meters");
| 123 |
| 124 |
| 125 |
meters2out = d1;
| 126 |
break;
| 127 |
case 'i': /* inches */
| 128 |
strcpy(units,"inches");
| 129 |
| 130 |
meters2out = d1*(12./F_M);
| 131 |
break;
| 132 |
case 'f': /* feet */
| 133 |
if (FEQ(d1,12.))
| 134 |
| 135 |
else {
| 136 |
strcpy(units,"feet");
| 137 |
| 138 |
| 139 |
meters2out = d1/F_M;
| 140 |
break;
| 141 |
default:
| 142 |
goto badopt;
| 143 |
| 144 |
break;
| 145 |
case 'l': /* library directory */
| 146 |
libdir = argv[++i];
| 147 |
break;
| 148 |
case 'p': /* prefix subdirectory */
| 149 |
prefdir = argv[++i];
| 150 |
break;
| 151 |
case 'f': /* lamp data file */
| 152 |
lampdat = argv[++i];
| 153 |
break;
| 154 |
case 'o': /* output file name */
| 155 |
outfile = argv[++i];
| 156 |
break;
| 157 |
case 'i': /* illum */
| 158 |
illumrad = atof(argv[++i]);
| 159 |
if (illumrad < MINDIM)
| 160 |
illumrad = MINDIM;
| 161 |
break;
| 162 |
case 't': /* override lamp type */
| 163 |
lamptype = argv[++i];
| 164 |
break;
| 165 |
case 'u': /* default lamp type */
| 166 |
deflamp = argv[++i];
| 167 |
break;
| 168 |
case 'c': /* default lamp color */
| 169 |
defcolor[0] = atof(argv[++i]);
| 170 |
defcolor[1] = atof(argv[++i]);
| 171 |
defcolor[2] = atof(argv[++i]);
| 172 |
break;
| 173 |
case 'm': /* multiplier */
| 174 |
multiplier = atof(argv[++i]);
| 175 |
break;
| 176 |
default:
| 177 |
badopt:
| 178 |
fprintf(stderr, "%s: bad option: %s\n",
| 179 |
argv[0], argv[i]);
| 180 |
exit(1);
| 181 |
| 182 |
gargc = i;
| 183 |
gargv = argv;
| 184 |
initlamps(); /* get lamp data (if needed) */
| 185 |
/* convert ies file(s) */
| 186 |
if (outfile != NULL) {
| 187 |
if (i == argc)
| 188 |
exit(ies2rad(NULL, outfile) == 0 ? 0 : 1);
| 189 |
else if (i == argc-1)
| 190 |
exit(ies2rad(argv[i], outfile) == 0 ? 0 : 1);
| 191 |
else {
| 192 |
fprintf(stderr, "%s: single input file required\n",
| 193 |
argv[0]);
| 194 |
exit(1);
| 195 |
| 196 |
} else if (i >= argc) {
| 197 |
fprintf(stderr, "%s: missing output file specification\n",
| 198 |
argv[0]);
| 199 |
exit(1);
| 200 |
| 201 |
status = 0;
| 202 |
for ( ; i < argc; i++) {
| 203 |
tailtrunc(strcpy(outname,filename(argv[i])));
| 204 |
if (ies2rad(argv[i], outname) != 0)
| 205 |
status = 1;
| 206 |
| 207 |
exit(status);
| 208 |
| 209 |
| 210 |
| 211 |
initlamps() /* set up lamps */
| 212 |
| 213 |
float *lcol;
| 214 |
int status;
| 215 |
| 216 |
if (lamptype != NULL && !strcmp(lamptype, default_name) &&
| 217 |
deflamp == NULL)
| 218 |
return; /* no need for data */
| 219 |
/* else load file */
| 220 |
if ((status = loadlamps(lampdat)) < 0)
| 221 |
exit(1);
| 222 |
if (status == 0) {
| 223 |
