| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: ies2rad.c,v 2.26 2011/06/22 19:57:17 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Convert IES luminaire data to Radiance description
| 6 |
| 7 |
* 07Apr90 Greg Ward
| 8 |
| 9 |
* Fixed correction factor for flat sources 29Oct2001 GW
| 10 |
| 11 |
| 12 |
#include <stdio.h>
| 13 |
#include <string.h>
| 14 |
#include <math.h>
| 15 |
#include <sys/types.h>
| 16 |
#include <ctype.h>
| 17 |
| 18 |
#include "rtio.h"
| 19 |
#include "color.h"
| 20 |
#include "paths.h"
| 21 |
| 22 |
#define PI 3.14159265358979323846
| 23 |
/* floating comparisons */
| 24 |
#define FTINY 1e-6
| 25 |
#define FEQ(a,b) ((a)<=(b)+FTINY&&(a)>=(b)-FTINY)
| 26 |
/* keywords */
| 27 |
#define MAGICID "IESNA"
| 28 |
#define LMAGICID 5
| 29 |
#define FIRSTREV 86
| 30 |
#define LASTREV 95
| 31 |
| 32 |
#define D86 0 /* keywords defined in LM-63-1986 */
| 33 |
| 34 |
#define K_TST 0
| 35 |
#define K_MAN 1
| 36 |
#define K_LMC 2
| 37 |
#define K_LMN 3
| 38 |
#define K_LPC 4
| 39 |
#define K_LMP 5
| 40 |
#define K_BAL 6
| 41 |
#define K_MTC 7
| 42 |
#define K_OTH 8
| 43 |
#define K_SCH 9
| 44 |
#define K_MOR 10
| 45 |
#define K_BLK 11
| 46 |
#define K_EBK 12
| 47 |
| 48 |
#define D91 ((1L<<13)-1) /* keywords defined in LM-63-1991 */
| 49 |
| 50 |
#define K_LMG 13
| 51 |
| 52 |
#define D95 ((1L<<14)-1) /* keywords defined in LM-63-1995 */
| 53 |
| 54 |
char k_kwd[][20] = {"TEST", "MANUFAC", "LUMCAT", "LUMINAIRE", "LAMPCAT",
| 55 |
"LAMP", "BALLAST", "MAINTCAT", "OTHER", "SEARCH",
| 56 |
"MORE", "BLOCK", "ENDBLOCK", "LUMINOUSGEOMETRY"};
| 57 |
| 58 |
long k_defined[] = {D86, D86, D86, D86, D86, D91, D91, D91, D91, D95};
| 59 |
| 60 |
int filerev = FIRSTREV;
| 61 |
| 62 |
#define keymatch(i,s) (k_defined[filerev-FIRSTREV]&1L<<(i) &&\
| 63 |
k_match(k_kwd[i],s))
| 64 |
| 65 |
#define checklamp(s) (!(k_defined[filerev-FIRSTREV]&(1<<K_LMP|1<<K_LPC)) ||\
| 66 |
keymatch(K_LMP,s) || keymatch(K_LPC,s))
| 67 |
| 68 |
/* tilt specs */
| 69 |
#define TLTSTR "TILT="
| 70 |
#define TLTSTRLEN 5
| 71 |
#define TLTNONE "NONE"
| 72 |
#define TLTINCL "INCLUDE"
| 73 |
#define TLT_VERT 1
| 74 |
#define TLT_H0 2
| 75 |
#define TLT_H90 3
| 76 |
/* photometric types */
| 77 |
#define PM_C 1
| 78 |
#define PM_B 2
| 79 |
#define PM_A 3
| 80 |
/* unit types */
| 81 |
#define U_FEET 1
| 82 |
#define U_METERS 2
| 83 |
/* string lengths */
| 84 |
#define MAXLINE 132
| 85 |
#define RMAXWORD 76
| 86 |
/* file types */
| 87 |
#define T_RAD ".rad"
| 88 |
#define T_DST ".dat"
| 89 |
#define T_TLT "%.dat"
| 90 |
#define T_OCT ".oct"
| 91 |
/* shape types */
| 92 |
#define RECT 1
| 93 |
#define DISK 2
| 94 |
#define SPHERE 3
| 95 |
| 96 |
#define MINDIM .001 /* minimum dimension (point source) */
| 97 |
| 98 |
#define F_M .3048 /* feet to meters */
| 99 |
| 100 |
#define abspath(p) (ISDIRSEP((p)[0]) || (p)[0] == '.')
