root/radiance/ray/src/cv/ies2rad.c
Revision: 2.5
Committed: Mon Feb 22 15:54:55 1993 UTC (31 years, 4 months ago) by greg
modified to generate glow types with negative radii of influence
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert IES luminaire data to Radiance description
9 *
10 * 07Apr90 Greg Ward
11 */
12
13 #include <stdio.h>
14 #include <ctype.h>
15 #include "color.h"
16 #include "paths.h"
17
18 #define PI 3.14159265358979323846
19 /* floating comparisons */
20 #define FTINY 1e-6
21 #define FEQ(a,b) ((a)<=(b)+FTINY&&(a)>=(b)-FTINY)
22 /* tilt specs */
23 #define TLTSTR "TILT="
24 #define TLTSTRLEN 5
25 #define TLTNONE "NONE"
26 #define TLTINCL "INCLUDE"
27 #define TLT_VERT 1
28 #define TLT_H0 2
29 #define TLT_H90 3
30 /* photometric types */
31 #define PM_C 1
32 #define PM_B 2
33 /* unit types */
34 #define U_FEET 1
35 #define U_METERS 2
36 /* string lengths */
37 #define MAXLINE 132
38 #define MAXWORD 76
39 /* file types */
40 #define T_RAD ".rad"
41 #define T_DST ".dat"
42 #define T_TLT "+.dat"
43 /* shape types */
44 #define RECT 1
45 #define DISK 2
46 #define SPHERE 3
47
48 #define MINDIM .001 /* minimum dimension (point source) */
49
50 #define F_M .3048 /* feet to meters */
51
52 #define abspath(p) (ISDIRSEP((p)[0]) || (p)[0] == '.')
53
54 static char default_name[] = "default";
55
56 char *libdir = NULL; /* library directory location */
57 char *prefdir = NULL; /* subdirectory */
58 char *lampdat = "lamp.tab"; /* lamp data file */
59
60 double meters2out = 1.0; /* conversion from meters to output */
61 char *lamptype = NULL; /* selected lamp type */
62 char *deflamp = NULL; /* default lamp type */
63 float defcolor[3] = {1.,1.,1.}; /* default lamp color */
64 float *lampcolor = defcolor; /* pointer to current lamp color */
65 double multiplier = 1.0; /* multiplier for all light sources */
66 char units[64] = "meters"; /* output units */
67 double illumrad = 0.0; /* radius for illum sphere */
68
69 typedef struct {
70 int type; /* RECT, DISK, SPHERE */
71 double w, l, h; /* width, length, height */
72 double area; /* max. projected area */
73 } SHAPE; /* a source shape */
74
75 int gargc; /* global argc (minus filenames) */
76 char **gargv; /* global argv */
77
78 extern char *strcpy(), *strcat(), *stradd(), *tailtrunc(), *filetrunc(),
79 *filename(), *libname(), *fullname(), *malloc();
80 extern float *matchlamp();
81
82
83 main(argc, argv)
84 int argc;
85 char *argv[];
86 {
87 char *outfile = NULL;
88 int status;
89 char outname[MAXWORD];
90 double d1;
91 int i;
92
93 for (i = 1; i < argc && argv[i][0] == '-'; i++)
94 switch (argv[i][1]) {
95 case 'd': /* dimensions */
96 if (argv[i][2] == '\0')
97 goto badopt;
98 if (argv[i][3] == '\0')
99 d1 = 1.0;
100 else if (argv[i][3] == '/') {
101 d1 = atof(argv[i]+4);
102 if (d1 <= FTINY)
103 goto badopt;
104 } else
105 goto badopt;
106 switch (argv[i][2]) {
107 case 'c': /* centimeters */
108 if (FEQ(d1,10.))
109 strcpy(units,"millimeters");
110 else {
111 strcpy(units,"centimeters");
112 strcat(units,argv[i]+3);
113 }
114 meters2out = 100.*d1;
115 break;
116 case 'm': /* meters */
117 if (FEQ(d1,1000.))
118 strcpy(units,"millimeters");
119 else if (FEQ(d1,100.))