fprintf(stderr, "%s: warning - no lamp data\n", lampdat);
| 224 |
lamptype = default_name;
| 225 |
return;
| 226 |
| 227 |
if (deflamp != NULL) { /* match default type */
| 228 |
if ((lcol = matchlamp(deflamp)) == NULL)
| 229 |
fprintf(stderr,
| 230 |
"%s: warning - unknown default lamp type\n",
| 231 |
deflamp);
| 232 |
else
| 233 |
copycolor(defcolor, lcol);
| 234 |
| 235 |
if (lamptype != NULL) { /* match selected type */
| 236 |
if (strcmp(lamptype, default_name)) {
| 237 |
if ((lcol = matchlamp(lamptype)) == NULL) {
| 238 |
fprintf(stderr,
| 239 |
"%s: warning - unknown lamp type\n",
| 240 |
lamptype);
| 241 |
| 242 |
} else
| 243 |
| 244 |
| 245 |
freelamps(); /* all done with data */
| 246 |
| 247 |
/* else keep lamp data */
| 248 |
| 249 |
| 250 |
| 251 |
char *
| 252 |
stradd(dst, src, sep) /* add a string at dst */
| 253 |
register char *dst, *src;
| 254 |
int sep;
| 255 |
| 256 |
if (src && *src) {
| 257 |
do
| 258 |
*dst++ = *src++;
| 259 |
while (*src);
| 260 |
if (sep && dst[-1] != sep)
| 261 |
*dst++ = sep;
| 262 |
| 263 |
*dst = '\0';
| 264 |
return(dst);
| 265 |
| 266 |
| 267 |
| 268 |
char *
| 269 |
fullname(path, fname, suffix) /* return full path name */
| 270 |
char *path, *fname, *suffix;
| 271 |
| 272 |
if (prefdir != NULL && abspath(prefdir))
| 273 |
libname(path, fname, suffix);
| 274 |
else if (abspath(fname))
| 275 |
strcpy(stradd(path, fname, 0), suffix);
| 276 |
else
| 277 |
libname(stradd(path, libdir, DIRSEP), fname, suffix);
| 278 |
| 279 |
return(path);
| 280 |
| 281 |
| 282 |
| 283 |
char *
| 284 |
libname(path, fname, suffix) /* return library relative name */
| 285 |
| 286 |
| 287 |
if (abspath(fname))
| 288 |
| 289 |
else
| 290 |
strcpy(stradd(stradd(path, prefdir, DIRSEP), fname, 0), suffix);
| 291 |
| 292 |
return(path);
| 293 |
| 294 |
| 295 |
| 296 |
char *
| 297 |
filename(path) /* get final component of pathname */
| 298 |
register char *path;
| 299 |
| 300 |
register char *cp;
| 301 |
| 302 |
for (cp = path; *path; path++)
| 303 |
if (ISDIRSEP(*path))
| 304 |
cp = path+1;
| 305 |
return(cp);
| 306 |
| 307 |
| 308 |
| 309 |
char *
| 310 |
filetrunc(path) /* truncate filename at end of path */
| 311 |
char *path;
| 312 |
| 313 |
register char *p1, *p2;
| 314 |
| 315 |
for (p1 = p2 = path; *p2; p2++)
| 316 |
if (ISDIRSEP(*p2))
| 317 |
p1 = p2;
| 318 |
*p1 = '\0';
| 319 |
return(path);
| 320 |
| 321 |
| 322 |
| 323 |
char *
| 324 |
tailtrunc(name) /* truncate tail of filename */
| 325 |
char *name;
| 326 |
| 327 |
| 328 |
| 329 |
for (p1 = filename(name); *p1 == '.'; p1++)
| 330 |
| 331 |
p2 = NULL;
| 332 |
for ( ; *p1; p1++)
| 333 |
if (*p1 == '.')
