root/radiance/ray/src/cv/ies2rad.c
Revision: 2.8
Committed: Fri Jun 4 14:40:25 1993 UTC (31 years ago) by greg
added math.h for atof() usage
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert IES luminaire data to Radiance description
9 *
10 * 07Apr90 Greg Ward
11 */
12
13 #include <stdio.h>
14 #include <math.h>
15 #include <ctype.h>
16 #include "color.h"
17 #include "paths.h"
18
19 #define PI 3.14159265358979323846
20 /* floating comparisons */
21 #define FTINY 1e-6
22 #define FEQ(a,b) ((a)<=(b)+FTINY&&(a)>=(b)-FTINY)
23 /* tilt specs */
24 #define TLTSTR "TILT="
25 #define TLTSTRLEN 5
26 #define TLTNONE "NONE"
27 #define TLTINCL "INCLUDE"
28 #define TLT_VERT 1
29 #define TLT_H0 2
30 #define TLT_H90 3
31 /* photometric types */
32 #define PM_C 1
33 #define PM_B 2
34 /* unit types */
35 #define U_FEET 1
36 #define U_METERS 2
37 /* string lengths */
38 #define MAXLINE 132
39 #define MAXWORD 76
40 /* file types */
41 #define T_RAD ".rad"
42 #define T_DST ".dat"
43 #define T_TLT "+.dat"
44 /* shape types */
45 #define RECT 1
46 #define DISK 2
47 #define SPHERE 3
48
49 #define MINDIM .001 /* minimum dimension (point source) */
50
51 #define F_M .3048 /* feet to meters */
52
53 #define abspath(p) (ISDIRSEP((p)[0]) || (p)[0] == '.')
54
55 static char default_name[] = "default";
56
57 char *libdir = NULL; /* library directory location */
58 char *prefdir = NULL; /* subdirectory */
59 char *lampdat = "lamp.tab"; /* lamp data file */
60
61 double meters2out = 1.0; /* conversion from meters to output */
62 char *lamptype = NULL; /* selected lamp type */
63 char *deflamp = NULL; /* default lamp type */
64 float defcolor[3] = {1.,1.,1.}; /* default lamp color */
65 float *lampcolor = defcolor; /* pointer to current lamp color */
66 double multiplier = 1.0; /* multiplier for all light sources */
67 char units[64] = "meters"; /* output units */
68 double illumrad = 0.0; /* radius for illum sphere */
69
70 typedef struct {
71 int type; /* RECT, DISK, SPHERE */
72 double w, l, h; /* width, length, height */
73 double area; /* max. projected area */
74 } SHAPE; /* a source shape */
75
76 int gargc; /* global argc (minus filenames) */
77 char **gargv; /* global argv */
78
79 extern char *strcpy(), *strcat(), *stradd(), *tailtrunc(), *filetrunc(),
80 *filename(), *libname(), *fullname(), *malloc(),
81 *getword(), *atos();
82 extern float *matchlamp();
83
84 #define scnint(fp,ip) cvtint(ip,getword(fp))
85 #define scnflt(fp,rp) cvtflt(rp,getword(fp))
86 #define isint isflt /* IES allows real as integer */
87
88
89 main(argc, argv)
90 int argc;
91 char *argv[];
92 {
93 char *outfile = NULL;
94 int status;
95 char outname[MAXWORD];
96 double d1;
97 int i;
98
99 for (i = 1; i < argc && argv[i][0] == '-'; i++)
100 switch (argv[i][1]) {
101 case 'd': /* dimensions */
102 if (argv[i][2] == '\0')
103 goto badopt;
104 if (argv[i][3] == '\0')
105 d1 = 1.0;
106 else if (argv[i][3] == '/') {
107 d1 = atof(argv[i]+4);
108 if (d1 <= FTINY)
109 goto badopt;
110 } else
111 goto badopt;
112 switch (argv[i][2]) {
113 case 'c': /* centimeters */
114 if (FEQ(d1,10.))
115 strcpy(units,"millimeters");
116 else {
117 strcpy(units,"centimeters");
118 strcat(units,argv[i]+3);
119 }
120 meters2out = 100.*d1;
121 break;
122 case 'm': /* meters */
123 if (FEQ(d1,1000.))
124 strcpy(units,"millimeters");
125 else if (FEQ(d1,100.))