120 strcpy(units,"centimeters");
121 else {
122 strcpy(units,"meters");
123 strcat(units,argv[i]+3);
124 }
125 meters2out = d1;
126 break;
127 case 'i': /* inches */
128 strcpy(units,"inches");
129 strcat(units,argv[i]+3);
130 meters2out = d1*(12./F_M);
131 break;
132 case 'f': /* feet */
133 if (FEQ(d1,12.))
134 strcpy(units,"inches");
135 else {
136 strcpy(units,"feet");
137 strcat(units,argv[i]+3);
138 }
139 meters2out = d1/F_M;
140 break;
141 default:
142 goto badopt;
143 }
144 break;
145 case 'l': /* library directory */
146 libdir = argv[++i];
147 break;
148 case 'p': /* prefix subdirectory */
149 prefdir = argv[++i];
150 break;
151 case 'f': /* lamp data file */
152 lampdat = argv[++i];
153 break;
154 case 'o': /* output file name */
155 outfile = argv[++i];
156 break;
157 case 'i': /* illum */
158 illumrad = atof(argv[++i]);
159 if (illumrad < MINDIM)
160 illumrad = MINDIM;
161 break;
162 case 't': /* override lamp type */
163 lamptype = argv[++i];
164 break;
165 case 'u': /* default lamp type */
166 deflamp = argv[++i];
167 break;
168 case 'c': /* default lamp color */
169 defcolor[0] = atof(argv[++i]);
170 defcolor[1] = atof(argv[++i]);
171 defcolor[2] = atof(argv[++i]);
172 break;
173 case 'm': /* multiplier */
174 multiplier = atof(argv[++i]);
175 break;
176 default:
177 badopt:
178 fprintf(stderr, "%s: bad option: %s\n",
179 argv[0], argv[i]);
180 exit(1);
181 }
182 gargc = i;
183 gargv = argv;
184 initlamps(); /* get lamp data (if needed) */
185 /* convert ies file(s) */
186 if (outfile != NULL) {
187 if (i == argc)
188 exit(ies2rad(NULL, outfile) == 0 ? 0 : 1);
189 else if (i == argc-1)
190 exit(ies2rad(argv[i], outfile) == 0 ? 0 : 1);
191 else {
192 fprintf(stderr, "%s: single input file required\n",
193 argv[0]);
194 exit(1);
195 }
196 } else if (i >= argc) {
197 fprintf(stderr, "%s: missing output file specification\n",
198 argv[0]);
199 exit(1);
200 }
201 status = 0;
202 for ( ; i < argc; i++) {
203 tailtrunc(strcpy(outname,filename(argv[i])));
204 if (ies2rad(argv[i], outname) != 0)
205 status = 1;
206 }
207 exit(status);
208 }
209
210
211 initlamps() /* set up lamps */
212 {
213 float *lcol;
214 int status;
215
216 if (lamptype != NULL && !strcmp(lamptype, default_name) &&
217 deflamp == NULL)
218 return; /* no need for data */
219 /* else load file */
220 if ((status = loadlamps(lampdat)) < 0)
221 exit(1);
222 if (status == 0) {
223 fprintf(stderr, "%s: warning - no lamp data\n", lampdat);
224 lamptype = default_name;
225 return;
226 }
227 if (deflamp != NULL) { /* match default type */
228 if ((lcol = matchlamp(deflamp)) == NULL)
229 fprintf(stderr,
230 "%s: warning - unknown default lamp type\n",
231 deflamp);
232 else
233 copycolor(defcolor, lcol);
234 }
235 if (lamptype != NULL) { /* match selected type */
236 if (strcmp(lamptype, default_name)) {
237 if ((lcol = matchlamp(lamptype)) == NULL) {
238 fprintf(stderr,
239 "%s: warning - unknown lamp type\n",
240 lamptype);
241 lamptype = default_name;
242 } else
243 copycolor(defcolor, lcol);
244 }