| 334 |
p2 = p1;
| 335 |
if (p2 != NULL)
| 336 |
*p2 = '\0';
| 337 |
return(name);
| 338 |
| 339 |
| 340 |
| 341 |
blanktrunc(s) /* truncate spaces at end of line */
| 342 |
char *s;
| 343 |
| 344 |
register char *cp;
| 345 |
| 346 |
for (cp = s; *cp; cp++)
| 347 |
| 348 |
while (cp-- > s && isspace(*cp))
| 349 |
| 350 |
*++cp = '\0';
| 351 |
| 352 |
| 353 |
| 354 |
putheader(out) /* print header */
| 355 |
FILE *out;
| 356 |
| 357 |
register int i;
| 358 |
| 359 |
putc('#', out);
| 360 |
for (i = 0; i < gargc; i++) {
| 361 |
putc(' ', out);
| 362 |
fputs(gargv[i], out);
| 363 |
| 364 |
fputs("\n# Dimensions in ", out);
| 365 |
fputs(units, out);
| 366 |
putc('\n', out);
| 367 |
| 368 |
| 369 |
| 370 |
ies2rad(inpname, outname) /* convert IES file */
| 371 |
char *inpname, *outname;
| 372 |
| 373 |
char buf[MAXLINE], tltid[MAXWORD];
| 374 |
FILE *inpfp, *outfp;
| 375 |
| 376 |
if (inpname == NULL) {
| 377 |
inpname = "<stdin>";
| 378 |
inpfp = stdin;
| 379 |
} else if ((inpfp = fopen(inpname, "r")) == NULL) {
| 380 |
perror(inpname);
| 381 |
return(-1);
| 382 |
| 383 |
if ((outfp = fopen(fullname(buf,outname,T_RAD), "w")) == NULL) {
| 384 |
perror(buf);
| 385 |
fclose(inpfp);
| 386 |
return(-1);
| 387 |
| 388 |
putheader(outfp);
| 389 |
if (lamptype == NULL)
| 390 |
lampcolor = NULL;
| 391 |
while (fgets(buf,sizeof(buf),inpfp) != NULL
| 392 |
&& strncmp(buf,TLTSTR,TLTSTRLEN)) {
| 393 |
blanktrunc(buf);
| 394 |
if (!buf[0])
| 395 |
continue;
| 396 |
fputs("#<", outfp);
| 397 |
fputs(buf, outfp);
| 398 |
putc('\n', outfp);
| 399 |
if (lampcolor == NULL)
| 400 |
lampcolor = matchlamp(buf);
| 401 |
| 402 |
if (lampcolor == NULL) {
| 403 |
fprintf(stderr, "%s: warning - no lamp type\n", inpname);
| 404 |
| 405 |
| 406 |
if (feof(inpfp)) {
| 407 |
fprintf(stderr, "%s: not in IES format\n", inpname);
| 408 |
goto readerr;
| 409 |
| 410 |
sscanf(buf+TLTSTRLEN, "%s", tltid);
| 411 |
if (inpfp == stdin)
| 412 |
buf[0] = '\0';
| 413 |
else
| 414 |
filetrunc(strcpy(buf, inpname));
| 415 |
if (dotilt(inpfp, outfp, buf, tltid, outname, tltid) != 0) {
| 416 |
fprintf(stderr, "%s: bad tilt data\n", inpname);
| 417 |
goto readerr;
| 418 |
| 419 |
if (dosource(inpfp, outfp, tltid, outname) != 0) {
| 420 |
fprintf(stderr, "%s: bad luminaire data\n", inpname);
| 421 |
goto readerr;
| 422 |
| 423 |
fclose(outfp);
| 424 |
fclose(inpfp);
| 425 |
return(0);
| 426 |
readerr:
| 427 |
fclose(outfp);
| 428 |
fclose(inpfp);
| 429 |
unlink(fullname(buf,outname,T_RAD));
| 430 |
return(-1);
| 431 |
| 432 |
| 433 |
| 434 |
dotilt(in, out, dir, tltspec, dfltname, tltid) /* convert tilt data */
| 435 |
FILE *in, *out;
| 436 |
char *dir, *tltspec, *dfltname, *tltid;
| 437 |
| 438 |
int nangles, tlt_type;
| 439 |
double minmax[2];
| 440 |
char buf[MAXPATH], tltname[MAXWORD];
| 441 |
FILE *datin, *datout;
| 442 |
| 443 |
if (!strcmp(tltspec, TLTNONE)) {
| 444 |
datin = NULL;
| 445 |
strcpy(tltid, "void");
| 446 |
} else if (!strcmp(tltspec, TLTINCL)) {
| 447 |
datin = in;
| 448 |
strcpy(tltname, dfltname);
| 449 |
} else {
| 450 |
if (ISDIRSEP(tltspec[0]))
| 451 |
strcpy(buf, tltspec);
| 452 |
else
| 453 |
strcpy(stradd(buf, dir, DIRSEP), tltspec);
| 454 |
if ((datin = fopen(buf, "r")) == NULL) {
| 455 |
perror(buf);
| 456 |
return(-1);
| 457 |
| 458 |
tailtrunc(strcpy(tltname,filename(tltspec)));
| 459 |
| 460 |
if (datin != NULL) {
| 461 |
if ((datout = fopen(fullname(buf,tltname,T_TLT),"w")) == NULL) {
| 462 |
