root/radiance/ray/src/cv/ies2rad.c
Thu Nov 7 17:09:18 2024 UTC (7 months, 1 week ago) by greg
Diff to previous 2.36 , to selected 2.28
fix(ies2rad): Fixed version test for non-compliant (older) files
Wed Nov 16 01:59:43 2022 UTC (2 years, 7 months ago) by greg
Changes since 2.35: +43 -28 lines
Diff to previous 2.35 , to selected 2.28
fix(ies2rad): Randolph Fritz fixed issue with some luminaire geometries and improved code readability
Mon Nov 29 16:07:36 2021 UTC (3 years, 6 months ago) by greg
Changes since 2.34: +673 -216 lines
Diff to previous 2.34 , to selected 2.28
feat(ies2rad): changes and enhancements to ies2rad by Randolph Fritz
Thu Sep 30 20:05:09 2021 UTC (3 years, 8 months ago) by greg
Changes since 2.33: +10 -10 lines
Diff to previous 2.33 , to selected 2.28
fix(ies2rad): Changes to allow spaces in input file names
Mon Sep 20 02:00:05 2021 UTC (3 years, 9 months ago) by greg
Changes since 2.32: +32 -15 lines
Diff to previous 2.32 , to selected 2.28
docs(ies2rad): Randolph Fritz updated some of the comments for us
Sat Dec 28 18:05:14 2019 UTC (5 years, 5 months ago) by greg
Changes since 2.31: +1 -4 lines
Diff to previous 2.31 , to selected 2.28
Tue Jun 5 16:04:00 2018 UTC (7 years ago) by greg
Changes since 2.30: +11 -8 lines
Diff to previous 2.30 , to selected 2.28
Increased maximum line length and allow spaces before bracketed keywords
Mon Jun 4 23:05:34 2018 UTC (7 years ago) by greg
Changes since 2.29: +9 -6 lines
Diff to previous 2.29 , to selected 2.28
Fixed issue with newer IES file version strings
Mon Jun 4 18:53:09 2018 UTC (7 years ago) by greg
Diff to previous 2.28
Fixed bug in header parsing pointed out by Randolph Fritz
Revision 2.28 - (view) (download) (annotate) - [selected]
Wed May 30 22:12:17 2018 UTC (7 years ago) by greg
Changes since 2.27: +704 -104 lines
Diff to previous 2.27
Randolph Fritz added copious comments to explain what's going on
Sat Aug 1 23:27:04 2015 UTC (9 years, 10 months ago) by greg
CVS Tags: rad5R0, rad5R1
Changes since 2.26: +24 -24 lines
Diff to previous 2.26 , to selected 2.28
Wed Jun 22 19:57:17 2011 UTC (14 years ago) by greg
Diff to previous 2.25 , to selected 2.28
Fixed mgf2rad -m option that needed to be -e
Thu Jan 24 23:15:46 2008 UTC (17 years, 4 months ago) by greg
CVS Tags: rad3R9, rad4R0
Changes since 2.24: +8 -2 lines
Diff to previous 2.24 , to selected 2.28
Wed Oct 5 05:17:41 2005 UTC (19 years, 8 months ago) by greg
Diff to previous 2.23 , to selected 2.28
Improved robustness of angle range check (minor change)
Sat Nov 15 13:29:23 2003 UTC (21 years, 7 months ago) by schorsch
Changes since 2.22: +205 -100 lines
Diff to previous 2.22 , to selected 2.28
ANSIfication. Fixed missing dosides parameter in putsource(). Fixed type of minmax variable in dotilt()
Sun Jul 27 22:12:01 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.21: +3 -3 lines
Diff to previous 2.21 , to selected 2.28
Thu Jul 3 22:41:44 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.20: +10 -10 lines
Diff to previous 2.20 , to selected 2.28
Mon Jun 30 18:18:22 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 2.19 , to selected 2.28
Removed stray strcpy() declarations
Mon Jun 30 14:59:11 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 2.18 , to selected 2.28
Sat Feb 22 02:07:23 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.17: +30 -25 lines
Diff to previous 2.17 , to selected 2.28