245 freelamps(); /* all done with data */
246 }
247 /* else keep lamp data */
248 }
249
250
251 char *
252 stradd(dst, src, sep) /* add a string at dst */
253 register char *dst, *src;
254 int sep;
255 {
256 if (src && *src) {
257 do
258 *dst++ = *src++;
259 while (*src);
260 if (sep && dst[-1] != sep)
261 *dst++ = sep;
262 }
263 *dst = '\0';
264 return(dst);
265 }
266
267
268 char *
269 fullname(path, fname, suffix) /* return full path name */
270 char *path, *fname, *suffix;
271 {
272 if (prefdir != NULL && abspath(prefdir))
273 libname(path, fname, suffix);
274 else if (abspath(fname))
275 strcpy(stradd(path, fname, 0), suffix);
276 else
277 libname(stradd(path, libdir, DIRSEP), fname, suffix);
278
279 return(path);
280 }
281
282
283 char *
284 libname(path, fname, suffix) /* return library relative name */
285 char *path, *fname, *suffix;
286 {
287 if (abspath(fname))
288 strcpy(stradd(path, fname, 0), suffix);
289 else
290 strcpy(stradd(stradd(path, prefdir, DIRSEP), fname, 0), suffix);
291
292 return(path);
293 }
294
295
296 char *
297 filename(path) /* get final component of pathname */
298 register char *path;
299 {
300 register char *cp;
301
302 for (cp = path; *path; path++)
303 if (ISDIRSEP(*path))
304 cp = path+1;
305 return(cp);
306 }
307
308
309 char *
310 filetrunc(path) /* truncate filename at end of path */
311 char *path;
312 {
313 register char *p1, *p2;
314
315 for (p1 = p2 = path; *p2; p2++)
316 if (ISDIRSEP(*p2))
317 p1 = p2;
318 *p1 = '\0';
319 return(path);
320 }
321
322
323 char *
324 tailtrunc(name) /* truncate tail of filename */
325 char *name;
326 {
327 register char *p1, *p2;
328
329 for (p1 = filename(name); *p1 == '.'; p1++)
330 ;
331 p2 = NULL;
332 for ( ; *p1; p1++)
333 if (*p1 == '.')
334 p2 = p1;
335 if (p2 != NULL)
336 *p2 = '\0';
337 return(name);
338 }
339
340
341 blanktrunc(s) /* truncate spaces at end of line */
342 char *s;
343 {
344 register char *cp;
345
346 for (cp = s; *cp; cp++)
347 ;
348 while (cp-- > s && isspace(*cp))
349 ;
350 *++cp = '\0';
351 }
352
353
354 putheader(out) /* print header */
355 FILE *out;
356 {
357 register int i;
358
359 putc('#', out);
360 for (i = 0; i < gargc; i++) {
361 putc(' ', out);
362 fputs(gargv[i], out);
363 }
364 fputs("\n# Dimensions in ", out);
365 fputs(units, out);
366 putc('\n', out);
367 }
368
369
370 ies2rad(inpname, outname) /* convert IES file */
371 char *inpname, *outname;
372 {
373 char buf[MAXLINE], tltid[MAXWORD];
374 FILE *inpfp, *outfp;
375
376 if (inpname == NULL) {
377 inpname = "<stdin>";
378 inpfp = stdin;
379 } else if ((inpfp = fopen(inpname, "r")) == NULL) {
380 perror(inpname);
381 return(-1);
382 }
383 if ((outfp = fopen(fullname(buf,outname,T_RAD), "w")) == NULL) {
384 perror(buf);
385 fclose(inpfp);
386 return(-1);
387 }
388 putheader(outfp);
389 if (lamptype == NULL)
390 lampcolor = NULL;
391 while (fgets(buf,sizeof(buf),inpfp) != NULL
392 && strncmp(buf,TLTSTR,TLTSTRLEN)) {
393 blanktrunc(buf);
394 if (!buf[0])
395 continue;
396 fputs("#<", outfp);
397 fputs(buf, outfp);
