root/radiance/ray/src/cv/ies2rad.c
Revision: 2.6
Committed: Thu Mar 18 11:21:21 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.5: +64 -9 lines
better checking of input data -- allow comma separators
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert IES luminaire data to Radiance description
9 *
10 * 07Apr90 Greg Ward
11 */
12
13 #include <stdio.h>
14 #include <ctype.h>
15 #include "color.h"
16 #include "paths.h"
17
18 #define PI 3.14159265358979323846
19 /* floating comparisons */
20 #define FTINY 1e-6
21 #define FEQ(a,b) ((a)<=(b)+FTINY&&(a)>=(b)-FTINY)
22 /* tilt specs */
23 #define TLTSTR "TILT="
24 #define TLTSTRLEN 5
25 #define TLTNONE "NONE"
26 #define TLTINCL "INCLUDE"
27 #define TLT_VERT 1
28 #define TLT_H0 2
29 #define TLT_H90 3
30 /* photometric types */
31 #define PM_C 1
32 #define PM_B 2
33 /* unit types */
34 #define U_FEET 1
35 #define U_METERS 2
36 /* string lengths */
37 #define MAXLINE 132
38 #define MAXWORD 76
39 /* file types */
40 #define T_RAD ".rad"
41 #define T_DST ".dat"
42 #define T_TLT "+.dat"
43 /* shape types */
44 #define RECT 1
45 #define DISK 2
46 #define SPHERE 3
47
48 #define MINDIM .001 /* minimum dimension (point source) */
49
50 #define F_M .3048 /* feet to meters */
51
52 #define abspath(p) (ISDIRSEP((p)[0]) || (p)[0] == '.')
53
54 static char default_name[] = "default";
55
56 char *libdir = NULL; /* library directory location */
57 char *prefdir = NULL; /* subdirectory */
58 char *lampdat = "lamp.tab"; /* lamp data file */
59
60 double meters2out = 1.0; /* conversion from meters to output */
61 char *lamptype = NULL; /* selected lamp type */
62 char *deflamp = NULL; /* default lamp type */
63 float defcolor[3] = {1.,1.,1.}; /* default lamp color */
64 float *lampcolor = defcolor; /* pointer to current lamp color */
65 double multiplier = 1.0; /* multiplier for all light sources */
66 char units[64] = "meters"; /* output units */
67 double illumrad = 0.0; /* radius for illum sphere */
68
69 typedef struct {
70 int type; /* RECT, DISK, SPHERE */
71 double w, l, h; /* width, length, height */
72 double area; /* max. projected area */
73 } SHAPE; /* a source shape */
74
75 int gargc; /* global argc (minus filenames) */
76 char **gargv; /* global argv */
77
78 extern char *strcpy(), *strcat(), *stradd(), *tailtrunc(), *filetrunc(),
79 *filename(), *libname(), *fullname(), *malloc(),
80 *getword(), *atos();
81 extern float *matchlamp();
82
83 #define scnint(fp,ip) cvtint(ip,getword(fp))
84 #define scnflt(fp,rp) cvtflt(rp,getword(fp))
85 #define isint isflt /* IES allows real as integer */
86
87
88 main(argc, argv)
89 int argc;
90 char *argv[];
91 {
92 char *outfile = NULL;
93 int status;
94 char outname[MAXWORD];
95 double d1;
96 int i;
97
98 for (i = 1; i < argc && argv[i][0] == '-'; i++)
99 switch (argv[i][1]) {
100 case 'd': /* dimensions */
101 if (argv[i][2] == '\0')
102 goto badopt;
103 if (argv[i][3] == '\0')
104 d1 = 1.0;
105 else if (argv[i][3] == '/') {
106 d1 = atof(argv[i]+4);
107 if (d1 <= FTINY)
108 goto badopt;
109 } else
110 goto badopt;
111 switch (argv[i][2]) {
112 case 'c': /* centimeters */
113 if (FEQ(d1,10.))
114 strcpy(units,"millimeters");
115 else {
116 strcpy(units,"centimeters");
117 strcat(units,argv[i]+3);
118 }
119 meters2out = 100.*d1;
120 break;
121 case 'm': /* meters */
122 if (FEQ(d1,1000.))
123 strcpy(units,"millimeters");
124 else if (FEQ(d1,100.))