126 strcpy(units,"centimeters");
127 else {
128 strcpy(units,"meters");
129 strcat(units,argv[i]+3);
130 }
131 meters2out = d1;
132 break;
133 case 'i': /* inches */
134 strcpy(units,"inches");
135 strcat(units,argv[i]+3);
136 meters2out = d1*(12./F_M);
137 break;
138 case 'f': /* feet */
139 if (FEQ(d1,12.))
140 strcpy(units,"inches");
141 else {
142 strcpy(units,"feet");
143 strcat(units,argv[i]+3);
144 }
145 meters2out = d1/F_M;
146 break;
147 default:
148 goto badopt;
149 }
150 break;
151 case 'l': /* library directory */
152 libdir = argv[++i];
153 break;
154 case 'p': /* prefix subdirectory */
155 prefdir = argv[++i];
156 break;
157 case 'f': /* lamp data file */
158 lampdat = argv[++i];
159 break;
160 case 'o': /* output file name */
161 outfile = argv[++i];
162 break;
163 case 'i': /* illum */
164 illumrad = atof(argv[++i]);
165 if (illumrad < MINDIM)
166 illumrad = MINDIM;
167 break;
168 case 't': /* override lamp type */
169 lamptype = argv[++i];
170 break;
171 case 'u': /* default lamp type */
172 deflamp = argv[++i];
173 break;
174 case 'c': /* default lamp color */
175 defcolor[0] = atof(argv[++i]);
176 defcolor[1] = atof(argv[++i]);
177 defcolor[2] = atof(argv[++i]);
178 break;
179 case 'm': /* multiplier */
180 multiplier = atof(argv[++i]);
181 break;
182 default:
183 badopt:
184 fprintf(stderr, "%s: bad option: %s\n",
185 argv[0], argv[i]);
186 exit(1);
187 }
188 gargc = i;
189 gargv = argv;
190 initlamps(); /* get lamp data (if needed) */
191 /* convert ies file(s) */
192 if (outfile != NULL) {
193 if (i == argc)
194 exit(ies2rad(NULL, outfile) == 0 ? 0 : 1);
195 else if (i == argc-1)
196 exit(ies2rad(argv[i], outfile) == 0 ? 0 : 1);
197 else {
198 fprintf(stderr, "%s: single input file required\n",
199 argv[0]);
200 exit(1);
201 }
202 } else if (i >= argc) {
203 fprintf(stderr, "%s: missing output file specification\n",
204 argv[0]);
205 exit(1);
206 }
207 status = 0;
208 for ( ; i < argc; i++) {
209 tailtrunc(strcpy(outname,filename(argv[i])));
210 if (ies2rad(argv[i], outname) != 0)
211 status = 1;
212 }
213 exit(status);
214 }
215
216
217 initlamps() /* set up lamps */
218 {
219 float *lcol;
220 int status;
221
222 if (lamptype != NULL && !strcmp(lamptype, default_name) &&
223 deflamp == NULL)
224 return; /* no need for data */
225 /* else load file */
226 if ((status = loadlamps(lampdat)) < 0)
227 exit(1);
228 if (status == 0) {
229 fprintf(stderr, "%s: warning - no lamp data\n", lampdat);
230 lamptype = default_name;
231 return;
232 }
233 if (deflamp != NULL) { /* match default type */
234 if ((lcol = matchlamp(deflamp)) == NULL)
235 fprintf(stderr,
236 "%s: warning - unknown default lamp type\n",
237 deflamp);
238 else
239 copycolor(defcolor, lcol);
240 }
241 if (lamptype != NULL) { /* match selected type */
242 if (strcmp(lamptype, default_name)) {
243 if ((lcol = matchlamp(lamptype)) == NULL) {
244 fprintf(stderr,
245 "%s: warning - unknown lamp type\n",
246 lamptype);
247 lamptype = default_name;
248 } else
249 copycolor(defcolor, lcol);
250 }
251 freelamps(); /* all done with data */
252 }
253 /* else keep lamp data */
254 }
255
256
257 char *
258 stradd(dst, src, sep) /* add a string at dst */