398 putc('\n', outfp);
399 if (lampcolor == NULL)
400 lampcolor = matchlamp(buf);
401 }
402 if (lampcolor == NULL) {
403 fprintf(stderr, "%s: warning - no lamp type\n", inpname);
404 lampcolor = defcolor;
405 }
406 if (feof(inpfp)) {
407 fprintf(stderr, "%s: not in IES format\n", inpname);
408 goto readerr;
409 }
410 sscanf(buf+TLTSTRLEN, "%s", tltid);
411 if (inpfp == stdin)
412 buf[0] = '\0';
413 else
414 filetrunc(strcpy(buf, inpname));
415 if (dotilt(inpfp, outfp, buf, tltid, outname, tltid) != 0) {
416 fprintf(stderr, "%s: bad tilt data\n", inpname);
417 goto readerr;
418 }
419 if (dosource(inpfp, outfp, tltid, outname) != 0) {
420 fprintf(stderr, "%s: bad luminaire data\n", inpname);
421 goto readerr;
422 }
423 fclose(outfp);
424 fclose(inpfp);
425 return(0);
426 readerr:
427 fclose(outfp);
428 fclose(inpfp);
429 unlink(fullname(buf,outname,T_RAD));
430 return(-1);
431 }
432
433
434 dotilt(in, out, dir, tltspec, dfltname, tltid) /* convert tilt data */
435 FILE *in, *out;
436 char *dir, *tltspec, *dfltname, *tltid;
437 {
438 int nangles, tlt_type;
439 double minmax[2];
440 char buf[MAXPATH], tltname[MAXWORD];
441 FILE *datin, *datout;
442
443 if (!strcmp(tltspec, TLTNONE)) {
444 datin = NULL;
445 strcpy(tltid, "void");
446 } else if (!strcmp(tltspec, TLTINCL)) {
447 datin = in;
448 strcpy(tltname, dfltname);
449 } else {
450 if (ISDIRSEP(tltspec[0]))
451 strcpy(buf, tltspec);
452 else
453 strcpy(stradd(buf, dir, DIRSEP), tltspec);
454 if ((datin = fopen(buf, "r")) == NULL) {
455 perror(buf);
456 return(-1);
457 }
458 tailtrunc(strcpy(tltname,filename(tltspec)));
459 }
460 if (datin != NULL) {
461 if ((datout = fopen(fullname(buf,tltname,T_TLT),"w")) == NULL) {
462 perror(buf);
463 if (datin != in)
464 fclose(datin);
465 return(-1);
466 }
467 if (fscanf(datin, "%d %d", &tlt_type, &nangles) != 2
468 || cvdata(datin,datout,1,&nangles,1.,minmax) != 0) {
469 fprintf(stderr, "%s: data format error\n", tltspec);
470 fclose(datout);
471 if (datin != in)
472 fclose(datin);
473 unlink(fullname(buf,tltname,T_TLT));
474 return(-1);
475 }
476 fclose(datout);
477 if (datin != in)
478 fclose(datin);
479 strcat(strcpy(tltid, filename(tltname)), "_tilt");
480 fprintf(out, "\nvoid brightdata %s\n", tltid);
481 libname(buf,tltname,T_TLT);
482 switch (tlt_type) {
483 case TLT_VERT: /* vertical */
484 fprintf(out, "4 noop %s tilt.cal %s\n", buf,
485 minmax[1]>90.+FTINY ? "tilt_ang" : "tilt_ang2");
486 break;
487 case TLT_H0: /* horiz. in 0 deg. plane */
488 fprintf(out, "6 noop %s tilt.cal %s -rz 90\n", buf,
489 minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
490 break;
491 case TLT_H90:
492 fprintf(out, "4 noop %s tilt.cal %s\n", buf,
493 minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
494 break;
495 default:
496 fprintf(stderr,
497 "%s: illegal lamp to luminaire geometry (%d)\n",
498 tltspec, tlt_type);
499 return(-1);
500 }
501 fprintf(out, "0\n0\n");
502 }
503 return(0);
504 }
505
506
507 dosource(in, out, mod, name) /* create source and distribution */
