root/radiance/ray/src/cv/ies2rad.c
Revision: 2.3
Committed: Thu May 21 09:56:36 1992 UTC (32 years, 1 month ago) by greg
fixed register allocation IBM RS/6000 didn't like
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert IES luminaire data to Radiance description
9 *
10 * 07Apr90 Greg Ward
11 */
12
13 #include <stdio.h>
14 #include <ctype.h>
15 #include "color.h"
16
17 #define PI 3.14159265358979323846
18 /* floating comparisons */
19 #define FTINY 1e-6
20 #define FEQ(a,b) ((a)<=(b)+FTINY&&(a)>=(b)-FTINY)
21 /* tilt specs */
22 #define TLTSTR "TILT="
23 #define TLTSTRLEN 5
24 #define TLTNONE "NONE"
25 #define TLTINCL "INCLUDE"
26 #define TLT_VERT 1
27 #define TLT_H0 2
28 #define TLT_H90 3
29 /* photometric types */
30 #define PM_C 1
31 #define PM_B 2
32 /* unit types */
33 #define U_FEET 1
34 #define U_METERS 2
35 /* string lengths */
36 #define MAXLINE 132
37 #define MAXWORD 76
38 #define MAXPATH 128
39 /* file types */
40 #define T_RAD ".rad"
41 #define T_DST ".dat"
42 #define T_TLT "+.dat"
43 /* shape types */
44 #define RECT 1
45 #define DISK 2
46 #define SPHERE 3
47
48 #define MINDIM .001 /* minimum dimension (point source) */
49
50 #define F_M .3048 /* feet to meters */
51
52 #define abspath(p) ((p)[0] == '/' || (p)[0] == '.')
53
54 static char default_name[] = "default";
55
56 char *libdir = NULL; /* library directory location */
57 char *prefdir = NULL; /* subdirectory */
58 char *lampdat = "lamp.tab"; /* lamp data file */
59
60 double meters2out = 1.0; /* conversion from meters to output */
61 char *lamptype = NULL; /* selected lamp type */
62 char *deflamp = NULL; /* default lamp type */
63 float defcolor[3] = {1.,1.,1.}; /* default lamp color */
64 float *lampcolor = defcolor; /* pointer to current lamp color */
65 double multiplier = 1.0; /* multiplier for all light sources */
66 char units[64] = "meters"; /* output units */
67 double minaspect = 0.0; /* minimum allowed aspect ratio */
68 int maxemitters = 1; /* maximum emitters per hemisphere */
69 double illumrad = 0.0; /* radius for illum sphere */
70
71 typedef struct {
72 int type; /* RECT, DISK, SPHERE */
73 double w, l, h; /* width, length, height */
74 double area; /* max. projected area */
75 } SHAPE; /* a source shape */
76
77 int gargc; /* global argc (minus filenames) */
78 char **gargv; /* global argv */
79
80 extern char *strcpy(), *strcat(), *stradd(), *tailtrunc(), *filetrunc(),
81 *filename(), *libname(), *fullname(), *malloc();
82 extern float *matchlamp();
83
84
85 main(argc, argv)
86 int argc;
87 char *argv[];
88 {
89 char *outfile = NULL;
90 int status;
91 char outname[MAXWORD];
92 double d1;
93 int i;
94
95 for (i = 1; i < argc && argv[i][0] == '-'; i++)
96 switch (argv[i][1]) {
97 case 'd': /* dimensions */
98 if (argv[i][2] == '\0')
99 goto badopt;
100 if (argv[i][3] == '\0')
101 d1 = 1.0;
102 else if (argv[i][3] == '/') {
103 d1 = atof(argv[i]+4);
104 if (d1 <= FTINY)
105 goto badopt;
106 } else
107 goto badopt;
108 switch (argv[i][2]) {
109 case 'c': /* centimeters */
110 if (FEQ(d1,10.))
111 strcpy(units,"millimeters");
112 else {
113 strcpy(units,"centimeters");
114 strcat(units,argv[i]+3);
115 }
116 meters2out = 100.*d1;
117 break;
118 case 'm': /* meters */
119 if (FEQ(d1,1000.))