| 101 |
| 102 |
static char default_name[] = "default";
| 103 |
| 104 |
char *libdir = NULL; /* library directory location */
| 105 |
char *prefdir = NULL; /* subdirectory */
| 106 |
char *lampdat = "lamp.tab"; /* lamp data file */
| 107 |
| 108 |
double meters2out = 1.0; /* conversion from meters to output */
| 109 |
char *lamptype = NULL; /* selected lamp type */
| 110 |
char *deflamp = NULL; /* default lamp type */
| 111 |
float defcolor[3] = {1.,1.,1.}; /* default lamp color */
| 112 |
float *lampcolor = defcolor; /* pointer to current lamp color */
| 113 |
double multiplier = 1.0; /* multiplier for all light sources */
| 114 |
char units[64] = "meters"; /* output units */
| 115 |
int out2stdout = 0; /* put out to stdout r.t. file */
| 116 |
int instantiate = 0; /* instantiate geometry */
| 117 |
double illumrad = 0.0; /* radius for illum sphere */
| 118 |
| 119 |
typedef struct {
| 120 |
int isillum; /* do as illum */
| 121 |
int type; /* RECT, DISK, SPHERE */
| 122 |
double mult; /* candela multiplier */
| 123 |
double w, l, h; /* width, length, height */
| 124 |
double area; /* max. projected area */
| 125 |
} SRCINFO; /* a source shape (units=meters) */
| 126 |
| 127 |
int gargc; /* global argc (minus filenames) */
| 128 |
char **gargv; /* global argv */
| 129 |
| 130 |
| 131 |
#define scnint(fp,ip) cvtint(ip,getword(fp))
| 132 |
#define scnflt(fp,rp) cvtflt(rp,getword(fp))
| 133 |
#define isint isflt /* IES allows real as integer */
| 134 |
| 135 |
| 136 |
static int ies2rad(char *inpname, char *outname);
| 137 |
static void initlamps(void);
| 138 |
static int dosource(SRCINFO *sinf, FILE *in, FILE *out, char *mod, char *name);
| 139 |
static int dotilt(FILE *in, FILE *out, char *dir, char *tltspec,
| 140 |
char *dfltname, char *tltid);
| 141 |
static int cvgeometry(char *inpname, SRCINFO *sinf, char *outname, FILE *outfp);
| 142 |
static int cvtint(int *ip, char *wrd);
| 143 |
static int cvdata(FILE *in, FILE *out, int ndim, int npts[], double mult,
| 144 |
double lim[][2]);
| 145 |
static int cvtflt(double *rp, char *wrd);
| 146 |
static int makeshape(SRCINFO *shp, double width, double length, double height);
| 147 |
static int putsource(SRCINFO *shp, FILE *fp, char *mod, char *name,
| 148 |
int dolower, int doupper, int dosides);
| 149 |
static void putrectsrc(SRCINFO *shp, FILE *fp, char *mod, char *name, int up);
| 150 |
static void putsides(SRCINFO *shp, FILE *fp, char *mod, char *name);
| 151 |
static void putdisksrc(SRCINFO *shp, FILE *fp, char *mod, char *name, int up);
| 152 |
static void putspheresrc(SRCINFO *shp, FILE *fp, char *mod, char *name);
| 153 |
static void putrect(SRCINFO *shp, FILE *fp, char *mod, char *name, char *suffix,
| 154 |
int a, int b, int c, int d);
| 155 |
static void putpoint(SRCINFO *shp, FILE *fp, int p);
| 156 |
static void putcyl(SRCINFO *shp, FILE *fp, char *mod, char *name);
| 157 |
static char * tailtrunc(char *name);
| 158 |
static char * filename(char *path);
| 159 |
static char * libname(char *path, char *fname, char *suffix);
| 160 |
static char * getword(FILE *fp);
| 161 |
static char * fullnam(char *path, char *fname, char *suffix);
| 162 |
| 163 |
| 164 |
int
| 165 |
main(
| 166 |
int argc,
| 167 |
char *argv[]
| 168 |
| 169 |
| 170 |
char *outfile = NULL;
| 171 |
int status;
| 172 |
char outname[RMAXWORD];
| 173 |
double d1;
| 174 |
int i;
| 175 |
| 176 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 177 |
switch (argv[i][1]) {
| 178 |
case 'd': /* dimensions */
| 179 |
if (argv[i][2] == '\0')
| 180 |
goto badopt;
| 181 |
if (argv[i][3] == '\0')
| 182 |
d1 = 1.0;
| 183 |
else if (argv[i][3] == '/') {
| 184 |
d1 = atof(argv[i]+4);
| 185 |
if (d1 <= FTINY)
| 186 |
goto badopt;
| 187 |
} else
| 188 |
goto badopt;
| 189 |
switch (argv[i][2]) {
| 190 |
case 'c': /* centimeters */
| 191 |
if (FEQ(d1,10.))
| 192 |
strcpy(units,"millimeters");
| 193 |
else {
| 194 |
strcpy(units,"centimeters");
| 195 |
strcat(units,argv[i]+3);
| 196 |
| 197 |
meters2out = 100.*d1;
| 198 |
break;
| 199 |
case 'm': /* meters */
| 200 |
if (FEQ(d1,1000.))
| 201 |
| 202 |
else if (FEQ(d1,100.))
| 203 |
| 204 |
else {
| 205 |
strcpy(units,"meters");
| 206 |
| 207 |
| 208 |
meters2out = d1;
| 209 |
break;
| 210 |
case 'i': /* inches */
| 211 |
strcpy(units,"inches");
| 212 |
| 213 |
meters2out = d1*(12./F_M);
| 214 |
break;
| 215 |
case 'f': /* feet */
| 216 |
if (FEQ(d1,12.))
| 217 |
| 218 |
else {
| 219 |
strcpy(units,"feet");
| 220 |
| 221 |
| 222 |
meters2out = d1/F_M;
| 223 |
break;
| 224 |
default:
| 225 |
goto badopt;
| 226 |
| 227 |
break;
| 228 |
case 'l': /* library directory */
| 229 |
libdir = argv[++i];
| 230 |
break;
| 231 |
case 'p': /* prefix subdirectory */
| 232 |
prefdir = argv[++i];
| 233 |
break;
| 234 |
case 'f': /* lamp data file */
| 235 |
lampdat = argv[++i];
| 236 |
break;
| 237 |
case 'o': /* output file root name */