508 FILE *in, *out;
509 char *mod, *name;
510 {
511 SHAPE srcshape;
512 char buf[MAXPATH], id[MAXWORD];
513 FILE *datout;
514 double mult, bfactor, pfactor, width, length, height, wattage;
515 double bounds[2][2];
516 int nangles[2], pmtype, unitype;
517 double d1;
518
519 if (fscanf(in, "%*d %*f %lf %d %d %d %d %lf %lf %lf %lf %lf %lf",
520 &mult, &nangles[0], &nangles[1], &pmtype, &unitype,
521 &width, &length, &height, &bfactor, &pfactor,
522 &wattage) != 11) {
523 fprintf(stderr, "dosource: bad lamp specification\n");
524 return(-1);
525 }
526 if (nangles[0] < 2 || nangles[1] < 1) {
527 fprintf(stderr, "dosource: too few measured angles\n");
528 return(-1);
529 }
530 if (unitype == U_FEET) {
531 width *= F_M;
532 length *= F_M;
533 height *= F_M;
534 }
535 if (makeshape(&srcshape, width, length, height) != 0) {
536 fprintf(stderr, "dosource: illegal source dimensions");
537 return(-1);
538 }
539 if ((datout = fopen(fullname(buf,name,T_DST), "w")) == NULL) {
540 perror(buf);
541 return(-1);
542 }
543 if (cvdata(in, datout, 2, nangles, 1./WHTEFFICACY, bounds) != 0) {
544 fprintf(stderr, "dosource: bad distribution data\n");
545 fclose(datout);
546 unlink(fullname(buf,name,T_DST));
547 return(-1);
548 }
549 fclose(datout);
550 fprintf(out, "# %g watt luminaire, lamp*ballast factor = %g\n",
551 wattage, bfactor*pfactor);
552 strcat(strcpy(id, filename(name)), "_dist");
553 fprintf(out, "\n%s brightdata %s\n", mod, id);
554 if (nangles[1] < 2)
555 fprintf(out, "4 ");
556 else if (pmtype == PM_B)
557 fprintf(out, "5 ");
558 else if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
559 fprintf(out, "8 ");
560 else
561 fprintf(out, "6 ");
562 fprintf(out, "%s %s source.cal ",
563 srcshape.type==SPHERE ? "corr" : "flatcorr",
564 libname(buf,name,T_DST));
565 if (pmtype == PM_B) {
566 if (FEQ(bounds[1][0],0.))
567 fprintf(out, "srcB_horiz2 ");
568 else
569 fprintf(out, "srcB_horiz ");
570 fprintf(out, "srcB_vert ");
571 } else {
572 if (nangles[1] >= 2) {
573 d1 = bounds[1][1] - bounds[1][0];
574 if (d1 <= 90.+FTINY)
575 fprintf(out, "src_phi4 ");
576 else if (d1 <= 180.+FTINY)
577 fprintf(out, "src_phi2 ");
578 else
579 fprintf(out, "src_phi ");
580 fprintf(out, "src_theta -my ");
581 if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
582 fprintf(out, "-rz -90 ");
583 } else
584 fprintf(out, "src_theta ");
585 }
586 fprintf(out, "\n0\n1 %g\n", multiplier*mult*bfactor*pfactor);
587 if (putsource(&srcshape, out, id, filename(name),
588 bounds[0][0]<90., bounds[0][1]>90.) != 0)
589 return(-1);
590 return(0);
591 }
592
593
594 putsource(shp, fp, mod, name, dolower, doupper) /* put out source */
595 SHAPE *shp;
596 FILE *fp;
597 char *mod, *name;
598 int dolower, doupper;
599 {
600 char buf[MAXWORD];
601
602 fprintf(fp, "\n%s %s %s_light\n", mod,
603 illumrad>=MINDIM/2. ? "illum" : "light",
604 name);
605 fprintf(fp, "0\n0\n3 %g %g %g\n",
606 lampcolor[0]/shp->area,
607 lampcolor[1]/shp->area,
608 lampcolor[2]/shp->area);
609 if (doupper && dolower && shp->type != SPHERE && shp->h > MINDIM) {