120 strcpy(units,"millimeters");
121 else if (FEQ(d1,100.))
122 strcpy(units,"centimeters");
123 else {
124 strcpy(units,"meters");
125 strcat(units,argv[i]+3);
126 }
127 meters2out = d1;
128 break;
129 case 'i': /* inches */
130 strcpy(units,"inches");
131 strcat(units,argv[i]+3);
132 meters2out = d1*(12./F_M);
133 break;
134 case 'f': /* feet */
135 if (FEQ(d1,12.))
136 strcpy(units,"inches");
137 else {
138 strcpy(units,"feet");
139 strcat(units,argv[i]+3);
140 }
141 meters2out = d1/F_M;
142 break;
143 default:
144 goto badopt;
145 }
146 break;
147 case 'l': /* library directory */
148 libdir = argv[++i];
149 break;
150 case 'p': /* prefix subdirectory */
151 prefdir = argv[++i];
152 break;
153 case 'f': /* lamp data file */
154 lampdat = argv[++i];
155 break;
156 case 'o': /* output file name */
157 outfile = argv[++i];
158 break;
159 case 's': /* square emitters */
160 minaspect = .6;
161 if (argv[i][2] == '/') {
162 maxemitters = atoi(argv[i]+3);
163 if (maxemitters < 1)
164 goto badopt;
165 }
166 break;
167 case 'i': /* illum */
168 illumrad = atof(argv[++i]);
169 if (illumrad < MINDIM)
170 illumrad = MINDIM;
171 break;
172 case 't': /* override lamp type */
173 lamptype = argv[++i];
174 break;
175 case 'u': /* default lamp type */
176 deflamp = argv[++i];
177 break;
178 case 'c': /* default lamp color */
179 defcolor[0] = atof(argv[++i]);
180 defcolor[1] = atof(argv[++i]);
181 defcolor[2] = atof(argv[++i]);
182 break;
183 case 'm': /* multiplier */
184 multiplier = atof(argv[++i]);
185 break;
186 default:
187 badopt:
188 fprintf(stderr, "%s: bad option: %s\n",
189 argv[0], argv[i]);
190 exit(1);
191 }
192 gargc = i;
193 gargv = argv;
194 initlamps(); /* get lamp data (if needed) */
195 /* convert ies file(s) */
196 if (outfile != NULL) {
197 if (i == argc)
198 exit(ies2rad(NULL, outfile) == 0 ? 0 : 1);
199 else if (i == argc-1)
200 exit(ies2rad(argv[i], outfile) == 0 ? 0 : 1);
201 else {
202 fprintf(stderr, "%s: single input file required\n",
203 argv[0]);
204 exit(1);
205 }
206 } else if (i >= argc) {
207 fprintf(stderr, "%s: missing output file specification\n",
208 argv[0]);
209 exit(1);
210 }
211 status = 0;
212 for ( ; i < argc; i++) {
213 tailtrunc(strcpy(outname,filename(argv[i])));
214 if (ies2rad(argv[i], outname) != 0)
215 status = 1;
216 }
217 exit(status);
218 }
219
220
221 initlamps() /* set up lamps */
222 {
223 float *lcol;
224 int status;
225
226 if (lamptype != NULL && !strcmp(lamptype, default_name) &&
227 deflamp == NULL)
228 return; /* no need for data */
229 /* else load file */
230 if ((status = loadlamps(lampdat)) < 0)
231 exit(1);
232 if (status == 0) {
233 fprintf(stderr, "%s: warning - no lamp data\n", lampdat);
234 lamptype = default_name;
235 return;
236 }
237 if (deflamp != NULL) { /* match default type */
238 if ((lcol = matchlamp(deflamp)) == NULL)
239 fprintf(stderr,
240 "%s: warning - unknown default lamp type\n",
241 deflamp);
242 else
243 copycolor(defcolor, lcol);
244 }
245 if (lamptype != NULL) { /* match selected type */
246 if (strcmp(lamptype, default_name)) {