259 register char *dst, *src;
260 int sep;
261 {
262 if (src && *src) {
263 do
264 *dst++ = *src++;
265 while (*src);
266 if (sep && dst[-1] != sep)
267 *dst++ = sep;
268 }
269 *dst = '\0';
270 return(dst);
271 }
272
273
274 char *
275 fullname(path, fname, suffix) /* return full path name */
276 char *path, *fname, *suffix;
277 {
278 if (prefdir != NULL && abspath(prefdir))
279 libname(path, fname, suffix);
280 else if (abspath(fname))
281 strcpy(stradd(path, fname, 0), suffix);
282 else
283 libname(stradd(path, libdir, DIRSEP), fname, suffix);
284
285 return(path);
286 }
287
288
289 char *
290 libname(path, fname, suffix) /* return library relative name */
291 char *path, *fname, *suffix;
292 {
293 if (abspath(fname))
294 strcpy(stradd(path, fname, 0), suffix);
295 else
296 strcpy(stradd(stradd(path, prefdir, DIRSEP), fname, 0), suffix);
297
298 return(path);
299 }
300
301
302 char *
303 filename(path) /* get final component of pathname */
304 register char *path;
305 {
306 register char *cp;
307
308 for (cp = path; *path; path++)
309 if (ISDIRSEP(*path))
310 cp = path+1;
311 return(cp);
312 }
313
314
315 char *
316 filetrunc(path) /* truncate filename at end of path */
317 char *path;
318 {
319 register char *p1, *p2;
320
321 for (p1 = p2 = path; *p2; p2++)
322 if (ISDIRSEP(*p2))
323 p1 = p2;
324 *p1 = '\0';
325 return(path);
326 }
327
328
329 char *
330 tailtrunc(name) /* truncate tail of filename */
331 char *name;
332 {
333 register char *p1, *p2;
334
335 for (p1 = filename(name); *p1 == '.'; p1++)
336 ;
337 p2 = NULL;
338 for ( ; *p1; p1++)
339 if (*p1 == '.')
340 p2 = p1;
341 if (p2 != NULL)
342 *p2 = '\0';
343 return(name);
344 }
345
346
347 blanktrunc(s) /* truncate spaces at end of line */
348 char *s;
349 {
350 register char *cp;
351
352 for (cp = s; *cp; cp++)
353 ;
354 while (cp-- > s && isspace(*cp))
355 ;
356 *++cp = '\0';
357 }
358
359
360 putheader(out) /* print header */
361 FILE *out;
362 {
363 register int i;
364
365 putc('#', out);
366 for (i = 0; i < gargc; i++) {
367 putc(' ', out);
368 fputs(gargv[i], out);
369 }
370 fputs("\n# Dimensions in ", out);
371 fputs(units, out);
372 putc('\n', out);
373 }
374
375
376 ies2rad(inpname, outname) /* convert IES file */
377 char *inpname, *outname;
378 {
379 char buf[MAXLINE], tltid[MAXWORD];
380 FILE *inpfp, *outfp;
381
382 if (inpname == NULL) {
383 inpname = "<stdin>";
384 inpfp = stdin;
385 } else if ((inpfp = fopen(inpname, "r")) == NULL) {
386 perror(inpname);
387 return(-1);
388 }
389 if ((outfp = fopen(fullname(buf,outname,T_RAD), "w")) == NULL) {
390 perror(buf);
391 fclose(inpfp);
392 return(-1);
393 }
394 putheader(outfp);
395 if (lamptype == NULL)
396 lampcolor = NULL;
397 while (fgets(buf,sizeof(buf),inpfp) != NULL
398 && strncmp(buf,TLTSTR,TLTSTRLEN)) {
399 blanktrunc(buf);
400 if (!buf[0])
401 continue;
402 fputs("#<", outfp);
403 fputs(buf, outfp);
404 putc('\n', outfp);
405 if (lampcolor == NULL)
406 lampcolor = matchlamp(buf);
407 }
408 if (lampcolor == NULL) {
409 fprintf(stderr, "%s: warning - no lamp type\n", inpname);
410 lampcolor = defcolor;
411 }
412 if (feof(inpfp)) {
413 fprintf(stderr, "%s: not in IES format\n", inpname);
