--- ray/src/cv/ies2rad.c 1993/02/22 15:54:55 2.5 +++ ray/src/cv/ies2rad.c 2003/11/15 13:29:23 2.23 @@ -1,17 +1,21 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: ies2rad.c,v 2.23 2003/11/15 13:29:23 schorsch Exp $"; #endif - /* * Convert IES luminaire data to Radiance description * * 07Apr90 Greg Ward + * + * Fixed correction factor for flat sources 29Oct2001 GW */ #include +#include +#include +#include #include + +#include "rtio.h" #include "color.h" #include "paths.h" @@ -19,6 +23,48 @@ static char SCCSid[] = "$SunId$ LBL"; /* floating comparisons */ #define FTINY 1e-6 #define FEQ(a,b) ((a)<=(b)+FTINY&&(a)>=(b)-FTINY) + /* keywords */ +#define MAGICID "IESNA" +#define LMAGICID 5 +#define FIRSTREV 86 +#define LASTREV 95 + +#define D86 0 /* keywords defined in LM-63-1986 */ + +#define K_TST 0 +#define K_MAN 1 +#define K_LMC 2 +#define K_LMN 3 +#define K_LPC 4 +#define K_LMP 5 +#define K_BAL 6 +#define K_MTC 7 +#define K_OTH 8 +#define K_SCH 9 +#define K_MOR 10 +#define K_BLK 11 +#define K_EBK 12 + +#define D91 ((1L<<13)-1) /* keywords defined in LM-63-1991 */ + +#define K_LMG 13 + +#define D95 ((1L<<14)-1) /* keywords defined in LM-63-1995 */ + +char k_kwd[][20] = {"TEST", "MANUFAC", "LUMCAT", "LUMINAIRE", "LAMPCAT", + "LAMP", "BALLAST", "MAINTCAT", "OTHER", "SEARCH", + "MORE", "BLOCK", "ENDBLOCK", "LUMINOUSGEOMETRY"}; + +long k_defined[] = {D86, D86, D86, D86, D86, D91, D91, D91, D91, D95}; + +int filerev = FIRSTREV; + +#define keymatch(i,s) (k_defined[filerev-FIRSTREV]&1L<<(i) &&\ + k_match(k_kwd[i],s)) + +#define checklamp(s) (!(k_defined[filerev-FIRSTREV]&(1<= argc) { fprintf(stderr, "%s: missing output file specification\n", argv[0]); exit(1); } + if (out2stdout && i != argc-1) + goto needsingle; status = 0; for ( ; i < argc; i++) { tailtrunc(strcpy(outname,filename(argv[i]))); @@ -205,10 +290,13 @@ char *argv[]; status = 1; } exit(status); +needsingle: + fprintf(stderr, "%s: single input file required\n", argv[0]); + exit(1); } - -initlamps() /* set up lamps */ +void +initlamps(void) /* set up lamps */ { float *lcol; int status; @@ -249,9 +337,11 @@ initlamps() /* set up lamps */ char * -stradd(dst, src, sep) /* add a string at dst */ -register char *dst, *src; -int sep; +stradd( /* add a string at dst */ + register char *dst, + register char *src, + int sep +) { if (src && *src) { do @@ -266,8 +356,11 @@ int sep; char * -fullname(path, fname, suffix) /* return full path name */ -char *path, *fname, *suffix; +fullnam( /* return full path name */ + char *path, + char *fname, + char *suffix +) { if (prefdir != NULL && abspath(prefdir)) libname(path, fname, suffix); @@ -281,8 +374,11 @@ char *path, *fname, *suffix; char * -libname(path, fname, suffix) /* return library relative name */ -char *path, *fname, *suffix; +libname( /* return library relative name */ + char *path, + char *fname, + char *suffix +) { if (abspath(fname)) strcpy(stradd(path, fname, 0), suffix); @@ -294,8 +390,9 @@ char *path, *fname, *suffix; char * -filename(path) /* get final component of pathname */ -register char *path; +filename( /* get final component of pathname */ + register char *path +) { register char *cp; @@ -307,22 +404,26 @@ register char *path; char * -filetrunc(path) /* truncate filename at end of path */ -char *path; +filetrunc( /* truncate filename at end of path */ + char *path +) { register char *p1, *p2; for (p1 = p2 = path; *p2; p2++) if (ISDIRSEP(*p2)) p1 = p2; + if (p1 == path && ISDIRSEP(*p1)) + p1++; *p1 = '\0'; return(path); } char * -tailtrunc(name) /* truncate tail of filename */ -char *name; +tailtrunc( /* truncate tail of filename */ + char *name +) { register char *p1, *p2; @@ -338,8 +439,10 @@ char *name; } -blanktrunc(s) /* truncate spaces at end of line */ -char *s; +void +blanktrunc( /* truncate spaces at end of line */ + char *s +) { register char *cp; @@ -351,9 +454,39 @@ char *s; } -putheader(out) /* print header */ -FILE *out; +int +k_match( /* header line matches keyword? */ + register char *kwd, + register char *hdl +) { + if (!*hdl++ == '[') + return(0); + while (islower(*hdl) ? toupper(*hdl) == *kwd++ : *hdl == *kwd++) + if (!*hdl++) + return(0); + return((!*kwd) & (*hdl == ']')); +} + + +char * +keyargs( /* return keyword arguments */ + register char *hdl +) +{ + while (*hdl && *hdl++ != ']') + ; + while (isspace(*hdl)) + hdl++; + return(hdl); +} + + +void +putheader( /* print header */ + FILE *out +) +{ register int i; putc('#', out); @@ -367,12 +500,20 @@ FILE *out; } -ies2rad(inpname, outname) /* convert IES file */ -char *inpname, *outname; +int +ies2rad( /* convert IES file */ + char *inpname, + char *outname +) { - char buf[MAXLINE], tltid[MAXWORD]; + SRCINFO srcinfo; + char buf[MAXLINE], tltid[RMAXWORD]; + char geomfile[128]; FILE *inpfp, *outfp; + int lineno = 0; + geomfile[0] = '\0'; + srcinfo.isillum = 0; if (inpname == NULL) { inpname = ""; inpfp = stdin; @@ -380,7 +521,9 @@ char *inpname, *outname; perror(inpname); return(-1); } - if ((outfp = fopen(fullname(buf,outname,T_RAD), "w")) == NULL) { + if (out2stdout) + outfp = stdout; + else if ((outfp = fopen(fullnam(buf,outname,T_RAD), "w")) == NULL) { perror(buf); fclose(inpfp); return(-1); @@ -393,21 +536,37 @@ char *inpname, *outname; blanktrunc(buf); if (!buf[0]) continue; + if (!lineno++ && !strncmp(buf, MAGICID, LMAGICID)) { + filerev = atoi(buf+LMAGICID); + if (filerev < FIRSTREV) + filerev = FIRSTREV; + else if (filerev > LASTREV) + filerev = LASTREV; + } fputs("#<", outfp); fputs(buf, outfp); putc('\n', outfp); - if (lampcolor == NULL) - lampcolor = matchlamp(buf); + if (lampcolor == NULL && checklamp(buf)) + lampcolor = matchlamp( buf[0] == '[' ? + keyargs(buf) : buf ); + if (keymatch(K_LMG, buf)) { /* geometry file */ + strcpy(geomfile, inpname); + strcpy(filename(geomfile), keyargs(buf)); + srcinfo.isillum = 1; + } } if (lampcolor == NULL) { fprintf(stderr, "%s: warning - no lamp type\n", inpname); + fputs("# Unknown lamp type (used default)\n", outfp); lampcolor = defcolor; - } + } else if (lamptype == NULL) + fprintf(outfp,"# CIE(x,y) = (%f,%f)\n# Depreciation = %.1f%%\n", + lampcolor[3], lampcolor[4], 100.