--- ray/src/cv/ies2rad.c 1993/06/04 14:40:25 2.8 +++ ray/src/cv/ies2rad.c 1995/04/25 21:37:14 2.12 @@ -20,6 +20,48 @@ static char SCCSid[] = "$SunId$ LBL"; /* floating comparisons */ #define FTINY 1e-6 #define FEQ(a,b) ((a)<=(b)+FTINY&&(a)>=(b)-FTINY) + /* keywords */ +#define MAGICID "IESNA" +#define LMAGICID 5 +#define FIRSTREV 86 +#define LASTREV 95 + +#define D86 0 /* keywords defined in LM-63-1986 */ + +#define K_TST 0 +#define K_MAN 1 +#define K_LMC 2 +#define K_LMN 3 +#define K_LPC 4 +#define K_LMP 5 +#define K_BAL 6 +#define K_MTC 7 +#define K_OTH 8 +#define K_SCH 9 +#define K_MOR 10 +#define K_BLK 11 +#define K_EBK 12 + +#define D91 ((1L<<13)-1) /* keywords defined in LM-63-1991 */ + +#define K_LMG 13 + +#define D95 ((1L<<14)-1) /* keywords defined in LM-63-1995 */ + +char k_kwd[][20] = {"TEST", "MANUFAC", "LUMCAT", "LUMINAIRE", "LAMPCAT", + "LAMP", "BALLAST", "MAINTCAT", "OTHER", "SEARCH", + "MORE", "BLOCK", "ENDBLOCK", "LUMINOUSGEOMETRY"}; + +long k_defined[] = {D86, D86, D86, D86, D86, D91, D91, D91, D91, D95}; + +int filerev = FIRSTREV; + +#define keymatch(i,s) (k_defined[filerev-FIRSTREV]&1L<<(i) &&\ + k_match(k_kwd[i],s)) + +#define checklamp(s) (!(k_defined[filerev-FIRSTREV]&(1< LASTREV) + filerev = LASTREV; + } fputs("#<", outfp); fputs(buf, outfp); putc('\n', outfp); - if (lampcolor == NULL) - lampcolor = matchlamp(buf); + if (lampcolor == NULL && checklamp(buf)) + lampcolor = matchlamp( buf[0] == '[' ? + keyargs(buf) : buf ); + if (keymatch(K_LMG, buf)) { /* geometry file */ + strcpy(geomfile, inpname); + strcpy(filename(geomfile), keyargs(buf)); + srcinfo.isillum = 1; + } } if (lampcolor == NULL) { fprintf(stderr, "%s: warning - no lamp type\n", inpname); + fputs("# Unknown lamp type (used default)\n", outfp); lampcolor = defcolor; - } + } else if (lamptype == NULL) + fprintf(outfp,"# CIE(x,y) = (%f,%f)\n# Depreciation = %.1f%%\n", + lampcolor[3], lampcolor[4], 100.*lampcolor[5]); if (feof(inpfp)) { fprintf(stderr, "%s: not in IES format\n", inpname); goto readerr; @@ -422,16 +516,20 @@ char *inpname, *outname; fprintf(stderr, "%s: bad tilt data\n", inpname); goto readerr; } - if (dosource(inpfp, outfp, tltid, outname) != 0) { + if (dosource(&srcinfo, inpfp, outfp, tltid, outname) != 0) { fprintf(stderr, "%s: bad luminaire data\n", inpname); goto readerr; } - fclose(outfp); fclose(inpfp); + /* cvgeometry closes outfp */ + if (cvgeometry(geomfile, &srcinfo, outname, outfp) != 0) { + fprintf(stderr, "%s: bad geometry file\n", geomfile); + return(-1); + } return(0); readerr: - fclose(outfp); fclose(inpfp); + fclose(outfp); unlink(fullname(buf,outname,T_RAD)); return(-1); } @@ -510,11 +608,11 @@ char *dir, *tltspec, *dfltname, *tltid; } -dosource(in, out, mod, name) /* create source and distribution */ +dosource(sinf, in, out, mod, name) /* create source and distribution */ +SRCINFO *sinf; FILE *in, *out; char *mod, *name; { - SHAPE srcshape; char buf[MAXPATH], id[MAXWORD]; FILE *datout; double mult, bfactor, pfactor, width, length, height, wattage; @@ -531,6 +629,7 @@ char *mod, *name; fprintf(stderr, "dosource: bad lamp specification\n"); return(-1); } + sinf->mult = multiplier*mult*bfactor*pfactor; if (nangles[0] < 2 || nangles[1] < 1) { fprintf(stderr, "dosource: too few measured angles\n"); return(-1); @@ -540,7 +639,7 @@ char *mod, *name; length *= F_M; height *= F_M; } - if (makeshape(&srcshape, width, length, height) != 0) { + if (makeshape(sinf, width, length, height) != 0) { fprintf(stderr, "dosource: illegal source dimensions"); return(-1); } @@ -568,7 +667,7 @@ char *mod, *name; else fprintf(out, "5 "); fprintf(out, "%s %s source.cal ", - srcshape.type==SPHERE ? "corr" : "flatcorr", + sinf->type==SPHERE ? "corr" : "flatcorr", libname(buf,name,T_DST)); if (pmtype == PM_B) { if (FEQ(bounds[1][0],0.)) @@ -591,8 +690,8 @@ char *mod, *name; } else fprintf(out, "src_theta "); } - fprintf(out, "\n0\n1 %g\n", multiplier*mult*bfactor*pfactor); - if (putsource(&srcshape, out, id, filename(name), + fprintf(out, "\n0\n1 %g\n", sinf->mult); + if (putsource(sinf, out, id, filename(name), bounds[0][0]<90., bounds[0][1]>90.) != 0) return(-1); return(0); @@ -600,7 +699,7 @@ char *mod, *name; putsource(shp, fp, mod, name, dolower, doupper) /* put out source */ -SHAPE *shp; +SRCINFO *shp; FILE *fp; char *mod, *name; int dolower, doupper; @@ -608,19 +707,23 @@ int dolower, doupper; char buf[MAXWORD]; fprintf(fp, "\n%s %s %s_light\n", mod, - illumrad>=MINDIM/2. ? "illum" : "light", + shp->isillum ? "illum" : "light", name); fprintf(fp, "0\n0\n3 %g %g %g\n", lampcolor[0]/shp->area, lampcolor[1]/shp->area, lampcolor[2]/shp->area); - if (doupper && dolower && shp->type != SPHERE && shp->h > MINDIM) { - fprintf(fp, "\n%s glow %s_glow\n", mod, name); - fprintf(fp, "0\n0\n4 %g %g %g -1\n", - lampcolor[0]/shp->area, - lampcolor[1]/shp->area, - lampcolor[2]/shp->area); - } + if (doupper && dolower && shp->type != SPHERE && shp->h > MINDIM) + if (shp->isillum) { + fprintf(fp, "\nvoid illum %s_glow\n", name); + fprintf(fp, "0\n0\n3 0 0 0\n"); + } else { + fprintf(fp, "\n%s glow %s_glow\n", mod, name); + fprintf(fp, "0\n0\n4 %g %g %g -1\n", + lampcolor[0]/shp->area, + lampcolor[1]/shp->area, + lampcolor[2]/shp->area); + } switch (shp->type) { case RECT: strcat(strcpy(buf, name), "_light"); @@ -654,12 +757,13 @@ int dolower, doupper; makeshape(shp, width, length, height) /* make source shape */ -register SHAPE *shp; +register SRCINFO *shp; double width, length, height; { - if (illumrad >= MINDIM/2.) { + if (illumrad/meters2out >= MINDIM/2.) { + shp->isillum = 1; shp->type = SPHERE; - shp->w = shp->l = shp->h = 2.*illumrad; + shp->w = shp->l = shp->h = 2.*illumrad / meters2out; } else if (width < MINDIM) { width = -width; if (width < MINDIM) { @@ -702,7 +806,7 @@ double width, length, height; putrectsrc(shp, fp, mod, name, up) /* rectangular source */ -SHAPE *shp; +SRCINFO *shp; FILE *fp; char *mod, *name; int up; @@ -715,7 +819,7 @@ int up; putsides(shp, fp, mod, name) /* put out sides of box */ -register SHAPE *shp; +register SRCINFO *shp; FILE *fp; char *mod, *name; { @@ -727,7 +831,7 @@ char *mod, *name; putrect(shp, fp, mod, name, suffix, a, b, c, d) /* put out a rectangle */ -SHAPE *shp; +SRCINFO *shp; FILE *fp; char *mod, *name, *suffix; int a, b, c, d; @@ -741,7 +845,7 @@ int a, b, c, d; putpoint(shp, fp, p) /* put out a point */ -register SHAPE *shp; +register SRCINFO *shp; FILE *fp; int p; { @@ -755,7 +859,7 @@ int p; putdisksrc(shp, fp, mod, name, up) /* put out a disk source */ -register SHAPE *shp; +register SRCINFO *shp; FILE *fp; char *mod, *name; int up; @@ -777,7 +881,7 @@ int up; putcyl(shp, fp, mod, name) /* put out a cylinder */ -register SHAPE *shp; +register SRCINFO *shp; FILE *fp; char *mod, *name; { @@ -790,7 +894,7 @@ char *mod, *name; putspheresrc(shp, fp, mod, name) /* put out a sphere source */ -SHAPE *shp; +SRCINFO *shp; FILE *fp; char *mod, *name; { @@ -905,4 +1009,61 @@ char *word; return(0); *rp = atof(word); return(1); +} + + +cvgeometry(inpname, sinf, outname, outfp) +char *inpname; +register SRCINFO *sinf; +char *outname; +FILE *outfp; /* close output file upon return */ +{ + char buf[256]; + register char *cp; + + if (inpname == NULL || !inpname[0]) { /* no geometry file */ + fclose(outfp); + return(0); + } + putc('\n', outfp); + strcpy(buf, "mgf2rad "); /* build mgf2rad command */ + cp = buf+8; + if (!FEQ(sinf->mult, 1.0)) { + sprintf(cp, "-m %f ", sinf->mult); + cp += strlen(cp); + } + sprintf(cp, "-g %f %s ", + sqrt(sinf->w*sinf->w + sinf->h*sinf->h + sinf->l*sinf->l), + inpname); + cp += strlen(cp); + if (instantiate) { /* instantiate octree */ + strcpy(cp, "| oconv - > "); + cp += 12; + fullname(cp,outname,T_OCT); + if (system(buf)) { /* create octree */ + fclose(outfp); + return(-1); + } + fprintf(outfp, "void instance %s_inst\n", outname); + if (!FEQ(meters2out, 1.0)) + fprintf(outfp, "3 %s -s %f\n", + libname(buf,outname,T_OCT), + meters2out); + else + fprintf(outfp, "1 %s\n", libname(buf,outname,T_OCT)); + fprintf(outfp, "0\n0\n"); + fclose(outfp); + } else { /* else append to luminaire file */ + fclose(outfp); + if (!FEQ(meters2out, 1.0)) { /* apply scalefactor */ + sprintf(cp, "| xform -s %f ", meters2out); + cp += strlen(cp); + } + strcpy(cp, ">> "); /* append works for DOS? */ + cp += 3; + fullname(cp,outname,T_RAD); + if (system(buf)) + return(-1); + } + return(0); }