414 goto readerr;
415 }
416 atos(tltid, MAXWORD, buf+TLTSTRLEN);
417 if (inpfp == stdin)
418 buf[0] = '\0';
419 else
420 filetrunc(strcpy(buf, inpname));
421 if (dotilt(inpfp, outfp, buf, tltid, outname, tltid) != 0) {
422 fprintf(stderr, "%s: bad tilt data\n", inpname);
423 goto readerr;
424 }
425 if (dosource(inpfp, outfp, tltid, outname) != 0) {
426 fprintf(stderr, "%s: bad luminaire data\n", inpname);
427 goto readerr;
428 }
429 fclose(outfp);
430 fclose(inpfp);
431 return(0);
432 readerr:
433 fclose(outfp);
434 fclose(inpfp);
435 unlink(fullname(buf,outname,T_RAD));
436 return(-1);
437 }
438
439
440 dotilt(in, out, dir, tltspec, dfltname, tltid) /* convert tilt data */
441 FILE *in, *out;
442 char *dir, *tltspec, *dfltname, *tltid;
443 {
444 int nangles, tlt_type;
445 double minmax[2];
446 char buf[MAXPATH], tltname[MAXWORD];
447 FILE *datin, *datout;
448
449 if (!strcmp(tltspec, TLTNONE)) {
450 datin = NULL;
451 strcpy(tltid, "void");
452 } else if (!strcmp(tltspec, TLTINCL)) {
453 datin = in;
454 strcpy(tltname, dfltname);
455 } else {
456 if (ISDIRSEP(tltspec[0]))
457 strcpy(buf, tltspec);
458 else
459 strcpy(stradd(buf, dir, DIRSEP), tltspec);
460 if ((datin = fopen(buf, "r")) == NULL) {
461 perror(buf);
462 return(-1);
463 }
464 tailtrunc(strcpy(tltname,filename(tltspec)));
465 }
466 if (datin != NULL) {
467 if ((datout = fopen(fullname(buf,tltname,T_TLT),"w")) == NULL) {
468 perror(buf);
469 if (datin != in)
470 fclose(datin);
471 return(-1);
472 }
473 if (!scnint(datin,&tlt_type) || !scnint(datin,&nangles)
474 || cvdata(datin,datout,1,&nangles,1.,minmax) != 0) {
475 fprintf(stderr, "%s: data format error\n", tltspec);
476 fclose(datout);
477 if (datin != in)
478 fclose(datin);
479 unlink(fullname(buf,tltname,T_TLT));
480 return(-1);
481 }
482 fclose(datout);
483 if (datin != in)
484 fclose(datin);
485 strcat(strcpy(tltid, filename(tltname)), "_tilt");
486 fprintf(out, "\nvoid brightdata %s\n", tltid);
487 libname(buf,tltname,T_TLT);
488 switch (tlt_type) {
489 case TLT_VERT: /* vertical */
490 fprintf(out, "4 noop %s tilt.cal %s\n", buf,
491 minmax[1]>90.+FTINY ? "tilt_ang" : "tilt_ang2");
492 break;
493 case TLT_H0: /* horiz. in 0 deg. plane */
494 fprintf(out, "6 noop %s tilt.cal %s -rz 90\n", buf,
495 minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
496 break;
497 case TLT_H90:
498 fprintf(out, "4 noop %s tilt.cal %s\n", buf,
499 minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
500 break;
501 default:
502 fprintf(stderr,
503 "%s: illegal lamp to luminaire geometry (%d)\n",
504 tltspec, tlt_type);
505 return(-1);
506 }
507 fprintf(out, "0\n0\n");
508 }
509 return(0);
510 }
511
512
513 dosource(in, out, mod, name) /* create source and distribution */
514 FILE *in, *out;
515 char *mod, *name;
516 {
517 SHAPE srcshape;
518 char buf[MAXPATH], id[MAXWORD];
519 FILE *datout;
520 double mult, bfactor, pfactor, width, length, height, wattage;
521 double bounds[2][2];
522 int nangles[2], pmtype, unitype;
523 double d1;
524
525 if (!isint(getword(in)) || !isflt(getword(in)) || !scnflt(in,&mult)
526 || !scnint(in,&nangles[0]) || !scnint(in,&nangles[1])
527 || !scnint(in,&pmtype) || !scnint(in,&unitype)