*lampcolor[5]); if (feof(inpfp)) { fprintf(stderr, "%s: not in IES format\n", inpname); goto readerr; } - sscanf(buf+TLTSTRLEN, "%s", tltid); + atos(tltid, RMAXWORD, buf+TLTSTRLEN); if (inpfp == stdin) buf[0] = '\0'; else @@ -416,28 +575,38 @@ char *inpname, *outname; fprintf(stderr, "%s: bad tilt data\n", inpname); goto readerr; } - if (dosource(inpfp, outfp, tltid, outname) != 0) { + if (dosource(&srcinfo, inpfp, outfp, tltid, outname) != 0) { fprintf(stderr, "%s: bad luminaire data\n", inpname); goto readerr; } - fclose(outfp); fclose(inpfp); + /* cvgeometry closes outfp */ + if (cvgeometry(geomfile, &srcinfo, outname, outfp) != 0) { + fprintf(stderr, "%s: bad geometry file\n", geomfile); + return(-1); + } return(0); readerr: - fclose(outfp); fclose(inpfp); - unlink(fullname(buf,outname,T_RAD)); + fclose(outfp); + unlink(fullnam(buf,outname,T_RAD)); return(-1); } -dotilt(in, out, dir, tltspec, dfltname, tltid) /* convert tilt data */ -FILE *in, *out; -char *dir, *tltspec, *dfltname, *tltid; +int +dotilt( /* convert tilt data */ + FILE *in, + FILE *out, + char *dir, + char *tltspec, + char *dfltname, + char *tltid +) { int nangles, tlt_type; - double minmax[2]; - char buf[MAXPATH], tltname[MAXWORD]; + double minmax[1][2]; + char buf[PATH_MAX], tltname[RMAXWORD]; FILE *datin, *datout; if (!strcmp(tltspec, TLTNONE)) { @@ -458,19 +627,19 @@ char *dir, *tltspec, *dfltname, *tltid; tailtrunc(strcpy(tltname,filename(tltspec))); } if (datin != NULL) { - if ((datout = fopen(fullname(buf,tltname,T_TLT),"w")) == NULL) { + if ((datout = fopen(fullnam(buf,tltname,T_TLT),"w")) == NULL) { perror(buf); if (datin != in) fclose(datin); return(-1); } - if (fscanf(datin, "%d %d", &tlt_type, &nangles) != 2 + if (!scnint(datin,&tlt_type) || !scnint(datin,&nangles) || cvdata(datin,datout,1,&nangles,1.,minmax) != 0) { fprintf(stderr, "%s: data format error\n", tltspec); fclose(datout); if (datin != in) fclose(datin); - unlink(fullname(buf,tltname,T_TLT)); + unlink(fullnam(buf,tltname,T_TLT)); return(-1); } fclose(datout); @@ -482,15 +651,15 @@ char *dir, *tltspec, *dfltname, *tltid; switch (tlt_type) { case TLT_VERT: /* vertical */ fprintf(out, "4 noop %s tilt.cal %s\n", buf, - minmax[1]>90.+FTINY ? "tilt_ang" : "tilt_ang2"); + minmax[0][1]>90.+FTINY ? "tilt_ang" : "tilt_ang2"); break; case TLT_H0: /* horiz. in 0 deg. plane */ fprintf(out, "6 noop %s tilt.cal %s -rz 90\n", buf, - minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2"); + minmax[0][1]>90.+FTINY ? "tilt_xang" : "tilt_xang2"); break; case TLT_H90: fprintf(out, "4 noop %s tilt.cal %s\n", buf, - minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2"); + minmax[0][1]>90.