247 if ((lcol = matchlamp(lamptype)) == NULL) {
248 fprintf(stderr,
249 "%s: warning - unknown lamp type\n",
250 lamptype);
251 lamptype = default_name;
252 } else
253 copycolor(defcolor, lcol);
254 }
255 freelamps(); /* all done with data */
256 }
257 /* else keep lamp data */
258 }
259
260
261 char *
262 stradd(dst, src, sep) /* add a string at dst */
263 register char *dst, *src;
264 int sep;
265 {
266 if (src && *src) {
267 do
268 *dst++ = *src++;
269 while (*src);
270 if (sep && dst[-1] != sep)
271 *dst++ = sep;
272 }
273 *dst = '\0';
274 return(dst);
275 }
276
277
278 char *
279 fullname(path, fname, suffix) /* return full path name */
280 char *path, *fname, *suffix;
281 {
282 if (prefdir != NULL && abspath(prefdir))
283 libname(path, fname, suffix);
284 else if (abspath(fname))
285 strcpy(stradd(path, fname, 0), suffix);
286 else
287 libname(stradd(path, libdir, '/'), fname, suffix);
288
289 return(path);
290 }
291
292
293 char *
294 libname(path, fname, suffix) /* return library relative name */
295 char *path, *fname, *suffix;
296 {
297 if (abspath(fname))
298 strcpy(stradd(path, fname, 0), suffix);
299 else
300 strcpy(stradd(stradd(path, prefdir, '/'), fname, 0), suffix);
301
302 return(path);
303 }
304
305
306 char *
307 filename(path) /* get final component of pathname */
308 register char *path;
309 {
310 register char *cp;
311
312 for (cp = path; *path; path++)
313 if (*path == '/')
314 cp = path+1;
315 return(cp);
316 }
317
318
319 char *
320 filetrunc(path) /* truncate filename at end of path */
321 char *path;
322 {
323 register char *p1, *p2;
324
325 for (p1 = p2 = path; *p2; p2++)
326 if (*p2 == '/')
327 p1 = p2;
328 *p1 = '\0';
329 return(path);
330 }
331
332
333 char *
334 tailtrunc(name) /* truncate tail of filename */
335 char *name;
336 {
337 register char *p1, *p2;
338
339 for (p1 = filename(name); *p1 == '.'; p1++)
340 ;
341 p2 = NULL;
342 for ( ; *p1; p1++)
343 if (*p1 == '.')
344 p2 = p1;
345 if (p2 != NULL)
346 *p2 = '\0';
347 return(name);
348 }
349
350
351 blanktrunc(s) /* truncate spaces at end of line */
352 char *s;
353 {
354 register char *cp;
355
356 for (cp = s; *cp; cp++)
357 ;
358 while (cp-- > s && isspace(*cp))
359 ;
360 *++cp = '\0';
361 }
362
363
364 putheader(out) /* print header */
365 FILE *out;
366 {
367 register int i;
368
369 putc('#', out);
370 for (i = 0; i < gargc; i++) {
371 putc(' ', out);
372 fputs(gargv[i], out);
373 }
374 fputs("\n# Dimensions in ", out);
375 fputs(units, out);
376 putc('\n', out);
377 }
378
379
380 ies2rad(inpname, outname) /* convert IES file */
381 char *inpname, *outname;
382 {
383 char buf[MAXLINE], tltid[MAXWORD];
384 FILE *inpfp, *outfp;
385
386 if (inpname == NULL) {
387 inpname = "<stdin>";
388 inpfp = stdin;
389 } else if ((inpfp = fopen(inpname, "r")) == NULL) {
390 perror(inpname);
391 return(-1);
392 }
393 if ((outfp = fopen(fullname(buf,outname,T_RAD), "w")) == NULL) {
394 perror(buf);
395 fclose(inpfp);
396 return(-1);
397 }
398 putheader(outfp);
399 if (lamptype == NULL)