| 238 |
outfile = argv[++i];
| 239 |
break;
| 240 |
case 's': /* output to stdout */
| 241 |
out2stdout = !out2stdout;
| 242 |
break;
| 243 |
case 'i': /* illum */
| 244 |
illumrad = atof(argv[++i]);
| 245 |
break;
| 246 |
case 'g': /* instatiate geometry? */
| 247 |
instantiate = !instantiate;
| 248 |
break;
| 249 |
case 't': /* override lamp type */
| 250 |
lamptype = argv[++i];
| 251 |
break;
| 252 |
case 'u': /* default lamp type */
| 253 |
deflamp = argv[++i];
| 254 |
break;
| 255 |
case 'c': /* default lamp color */
| 256 |
defcolor[0] = atof(argv[++i]);
| 257 |
defcolor[1] = atof(argv[++i]);
| 258 |
defcolor[2] = atof(argv[++i]);
| 259 |
break;
| 260 |
case 'm': /* multiplier */
| 261 |
multiplier = atof(argv[++i]);
| 262 |
break;
| 263 |
default:
| 264 |
badopt:
| 265 |
fprintf(stderr, "%s: bad option: %s\n",
| 266 |
argv[0], argv[i]);
| 267 |
exit(1);
| 268 |
| 269 |
gargc = i;
| 270 |
gargv = argv;
| 271 |
initlamps(); /* get lamp data (if needed) */
| 272 |
/* convert ies file(s) */
| 273 |
if (outfile != NULL) {
| 274 |
if (i == argc)
| 275 |
exit(ies2rad(NULL, outfile) == 0 ? 0 : 1);
| 276 |
else if (i == argc-1)
| 277 |
exit(ies2rad(argv[i], outfile) == 0 ? 0 : 1);
| 278 |
else
| 279 |
goto needsingle;
| 280 |
} else if (i >= argc) {
| 281 |
fprintf(stderr, "%s: missing output file specification\n",
| 282 |
argv[0]);
| 283 |
exit(1);
| 284 |
| 285 |
if (out2stdout && i != argc-1)
| 286 |
goto needsingle;
| 287 |
status = 0;
| 288 |
for ( ; i < argc; i++) {
| 289 |
tailtrunc(strcpy(outname,filename(argv[i])));
| 290 |
if (ies2rad(argv[i], outname) != 0)
| 291 |
status = 1;
| 292 |
| 293 |
exit(status);
| 294 |
needsingle:
| 295 |
fprintf(stderr, "%s: single input file required\n", argv[0]);
| 296 |
exit(1);
| 297 |
| 298 |
| 299 |
void
| 300 |
initlamps(void) /* set up lamps */
| 301 |
| 302 |
float *lcol;
| 303 |
int status;
| 304 |
| 305 |
if (lamptype != NULL && !strcmp(lamptype, default_name) &&
| 306 |
deflamp == NULL)
| 307 |
return; /* no need for data */
| 308 |
/* else load file */
| 309 |
if ((status = loadlamps(lampdat)) < 0)
| 310 |
exit(1);
| 311 |
if (status == 0) {
| 312 |
fprintf(stderr, "%s: warning - no lamp data\n", lampdat);
| 313 |
lamptype = default_name;
| 314 |
return;
| 315 |
| 316 |
if (deflamp != NULL) { /* match default type */
| 317 |
if ((lcol = matchlamp(deflamp)) == NULL)
| 318 |
fprintf(stderr,
| 319 |
"%s: warning - unknown default lamp type\n",
| 320 |
deflamp);
| 321 |
else
| 322 |
copycolor(defcolor, lcol);
| 323 |
| 324 |
if (lamptype != NULL) { /* match selected type */
| 325 |
if (strcmp(lamptype, default_name)) {
| 326 |
if ((lcol = matchlamp(lamptype)) == NULL) {
| 327 |
fprintf(stderr,
| 328 |
"%s: warning - unknown lamp type\n",
| 329 |
lamptype);
| 330 |
| 331 |
} else
| 332 |
| 333 |
| 334 |
freelamps(); /* all done with data */
| 335 |
| 336 |
/* else keep lamp data */
| 337 |
| 338 |
| 339 |
| 340 |
char *
| 341 |
stradd( /* add a string at dst */
| 342 |
char *dst,
| 343 |
char *src,
| 344 |
int sep
| 345 |
| 346 |
| 347 |
if (src && *src) {
| 348 |
do
| 349 |
*dst++ = *src++;
| 350 |
while (*src);
| 351 |
if (sep && dst[-1] != sep)
| 352 |
*dst++ = sep;
| 353 |
| 354 |
*dst = '\0';
| 355 |
return(dst);
| 356 |
| 357 |
| 358 |
| 359 |
char *
| 360 |
fullnam( /* return full path name */
| 361 |
char *path,
| 362 |
char *fname,
| 363 |
char *suffix
| 364 |
| 365 |
| 366 |
if (prefdir != NULL && abspath(prefdir))
| 367 |
libname(path, fname, suffix);
| 368 |
else if (abspath(fname))
| 369 |
strcpy(stradd(path, fname, 0), suffix);
| 370 |
else
| 371 |
libname(stradd(path, libdir, DIRSEP), fname, suffix);
| 372 |
| 373 |
return(path);
| 374 |
| 375 |
| 376 |
| 377 |
char *
| 378 |
libname( /* return library relative name */
| 379 |
char *path,
| 380 |
char *fname,
| 381 |
char *suffix
| 382 |
| 383 |
| 384 |
if (abspath(fname))
| 385 |
| 386 |
else
| 387 |
strcpy(stradd(stradd(path, prefdir, DIRSEP), fname, 0), suffix);
| 388 |
| 389 |
return(path);
| 390 |
| 391 |
| 392 |
| 393 |
char *
| 394 |
filename( /* get final component of pathname */
| 395 |
char *path
| 396 |
| 397 |
| 398 |
char *cp;
| 399 |
| 400 |
for (cp = path; *path; path++)
| 401 |
if (ISDIRSEP(*path))
| 402 |
cp = path+1;
| 403 |
return(cp);
| 404 |
| 405 |
| 406 |
| 407 |
char *
| 408 |
filetrunc( /* truncate filename at end of path */
| 409 |
char *path
| 410 |
| 411 |
| 412 |
char *p1, *p2;
| 413 |
| 414 |
for (p1 = p2 = path; *p2; p2++)
| 415 |
if (ISDIRSEP(*p2))
| 416 |
p1 = p2;
| 417 |
if (p1 == path && ISDIRSEP(*p1))
| 418 |
p1++;
| 419 |
*p1 = '\0';
| 420 |
return(path);
| 421 |
| 422 |
| 423 |
| 424 |
char *
| 425 |
tailtrunc( /* truncate tail of filename */
| 426 |
char *name
| 427 |
| 428 |
| 429 |
char *p1, *p2;
| 430 |
| 431 |
for (p1 = filename(name); *p1 == '.'; p1++)
| 432 |
| 433 |
p2 = NULL;
| 434 |
for ( ; *p1; p1++)
| 435 |
if (*p1 == '.')