+FTINY ? "tilt_xang" : "tilt_xang2"); break; default: fprintf(stderr, @@ -504,25 +673,33 @@ char *dir, *tltspec, *dfltname, *tltid; } -dosource(in, out, mod, name) /* create source and distribution */ -FILE *in, *out; -char *mod, *name; +int +dosource( /* create source and distribution */ + SRCINFO *sinf, + FILE *in, + FILE *out, + char *mod, + char *name +) { - SHAPE srcshape; - char buf[MAXPATH], id[MAXWORD]; + char buf[PATH_MAX], id[RMAXWORD]; FILE *datout; double mult, bfactor, pfactor, width, length, height, wattage; double bounds[2][2]; int nangles[2], pmtype, unitype; double d1; + int doupper, dolower, dosides; - if (fscanf(in, "%*d %*f %lf %d %d %d %d %lf %lf %lf %lf %lf %lf", - &mult, &nangles[0], &nangles[1], &pmtype, &unitype, - &width, &length, &height, &bfactor, &pfactor, - &wattage) != 11) { + if (!isint(getword(in)) || !isflt(getword(in)) || !scnflt(in,&mult) + || !scnint(in,&nangles[0]) || !scnint(in,&nangles[1]) + || !scnint(in,&pmtype) || !scnint(in,&unitype) + || !scnflt(in,&width) || !scnflt(in,&length) + || !scnflt(in,&height) || !scnflt(in,&bfactor) + || !scnflt(in,&pfactor) || !scnflt(in,&wattage)) { fprintf(stderr, "dosource: bad lamp specification\n"); return(-1); } + sinf->mult = multiplier*mult*bfactor*pfactor; if (nangles[0] < 2 || nangles[1] < 1) { fprintf(stderr, "dosource: too few measured angles\n"); return(-1); @@ -532,18 +709,18 @@ char *mod, *name; length *= F_M; height *= F_M; } - if (makeshape(&srcshape, width, length, height) != 0) { + if (makeshape(sinf, width, length, height) != 0) { fprintf(stderr, "dosource: illegal source dimensions"); return(-1); } - if ((datout = fopen(fullname(buf,name,T_DST), "w")) == NULL) { + if ((datout = fopen(fullnam(buf,name,T_DST), "w")) == NULL) { perror(buf); return(-1); } if (cvdata(in, datout, 2, nangles, 1./WHTEFFICACY, bounds) != 0) { fprintf(stderr, "dosource: bad distribution data\n"); fclose(datout); - unlink(fullname(buf,name,T_DST)); + unlink(fullnam(buf,name,T_DST)); return(-1); } fclose(datout); @@ -556,11 +733,16 @@ char *mod, *name; else if (pmtype == PM_B) fprintf(out, "5 "); else if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.)) - fprintf(out, "8 "); + fprintf(out, "7 "); else - fprintf(out, "6 "); + fprintf(out, "5 "); + dolower = (bounds[0][0] < 90.); + doupper = (bounds[0][1] > 90.); + dosides = (doupper & dolower && sinf->h > MINDIM); fprintf(out, "%s %s source.cal ", - srcshape.type==SPHERE ? "corr" : "flatcorr", + sinf->type==SPHERE ? "corr" : + !dosides ? "flatcorr" : + sinf->type==DISK ? "cylcorr" : "boxcorr", libname(buf,name,T_DST)); if (pmtype == PM_B) { if (FEQ(bounds[1][0],0.)) @@ -568,90 +750,94 @@ char *mod, *name; else fprintf(out, "srcB_horiz "); fprintf(out, "srcB_vert "); - } else { + } else /* pmtype == PM_A */ { if (nangles[1] >= 2) { d1 = bounds[1][1] - bounds[1][0]; if (d1 <= 90.+FTINY) fprintf(out, "src_phi4 "); - else if (d1 <= 180.+FTINY) - fprintf(out, "src_phi2 "); - else + else if (d1 <= 180.