528 || !scnflt(in,&width) || !scnflt(in,&length)
529 || !scnflt(in,&height) || !scnflt(in,&bfactor)
530 || !scnflt(in,&pfactor) || !scnflt(in,&wattage)) {
531 fprintf(stderr, "dosource: bad lamp specification\n");
532 return(-1);
533 }
534 if (nangles[0] < 2 || nangles[1] < 1) {
535 fprintf(stderr, "dosource: too few measured angles\n");
536 return(-1);
537 }
538 if (unitype == U_FEET) {
539 width *= F_M;
540 length *= F_M;
541 height *= F_M;
542 }
543 if (makeshape(&srcshape, width, length, height) != 0) {
544 fprintf(stderr, "dosource: illegal source dimensions");
545 return(-1);
546 }
547 if ((datout = fopen(fullname(buf,name,T_DST), "w")) == NULL) {
548 perror(buf);
549 return(-1);
550 }
551 if (cvdata(in, datout, 2, nangles, 1./WHTEFFICACY, bounds) != 0) {
552 fprintf(stderr, "dosource: bad distribution data\n");
553 fclose(datout);
554 unlink(fullname(buf,name,T_DST));
555 return(-1);
556 }
557 fclose(datout);
558 fprintf(out, "# %g watt luminaire, lamp*ballast factor = %g\n",
559 wattage, bfactor*pfactor);
560 strcat(strcpy(id, filename(name)), "_dist");
561 fprintf(out, "\n%s brightdata %s\n", mod, id);
562 if (nangles[1] < 2)
563 fprintf(out, "4 ");
564 else if (pmtype == PM_B)
565 fprintf(out, "5 ");
566 else if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
567 fprintf(out, "7 ");
568 else
569 fprintf(out, "5 ");
570 fprintf(out, "%s %s source.cal ",
571 srcshape.type==SPHERE ? "corr" : "flatcorr",
572 libname(buf,name,T_DST));
573 if (pmtype == PM_B) {
574 if (FEQ(bounds[1][0],0.))
575 fprintf(out, "srcB_horiz2 ");
576 else
577 fprintf(out, "srcB_horiz ");
578 fprintf(out, "srcB_vert ");
579 } else {
580 if (nangles[1] >= 2) {
581 d1 = bounds[1][1] - bounds[1][0];
582 if (d1 <= 90.+FTINY)
583 fprintf(out, "src_phi4 ");
584 else if (d1 <= 180.+FTINY)
585 fprintf(out, "src_phi2 ");
586 else
587 fprintf(out, "src_phi ");
588 fprintf(out, "src_theta ");
589 if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
590 fprintf(out, "-rz -90 ");
591 } else
592 fprintf(out, "src_theta ");
593 }
594 fprintf(out, "\n0\n1 %g\n", multiplier*mult*bfactor*pfactor);
595 if (putsource(&srcshape, out, id, filename(name),
596 bounds[0][0]<90., bounds[0][1]>90.) != 0)
597 return(-1);
598 return(0);
599 }
600
601
602 putsource(shp, fp, mod, name, dolower, doupper) /* put out source */
603 SHAPE *shp;
604 FILE *fp;
605 char *mod, *name;
606 int dolower, doupper;
607 {
608 char buf[MAXWORD];
609
610 fprintf(fp, "\n%s %s %s_light\n", mod,
611 illumrad>=MINDIM/2. ? "illum" : "light",
612 name);
613 fprintf(fp, "0\n0\n3 %g %g %g\n",
614 lampcolor[0]/shp->area,
615 lampcolor[1]/shp->area,
616 lampcolor[2]/shp->area);
617 if (doupper && dolower && shp->type != SPHERE && shp->h > MINDIM) {
618 fprintf(fp, "\n%s glow %s_glow\n", mod, name);
619 fprintf(fp, "0\n0\n4 %g %g %g -1\n",
620 lampcolor[0]/shp->area,
621 lampcolor[1]/shp->area,
622 lampcolor[2]/shp->area);
623 }
624 switch (shp->type) {
625 case RECT:
626 strcat(strcpy(buf, name), "_light");
627 if (dolower)
628 putrectsrc(shp, fp, buf, name, 0);
629 if (doupper)
630 putrectsrc(shp, fp, buf, name, 1);
631 if (doupper && dolower && shp->h > MINDIM) {
632 strcat(strcpy(buf, name), "_glow");