400 lampcolor = NULL;
401 while (fgets(buf,sizeof(buf),inpfp) != NULL
402 && strncmp(buf,TLTSTR,TLTSTRLEN)) {
403 blanktrunc(buf);
404 if (!buf[0])
405 continue;
406 fputs("#<", outfp);
407 fputs(buf, outfp);
408 putc('\n', outfp);
409 if (lampcolor == NULL)
410 lampcolor = matchlamp(buf);
411 }
412 if (lampcolor == NULL) {
413 fprintf(stderr, "%s: warning - no lamp type\n", inpname);
414 lampcolor = defcolor;
415 }
416 if (feof(inpfp)) {
417 fprintf(stderr, "%s: not in IES format\n", inpname);
418 goto readerr;
419 }
420 sscanf(buf+TLTSTRLEN, "%s", tltid);
421 if (inpfp == stdin)
422 buf[0] = '\0';
423 else
424 filetrunc(strcpy(buf, inpname));
425 if (dotilt(inpfp, outfp, buf, tltid, outname, tltid) != 0) {
426 fprintf(stderr, "%s: bad tilt data\n", inpname);
427 goto readerr;
428 }
429 if (dosource(inpfp, outfp, tltid, outname) != 0) {
430 fprintf(stderr, "%s: bad luminaire data\n", inpname);
431 goto readerr;
432 }
433 fclose(outfp);
434 fclose(inpfp);
435 return(0);
436 readerr:
437 fclose(outfp);
438 fclose(inpfp);
439 unlink(fullname(buf,outname,T_RAD));
440 return(-1);
441 }
442
443
444 dotilt(in, out, dir, tltspec, dfltname, tltid) /* convert tilt data */
445 FILE *in, *out;
446 char *dir, *tltspec, *dfltname, *tltid;
447 {
448 int nangles, tlt_type;
449 double minmax[2];
450 char buf[MAXPATH], tltname[MAXWORD];
451 FILE *datin, *datout;
452
453 if (!strcmp(tltspec, TLTNONE)) {
454 datin = NULL;
455 strcpy(tltid, "void");
456 } else if (!strcmp(tltspec, TLTINCL)) {
457 datin = in;
458 strcpy(tltname, dfltname);
459 } else {
460 if (tltspec[0] == '/')
461 strcpy(buf, tltspec);
462 else
463 strcpy(stradd(buf, dir, '/'), tltspec);
464 if ((datin = fopen(buf, "r")) == NULL) {
465 perror(buf);
466 return(-1);
467 }
468 tailtrunc(strcpy(tltname,filename(tltspec)));
469 }
470 if (datin != NULL) {
471 if ((datout = fopen(fullname(buf,tltname,T_TLT),"w")) == NULL) {
472 perror(buf);
473 if (datin != in)
474 fclose(datin);
475 return(-1);
476 }
477 if (fscanf(datin, "%d %d", &tlt_type, &nangles) != 2
478 || cvdata(datin,datout,1,&nangles,1.,minmax) != 0) {
479 fprintf(stderr, "%s: data format error\n", tltspec);
480 fclose(datout);
481 if (datin != in)
482 fclose(datin);
483 unlink(fullname(buf,tltname,T_TLT));
484 return(-1);
485 }
486 fclose(datout);
487 if (datin != in)
488 fclose(datin);
489 strcat(strcpy(tltid, filename(tltname)), "_tilt");
490 fprintf(out, "\nvoid brightdata %s\n", tltid);
491 libname(buf,tltname,T_TLT);
492 switch (tlt_type) {
493 case TLT_VERT: /* vertical */
494 fprintf(out, "4 noop %s tilt.cal %s\n", buf,
495 minmax[1]>90.+FTINY ? "tilt_ang" : "tilt_ang2");
496 break;
497 case TLT_H0: /* horiz. in 0 deg. plane */
498 fprintf(out, "6 noop %s tilt.cal %s -rz 90\n", buf,
499 minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
500 break;
501 case TLT_H90:
502 fprintf(out, "4 noop %s tilt.cal %s\n", buf,
503 minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
504 break;
505 default:
506 fprintf(stderr,
507 "%s: illegal lamp to luminaire geometry (%d)\n",