125 strcpy(units,"centimeters");
126 else {
127 strcpy(units,"meters");
128 strcat(units,argv[i]+3);
129 }
130 meters2out = d1;
131 break;
132 case 'i': /* inches */
133 strcpy(units,"inches");
134 strcat(units,argv[i]+3);
135 meters2out = d1*(12./F_M);
136 break;
137 case 'f': /* feet */
138 if (FEQ(d1,12.))
139 strcpy(units,"inches");
140 else {
141 strcpy(units,"feet");
142 strcat(units,argv[i]+3);
143 }
144 meters2out = d1/F_M;
145 break;
146 default:
147 goto badopt;
148 }
149 break;
150 case 'l': /* library directory */
151 libdir = argv[++i];
152 break;
153 case 'p': /* prefix subdirectory */
154 prefdir = argv[++i];
155 break;
156 case 'f': /* lamp data file */
157 lampdat = argv[++i];
158 break;
159 case 'o': /* output file name */
160 outfile = argv[++i];
161 break;
162 case 'i': /* illum */
163 illumrad = atof(argv[++i]);
164 if (illumrad < MINDIM)
165 illumrad = MINDIM;
166 break;
167 case 't': /* override lamp type */
168 lamptype = argv[++i];
169 break;
170 case 'u': /* default lamp type */
171 deflamp = argv[++i];
172 break;
173 case 'c': /* default lamp color */
174 defcolor[0] = atof(argv[++i]);
175 defcolor[1] = atof(argv[++i]);
176 defcolor[2] = atof(argv[++i]);
177 break;
178 case 'm': /* multiplier */
179 multiplier = atof(argv[++i]);
180 break;
181 default:
182 badopt:
183 fprintf(stderr, "%s: bad option: %s\n",
184 argv[0], argv[i]);
185 exit(1);
186 }
187 gargc = i;
188 gargv = argv;
189 initlamps(); /* get lamp data (if needed) */
190 /* convert ies file(s) */
191 if (outfile != NULL) {
192 if (i == argc)
193 exit(ies2rad(NULL, outfile) == 0 ? 0 : 1);
194 else if (i == argc-1)
195 exit(ies2rad(argv[i], outfile) == 0 ? 0 : 1);
196 else {
197 fprintf(stderr, "%s: single input file required\n",
198 argv[0]);
199 exit(1);
200 }
201 } else if (i >= argc) {
202 fprintf(stderr, "%s: missing output file specification\n",
203 argv[0]);
204 exit(1);
205 }
206 status = 0;
207 for ( ; i < argc; i++) {
208 tailtrunc(strcpy(outname,filename(argv[i])));
209 if (ies2rad(argv[i], outname) != 0)
210 status = 1;
211 }
212 exit(status);
213 }
214
215
216 initlamps() /* set up lamps */
217 {
218 float *lcol;
219 int status;
220
221 if (lamptype != NULL && !strcmp(lamptype, default_name) &&
222 deflamp == NULL)
223 return; /* no need for data */
224 /* else load file */
225 if ((status = loadlamps(lampdat)) < 0)
226 exit(1);
227 if (status == 0) {
228 fprintf(stderr, "%s: warning - no lamp data\n", lampdat);
229 lamptype = default_name;
230 return;
231 }
232 if (deflamp != NULL) { /* match default type */
233 if ((lcol = matchlamp(deflamp)) == NULL)
234 fprintf(stderr,
235 "%s: warning - unknown default lamp type\n",
236 deflamp);
237 else
238 copycolor(defcolor, lcol);
239 }
240 if (lamptype != NULL) { /* match selected type */
241 if (strcmp(lamptype, default_name)) {
242 if ((lcol = matchlamp(lamptype)) == NULL) {
243 fprintf(stderr,
244 "%s: warning - unknown lamp type\n",
245 lamptype);
246 lamptype = default_name;
247 } else
248 copycolor(defcolor, lcol);
249 }
250 freelamps(); /* all done with data */
251 }
252 /* else keep lamp data */
253 }
254
255
256 char *
257 stradd(dst, src, sep) /* add a string at dst */