| 436 |
p2 = p1;
| 437 |
if (p2 != NULL)
| 438 |
*p2 = '\0';
| 439 |
return(name);
| 440 |
| 441 |
| 442 |
| 443 |
void
| 444 |
blanktrunc( /* truncate spaces at end of line */
| 445 |
char *s
| 446 |
| 447 |
| 448 |
char *cp;
| 449 |
| 450 |
for (cp = s; *cp; cp++)
| 451 |
| 452 |
while (cp-- > s && isspace(*cp))
| 453 |
| 454 |
*++cp = '\0';
| 455 |
| 456 |
| 457 |
| 458 |
int
| 459 |
k_match( /* header line matches keyword? */
| 460 |
char *kwd,
| 461 |
char *hdl
| 462 |
| 463 |
| 464 |
if (*hdl++ != '[')
| 465 |
return(0);
| 466 |
while (islower(*hdl) ? toupper(*hdl) == *kwd++ : *hdl == *kwd++)
| 467 |
if (!*hdl++)
| 468 |
return(0);
| 469 |
return((!*kwd) & (*hdl == ']'));
| 470 |
| 471 |
| 472 |
| 473 |
char *
| 474 |
keyargs( /* return keyword arguments */
| 475 |
char *hdl
| 476 |
| 477 |
| 478 |
while (*hdl && *hdl++ != ']')
| 479 |
| 480 |
while (isspace(*hdl))
| 481 |
hdl++;
| 482 |
return(hdl);
| 483 |
| 484 |
| 485 |
| 486 |
void
| 487 |
putheader( /* print header */
| 488 |
FILE *out
| 489 |
| 490 |
| 491 |
int i;
| 492 |
| 493 |
putc('#', out);
| 494 |
for (i = 0; i < gargc; i++) {
| 495 |
putc(' ', out);
| 496 |
fputs(gargv[i], out);
| 497 |
| 498 |
fputs("\n# Dimensions in ", out);
| 499 |
fputs(units, out);
| 500 |
putc('\n', out);
| 501 |
| 502 |
| 503 |
| 504 |
int
| 505 |
ies2rad( /* convert IES file */
| 506 |
char *inpname,
| 507 |
char *outname
| 508 |
| 509 |
| 510 |
SRCINFO srcinfo;
| 511 |
char buf[MAXLINE], tltid[RMAXWORD];
| 512 |
char geomfile[128];
| 513 |
FILE *inpfp, *outfp;
| 514 |
int lineno = 0;
| 515 |
| 516 |
geomfile[0] = '\0';
| 517 |
srcinfo.isillum = 0;
| 518 |
if (inpname == NULL) {
| 519 |
inpname = "<stdin>";
| 520 |
inpfp = stdin;
| 521 |
} else if ((inpfp = fopen(inpname, "r")) == NULL) {
| 522 |
perror(inpname);
| 523 |
return(-1);
| 524 |
| 525 |
if (out2stdout)
| 526 |
outfp = stdout;
| 527 |
else if ((outfp = fopen(fullnam(buf,outname,T_RAD), "w")) == NULL) {
| 528 |
perror(buf);
| 529 |
fclose(inpfp);
| 530 |
return(-1);
| 531 |
| 532 |
putheader(outfp);
| 533 |
if (lamptype == NULL)
| 534 |
lampcolor = NULL;
| 535 |
while (fgets(buf,sizeof(buf),inpfp) != NULL
| 536 |
&& strncmp(buf,TLTSTR,TLTSTRLEN)) {
| 537 |
blanktrunc(buf);
| 538 |
if (!buf[0])
| 539 |
continue;
| 540 |
if (!lineno++ && !strncmp(buf, MAGICID, LMAGICID)) {
| 541 |
filerev = atoi(buf+LMAGICID);
| 542 |
if (filerev < FIRSTREV)
| 543 |
filerev = FIRSTREV;
| 544 |
else if (filerev > LASTREV)
| 545 |
filerev = LASTREV;
| 546 |
| 547 |
fputs("#<", outfp);
| 548 |
fputs(buf, outfp);
| 549 |
putc('\n', outfp);
| 550 |
if (lampcolor == NULL && checklamp(buf))
| 551 |
lampcolor = matchlamp( buf[0] == '[' ?
| 552 |
keyargs(buf) : buf );
| 553 |
if (keymatch(K_LMG, buf)) { /* geometry file */
| 554 |
strcpy(geomfile, inpname);
| 555 |
strcpy(filename(geomfile), keyargs(buf));
| 556 |
srcinfo.isillum = 1;
| 557 |
| 558 |
| 559 |
if (lampcolor == NULL) {
| 560 |
fprintf(stderr, "%s: warning - no lamp type\n", inpname);
| 561 |
fputs("# Unknown lamp type (used default)\n", outfp);
| 562 |
| 563 |
} else if (lamptype == NULL)
| 564 |
fprintf(outfp,"# CIE(x,y) = (%f,%f)\n# Depreciation = %.1f%%\n",
| 565 |
lampcolor[3], lampcolor[4], 100.*lampcolor[5]);
| 566 |
if (feof(inpfp)) {
| 567 |
fprintf(stderr, "%s: not in IES format\n", inpname);
| 568 |
goto readerr;
| 569 |
| 570 |
atos(tltid, RMAXWORD, buf+TLTSTRLEN);
| 571 |
if (inpfp == stdin)
| 572 |
buf[0] = '\0';
| 573 |
else
| 574 |
filetrunc(strcpy(buf, inpname));
| 575 |
if (dotilt(inpfp, outfp, buf, tltid, outname, tltid) != 0) {
| 576 |
fprintf(stderr, "%s: bad tilt data\n", inpname);
| 577 |
goto readerr;
| 578 |
| 579 |
if (dosource(&srcinfo, inpfp, outfp, tltid, outname) != 0) {
| 580 |
fprintf(stderr, "%s: bad luminaire data\n", inpname);
| 581 |
goto readerr;
| 582 |
| 583 |
fclose(inpfp);
| 584 |
/* cvgeometry closes outfp */
| 585 |
if (cvgeometry(geomfile, &srcinfo, outname, outfp) != 0) {
| 586 |
fprintf(stderr, "%s: bad geometry file\n", geomfile);
| 587 |
return(-1);
| 588 |
| 589 |
return(0);
| 590 |
readerr:
| 591 |
fclose(inpfp);
| 592 |
fclose(outfp);
| 593 |
unlink(fullnam(buf,outname,T_RAD));
| 594 |
return(-1);
| 595 |
| 596 |
| 597 |
| 598 |
int
| 599 |
dotilt( /* convert tilt data */
| 600 |
FILE *in,
| 601 |
FILE *out,
| 602 |
char *dir,
| 603 |
char *tltspec,
| 604 |
char *dfltname,
| 605 |
char *tltid
| 606 |
| 607 |
| 608 |
int nangles, tlt_type;
| 609 |
double minmax[1][2];
| 610 |
char buf[PATH_MAX], tltname[RMAXWORD];
| 611 |
FILE *datin, *datout;
| 612 |
| 613 |
if (!strcmp(tltspec, TLTNONE)) {
| 614 |
datin = NULL;
| 615 |
strcpy(tltid, "void");