633 putsides(shp, fp, buf, name);
634 }
635 break;
636 case DISK:
637 strcat(strcpy(buf, name), "_light");
638 if (dolower)
639 putdisksrc(shp, fp, buf, name, 0);
640 if (doupper)
641 putdisksrc(shp, fp, buf, name, 1);
642 if (doupper && dolower && shp->h > MINDIM) {
643 strcat(strcpy(buf, name), "_glow");
644 putcyl(shp, fp, buf, name);
645 }
646 break;
647 case SPHERE:
648 strcat(strcpy(buf, name), "_light");
649 putspheresrc(shp, fp, buf, name);
650 break;
651 }
652 return(0);
653 }
654
655
656 makeshape(shp, width, length, height) /* make source shape */
657 register SHAPE *shp;
658 double width, length, height;
659 {
660 if (illumrad >= MINDIM/2.) {
661 shp->type = SPHERE;
662 shp->w = shp->l = shp->h = 2.*illumrad;
663 } else if (width < MINDIM) {
664 width = -width;
665 if (width < MINDIM) {
666 shp->type = SPHERE;
667 shp->w = shp->l = shp->h = MINDIM;
668 } else if (height < .5*width) {
669 shp->type = DISK;
670 shp->w = shp->l = width;
671 if (height >= MINDIM)
672 shp->h = height;
673 else
674 shp->h = .5*MINDIM;
675 } else {
676 shp->type = SPHERE;
677 shp->w = shp->l = shp->h = width;
678 }
679 } else {
680 shp->type = RECT;
681 shp->w = width;
682 if (length >= MINDIM)
683 shp->l = length;
684 else
685 shp->l = MINDIM;
686 if (height >= MINDIM)
687 shp->h = height;
688 else
689 shp->h = .5*MINDIM;
690 }
691 switch (shp->type) {
692 case RECT:
693 shp->area = shp->w * shp->l;
694 break;
695 case DISK:
696 case SPHERE:
697 shp->area = PI/4. * shp->w * shp->w;
698 break;
699 }
700 return(0);
701 }
702
703
704 putrectsrc(shp, fp, mod, name, up) /* rectangular source */
705 SHAPE *shp;
706 FILE *fp;
707 char *mod, *name;
708 int up;
709 {
710 if (up)
711 putrect(shp, fp, mod, name, ".u", 4, 5, 7, 6);
712 else
713 putrect(shp, fp, mod, name, ".d", 0, 2, 3, 1);
714 }
715
716
717 putsides(shp, fp, mod, name) /* put out sides of box */
718 register SHAPE *shp;
719 FILE *fp;
720 char *mod, *name;
721 {
722 putrect(shp, fp, mod, name, ".1", 0, 1, 5, 4);
723 putrect(shp, fp, mod, name, ".2", 1, 3, 7, 5);
724 putrect(shp, fp, mod, name, ".3", 3, 2, 6, 7);
725 putrect(shp, fp, mod, name, ".4", 2, 0, 4, 6);
726 }
727
728
729 putrect(shp, fp, mod, name, suffix, a, b, c, d) /* put out a rectangle */
730 SHAPE *shp;
731 FILE *fp;
732 char *mod, *name, *suffix;
733 int a, b, c, d;
734 {
735 fprintf(fp, "\n%s polygon %s%s\n0\n0\n12\n", mod, name, suffix);
736 putpoint(shp, fp, a);
737 putpoint(shp, fp, b);
738 putpoint(shp, fp, c);
739 putpoint(shp, fp, d);
740 }
741
742
743 putpoint(shp, fp, p) /* put out a point */
744 register SHAPE *shp;
745 FILE *fp;
746 int p;
747 {
748 static double mult[2] = {-.5, .5};
749
750 fprintf(fp, "\t%g\t%g\t%g\n",
751 mult[p&1]*shp->l*meters2out,
752 mult[p>>1&1]*shp->w*meters2out,
753 mult[p>>2]*shp->h*meters2out);
754 }
755
756
757 putdisksrc(shp, fp, mod, name, up) /* put out a disk source */
758 register SHAPE *shp;
759 FILE *fp;
760 char *mod, *name;
761 int up;
762 {
763 if (up) {
764 fprintf(fp, "\n%s ring %s.u\n", mod, name);
765 fprintf(fp, "0\n0\n8\n");
766 fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
767 fprintf(fp, "\t0 0 1\n");
768 fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