258 register char *dst, *src;
259 int sep;
260 {
261 if (src && *src) {
262 do
263 *dst++ = *src++;
264 while (*src);
265 if (sep && dst[-1] != sep)
266 *dst++ = sep;
267 }
268 *dst = '\0';
269 return(dst);
270 }
271
272
273 char *
274 fullname(path, fname, suffix) /* return full path name */
275 char *path, *fname, *suffix;
276 {
277 if (prefdir != NULL && abspath(prefdir))
278 libname(path, fname, suffix);
279 else if (abspath(fname))
280 strcpy(stradd(path, fname, 0), suffix);
281 else
282 libname(stradd(path, libdir, DIRSEP), fname, suffix);
283
284 return(path);
285 }
286
287
288 char *
289 libname(path, fname, suffix) /* return library relative name */
290 char *path, *fname, *suffix;
291 {
292 if (abspath(fname))
293 strcpy(stradd(path, fname, 0), suffix);
294 else
295 strcpy(stradd(stradd(path, prefdir, DIRSEP), fname, 0), suffix);
296
297 return(path);
298 }
299
300
301 char *
302 filename(path) /* get final component of pathname */
303 register char *path;
304 {
305 register char *cp;
306
307 for (cp = path; *path; path++)
308 if (ISDIRSEP(*path))
309 cp = path+1;
310 return(cp);
311 }
312
313
314 char *
315 filetrunc(path) /* truncate filename at end of path */
316 char *path;
317 {
318 register char *p1, *p2;
319
320 for (p1 = p2 = path; *p2; p2++)
321 if (ISDIRSEP(*p2))
322 p1 = p2;
323 *p1 = '\0';
324 return(path);
325 }
326
327
328 char *
329 tailtrunc(name) /* truncate tail of filename */
330 char *name;
331 {
332 register char *p1, *p2;
333
334 for (p1 = filename(name); *p1 == '.'; p1++)
335 ;
336 p2 = NULL;
337 for ( ; *p1; p1++)
338 if (*p1 == '.')
339 p2 = p1;
340 if (p2 != NULL)
341 *p2 = '\0';
342 return(name);
343 }
344
345
346 blanktrunc(s) /* truncate spaces at end of line */
347 char *s;
348 {
349 register char *cp;
350
351 for (cp = s; *cp; cp++)
352 ;
353 while (cp-- > s && isspace(*cp))
354 ;
355 *++cp = '\0';
356 }
357
358
359 putheader(out) /* print header */
360 FILE *out;
361 {
362 register int i;
363
364 putc('#', out);
365 for (i = 0; i < gargc; i++) {
366 putc(' ', out);
367 fputs(gargv[i], out);
368 }
369 fputs("\n# Dimensions in ", out);
370 fputs(units, out);
371 putc('\n', out);
372 }
373
374
375 ies2rad(inpname, outname) /* convert IES file */
376 char *inpname, *outname;
377 {
378 char buf[MAXLINE], tltid[MAXWORD];
379 FILE *inpfp, *outfp;
380
381 if (inpname == NULL) {
382 inpname = "<stdin>";
383 inpfp = stdin;
384 } else if ((inpfp = fopen(inpname, "r")) == NULL) {
385 perror(inpname);
386 return(-1);
387 }
388 if ((outfp = fopen(fullname(buf,outname,T_RAD), "w")) == NULL) {
389 perror(buf);
390 fclose(inpfp);
391 return(-1);
392 }
393 putheader(outfp);
394 if (lamptype == NULL)
395 lampcolor = NULL;
396 while (fgets(buf,sizeof(buf),inpfp) != NULL
397 && strncmp(buf,TLTSTR,TLTSTRLEN)) {
398 blanktrunc(buf);
399 if (!buf[0])
400 continue;
401 fputs("#<", outfp);
402 fputs(buf, outfp);
403 putc('\n', outfp);
404 if (lampcolor == NULL)
405 lampcolor = matchlamp(buf);
406 }
407 if (lampcolor == NULL) {
408 fprintf(stderr, "%s: warning - no lamp type\n", inpname);
409 lampcolor = defcolor;
410 }
411 if (feof(inpfp)) {
412 fprintf(stderr, "%s: not in IES format\n", inpname);