| 616 |
} else if (!strcmp(tltspec, TLTINCL)) {
| 617 |
datin = in;
| 618 |
strcpy(tltname, dfltname);
| 619 |
} else {
| 620 |
if (ISDIRSEP(tltspec[0]))
| 621 |
strcpy(buf, tltspec);
| 622 |
else
| 623 |
strcpy(stradd(buf, dir, DIRSEP), tltspec);
| 624 |
if ((datin = fopen(buf, "r")) == NULL) {
| 625 |
perror(buf);
| 626 |
return(-1);
| 627 |
| 628 |
tailtrunc(strcpy(tltname,filename(tltspec)));
| 629 |
| 630 |
if (datin != NULL) {
| 631 |
if ((datout = fopen(fullnam(buf,tltname,T_TLT),"w")) == NULL) {
| 632 |
perror(buf);
| 633 |
if (datin != in)
| 634 |
fclose(datin);
| 635 |
return(-1);
| 636 |
| 637 |
if (!scnint(datin,&tlt_type) || !scnint(datin,&nangles)
| 638 |
|| cvdata(datin,datout,1,&nangles,1.,minmax) != 0) {
| 639 |
fprintf(stderr, "%s: data format error\n", tltspec);
| 640 |
fclose(datout);
| 641 |
if (datin != in)
| 642 |
fclose(datin);
| 643 |
unlink(fullnam(buf,tltname,T_TLT));
| 644 |
return(-1);
| 645 |
| 646 |
fclose(datout);
| 647 |
if (datin != in)
| 648 |
fclose(datin);
| 649 |
strcat(strcpy(tltid, filename(tltname)), "_tilt");
| 650 |
fprintf(out, "\nvoid brightdata %s\n", tltid);
| 651 |
libname(buf,tltname,T_TLT);
| 652 |
switch (tlt_type) {
| 653 |
case TLT_VERT: /* vertical */
| 654 |
fprintf(out, "4 noop %s tilt.cal %s\n", buf,
| 655 |
minmax[0][1]>90.+FTINY ? "tilt_ang" : "tilt_ang2");
| 656 |
break;
| 657 |
case TLT_H0: /* horiz. in 0 deg. plane */
| 658 |
fprintf(out, "6 noop %s tilt.cal %s -rz 90\n", buf,
| 659 |
minmax[0][1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
| 660 |
break;
| 661 |
case TLT_H90:
| 662 |
| 663 |
| 664 |
break;
| 665 |
default:
| 666 |
fprintf(stderr,
| 667 |
"%s: illegal lamp to luminaire geometry (%d)\n",
| 668 |
tltspec, tlt_type);
| 669 |
return(-1);
| 670 |
| 671 |
fprintf(out, "0\n0\n");
| 672 |
| 673 |
return(0);
| 674 |
| 675 |
| 676 |
| 677 |
int
| 678 |
dosource( /* create source and distribution */
| 679 |
SRCINFO *sinf,
| 680 |
FILE *in,
| 681 |
FILE *out,
| 682 |
char *mod,
| 683 |
char *name
| 684 |
| 685 |
| 686 |
char buf[PATH_MAX], id[RMAXWORD];
| 687 |
FILE *datout;
| 688 |
double mult, bfactor, pfactor, width, length, height, wattage;
| 689 |
double bounds[2][2];
| 690 |
int nangles[2], pmtype, unitype;
| 691 |
double d1;
| 692 |
int doupper, dolower, dosides;
| 693 |
| 694 |
if (!isint(getword(in)) || !isflt(getword(in)) || !scnflt(in,&mult)
| 695 |
|| !scnint(in,&nangles[0]) || !scnint(in,&nangles[1])
| 696 |
|| !scnint(in,&pmtype) || !scnint(in,&unitype)
| 697 |
|| !scnflt(in,&width) || !scnflt(in,&length)
| 698 |
|| !scnflt(in,&height) || !scnflt(in,&bfactor)
| 699 |
|| !scnflt(in,&pfactor) || !scnflt(in,&wattage)) {
| 700 |
fprintf(stderr, "dosource: bad lamp specification\n");
| 701 |
return(-1);
| 702 |
| 703 |
if (pmtype != PM_C && pmtype != PM_B) {
| 704 |
fprintf(stderr, "dosource: unsupported photometric type (%d)\n",
| 705 |
pmtype);
| 706 |
return(-1);
| 707 |
| 708 |
sinf->mult = multiplier*mult*bfactor*pfactor;
| 709 |
if (nangles[0] < 2 || nangles[1] < 1) {
| 710 |
fprintf(stderr, "dosource: too few measured angles\n");
| 711 |
return(-1);
| 712 |
| 713 |
if (unitype == U_FEET) {
| 714 |
width *= F_M;
| 715 |
length *= F_M;
| 716 |
height *= F_M;
| 717 |
| 718 |
if (makeshape(sinf, width, length, height) != 0) {
| 719 |
fprintf(stderr, "dosource: illegal source dimensions");
| 720 |
return(-1);
| 721 |
| 722 |
if ((datout = fopen(fullnam(buf,name,T_DST), "w")) == NULL) {
| 723 |
perror(buf);
| 724 |
return(-1);
| 725 |
| 726 |
if (cvdata(in, datout, 2, nangles, 1./WHTEFFICACY, bounds) != 0) {
| 727 |
fprintf(stderr, "dosource: bad distribution data\n");
| 728 |
fclose(datout);
| 729 |
unlink(fullnam(buf,name,T_DST));
| 730 |
return(-1);
| 731 |
| 732 |
fclose(datout);
| 733 |
fprintf(out, "# %g watt luminaire, lamp*ballast factor = %g\n",
| 734 |
wattage, bfactor*pfactor);
| 735 |
strcat(strcpy(id, filename(name)), "_dist");
| 736 |
fprintf(out, "\n%s brightdata %s\n", mod, id);
| 737 |
if (nangles[1] < 2)
| 738 |
fprintf(out, "4 ");
| 739 |
else if (pmtype == PM_B)
| 740 |
fprintf(out, "5 ");
| 741 |
else if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
| 742 |
fprintf(out, "7 ");
| 743 |
else
| 744 |
fprintf(out, "5 ");
| 745 |
dolower = (bounds[0][0] < 90.-FTINY);
| 746 |
doupper = (bounds[0][1] > 90.+FTINY);
| 747 |
dosides = (doupper & dolower && sinf->h > MINDIM);
| 748 |
fprintf(out, "%s %s source.cal ",
| 749 |
sinf->type==SPHERE ? "corr" :
| 750 |
!dosides ? "flatcorr" :
| 751 |
sinf->type==DISK ? "cylcorr" : "boxcorr",
| 752 |
libname(buf,name,T_DST));
| 753 |
if (pmtype == PM_B) {
| 754 |
if (FEQ(bounds[1][0],0.))