508 tltspec, tlt_type);
509 return(-1);
510 }
511 fprintf(out, "0\n0\n");
512 }
513 return(0);
514 }
515
516
517 dosource(in, out, mod, name) /* create source and distribution */
518 FILE *in, *out;
519 char *mod, *name;
520 {
521 SHAPE srcshape;
522 char buf[MAXPATH], id[MAXWORD];
523 FILE *datout;
524 double mult, bfactor, pfactor, width, length, height, wattage;
525 double bounds[2][2];
526 int nangles[2], pmtype, unitype;
527 double d1;
528
529 if (fscanf(in, "%*d %*f %lf %d %d %d %d %lf %lf %lf %lf %lf %lf",
530 &mult, &nangles[0], &nangles[1], &pmtype, &unitype,
531 &width, &length, &height, &bfactor, &pfactor,
532 &wattage) != 11) {
533 fprintf(stderr, "dosource: bad lamp specification\n");
534 return(-1);
535 }
536 if (nangles[0] < 2 || nangles[1] < 1) {
537 fprintf(stderr, "dosource: too few measured angles\n");
538 return(-1);
539 }
540 if (unitype == U_FEET) {
541 width *= F_M;
542 length *= F_M;
543 height *= F_M;
544 }
545 if (makeshape(&srcshape, width, length, height) != 0) {
546 fprintf(stderr, "dosource: illegal source dimensions");
547 return(-1);
548 }
549 if ((datout = fopen(fullname(buf,name,T_DST), "w")) == NULL) {
550 perror(buf);
551 return(-1);
552 }
553 if (cvdata(in, datout, 2, nangles, 1./WHTEFFICACY, bounds) != 0) {
554 fprintf(stderr, "dosource: bad distribution data\n");
555 fclose(datout);
556 unlink(fullname(buf,name,T_DST));
557 return(-1);
558 }
559 fclose(datout);
560 fprintf(out, "# %g watt luminaire, lamp*ballast factor = %g\n",
561 wattage, bfactor*pfactor);
562 strcat(strcpy(id, filename(name)), "_dist");
563 fprintf(out, "\n%s brightdata %s\n", mod, id);
564 if (nangles[1] < 2)
565 fprintf(out, "4 ");
566 else if (pmtype == PM_B)
567 fprintf(out, "5 ");
568 else if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
569 fprintf(out, "8 ");
570 else
571 fprintf(out, "6 ");
572 fprintf(out, "%s %s source.cal ",
573 srcshape.type==SPHERE ? "corr" : "flatcorr",
574 libname(buf,name,T_DST));
575 if (pmtype == PM_B) {
576 if (FEQ(bounds[1][0],0.))
577 fprintf(out, "srcB_horiz2 ");
578 else
579 fprintf(out, "srcB_horiz ");
580 fprintf(out, "srcB_vert ");
581 } else {
582 if (nangles[1] >= 2) {
583 d1 = bounds[1][1] - bounds[1][0];
584 if (d1 <= 90.+FTINY)
585 fprintf(out, "src_phi4 ");
586 else if (d1 <= 180.+FTINY)
587 fprintf(out, "src_phi2 ");
588 else
589 fprintf(out, "src_phi ");
590 fprintf(out, "src_theta -my ");
591 if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
592 fprintf(out, "-rz -90 ");
593 } else
594 fprintf(out, "src_theta ");
595 }
596 fprintf(out, "\n0\n1 %g\n", multiplier*mult*bfactor*pfactor);
597 if (putsource(&srcshape, out, id, filename(name),
598 bounds[0][0]<90., bounds[0][1]>90.) != 0)
599 return(-1);
600 return(0);
601 }
602
603
604 putsource(shp, fp, mod, name, dolower, doupper) /* put out source */
605 SHAPE *shp;
606 FILE *fp;
607 char *mod, *name;
608 int dolower, doupper;
609 {
610 char buf[MAXWORD];
611
612 fprintf(fp, "\n%s %s %s_light\n", mod,
613 illumrad>=MINDIM/2. ? "illum" : "light",
614 name);
615 fprintf(fp, "0\n0\n3 %g %g %g\n",