Mon Nov 10 10:13:58 1997 UTC (27 years, 7 months ago) by gregl
Changes since 2.16: +12 -12 lines
Diff to previous 2.16 , to selected 2.28
removed use of "word", which is a typedef on Cray systems
Fri Jul 25 12:08:06 1997 UTC (27 years, 11 months ago) by gregl
Changes since 2.15: +25 -35 lines
Diff to previous 2.15 , to selected 2.28
eliminated use of "glow" type and applied boxcorr and new cylcorr
Fri Jul 25 11:18:18 1997 UTC (27 years, 11 months ago) by gregl
Diff to previous 2.14 , to selected 2.28
eliminated output of sides when they're not wanted
Tue Jun 18 21:28:52 1996 UTC (29 years ago) by greg
Diff to previous 2.13 , to selected 2.28
added check to avoid rerunning oconv unnecessarily
Wed Jun 12 19:13:42 1996 UTC (29 years ago) by greg
Changes since 2.12: +22 -12 lines
Diff to previous 2.12 , to selected 2.28
added -s option to send to stdout
Tue Apr 25 21:37:14 1995 UTC (30 years, 2 months ago) by greg
Changes since 2.11: +189 -31 lines
Diff to previous 2.11 , to selected 2.28
added MGF detail geometry conversion
Mon May 23 10:45:41 1994 UTC (31 years, 1 month ago) by greg
Diff to previous 2.10 , to selected 2.28
fixed bug in -i option that caused it to assume inappropriate units
Thu Dec 16 10:01:30 1993 UTC (31 years, 6 months ago) by greg
Diff to previous 2.9 , to selected 2.28
changed tilt suffix from +.dat to %.dat for MS-DOS compatibility
Mon Aug 23 10:22:42 1993 UTC (31 years, 10 months ago) by greg
Diff to previous 2.8 , to selected 2.28
added reporting of lamp color and depreciation in comment
Fri Jun 4 14:40:25 1993 UTC (32 years ago) by greg
Diff to previous 2.7 , to selected 2.28
added math.h for atof() usage
Mon Apr 5 16:40:07 1993 UTC (32 years, 2 months ago) by greg
Diff to previous 2.6 , to selected 2.28
corrected error in azimuthal angle specification
Thu Mar 18 11:21:21 1993 UTC (32 years, 3 months ago) by greg
Changes since 2.5: +64 -9 lines
Diff to previous 2.5 , to selected 2.28
better checking of input data -- allow comma separators
Mon Feb 22 15:54:55 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.4 , to selected 2.28
modified to generate glow types with negative radii of influence
Tue Sep 8 10:06:29 1992 UTC (32 years, 9 months ago) by greg
Changes since 2.3: +9 -19 lines
Diff to previous 2.3 , to selected 2.28
added paths.h for non-UNIX file naming
Thu May 21 09:56:36 1992 UTC (33 years, 1 month ago) by greg
Diff to previous 2.2 , to selected 2.28
fixed register allocation IBM RS/6000 didn't like
Thu Dec 19 15:10:45 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 2.1 , to selected 2.28
Tue Nov 12 17:02:02 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.5 , to selected 2.28
Thu Oct 24 12:17:35 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.4 , to selected 2.28
fixed conversion between lumens and watts
Thu Sep 5 13:17:13 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.3 , to selected 2.28
corrected lumens to watts conversion factor
Tue Jan 29 12:19:10 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.2: +2 -4 lines
Diff to previous 1.2 , to selected 2.28
fixed incorrect calculation of radiance for spherical sources
Fri Dec 14 14:41:14 1990 UTC (34 years, 6 months ago) by greg
Changes since 1.1: +50 -10 lines
Diff to previous 1.1 , to selected 2.28
improved use of lamp data
Tue Dec 11 08:45:48 1990 UTC (34 years, 6 months ago) by greg
Diff to selected 2.28