+FTINY) { + if (FEQ(bounds[1][0],90.)) + fprintf(out, "src_phi2+90 "); + else + fprintf(out, "src_phi2 "); + } else fprintf(out, "src_phi "); - fprintf(out, "src_theta -my "); + fprintf(out, "src_theta "); if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.)) fprintf(out, "-rz -90 "); } else fprintf(out, "src_theta "); } - fprintf(out, "\n0\n1 %g\n", multiplier*mult*bfactor*pfactor); - if (putsource(&srcshape, out, id, filename(name), - bounds[0][0]<90., bounds[0][1]>90.) != 0) + if (!dosides || sinf->type == SPHERE) + fprintf(out, "\n0\n1 %g\n", sinf->mult/sinf->area); + else if (sinf->type == DISK) + fprintf(out, "\n0\n3 %g %g %g\n", sinf->mult, + sinf->w, sinf->h); + else + fprintf(out, "\n0\n4 %g %g %g %g\n", sinf->mult, + sinf->l, sinf->w, sinf->h); + if (putsource(sinf, out, id, filename(name), + dolower, doupper, dosides) != 0) return(-1); return(0); } -putsource(shp, fp, mod, name, dolower, doupper) /* put out source */ -SHAPE *shp; -FILE *fp; -char *mod, *name; -int dolower, doupper; +int +putsource( /* put out source */ + SRCINFO *shp, + FILE *fp, + char *mod, + char *name, + int dolower, + int doupper, + int dosides +) { - char buf[MAXWORD]; + char lname[RMAXWORD]; - fprintf(fp, "\n%s %s %s_light\n", mod, - illumrad>=MINDIM/2. ? "illum" : "light", - name); + strcat(strcpy(lname, name), "_light"); + fprintf(fp, "\n%s %s %s\n", mod, + shp->isillum ? "illum" : "light", lname); fprintf(fp, "0\n0\n3 %g %g %g\n", - lampcolor[0]/shp->area, - lampcolor[1]/shp->area, - lampcolor[2]/shp->area); - if (doupper && dolower && shp->type != SPHERE && shp->h > MINDIM) { - fprintf(fp, "\n%s glow %s_glow\n", mod, name); - fprintf(fp, "0\n0\n4 %g %g %g -1\n", - lampcolor[0]/shp->area, - lampcolor[1]/shp->area, - lampcolor[2]/shp->area); - } + lampcolor[0], lampcolor[1], lampcolor[2]); switch (shp->type) { case RECT: - strcat(strcpy(buf, name), "_light"); if (dolower) - putrectsrc(shp, fp, buf, name, 0); + putrectsrc(shp, fp, lname, name, 0); if (doupper) - putrectsrc(shp, fp, buf, name, 1); - if (doupper && dolower && shp->h > MINDIM) { - strcat(strcpy(buf, name), "_glow"); - putsides(shp, fp, buf, name); - } + putrectsrc(shp, fp, lname, name, 1); + if (dosides) + putsides(shp, fp, lname, name); break; case DISK: - strcat(strcpy(buf, name), "_light"); if (dolower) - putdisksrc(shp, fp, buf, name, 0); + putdisksrc(shp, fp, lname, name, 0); if (doupper) - putdisksrc(shp, fp, buf, name, 1); - if (doupper && dolower && shp->h > MINDIM) { - strcat(strcpy(buf, name), "_glow"); - putcyl(shp, fp, buf, name); - } + putdisksrc(shp, fp, lname, name, 1); + if (dosides) + putcyl(shp, fp, lname, name); break; case SPHERE: - strcat(strcpy(buf, name), "_light"); - putspheresrc(shp, fp, buf, name); + putspheresrc(shp, fp, lname, name); break; } return(0); } -makeshape(shp, width, length, height) /* make source shape */ -register SHAPE *shp; -double width, length, height; +int +makeshape( /* make source shape */ + register SRCINFO *shp, + double width, + double length, + double height +) { - if (illumrad >= MINDIM/2.) { + if (illumrad/meters2out >= MINDIM/2.) { + shp->isillum = 1; shp->type = SPHERE; - shp->w = shp->l = shp->h = 2.