769 } else {
770 fprintf(fp, "\n%s ring %s.d\n", mod, name);
771 fprintf(fp, "0\n0\n8\n");
772 fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
773 fprintf(fp, "\t0 0 -1\n");
774 fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
775 }
776 }
777
778
779 putcyl(shp, fp, mod, name) /* put out a cylinder */
780 register SHAPE *shp;
781 FILE *fp;
782 char *mod, *name;
783 {
784 fprintf(fp, "\n%s cylinder %s.c\n", mod, name);
785 fprintf(fp, "0\n0\n7\n");
786 fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
787 fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
788 fprintf(fp, "\t%g\n", .5*shp->w*meters2out);
789 }
790
791
792 putspheresrc(shp, fp, mod, name) /* put out a sphere source */
793 SHAPE *shp;
794 FILE *fp;
795 char *mod, *name;
796 {
797 fprintf(fp, "\n%s sphere %s.s\n", mod, name);
798 fprintf(fp, "0\n0\n4 0 0 0 %g\n", .5*shp->w*meters2out);
799 }
800
801
802 cvdata(in, out, ndim, npts, mult, lim) /* convert data */
803 FILE *in, *out;
804 int ndim, npts[];
805 double mult, lim[][2];
806 {
807 double *pt[4];
808 register int i, j;
809 double val;
810 int total;
811
812 total = 1; j = 0;
813 for (i = 0; i < ndim; i++)
814 if (npts[i] > 1) {
815 total *= npts[i];
816 j++;
817 }
818 fprintf(out, "%d\n", j);
819 /* get coordinates */
820 for (i = 0; i < ndim; i++) {
821 pt[i] = (double *)malloc(npts[i]*sizeof(double));
822 for (j = 0; j < npts[i]; j++)
823 if (!scnflt(in, &pt[i][j]))
824 return(-1);
825 if (lim != NULL) {
826 lim[i][0] = pt[i][0];
827 lim[i][1] = pt[i][npts[i]-1];
828 }
829 }
830 /* write out in reverse */
831 for (i = ndim-1; i >= 0; i--) {
832 if (npts[i] > 1) {
833 for (j = 1; j < npts[i]-1; j++)
834 if (!FEQ(pt[i][j]-pt[i][j-1],
835 pt[i][j+1]-pt[i][j]))
836 break;
837 if (j == npts[i]-1)
838 fprintf(out, "%g %g %d\n", pt[i][0], pt[i][j],
839 npts[i]);
840 else {
841 fprintf(out, "0 0 %d", npts[i]);
842 for (j = 0; j < npts[i]; j++) {
843 if (j%4 == 0)
844 putc('\n', out);
845 fprintf(out, "\t%g", pt[i][j]);
846 }
847 putc('\n', out);
848 }
849 }
850 free((char *)pt[i]);
851 }
852 for (i = 0; i < total; i++) {
853 if (i%4 == 0)
854 putc('\n', out);
855 if (!scnflt(in, &val))
856 return(-1);
857 fprintf(out, "\t%g", val*mult);
858 }
859 putc('\n', out);
860 return(0);
861 }
862
863
864 char *
865 getword(fp) /* scan a word from fp */
866 register FILE *fp;
867 {
868 static char word[MAXWORD];
869 register char *cp;
870 register int c;
871
872 while (isspace(c=getc(fp)))
873 ;
874 for (cp = word; c != EOF && cp < word+MAXWORD-1;
875 *cp++ = c, c = getc(fp))
876 if (isspace(c) || c == ',') {
877 while (isspace(c))
878 c = getc(fp);
879 if (c != EOF & c != ',')
880 ungetc(c, fp);
881 *cp = '\0';
882 return(word);
883 }
884 *cp = '\0';
885 return(cp > word ? word : NULL);
886 }
887
888
889 cvtint(ip, word) /* convert a word to an integer */
890 int *ip;
891 char *word;
892 {
893 if (word == NULL || !isint(word))
894 return(0);
895 *ip = atoi(word);
896 return(1);
897 }
898
899
900 cvtflt(rp, word) /* convert a word to a double */
901 double *rp;
902 char *word;
903 {
904 if (word == NULL || !isflt(word))
905 return(0);
906 *rp = atof(word);
907 return(1);
908 }