| 755 |
fprintf(out, "srcB_horiz2 ");
| 756 |
else
| 757 |
fprintf(out, "srcB_horiz ");
| 758 |
fprintf(out, "srcB_vert ");
| 759 |
} else /* pmtype == PM_C */ {
| 760 |
if (nangles[1] >= 2) {
| 761 |
d1 = bounds[1][1] - bounds[1][0];
| 762 |
if (d1 <= 90.+FTINY)
| 763 |
fprintf(out, "src_phi4 ");
| 764 |
else if (d1 <= 180.+FTINY) {
| 765 |
if (FEQ(bounds[1][0],90.))
| 766 |
fprintf(out, "src_phi2+90 ");
| 767 |
else
| 768 |
fprintf(out, "src_phi2 ");
| 769 |
} else
| 770 |
fprintf(out, "src_phi ");
| 771 |
fprintf(out, "src_theta ");
| 772 |
| 773 |
fprintf(out, "-rz -90 ");
| 774 |
} else
| 775 |
| 776 |
| 777 |
if (!dosides || sinf->type == SPHERE)
| 778 |
fprintf(out, "\n0\n1 %g\n", sinf->mult/sinf->area);
| 779 |
else if (sinf->type == DISK)
| 780 |
fprintf(out, "\n0\n3 %g %g %g\n", sinf->mult,
| 781 |
sinf->w, sinf->h);
| 782 |
else
| 783 |
fprintf(out, "\n0\n4 %g %g %g %g\n", sinf->mult,
| 784 |
sinf->l, sinf->w, sinf->h);
| 785 |
if (putsource(sinf, out, id, filename(name),
| 786 |
dolower, doupper, dosides) != 0)
| 787 |
return(-1);
| 788 |
return(0);
| 789 |
| 790 |
| 791 |
| 792 |
int
| 793 |
putsource( /* put out source */
| 794 |
SRCINFO *shp,
| 795 |
FILE *fp,
| 796 |
char *mod,
| 797 |
char *name,
| 798 |
int dolower,
| 799 |
int doupper,
| 800 |
int dosides
| 801 |
| 802 |
| 803 |
char lname[RMAXWORD];
| 804 |
| 805 |
strcat(strcpy(lname, name), "_light");
| 806 |
fprintf(fp, "\n%s %s %s\n", mod,
| 807 |
shp->isillum ? "illum" : "light", lname);
| 808 |
fprintf(fp, "0\n0\n3 %g %g %g\n",
| 809 |
lampcolor[0], lampcolor[1], lampcolor[2]);
| 810 |
switch (shp->type) {
| 811 |
case RECT:
| 812 |
if (dolower)
| 813 |
putrectsrc(shp, fp, lname, name, 0);
| 814 |
if (doupper)
| 815 |
putrectsrc(shp, fp, lname, name, 1);
| 816 |
if (dosides)
| 817 |
putsides(shp, fp, lname, name);
| 818 |
break;
| 819 |
case DISK:
| 820 |
if (dolower)
| 821 |
putdisksrc(shp, fp, lname, name, 0);
| 822 |
if (doupper)
| 823 |
putdisksrc(shp, fp, lname, name, 1);
| 824 |
if (dosides)
| 825 |
putcyl(shp, fp, lname, name);
| 826 |
break;
| 827 |
case SPHERE:
| 828 |
putspheresrc(shp, fp, lname, name);
| 829 |
break;
| 830 |
| 831 |
return(0);
| 832 |
| 833 |
| 834 |
| 835 |
int
| 836 |
makeshape( /* make source shape */
| 837 |
SRCINFO *shp,
| 838 |
double width,
| 839 |
double length,
| 840 |
double height
| 841 |
| 842 |
| 843 |
if (illumrad/meters2out >= MINDIM/2.) {
| 844 |
shp->isillum = 1;
| 845 |
shp->type = SPHERE;
| 846 |
shp->w = shp->l = shp->h = 2.*illumrad / meters2out;
| 847 |
} else if (width < MINDIM) {
| 848 |
width = -width;
| 849 |
| 850 |
shp->type = SPHERE;
| 851 |
shp->w = shp->l = shp->h = MINDIM;
| 852 |
} else if (height < .5*width) {
| 853 |
shp->type = DISK;
| 854 |
shp->w = shp->l = width;
| 855 |
if (height >= MINDIM)
| 856 |
shp->h = height;
| 857 |
else
| 858 |
shp->h = .5*MINDIM;
| 859 |
} else {
| 860 |
shp->type = SPHERE;
| 861 |
shp->w = shp->l = shp->h = width;
| 862 |
| 863 |
} else {
| 864 |
shp->type = RECT;
| 865 |
shp->w = width;
| 866 |
if (length >= MINDIM)
| 867 |
shp->l = length;
| 868 |
else
| 869 |
shp->l = MINDIM;
| 870 |
| 871 |
shp->h = height;
| 872 |
else
| 873 |
shp->h = .5*MINDIM;
| 874 |
| 875 |
| 876 |
case RECT:
| 877 |
shp->area = shp->w * shp->l;
| 878 |
break;
| 879 |
case DISK:
| 880 |
case SPHERE:
| 881 |
shp->area = PI/4. * shp->w * shp->w;
| 882 |
break;
| 883 |
| 884 |
return(0);
| 885 |
| 886 |
| 887 |
| 888 |
void
| 889 |
putrectsrc( /* rectangular source */
| 890 |
SRCINFO *shp,
| 891 |
FILE *fp,
| 892 |
char *mod,
| 893 |
char *name,
| 894 |
int up
| 895 |
| 896 |
| 897 |
if (up)
| 898 |