perror(buf);
| 463 |
if (datin != in)
| 464 |
fclose(datin);
| 465 |
return(-1);
| 466 |
| 467 |
if (fscanf(datin, "%d %d", &tlt_type, &nangles) != 2
| 468 |
|| cvdata(datin,datout,1,&nangles,1.,minmax) != 0) {
| 469 |
fprintf(stderr, "%s: data format error\n", tltspec);
| 470 |
fclose(datout);
| 471 |
if (datin != in)
| 472 |
fclose(datin);
| 473 |
unlink(fullname(buf,tltname,T_TLT));
| 474 |
return(-1);
| 475 |
| 476 |
fclose(datout);
| 477 |
if (datin != in)
| 478 |
fclose(datin);
| 479 |
strcat(strcpy(tltid, filename(tltname)), "_tilt");
| 480 |
fprintf(out, "\nvoid brightdata %s\n", tltid);
| 481 |
libname(buf,tltname,T_TLT);
| 482 |
switch (tlt_type) {
| 483 |
case TLT_VERT: /* vertical */
| 484 |
fprintf(out, "4 noop %s tilt.cal %s\n", buf,
| 485 |
minmax[1]>90.+FTINY ? "tilt_ang" : "tilt_ang2");
| 486 |
break;
| 487 |
case TLT_H0: /* horiz. in 0 deg. plane */
| 488 |
fprintf(out, "6 noop %s tilt.cal %s -rz 90\n", buf,
| 489 |
minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
| 490 |
break;
| 491 |
case TLT_H90:
| 492 |
| 493 |
| 494 |
break;
| 495 |
default:
| 496 |
fprintf(stderr,
| 497 |
"%s: illegal lamp to luminaire geometry (%d)\n",
| 498 |
tltspec, tlt_type);
| 499 |
return(-1);
| 500 |
| 501 |
fprintf(out, "0\n0\n");
| 502 |
| 503 |
return(0);
| 504 |
| 505 |
| 506 |
| 507 |
dosource(in, out, mod, name) /* create source and distribution */
| 508 |
FILE *in, *out;
| 509 |
char *mod, *name;
| 510 |
| 511 |
SHAPE srcshape;
| 512 |
char buf[MAXPATH], id[MAXWORD];
| 513 |
FILE *datout;
| 514 |
double mult, bfactor, pfactor, width, length, height, wattage;
| 515 |
double bounds[2][2];
| 516 |
int nangles[2], pmtype, unitype;
| 517 |
double d1;
| 518 |
| 519 |
if (fscanf(in, "%*d %*f %lf %d %d %d %d %lf %lf %lf %lf %lf %lf",
| 520 |
&mult, &nangles[0], &nangles[1], &pmtype, &unitype,
| 521 |
&width, &length, &height, &bfactor, &pfactor,
| 522 |
&wattage) != 11) {
| 523 |
fprintf(stderr, "dosource: bad lamp specification\n");
| 524 |
return(-1);
| 525 |
| 526 |
if (nangles[0] < 2 || nangles[1] < 1) {
| 527 |
fprintf(stderr, "dosource: too few measured angles\n");
| 528 |
return(-1);
| 529 |
| 530 |
if (unitype == U_FEET) {
| 531 |
width *= F_M;
| 532 |
length *= F_M;
| 533 |
height *= F_M;
| 534 |
| 535 |
if (makeshape(&srcshape, width, length, height) != 0) {
| 536 |
fprintf(stderr, "dosource: illegal source dimensions");
| 537 |
return(-1);
| 538 |
| 539 |
if ((datout = fopen(fullname(buf,name,T_DST), "w")) == NULL) {
| 540 |
perror(buf);
| 541 |
return(-1);
| 542 |
| 543 |
if (cvdata(in, datout, 2, nangles, 1./WHTEFFICACY, bounds) != 0) {
| 544 |
fprintf(stderr, "dosource: bad distribution data\n");
| 545 |
fclose(datout);
| 546 |
unlink(fullname(buf,name,T_DST));
| 547 |
return(-1);
| 548 |
| 549 |
fclose(datout);
| 550 |
fprintf(out, "# %g watt luminaire, lamp*ballast factor = %g\n",
| 551 |
wattage, bfactor*pfactor);
| 552 |
strcat(strcpy(id, filename(name)), "_dist");
| 553 |
fprintf(out, "\n%s brightdata %s\n", mod, id);
| 554 |
if (nangles[1] < 2)
| 555 |
fprintf(out, "4 ");
| 556 |
else if (pmtype == PM_B)
| 557 |
fprintf(out, "5 ");
| 558 |
else if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
| 559 |
fprintf(out, "8 ");
| 560 |
else
| 561 |
fprintf(out, "6 ");
| 562 |
fprintf(out, "%s %s source.cal ",
| 563 |
srcshape.type==SPHERE ? "corr" : "flatcorr",
| 564 |
libname(buf,name,T_DST));
| 565 |
if (pmtype == PM_B) {
| 566 |
if (FEQ(bounds[1][0],0.))