413 goto readerr;
414 }
415 atos(tltid, MAXWORD, buf+TLTSTRLEN);
416 if (inpfp == stdin)
417 buf[0] = '\0';
418 else
419 filetrunc(strcpy(buf, inpname));
420 if (dotilt(inpfp, outfp, buf, tltid, outname, tltid) != 0) {
421 fprintf(stderr, "%s: bad tilt data\n", inpname);
422 goto readerr;
423 }
424 if (dosource(inpfp, outfp, tltid, outname) != 0) {
425 fprintf(stderr, "%s: bad luminaire data\n", inpname);
426 goto readerr;
427 }
428 fclose(outfp);
429 fclose(inpfp);
430 return(0);
431 readerr:
432 fclose(outfp);
433 fclose(inpfp);
434 unlink(fullname(buf,outname,T_RAD));
435 return(-1);
436 }
437
438
439 dotilt(in, out, dir, tltspec, dfltname, tltid) /* convert tilt data */
440 FILE *in, *out;
441 char *dir, *tltspec, *dfltname, *tltid;
442 {
443 int nangles, tlt_type;
444 double minmax[2];
445 char buf[MAXPATH], tltname[MAXWORD];
446 FILE *datin, *datout;
447
448 if (!strcmp(tltspec, TLTNONE)) {
449 datin = NULL;
450 strcpy(tltid, "void");
451 } else if (!strcmp(tltspec, TLTINCL)) {
452 datin = in;
453 strcpy(tltname, dfltname);
454 } else {
455 if (ISDIRSEP(tltspec[0]))
456 strcpy(buf, tltspec);
457 else
458 strcpy(stradd(buf, dir, DIRSEP), tltspec);
459 if ((datin = fopen(buf, "r")) == NULL) {
460 perror(buf);
461 return(-1);
462 }
463 tailtrunc(strcpy(tltname,filename(tltspec)));
464 }
465 if (datin != NULL) {
466 if ((datout = fopen(fullname(buf,tltname,T_TLT),"w")) == NULL) {
467 perror(buf);
468 if (datin != in)
469 fclose(datin);
470 return(-1);
471 }
472 if (!scnint(datin,&tlt_type) || !scnint(datin,&nangles)
473 || cvdata(datin,datout,1,&nangles,1.,minmax) != 0) {
474 fprintf(stderr, "%s: data format error\n", tltspec);
475 fclose(datout);
476 if (datin != in)
477 fclose(datin);
478 unlink(fullname(buf,tltname,T_TLT));
479 return(-1);
480 }
481 fclose(datout);
482 if (datin != in)
483 fclose(datin);
484 strcat(strcpy(tltid, filename(tltname)), "_tilt");
485 fprintf(out, "\nvoid brightdata %s\n", tltid);
486 libname(buf,tltname,T_TLT);
487 switch (tlt_type) {
488 case TLT_VERT: /* vertical */
489 fprintf(out, "4 noop %s tilt.cal %s\n", buf,
490 minmax[1]>90.+FTINY ? "tilt_ang" : "tilt_ang2");
491 break;
492 case TLT_H0: /* horiz. in 0 deg. plane */
493 fprintf(out, "6 noop %s tilt.cal %s -rz 90\n", buf,
494 minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
495 break;
496 case TLT_H90:
497 fprintf(out, "4 noop %s tilt.cal %s\n", buf,
498 minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
499 break;
500 default:
501 fprintf(stderr,
502 "%s: illegal lamp to luminaire geometry (%d)\n",
503 tltspec, tlt_type);
504 return(-1);
505 }
506 fprintf(out, "0\n0\n");
507 }
508 return(0);
509 }
510
511
512 dosource(in, out, mod, name) /* create source and distribution */
513 FILE *in, *out;
514 char *mod, *name;
515 {
516 SHAPE srcshape;
517 char buf[MAXPATH], id[MAXWORD];
518 FILE *datout;
519 double mult, bfactor, pfactor, width, length, height, wattage;
520 double bounds[2][2];
521 int nangles[2], pmtype, unitype;
522 double d1;
523
524 if (!isint(getword(in)) || !isflt(getword(in)) || !scnflt(in,&mult)
525 || !scnint(in,&nangles[0]) || !scnint(in,&nangles[1])
526 || !scnint(in,&pmtype) || !scnint(in,&unitype)