putrect(shp, fp, mod, name, ".u", 4, 5, 7, 6);
| 899 |
else
| 900 |
putrect(shp, fp, mod, name, ".d", 0, 2, 3, 1);
| 901 |
| 902 |
| 903 |
| 904 |
void
| 905 |
putsides( /* put out sides of box */
| 906 |
SRCINFO *shp,
| 907 |
FILE *fp,
| 908 |
char *mod,
| 909 |
char *name
| 910 |
| 911 |
| 912 |
putrect(shp, fp, mod, name, ".1", 0, 1, 5, 4);
| 913 |
putrect(shp, fp, mod, name, ".2", 1, 3, 7, 5);
| 914 |
putrect(shp, fp, mod, name, ".3", 3, 2, 6, 7);
| 915 |
putrect(shp, fp, mod, name, ".4", 2, 0, 4, 6);
| 916 |
| 917 |
| 918 |
| 919 |
void
| 920 |
putrect( /* put out a rectangle */
| 921 |
SRCINFO *shp,
| 922 |
FILE *fp,
| 923 |
char *mod,
| 924 |
char *name,
| 925 |
char *suffix,
| 926 |
int a,
| 927 |
int b,
| 928 |
int c,
| 929 |
int d
| 930 |
| 931 |
| 932 |
fprintf(fp, "\n%s polygon %s%s\n0\n0\n12\n", mod, name, suffix);
| 933 |
putpoint(shp, fp, a);
| 934 |
putpoint(shp, fp, b);
| 935 |
putpoint(shp, fp, c);
| 936 |
putpoint(shp, fp, d);
| 937 |
| 938 |
| 939 |
| 940 |
void
| 941 |
putpoint( /* put out a point */
| 942 |
SRCINFO *shp,
| 943 |
FILE *fp,
| 944 |
int p
| 945 |
| 946 |
| 947 |
static double mult[2] = {-.5, .5};
| 948 |
| 949 |
fprintf(fp, "\t%g\t%g\t%g\n",
| 950 |
mult[p&1]*shp->l*meters2out,
| 951 |
mult[p>>1&1]*shp->w*meters2out,
| 952 |
mult[p>>2]*shp->h*meters2out);
| 953 |
| 954 |
| 955 |
| 956 |
void
| 957 |
putdisksrc( /* put out a disk source */
| 958 |
SRCINFO *shp,
| 959 |
FILE *fp,
| 960 |
char *mod,
| 961 |
char *name,
| 962 |
int up
| 963 |
| 964 |
| 965 |
if (up) {
| 966 |
fprintf(fp, "\n%s ring %s.u\n", mod, name);
| 967 |
fprintf(fp, "0\n0\n8\n");
| 968 |
fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
| 969 |
fprintf(fp, "\t0 0 1\n");
| 970 |
fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
| 971 |
} else {
| 972 |
fprintf(fp, "\n%s ring %s.d\n", mod, name);
| 973 |
| 974 |
fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
| 975 |
fprintf(fp, "\t0 0 -1\n");
| 976 |
| 977 |
| 978 |
| 979 |
| 980 |
| 981 |
void
| 982 |
putcyl( /* put out a cylinder */
| 983 |
SRCINFO *shp,
| 984 |
FILE *fp,
| 985 |
char *mod,
| 986 |
char *name
| 987 |
| 988 |
| 989 |
fprintf(fp, "\n%s cylinder %s.c\n", mod, name);
| 990 |
fprintf(fp, "0\n0\n7\n");
| 991 |
| 992 |
| 993 |
fprintf(fp, "\t%g\n", .5*shp->w*meters2out);
| 994 |
| 995 |
| 996 |
| 997 |
void
| 998 |
putspheresrc( /* put out a sphere source */
| 999 |
SRCINFO *shp,
| 1000 |
FILE *fp,
| 1001 |
char *mod,
| 1002 |
char *name
| 1003 |
| 1004 |
| 1005 |
fprintf(fp, "\n%s sphere %s.s\n", mod, name);
| 1006 |
fprintf(fp, "0\n0\n4 0 0 0 %g\n", .5*shp->w*meters2out);
| 1007 |
| 1008 |
| 1009 |
| 1010 |
int
| 1011 |
cvdata( /* convert data */
| 1012 |
FILE *in,
| 1013 |
FILE *out,
| 1014 |
int ndim,
| 1015 |
int npts[],
| 1016 |
double mult,
| 1017 |
double lim[][2]
| 1018 |
| 1019 |
| 1020 |
double *pt[4];
| 1021 |
int i, j;
| 1022 |
double val;
| 1023 |
int total;
| 1024 |
| 1025 |
total = 1; j = 0;
| 1026 |
for (i = 0; i < ndim; i++)
| 1027 |
if (npts[i] > 1) {
| 1028 |
total *= npts[i];
| 1029 |
j++;
| 1030 |
| 1031 |
fprintf(out, "%d\n", j);
| 1032 |
/* get coordinates */
| 1033 |
for (i = 0; i < ndim; i++) {
| 1034 |
pt[i] = (double *)malloc(npts[i]*sizeof(double));
| 1035 |
for (j = 0; j < npts[i]; j++)
| 1036 |
if (!scnflt(in, &pt[i][j]))
| 1037 |
return(-1);
| 1038 |
if (lim != NULL) {
| 1039 |
lim[i][0] = pt[i][0];
| 1040 |
lim[i][1] = pt[i][npts[i]-1];
| 1041 |
| 1042 |
| 1043 |
/* write out in reverse */
| 1044 |
for (i = ndim-1; i >= 0; i--) {
| 1045 |
if (npts[i] > 1) {
| 1046 |
for (j = 1; j < npts[i]-1; j++)
| 1047 |
if (!FEQ(pt[i][j]-pt[i][j-1],
| 1048 |