*illumrad; + shp->w = shp->l = shp->h = 2.*illumrad / meters2out; } else if (width < MINDIM) { width = -width; if (width < MINDIM) { @@ -693,11 +879,14 @@ double width, length, height; } -putrectsrc(shp, fp, mod, name, up) /* rectangular source */ -SHAPE *shp; -FILE *fp; -char *mod, *name; -int up; +void +putrectsrc( /* rectangular source */ + SRCINFO *shp, + FILE *fp, + char *mod, + char *name, + int up +) { if (up) putrect(shp, fp, mod, name, ".u", 4, 5, 7, 6); @@ -706,10 +895,13 @@ int up; } -putsides(shp, fp, mod, name) /* put out sides of box */ -register SHAPE *shp; -FILE *fp; -char *mod, *name; +void +putsides( /* put out sides of box */ + register SRCINFO *shp, + FILE *fp, + char *mod, + char *name +) { putrect(shp, fp, mod, name, ".1", 0, 1, 5, 4); putrect(shp, fp, mod, name, ".2", 1, 3, 7, 5); @@ -718,11 +910,18 @@ char *mod, *name; } -putrect(shp, fp, mod, name, suffix, a, b, c, d) /* put out a rectangle */ -SHAPE *shp; -FILE *fp; -char *mod, *name, *suffix; -int a, b, c, d; +void +putrect( /* put out a rectangle */ + SRCINFO *shp, + FILE *fp, + char *mod, + char *name, + char *suffix, + int a, + int b, + int c, + int d +) { fprintf(fp, "\n%s polygon %s%s\n0\n0\n12\n", mod, name, suffix); putpoint(shp, fp, a); @@ -732,10 +931,12 @@ int a, b, c, d; } -putpoint(shp, fp, p) /* put out a point */ -register SHAPE *shp; -FILE *fp; -int p; +void +putpoint( /* put out a point */ + register SRCINFO *shp, + FILE *fp, + int p +) { static double mult[2] = {-.5, .5}; @@ -746,11 +947,14 @@ int p; } -putdisksrc(shp, fp, mod, name, up) /* put out a disk source */ -register SHAPE *shp; -FILE *fp; -char *mod, *name; -int up; +void +putdisksrc( /* put out a disk source */ + register SRCINFO *shp, + FILE *fp, + char *mod, + char *name, + int up +) { if (up) { fprintf(fp, "\n%s ring %s.u\n", mod, name); @@ -768,10 +972,13 @@ int up; } -putcyl(shp, fp, mod, name) /* put out a cylinder */ -register SHAPE *shp; -FILE *fp; -char *mod, *name; +void +putcyl( /* put out a cylinder */ + register SRCINFO *shp, + FILE *fp, + char *mod, + char *name +) { fprintf(fp, "\n%s cylinder %s.c\n", mod, name); fprintf(fp, "0\n0\n7\n"); @@ -781,20 +988,28 @@ char *mod, *name; } -putspheresrc(shp, fp, mod, name) /* put out a sphere source */ -SHAPE *shp; -FILE *fp; -char *mod, *name; +void +putspheresrc( /* put out a sphere source */ + SRCINFO *shp, + FILE *fp, + char *mod, + char *name +) { fprintf(fp, "\n%s sphere %s.s\n", mod, name); fprintf(fp, "0\n0\n4 0 0 0 %g\n", .5*shp->w*meters2out); } -cvdata(in, out, ndim, npts, mult, lim) /* convert data */ -FILE *in, *out; -int ndim, npts[]; -double mult, lim[][2]; +int +cvdata( /* convert data */ + FILE *in, + FILE *out, + int ndim, + int npts[], + double mult, + double lim[][2] +) { double *pt[4]; register int i, j; @@ -812,7 +1027,8 @@ double mult, lim[][2]; for (i = 0; i < ndim; i++) { pt[i] = (double *)malloc(npts[i]*sizeof(double)); for (j = 0; j < npts[i]; j++) - fscanf(in, "%lf", &pt[i][j]); + if (!scnflt(in, &pt[i][j])) + return(-1); if (lim != NULL) { lim[i][0] = pt[i][0]; lim[i][1] = pt[i][npts[i]-1]; @@ -838,15 +1054,129 @@ double mult, lim[][2]; putc('\n', out); } } - free((char *)pt[i]); + free((void *)pt[i]); } for (i = 0; i < total; i++) { if (i%4 == 0) putc('\n', out); - if (fscanf(in, "%lf", &val) != 1) + if (!scnflt(in, &val)) return(-1); fprintf(out, "\t%g", val*mult); } putc('\n', out); + return(0); +} + + +char * +getword( /* scan a word from fp */ + register FILE *fp +) +{ + static char wrd[RMAXWORD]; + register char *cp; + register int c; + + while (isspace(c=getc(fp))) + ; + for (cp = wrd; c != EOF && cp < wrd+RMAXWORD-1; + *cp++ = c, c = getc(fp)) + if (isspace(c) || c == ',') { + while (isspace(c)) + c = getc(fp); + if ((c != EOF) & (c != ',')) + ungetc(c, fp); + *cp = '\0'; + return(wrd); + } + *cp = '\0'; + return(cp > wrd ? wrd : NULL); +} + + +int +cvtint( /* convert a word to an integer */ + int *ip, + char *wrd +) +{ + if (wrd == NULL || !isint(wrd)) + return(0); + *ip = atoi(wrd); + return(1); +} + + +int +cvtflt( /* convert a word to a double */ + double *rp, + char *wrd +) +{ + if (wrd == NULL || !isflt(wrd)) + return(0); + *rp = atof(wrd); + return(1); +} + + +int +cvgeometry( + char *inpname, + register SRCINFO *sinf, + char *outname, + FILE *outfp /* close output file upon return */ +) +{ + char buf[256]; + register char *cp; + + if (inpname == NULL || !inpname[0]) { /* no geometry file */ + fclose(outfp); + return(0); + } + putc('\n', outfp); + strcpy(buf, "mgf2rad "); /* build mgf2rad command */ + cp = buf+8; + if (!FEQ(sinf->mult, 1.0)) { + sprintf(cp, "-m %f ", sinf->mult); + cp += strlen(cp); + } + sprintf(cp, "-g %f %s ", + sqrt(sinf->w*sinf->w + sinf->h*sinf->h + sinf->l*sinf->l), + inpname); + cp += strlen(cp); + if (instantiate) { /* instantiate octree */ + strcpy(cp, "| oconv - > "); + cp += 12; + fullnam(cp,outname,T_OCT); + if (fdate(inpname) > fdate(outname) && + system(buf)) { /* create octree */ + fclose(outfp); + return(-1); + } + fprintf(outfp, "void instance %s_inst\n", outname); + if (!FEQ(meters2out, 1.0)) + fprintf(outfp, "3 %s -s %f\n", + libname(buf,outname,T_OCT), + meters2out); + else + fprintf(outfp, "1 %s\n", libname(buf,outname,T_OCT)); + fprintf(outfp, "0\n0\n"); + fclose(outfp); + } else { /* else append to luminaire file */ + if (!FEQ(meters2out, 1.0)) { /* apply scalefactor */ + sprintf(cp, "| xform -s %f ", meters2out); + cp += strlen(cp); + } + if (!out2stdout) { + fclose(outfp); + strcpy(cp, ">> "); /* append works for DOS? */ + cp += 3; + fullnam(cp,outname,T_RAD); + } + if (system(buf)) + return(-1); + } return(0); }