527 || !scnflt(in,&width) || !scnflt(in,&length)
528 || !scnflt(in,&height) || !scnflt(in,&bfactor)
529 || !scnflt(in,&pfactor) || !scnflt(in,&wattage)) {
530 fprintf(stderr, "dosource: bad lamp specification\n");
531 return(-1);
532 }
533 if (nangles[0] < 2 || nangles[1] < 1) {
534 fprintf(stderr, "dosource: too few measured angles\n");
535 return(-1);
536 }
537 if (unitype == U_FEET) {
538 width *= F_M;
539 length *= F_M;
540 height *= F_M;
541 }
542 if (makeshape(&srcshape, width, length, height) != 0) {
543 fprintf(stderr, "dosource: illegal source dimensions");
544 return(-1);
545 }
546 if ((datout = fopen(fullname(buf,name,T_DST), "w")) == NULL) {
547 perror(buf);
548 return(-1);
549 }
550 if (cvdata(in, datout, 2, nangles, 1./WHTEFFICACY, bounds) != 0) {
551 fprintf(stderr, "dosource: bad distribution data\n");
552 fclose(datout);
553 unlink(fullname(buf,name,T_DST));
554 return(-1);
555 }
556 fclose(datout);
557 fprintf(out, "# %g watt luminaire, lamp*ballast factor = %g\n",
558 wattage, bfactor*pfactor);
559 strcat(strcpy(id, filename(name)), "_dist");
560 fprintf(out, "\n%s brightdata %s\n", mod, id);
561 if (nangles[1] < 2)
562 fprintf(out, "4 ");
563 else if (pmtype == PM_B)
564 fprintf(out, "5 ");
565 else if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
566 fprintf(out, "8 ");
567 else
568 fprintf(out, "6 ");
569 fprintf(out, "%s %s source.cal ",
570 srcshape.type==SPHERE ? "corr" : "flatcorr",
571 libname(buf,name,T_DST));
572 if (pmtype == PM_B) {
573 if (FEQ(bounds[1][0],0.))
574 fprintf(out, "srcB_horiz2 ");
575 else
576 fprintf(out, "srcB_horiz ");
577 fprintf(out, "srcB_vert ");
578 } else {
579 if (nangles[1] >= 2) {
580 d1 = bounds[1][1] - bounds[1][0];
581 if (d1 <= 90.+FTINY)
582 fprintf(out, "src_phi4 ");
583 else if (d1 <= 180.+FTINY)
584 fprintf(out, "src_phi2 ");
585 else
586 fprintf(out, "src_phi ");
587 fprintf(out, "src_theta -my ");
588 if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
589 fprintf(out, "-rz -90 ");
590 } else
591 fprintf(out, "src_theta ");
592 }
593 fprintf(out, "\n0\n1 %g\n", multiplier*mult*bfactor*pfactor);
594 if (putsource(&srcshape, out, id, filename(name),
595 bounds[0][0]<90., bounds[0][1]>90.) != 0)
596 return(-1);
597 return(0);
598 }
599
600
601 putsource(shp, fp, mod, name, dolower, doupper) /* put out source */
602 SHAPE *shp;
603 FILE *fp;
604 char *mod, *name;
605 int dolower, doupper;
606 {
607 char buf[MAXWORD];
608
609 fprintf(fp, "\n%s %s %s_light\n", mod,
610 illumrad>=MINDIM/2. ? "illum" : "light",
611 name);
612 fprintf(fp, "0\n0\n3 %g %g %g\n",
613 lampcolor[0]/shp->area,
614 lampcolor[1]/shp->area,
615 lampcolor[2]/shp->area);
616 if (doupper && dolower && shp->type != SPHERE && shp->h > MINDIM) {
617 fprintf(fp, "\n%s glow %s_glow\n", mod, name);
618 fprintf(fp, "0\n0\n4 %g %g %g -1\n",
619 lampcolor[0]/shp->area,
620 lampcolor[1]/shp->area,
621 lampcolor[2]/shp->area);
622 }
623 switch (shp->type) {
624 case RECT:
625 strcat(strcpy(buf, name), "_light");
626 if (dolower)
627 putrectsrc(shp, fp, buf, name, 0);
628 if (doupper)
629 putrectsrc(shp, fp, buf, name, 1);
630 if (doupper && dolower && shp->h > MINDIM) {
631 strcat(strcpy(buf, name), "_glow");