| 567 |
fprintf(out, "srcB_horiz2 ");
| 568 |
else
| 569 |
fprintf(out, "srcB_horiz ");
| 570 |
fprintf(out, "srcB_vert ");
| 571 |
} else {
| 572 |
if (nangles[1] >= 2) {
| 573 |
d1 = bounds[1][1] - bounds[1][0];
| 574 |
if (d1 <= 90.+FTINY)
| 575 |
fprintf(out, "src_phi4 ");
| 576 |
else if (d1 <= 180.+FTINY)
| 577 |
fprintf(out, "src_phi2 ");
| 578 |
else
| 579 |
fprintf(out, "src_phi ");
| 580 |
fprintf(out, "src_theta -my ");
| 581 |
| 582 |
fprintf(out, "-rz -90 ");
| 583 |
} else
| 584 |
fprintf(out, "src_theta ");
| 585 |
| 586 |
fprintf(out, "\n0\n1 %g\n", multiplier*mult*bfactor*pfactor);
| 587 |
if (putsource(&srcshape, out, id, filename(name),
| 588 |
bounds[0][0]<90., bounds[0][1]>90.) != 0)
| 589 |
return(-1);
| 590 |
return(0);
| 591 |
| 592 |
| 593 |
| 594 |
putsource(shp, fp, mod, name, dolower, doupper) /* put out source */
| 595 |
SHAPE *shp;
| 596 |
FILE *fp;
| 597 |
char *mod, *name;
| 598 |
int dolower, doupper;
| 599 |
| 600 |
char buf[MAXWORD];
| 601 |
| 602 |
fprintf(fp, "\n%s %s %s_light\n", mod,
| 603 |
illumrad>=MINDIM/2. ? "illum" : "light",
| 604 |
name);
| 605 |
fprintf(fp, "0\n0\n3 %g %g %g\n",
| 606 |
lampcolor[0]/shp->area,
| 607 |
lampcolor[1]/shp->area,
| 608 |
lampcolor[2]/shp->area);
| 609 |
if (doupper && dolower && shp->type != SPHERE && shp->h > MINDIM) {
| 610 |
fprintf(fp, "\n%s glow %s_glow\n", mod, name);
| 611 |
fprintf(fp, "0\n0\n4 %g %g %g 0\n",
| 612 |
| 613 |
| 614 |
| 615 |
| 616 |
switch (shp->type) {
| 617 |
case RECT:
| 618 |
strcat(strcpy(buf, name), "_light");
| 619 |
if (dolower)
| 620 |
putrectsrc(shp, fp, buf, name, 0);
| 621 |
if (doupper)
| 622 |
putrectsrc(shp, fp, buf, name, 1);
| 623 |
if (doupper && dolower && shp->h > MINDIM) {
| 624 |
strcat(strcpy(buf, name), "_glow");
| 625 |
putsides(shp, fp, buf, name);
| 626 |
| 627 |
break;
| 628 |
case DISK:
| 629 |
| 630 |
if (dolower)
| 631 |
putdisksrc(shp, fp, buf, name, 0);
| 632 |
if (doupper)
| 633 |
putdisksrc(shp, fp, buf, name, 1);
| 634 |
| 635 |
| 636 |
putcyl(shp, fp, buf, name);
| 637 |
| 638 |
break;
| 639 |
case SPHERE:
| 640 |
| 641 |
putspheresrc(shp, fp, buf, name);
| 642 |
break;
| 643 |
| 644 |
return(0);
| 645 |
| 646 |
| 647 |
| 648 |
makeshape(shp, width, length, height) /* make source shape */
| 649 |
register SHAPE *shp;
| 650 |
double width, length, height;
| 651 |
| 652 |
if (illumrad >= MINDIM/2.) {
| 653 |
shp->type = SPHERE;
| 654 |
shp->w = shp->l = shp->h = 2.*illumrad;
| 655 |
} else if (width < MINDIM) {
| 656 |
width = -width;
| 657 |