616 lampcolor[0]/shp->area,
617 lampcolor[1]/shp->area,
618 lampcolor[2]/shp->area);
619 if (doupper && dolower && shp->type != SPHERE && shp->h > MINDIM) {
620 fprintf(fp, "\n%s glow %s_glow\n", mod, name);
621 fprintf(fp, "0\n0\n4 %g %g %g 0\n",
622 lampcolor[0]/shp->area,
623 lampcolor[1]/shp->area,
624 lampcolor[2]/shp->area);
625 }
626 switch (shp->type) {
627 case RECT:
628 strcat(strcpy(buf, name), "_light");
629 if (dolower)
630 putrectsrc(shp, fp, buf, name, 0);
631 if (doupper)
632 putrectsrc(shp, fp, buf, name, 1);
633 if (doupper && dolower && shp->h > MINDIM) {
634 strcat(strcpy(buf, name), "_glow");
635 putsides(shp, fp, buf, name);
636 }
637 break;
638 case DISK:
639 strcat(strcpy(buf, name), "_light");
640 if (dolower)
641 putdisksrc(shp, fp, buf, name, 0);
642 if (doupper)
643 putdisksrc(shp, fp, buf, name, 1);
644 if (doupper && dolower && shp->h > MINDIM) {
645 strcat(strcpy(buf, name), "_glow");
646 putcyl(shp, fp, buf, name);
647 }
648 break;
649 case SPHERE:
650 strcat(strcpy(buf, name), "_light");
651 putspheresrc(shp, fp, buf, name);
652 break;
653 }
654 return(0);
655 }
656
657
658 makeshape(shp, width, length, height) /* make source shape */
659 register SHAPE *shp;
660 double width, length, height;
661 {
662 if (illumrad >= MINDIM/2.) {
663 shp->type = SPHERE;
664 shp->w = shp->l = shp->h = 2.*illumrad;
665 } else if (width < MINDIM) {
666 width = -width;
667 if (width < MINDIM) {
668 shp->type = SPHERE;
669 shp->w = shp->l = shp->h = MINDIM;
670 } else if (height < .5*width) {
671 shp->type = DISK;
672 shp->w = shp->l = width;
673 if (height >= MINDIM)
674 shp->h = height;
675 else
676 shp->h = .5*MINDIM;
677 } else {
678 shp->type = SPHERE;
679 shp->w = shp->l = shp->h = width;
680 }
681 } else {
682 shp->type = RECT;
683 shp->w = width;
684 if (length >= MINDIM)
685 shp->l = length;
686 else
687 shp->l = MINDIM;
688 if (height >= MINDIM)
689 shp->h = height;
690 else
691 shp->h = .5*MINDIM;
692 }
693 switch (shp->type) {
694 case RECT:
695 shp->area = shp->w * shp->l;
696 break;
697 case DISK:
698 case SPHERE:
699 shp->area = PI/4. * shp->w * shp->w;
700 break;
701 }
702 return(0);
703 }
704
705
706 putrectsrc(shp, fp, mod, name, up) /* rectangular source */
707 SHAPE *shp;
708 FILE *fp;
709 char *mod, *name;
710 int up;
711 {
712 if (up)
713 putrect(shp, fp, mod, name, ".u", 4, 5, 7, 6);
714 else
715 putrect(shp, fp, mod, name, ".d", 0, 2, 3, 1);
716 }
717
718
719 putsides(shp, fp, mod, name) /* put out sides of box */
720 register SHAPE *shp;
721 FILE *fp;
722 char *mod, *name;
723 {
724 putrect(shp, fp, mod, name, ".1", 0, 1, 5, 4);
725 putrect(shp, fp, mod, name, ".2", 1, 3, 7, 5);
726 putrect(shp, fp, mod, name, ".3", 3, 2, 6, 7);
727 putrect(shp, fp, mod, name, ".4", 2, 0, 4, 6);
728 }
729
730
731 putrect(shp, fp, mod, name, suffix, a, b, c, d) /* put out a rectangle */
732 SHAPE *shp;
733 FILE *fp;
734 char *mod, *name, *suffix;
735 int a, b, c, d;
736 {
737 fprintf(fp, "\n%s polygon %s%s\n0\n0\n12\n", mod, name, suffix);
738 putpoint(shp, fp, a);