632 putsides(shp, fp, buf, name);
633 }
634 break;
635 case DISK:
636 strcat(strcpy(buf, name), "_light");
637 if (dolower)
638 putdisksrc(shp, fp, buf, name, 0);
639 if (doupper)
640 putdisksrc(shp, fp, buf, name, 1);
641 if (doupper && dolower && shp->h > MINDIM) {
642 strcat(strcpy(buf, name), "_glow");
643 putcyl(shp, fp, buf, name);
644 }
645 break;
646 case SPHERE:
647 strcat(strcpy(buf, name), "_light");
648 putspheresrc(shp, fp, buf, name);
649 break;
650 }
651 return(0);
652 }
653
654
655 makeshape(shp, width, length, height) /* make source shape */
656 register SHAPE *shp;
657 double width, length, height;
658 {
659 if (illumrad >= MINDIM/2.) {
660 shp->type = SPHERE;
661 shp->w = shp->l = shp->h = 2.*illumrad;
662 } else if (width < MINDIM) {
663 width = -width;
664 if (width < MINDIM) {
665 shp->type = SPHERE;
666 shp->w = shp->l = shp->h = MINDIM;
667 } else if (height < .5*width) {
668 shp->type = DISK;
669 shp->w = shp->l = width;
670 if (height >= MINDIM)
671 shp->h = height;
672 else
673 shp->h = .5*MINDIM;
674 } else {
675 shp->type = SPHERE;
676 shp->w = shp->l = shp->h = width;
677 }
678 } else {
679 shp->type = RECT;
680 shp->w = width;
681 if (length >= MINDIM)
682 shp->l = length;
683 else
684 shp->l = MINDIM;
685 if (height >= MINDIM)
686 shp->h = height;
687 else
688 shp->h = .5*MINDIM;
689 }
690 switch (shp->type) {
691 case RECT:
692 shp->area = shp->w * shp->l;
693 break;
694 case DISK:
695 case SPHERE:
696 shp->area = PI/4. * shp->w * shp->w;
697 break;
698 }
699 return(0);
700 }
701
702
703 putrectsrc(shp, fp, mod, name, up) /* rectangular source */
704 SHAPE *shp;
705 FILE *fp;
706 char *mod, *name;
707 int up;
708 {
709 if (up)
710 putrect(shp, fp, mod, name, ".u", 4, 5, 7, 6);
711 else
712 putrect(shp, fp, mod, name, ".d", 0, 2, 3, 1);
713 }
714
715
716 putsides(shp, fp, mod, name) /* put out sides of box */
717 register SHAPE *shp;
718 FILE *fp;
719 char *mod, *name;
720 {
721 putrect(shp, fp, mod, name, ".1", 0, 1, 5, 4);
722 putrect(shp, fp, mod, name, ".2", 1, 3, 7, 5);
723 putrect(shp, fp, mod, name, ".3", 3, 2, 6, 7);
724 putrect(shp, fp, mod, name, ".4", 2, 0, 4, 6);
725 }
726
727
728 putrect(shp, fp, mod, name, suffix, a, b, c, d) /* put out a rectangle */
729 SHAPE *shp;
730 FILE *fp;
731 char *mod, *name, *suffix;
732 int a, b, c, d;
733 {
734 fprintf(fp, "\n%s polygon %s%s\n0\n0\n12\n", mod, name, suffix);
735 putpoint(shp, fp, a);
736 putpoint(shp, fp, b);
737 putpoint(shp, fp, c);
738 putpoint(shp, fp, d);
739 }
740
741
742 putpoint(shp, fp, p) /* put out a point */
743 register SHAPE *shp;
744 FILE *fp;
745 int p;
746 {
747 static double mult[2] = {-.5, .5};
748
749 fprintf(fp, "\t%g\t%g\t%g\n",
750 mult[p&1]*shp->l*meters2out,
751 mult[p>>1&1]*shp->w*meters2out,
752 mult[p>>2]*shp->h*meters2out);
753 }
754
755
756 putdisksrc(shp, fp, mod, name, up) /* put out a disk source */
757 register SHAPE *shp;
758 FILE *fp;
759 char *mod, *name;
760 int up;
761 {
762 if (up) {
763 fprintf(fp, "\n%s ring %s.u\n", mod, name);
764 fprintf(fp, "0\n0\n8\n");
765 fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
766 fprintf(fp, "\t0 0 1\n");
767 fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