| 658 |
shp->type = SPHERE;
| 659 |
shp->w = shp->l = shp->h = MINDIM;
| 660 |
} else if (height < .5*width) {
| 661 |
shp->type = DISK;
| 662 |
shp->w = shp->l = width;
| 663 |
if (height >= MINDIM)
| 664 |
shp->h = height;
| 665 |
else
| 666 |
shp->h = .5*MINDIM;
| 667 |
} else {
| 668 |
shp->type = SPHERE;
| 669 |
shp->w = shp->l = shp->h = width;
| 670 |
| 671 |
} else {
| 672 |
shp->type = RECT;
| 673 |
shp->w = width;
| 674 |
if (length >= MINDIM)
| 675 |
shp->l = length;
| 676 |
else
| 677 |
shp->l = MINDIM;
| 678 |
| 679 |
shp->h = height;
| 680 |
else
| 681 |
shp->h = .5*MINDIM;
| 682 |
| 683 |
| 684 |
case RECT:
| 685 |
shp->area = shp->w * shp->l;
| 686 |
break;
| 687 |
case DISK:
| 688 |
case SPHERE:
| 689 |
shp->area = PI/4. * shp->w * shp->w;
| 690 |
break;
| 691 |
| 692 |
return(0);
| 693 |
| 694 |
| 695 |
| 696 |
putrectsrc(shp, fp, mod, name, up) /* rectangular source */
| 697 |
SHAPE *shp;
| 698 |
FILE *fp;
| 699 |
char *mod, *name;
| 700 |
int up;
| 701 |
| 702 |
if (up)
| 703 |
putrect(shp, fp, mod, name, ".u", 4, 5, 7, 6);
| 704 |
else
| 705 |
putrect(shp, fp, mod, name, ".d", 0, 2, 3, 1);
| 706 |
| 707 |
| 708 |
| 709 |
putsides(shp, fp, mod, name) /* put out sides of box */
| 710 |
| 711 |
FILE *fp;
| 712 |
char *mod, *name;
| 713 |
| 714 |
putrect(shp, fp, mod, name, ".1", 0, 1, 5, 4);
| 715 |
putrect(shp, fp, mod, name, ".2", 1, 3, 7, 5);
| 716 |
putrect(shp, fp, mod, name, ".3", 3, 2, 6, 7);
| 717 |
putrect(shp, fp, mod, name, ".4", 2, 0, 4, 6);
| 718 |
| 719 |
| 720 |
| 721 |
putrect(shp, fp, mod, name, suffix, a, b, c, d) /* put out a rectangle */
| 722 |
SHAPE *shp;
| 723 |
FILE *fp;
| 724 |
char *mod, *name, *suffix;
| 725 |
int a, b, c, d;
| 726 |
| 727 |
fprintf(fp, "\n%s polygon %s%s\n0\n0\n12\n", mod, name, suffix);
| 728 |
putpoint(shp, fp, a);
| 729 |
putpoint(shp, fp, b);
| 730 |
putpoint(shp, fp, c);
| 731 |
putpoint(shp, fp, d);
| 732 |
| 733 |
| 734 |
| 735 |
putpoint(shp, fp, p) /* put out a point */
| 736 |
| 737 |
FILE *fp;
| 738 |
int p;
| 739 |
| 740 |
static double mult[2] = {-.5, .5};
| 741 |
| 742 |
fprintf(fp, "\t%g\t%g\t%g\n",
| 743 |
mult[p&1]*shp->l*meters2out,
| 744 |
mult[p>>1&1]*shp->w*meters2out,
| 745 |
mult[p>>2]*shp->h*meters2out);
| 746 |
| 747 |
| 748 |
| 749 |
putdisksrc(shp, fp, mod, name, up) /* put out a disk source */
| 750 |
| 751 |
FILE *fp;
| 752 |
char *mod, *name;
| 753 |
int up;
| 754 |
| 755 |
if (up) {
| 756 |
fprintf(fp, "\n%s ring %s.u\n", mod, name);
| 757 |
fprintf(fp, "0\n0\n8\n");
| 758 |
fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
| 759 |
fprintf(fp, "\t0 0 1\n");
| 760 |
fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
| 761 |
} else {
| 762 |
fprintf(fp, "\n%s ring %s.d\n", mod, name);
| 763 |
| 764 |
fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
| 765 |
fprintf(fp, "\t0 0 -1\n");
| 766 |
| 767 |
| 768 |
| 769 |
| 770 |
| 771 |
putcyl(shp, fp, mod, name) /* put out a cylinder */
| 772 |
| 773 |
FILE *fp;
| 774 |
char *mod, *name;
| 775 |
| 776 |
fprintf(fp, "\n%s cylinder %s.c\n", mod, name);
| 777 |
fprintf(fp, "0\n0\n7\n");
| 778 |
| 779 |
| 780 |
fprintf(fp, "\t%g\n", .5*shp->w*meters2out);
| 781 |
| 782 |
| 783 |
| 784 |
putspheresrc(shp, fp, mod, name) /* put out a sphere source */
| 785 |
SHAPE *shp;
| 786 |
FILE *fp;
| 787 |
char *mod, *name;
| 788 |
| 789 |
fprintf(fp, "\n%s sphere %s.s\n", mod, name);
| 790 |
fprintf(fp, "0\n0\n4 0 0 0 %g\n", .5*shp->w*meters2out);
| 791 |
| 792 |
| 793 |
| 794 |
cvdata(in, out, ndim, npts, mult, lim) /* convert data */
| 795 |
FILE *in, *out;
| 796 |
int ndim, npts[];
| 797 |
double mult, lim[][2];
| 798 |
| 799 |
double *pt[4];
| 800 |
register int i, j;
| 801 |
double val;
| 802 |
int total;
| 803 |
| 804 |
total = 1; j = 0;
| 805 |
for (i = 0; i < ndim; i++)
| 806 |
if (npts[i] > 1) {
| 807 |
total *= npts[i];
| 808 |
j++;
| 809 |
| 810 |
fprintf(out, "%d\n", j);
| 811 |
/* get coordinates */
| 812 |
for (i = 0; i < ndim; i++) {
| 813 |
pt[i] = (double *)malloc(npts[i]*sizeof(double));
| 814 |
for (j = 0; j < npts[i]; j++)
| 815 |
fscanf(in, "%lf", &pt[i][j]);
| 816 |
if (lim != NULL) {
| 817 |
lim[i][0] = pt[i][0];
| 818 |
lim[i][1] = pt[i][npts[i]-1];
| 819 |
| 820 |
| 821 |
/* write out in reverse */
| 822 |
for (i = ndim-1; i >= 0; i--) {
| 823 |
if (npts[i] > 1) {
| 824 |
for (j = 1; j < npts[i]-1; j++)
| 825 |
if (!FEQ(pt[i][j]-pt[i][j-1],
| 826 |
pt[i][j+1]-pt[i][j]))
| 827 |
break;
| 828 |
if (j == npts[i]-1)
| 829 |
fprintf(out, "%g %g %d\n", pt[i][0], pt[i][j],
| 830 |
npts[i]);
| 831 |
else {
| 832 |
fprintf(out, "0 0 %d", npts[i]);
| 833 |
for (j = 0; j < npts[i]; j++) {
| 834 |
if (j%4 == 0)
| 835 |
putc('\n', out);
| 836 |
fprintf(out, "\t%g", pt[i][j]);
| 837 |
| 838 |
putc('\n', out);
| 839 |
| 840 |
| 841 |
free((char *)pt[i]);
| 842 |
| 843 |
for (i = 0; i < total; i++) {
| 844 |
if (i%4 == 0)
| 845 |
putc('\n', out);
| 846 |
if (fscanf(in, "%lf", &val) != 1)
| 847 |
return(-1);
| 848 |
fprintf(out, "\t%g", val*mult);
| 849 |
| 850 |
putc('\n', out);
| 851 |
return(0);
| 852 |
