--- ray/src/cv/ies2rad.c 1991/09/05 13:17:13 1.4 +++ ray/src/cv/ies2rad.c 1992/09/08 10:06:29 2.4 @@ -1,4 +1,4 @@ -/* Copyright (c) 1990 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -13,6 +13,7 @@ static char SCCSid[] = "$SunId$ LBL"; #include #include #include "color.h" +#include "paths.h" #define PI 3.14159265358979323846 /* floating comparisons */ @@ -35,7 +36,6 @@ static char SCCSid[] = "$SunId$ LBL"; /* string lengths */ #define MAXLINE 132 #define MAXWORD 76 -#define MAXPATH 128 /* file types */ #define T_RAD ".rad" #define T_DST ".dat" @@ -49,7 +49,7 @@ static char SCCSid[] = "$SunId$ LBL"; #define F_M .3048 /* feet to meters */ -#define abspath(p) ((p)[0] == '/' || (p)[0] == '.') +#define abspath(p) (ISDIRSEP((p)[0]) || (p)[0] == '.') static char default_name[] = "default"; @@ -64,8 +64,6 @@ float defcolor[3] = {1.,1.,1.}; /* default lamp color float *lampcolor = defcolor; /* pointer to current lamp color */ double multiplier = 1.0; /* multiplier for all light sources */ char units[64] = "meters"; /* output units */ -double minaspect = 0.0; /* minimum allowed aspect ratio */ -int maxemitters = 1; /* maximum emitters per hemisphere */ double illumrad = 0.0; /* radius for illum sphere */ typedef struct { @@ -79,7 +77,6 @@ char **gargv; /* global argv */ extern char *strcpy(), *strcat(), *stradd(), *tailtrunc(), *filetrunc(), *filename(), *libname(), *fullname(), *malloc(); -extern double atof(); extern float *matchlamp(); @@ -157,14 +154,6 @@ char *argv[]; case 'o': /* output file name */ outfile = argv[++i]; break; - case 's': /* square emitters */ - minaspect = .6; - if (argv[i][2] == '/') { - maxemitters = atoi(argv[i]+3); - if (maxemitters < 1) - goto badopt; - } - break; case 'i': /* illum */ illumrad = atof(argv[++i]); if (illumrad < MINDIM) @@ -285,7 +274,7 @@ char *path, *fname, *suffix; else if (abspath(fname)) strcpy(stradd(path, fname, 0), suffix); else - libname(stradd(path, libdir, '/'), fname, suffix); + libname(stradd(path, libdir, DIRSEP), fname, suffix); return(path); } @@ -298,7 +287,7 @@ char *path, *fname, *suffix; if (abspath(fname)) strcpy(stradd(path, fname, 0), suffix); else - strcpy(stradd(stradd(path, prefdir, '/'), fname, 0), suffix); + strcpy(stradd(stradd(path, prefdir, DIRSEP), fname, 0), suffix); return(path); } @@ -311,7 +300,7 @@ register char *path; register char *cp; for (cp = path; *path; path++) - if (*path == '/') + if (ISDIRSEP(*path)) cp = path+1; return(cp); } @@ -324,7 +313,7 @@ char *path; register char *p1, *p2; for (p1 = p2 = path; *p2; p2++) - if (*p2 == '/') + if (ISDIRSEP(*p2)) p1 = p2; *p1 = '\0'; return(path); @@ -458,10 +447,10 @@ char *dir, *tltspec, *dfltname, *tltid; datin = in; strcpy(tltname, dfltname); } else { - if (tltspec[0] == '/') + if (ISDIRSEP(tltspec[0])) strcpy(buf, tltspec); else - strcpy(stradd(buf, dir, '/'), tltspec); + strcpy(stradd(buf, dir, DIRSEP), tltspec); if ((datin = fopen(buf, "r")) == NULL) { perror(buf); return(-1); @@ -551,7 +540,7 @@ char *mod, *name; perror(buf); return(-1); } - if (cvdata(in, datout, 2, nangles, 1./470., bounds) != 0) { + if (cvdata(in, datout, 2, nangles, 1./WHTEFFICACY, bounds) != 0) { fprintf(stderr, "dosource: bad distribution data\n"); fclose(datout); unlink(fullname(buf,name,T_DST)); @@ -807,7 +796,7 @@ FILE *in, *out; int ndim, npts[]; double mult, lim[][2]; { - register double *pt[4]; + double *pt[4]; register int i, j; double val; int total;