768 } else {
769 fprintf(fp, "\n%s ring %s.d\n", mod, name);
770 fprintf(fp, "0\n0\n8\n");
771 fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
772 fprintf(fp, "\t0 0 -1\n");
773 fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
774 }
775 }
776
777
778 putcyl(shp, fp, mod, name) /* put out a cylinder */
779 register SHAPE *shp;
780 FILE *fp;
781 char *mod, *name;
782 {
783 fprintf(fp, "\n%s cylinder %s.c\n", mod, name);
784 fprintf(fp, "0\n0\n7\n");
785 fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
786 fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
787 fprintf(fp, "\t%g\n", .5*shp->w*meters2out);
788 }
789
790
791 putspheresrc(shp, fp, mod, name) /* put out a sphere source */
792 SHAPE *shp;
793 FILE *fp;
794 char *mod, *name;
795 {
796 fprintf(fp, "\n%s sphere %s.s\n", mod, name);
797 fprintf(fp, "0\n0\n4 0 0 0 %g\n", .5*shp->w*meters2out);
798 }
799
800
801 cvdata(in, out, ndim, npts, mult, lim) /* convert data */
802 FILE *in, *out;
803 int ndim, npts[];
804 double mult, lim[][2];
805 {
806 double *pt[4];
807 register int i, j;
808 double val;
809 int total;
810
811 total = 1; j = 0;
812 for (i = 0; i < ndim; i++)
813 if (npts[i] > 1) {
814 total *= npts[i];
815 j++;
816 }
817 fprintf(out, "%d\n", j);
818 /* get coordinates */
819 for (i = 0; i < ndim; i++) {
820 pt[i] = (double *)malloc(npts[i]*sizeof(double));
821 for (j = 0; j < npts[i]; j++)
822 if (!scnflt(in, &pt[i][j]))
823 return(-1);
824 if (lim != NULL) {
825 lim[i][0] = pt[i][0];
826 lim[i][1] = pt[i][npts[i]-1];
827 }
828 }
829 /* write out in reverse */
830 for (i = ndim-1; i >= 0; i--) {
831 if (npts[i] > 1) {
832 for (j = 1; j < npts[i]-1; j++)
833 if (!FEQ(pt[i][j]-pt[i][j-1],
834 pt[i][j+1]-pt[i][j]))
835 break;
836 if (j == npts[i]-1)
837 fprintf(out, "%g %g %d\n", pt[i][0], pt[i][j],
838 npts[i]);
839 else {
840 fprintf(out, "0 0 %d", npts[i]);
841 for (j = 0; j < npts[i]; j++) {
842 if (j%4 == 0)
843 putc('\n', out);
844 fprintf(out, "\t%g", pt[i][j]);
845 }
846 putc('\n', out);
847 }
848 }
849 free((char *)pt[i]);
850 }
851 for (i = 0; i < total; i++) {
852 if (i%4 == 0)
853 putc('\n', out);
854 if (!scnflt(in, &val))
855 return(-1);
856 fprintf(out, "\t%g", val*mult);
857 }
858 putc('\n', out);
859 return(0);
860 }
861
862
863 char *
864 getword(fp) /* scan a word from fp */
865 register FILE *fp;
866 {
867 static char word[MAXWORD];
868 register char *cp;
869 register int c;
870
871 while (isspace(c=getc(fp)))
872 ;
873 for (cp = word; c != EOF && cp < word+MAXWORD-1;
874 *cp++ = c, c = getc(fp))
875 if (isspace(c) || c == ',') {
876 while (isspace(c))
877 c = getc(fp);
878 if (c != EOF & c != ',')
879 ungetc(c, fp);
880 *cp = '\0';
881 return(word);
882 }
883 *cp = '\0';
884 return(cp > word ? word : NULL);
885 }
886
887
888 cvtint(ip, word) /* convert a word to an integer */
889 int *ip;
890 char *word;
891 {
892 if (word == NULL || !isint(word))
893 return(0);
894 *ip = atoi(word);
895 return(1);
896 }
897
898
899 cvtflt(rp, word) /* convert a word to a double */
900 double *rp;
901 char *word;
902 {
903 if (word == NULL || !isflt(word))
904 return(0);
905 *rp = atof(word);
906 return(1);
907 }