739 putpoint(shp, fp, b);
740 putpoint(shp, fp, c);
741 putpoint(shp, fp, d);
742 }
743
744
745 putpoint(shp, fp, p) /* put out a point */
746 register SHAPE *shp;
747 FILE *fp;
748 int p;
749 {
750 static double mult[2] = {-.5, .5};
751
752 fprintf(fp, "\t%g\t%g\t%g\n",
753 mult[p&1]*shp->l*meters2out,
754 mult[p>>1&1]*shp->w*meters2out,
755 mult[p>>2]*shp->h*meters2out);
756 }
757
758
759 putdisksrc(shp, fp, mod, name, up) /* put out a disk source */
760 register SHAPE *shp;
761 FILE *fp;
762 char *mod, *name;
763 int up;
764 {
765 if (up) {
766 fprintf(fp, "\n%s ring %s.u\n", mod, name);
767 fprintf(fp, "0\n0\n8\n");
768 fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
769 fprintf(fp, "\t0 0 1\n");
770 fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
771 } else {
772 fprintf(fp, "\n%s ring %s.d\n", mod, name);
773 fprintf(fp, "0\n0\n8\n");
774 fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
775 fprintf(fp, "\t0 0 -1\n");
776 fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
777 }
778 }
779
780
781 putcyl(shp, fp, mod, name) /* put out a cylinder */
782 register SHAPE *shp;
783 FILE *fp;
784 char *mod, *name;
785 {
786 fprintf(fp, "\n%s cylinder %s.c\n", mod, name);
787 fprintf(fp, "0\n0\n7\n");
788 fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
789 fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
790 fprintf(fp, "\t%g\n", .5*shp->w*meters2out);
791 }
792
793
794 putspheresrc(shp, fp, mod, name) /* put out a sphere source */
795 SHAPE *shp;
796 FILE *fp;
797 char *mod, *name;
798 {
799 fprintf(fp, "\n%s sphere %s.s\n", mod, name);
800 fprintf(fp, "0\n0\n4 0 0 0 %g\n", .5*shp->w*meters2out);
801 }
802
803
804 cvdata(in, out, ndim, npts, mult, lim) /* convert data */
805 FILE *in, *out;
806 int ndim, npts[];
807 double mult, lim[][2];
808 {
809 double *pt[4];
810 register int i, j;
811 double val;
812 int total;
813
814 total = 1; j = 0;
815 for (i = 0; i < ndim; i++)
816 if (npts[i] > 1) {
817 total *= npts[i];
818 j++;
819 }
820 fprintf(out, "%d\n", j);
821 /* get coordinates */
822 for (i = 0; i < ndim; i++) {
823 pt[i] = (double *)malloc(npts[i]*sizeof(double));
824 for (j = 0; j < npts[i]; j++)
825 fscanf(in, "%lf", &pt[i][j]);
826 if (lim != NULL) {
827 lim[i][0] = pt[i][0];
828 lim[i][1] = pt[i][npts[i]-1];
829 }
830 }
831 /* write out in reverse */
832 for (i = ndim-1; i >= 0; i--) {
833 if (npts[i] > 1) {
834 for (j = 1; j < npts[i]-1; j++)
835 if (!FEQ(pt[i][j]-pt[i][j-1],
836 pt[i][j+1]-pt[i][j]))
837 break;
838 if (j == npts[i]-1)
839 fprintf(out, "%g %g %d\n", pt[i][0], pt[i][j],
840 npts[i]);
841 else {
842 fprintf(out, "0 0 %d", npts[i]);
843 for (j = 0; j < npts[i]; j++) {
844 if (j%4 == 0)
845 putc('\n', out);
846 fprintf(out, "\t%g", pt[i][j]);
847 }
848 putc('\n', out);
849 }
850 }
851 free((char *)pt[i]);
852 }
853 for (i = 0; i < total; i++) {
854 if (i%4 == 0)
855 putc('\n', out);
856 if (fscanf(in, "%lf", &val) != 1)
857 return(-1);
858 fprintf(out, "\t%g", val*mult);
859 }
860 putc('\n', out);
861 return(0);
862 }