pt[i][j+1]-pt[i][j]))
| 1049 |
break;
| 1050 |
if (j == npts[i]-1)
| 1051 |
fprintf(out, "%g %g %d\n", pt[i][0], pt[i][j],
| 1052 |
npts[i]);
| 1053 |
else {
| 1054 |
fprintf(out, "0 0 %d", npts[i]);
| 1055 |
for (j = 0; j < npts[i]; j++) {
| 1056 |
if (j%4 == 0)
| 1057 |
putc('\n', out);
| 1058 |
fprintf(out, "\t%g", pt[i][j]);
| 1059 |
| 1060 |
putc('\n', out);
| 1061 |
| 1062 |
| 1063 |
free((void *)pt[i]);
| 1064 |
| 1065 |
for (i = 0; i < total; i++) {
| 1066 |
if (i%4 == 0)
| 1067 |
putc('\n', out);
| 1068 |
if (!scnflt(in, &val))
| 1069 |
return(-1);
| 1070 |
fprintf(out, "\t%g", val*mult);
| 1071 |
| 1072 |
putc('\n', out);
| 1073 |
return(0);
| 1074 |
| 1075 |
| 1076 |
| 1077 |
char *
| 1078 |
getword( /* scan a word from fp */
| 1079 |
FILE *fp
| 1080 |
| 1081 |
| 1082 |
static char wrd[RMAXWORD];
| 1083 |
char *cp;
| 1084 |
int c;
| 1085 |
| 1086 |
while (isspace(c=getc(fp)))
| 1087 |
| 1088 |
for (cp = wrd; c != EOF && cp < wrd+RMAXWORD-1;
| 1089 |
*cp++ = c, c = getc(fp))
| 1090 |
if (isspace(c) || c == ',') {
| 1091 |
while (isspace(c))
| 1092 |
c = getc(fp);
| 1093 |
if ((c != EOF) & (c != ','))
| 1094 |
ungetc(c, fp);
| 1095 |
*cp = '\0';
| 1096 |
return(wrd);
| 1097 |
| 1098 |
*cp = '\0';
| 1099 |
return(cp > wrd ? wrd : NULL);
| 1100 |
| 1101 |
| 1102 |
| 1103 |
int
| 1104 |
cvtint( /* convert a word to an integer */
| 1105 |
int *ip,
| 1106 |
char *wrd
| 1107 |
| 1108 |
| 1109 |
if (wrd == NULL || !isint(wrd))
| 1110 |
return(0);
| 1111 |
*ip = atoi(wrd);
| 1112 |
return(1);
| 1113 |
| 1114 |
| 1115 |
| 1116 |
int
| 1117 |
cvtflt( /* convert a word to a double */
| 1118 |
double *rp,
| 1119 |
char *wrd
| 1120 |
| 1121 |
| 1122 |
if (wrd == NULL || !isflt(wrd))
| 1123 |
return(0);
| 1124 |
*rp = atof(wrd);
| 1125 |
return(1);
| 1126 |
| 1127 |
| 1128 |
| 1129 |
int
| 1130 |
cvgeometry(
| 1131 |
char *inpname,
| 1132 |
SRCINFO *sinf,
| 1133 |
char *outname,
| 1134 |
FILE *outfp /* close output file upon return */
| 1135 |
| 1136 |
| 1137 |
char buf[256];
| 1138 |
char *cp;
| 1139 |
| 1140 |
if (inpname == NULL || !inpname[0]) { /* no geometry file */
| 1141 |
fclose(outfp);
| 1142 |
return(0);
| 1143 |
| 1144 |
putc('\n', outfp);
| 1145 |
strcpy(buf, "mgf2rad "); /* build mgf2rad command */
| 1146 |
cp = buf+8;
| 1147 |
if (!FEQ(sinf->mult, 1.0)) {
| 1148 |
sprintf(cp, "-e %f ", sinf->mult);
| 1149 |
cp += strlen(cp);
| 1150 |
| 1151 |
sprintf(cp, "-g %f %s ",
| 1152 |
sqrt(sinf->w*sinf->w + sinf->h*sinf->h + sinf->l*sinf->l),
| 1153 |
inpname);
| 1154 |
cp += strlen(cp);
| 1155 |
if (instantiate) { /* instantiate octree */
| 1156 |
strcpy(cp, "| oconv - > ");
| 1157 |
cp += 12;
| 1158 |
fullnam(cp,outname,T_OCT);
| 1159 |
if (fdate(inpname) > fdate(outname) &&
| 1160 |
system(buf)) { /* create octree */
| 1161 |
fclose(outfp);
| 1162 |
return(-1);
| 1163 |
| 1164 |
fprintf(outfp, "void instance %s_inst\n", outname);
| 1165 |
if (!FEQ(meters2out, 1.0))
| 1166 |
fprintf(outfp, "3 %s -s %f\n",
| 1167 |
libname(buf,outname,T_OCT),
| 1168 |
meters2out);
| 1169 |
else
| 1170 |
fprintf(outfp, "1 %s\n", libname(buf,outname,T_OCT));
| 1171 |
fprintf(outfp, "0\n0\n");
| 1172 |
fclose(outfp);
| 1173 |
} else { /* else append to luminaire file */
| 1174 |
if (!FEQ(meters2out, 1.0)) { /* apply scalefactor */
| 1175 |
sprintf(cp, "| xform -s %f ", meters2out);
| 1176 |
cp += strlen(cp);
| 1177 |
| 1178 |
if (!out2stdout) {
| 1179 |
fclose(outfp);
| 1180 |
strcpy(cp, ">> "); /* append works for DOS? */
| 1181 |
cp += 3;
| 1182 |
fullnam(cp,outname,T_RAD);
| 1183 |
| 1184 |
if (system(buf))
| 1185 |
return(-1);
| 1186 |
| 1187 |
return(0);
| 1188 |