610 fprintf(fp, "\n%s glow %s_glow\n", mod, name);
611 fprintf(fp, "0\n0\n4 %g %g %g -1\n",
612 lampcolor[0]/shp->area,
613 lampcolor[1]/shp->area,
614 lampcolor[2]/shp->area);
615 }
616 switch (shp->type) {
617 case RECT:
618 strcat(strcpy(buf, name), "_light");
619 if (dolower)
620 putrectsrc(shp, fp, buf, name, 0);
621 if (doupper)
622 putrectsrc(shp, fp, buf, name, 1);
623 if (doupper && dolower && shp->h > MINDIM) {
624 strcat(strcpy(buf, name), "_glow");
625 putsides(shp, fp, buf, name);
626 }
627 break;
628 case DISK:
629 strcat(strcpy(buf, name), "_light");
630 if (dolower)
631 putdisksrc(shp, fp, buf, name, 0);
632 if (doupper)
633 putdisksrc(shp, fp, buf, name, 1);
634 if (doupper && dolower && shp->h > MINDIM) {
635 strcat(strcpy(buf, name), "_glow");
636 putcyl(shp, fp, buf, name);
637 }
638 break;
639 case SPHERE:
640 strcat(strcpy(buf, name), "_light");
641 putspheresrc(shp, fp, buf, name);
642 break;
643 }
644 return(0);
645 }
646
647
648 makeshape(shp, width, length, height) /* make source shape */
649 register SHAPE *shp;
650 double width, length, height;
651 {
652 if (illumrad >= MINDIM/2.) {
653 shp->type = SPHERE;
654 shp->w = shp->l = shp->h = 2.*illumrad;
655 } else if (width < MINDIM) {
656 width = -width;
657 if (width < MINDIM) {
658 shp->type = SPHERE;
659 shp->w = shp->l = shp->h = MINDIM;
660 } else if (height < .5*width) {
661 shp->type = DISK;
662 shp->w = shp->l = width;
663 if (height >= MINDIM)
664 shp->h = height;
665 else
666 shp->h = .5*MINDIM;
667 } else {
668 shp->type = SPHERE;
669 shp->w = shp->l = shp->h = width;
670 }
671 } else {
672 shp->type = RECT;
673 shp->w = width;
674 if (length >= MINDIM)
675 shp->l = length;
676 else
677 shp->l = MINDIM;
678 if (height >= MINDIM)
679 shp->h = height;
680 else
681 shp->h = .5*MINDIM;
682 }
683 switch (shp->type) {
684 case RECT:
685 shp->area = shp->w * shp->l;
686 break;
687 case DISK:
688 case SPHERE:
689 shp->area = PI/4. * shp->w * shp->w;
690 break;
691 }
692 return(0);
693 }
694
695
696 putrectsrc(shp, fp, mod, name, up) /* rectangular source */
697 SHAPE *shp;
698 FILE *fp;
699 char *mod, *name;
700 int up;
701 {
702 if (up)
703 putrect(shp, fp, mod, name, ".u", 4, 5, 7, 6);
704 else
705 putrect(shp, fp, mod, name, ".d", 0, 2, 3, 1);
706 }
707
708
709 putsides(shp, fp, mod, name) /* put out sides of box */
710 register SHAPE *shp;
711 FILE *fp;
712 char *mod, *name;
713 {
714 putrect(shp, fp, mod, name, ".1", 0, 1, 5, 4);
715 putrect(shp, fp, mod, name, ".2", 1, 3, 7, 5);
716 putrect(shp, fp, mod, name, ".3", 3, 2, 6, 7);
717 putrect(shp, fp, mod, name, ".4", 2, 0, 4, 6);
718 }
719
720
721 putrect(shp, fp, mod, name, suffix, a, b, c, d) /* put out a rectangle */
722 SHAPE *shp;
723 FILE *fp;
724 char *mod, *name, *suffix;
725 int a, b, c, d;
726 {
727 fprintf(fp, "\n%s polygon %s%s\n0\n0\n12\n", mod, name, suffix);
728 putpoint(shp, fp, a);
729 putpoint(shp, fp, b);
730 putpoint(shp, fp, c);
731 putpoint(shp, fp, d);
732 }
733
734
735 putpoint(shp, fp, p) /* put out a point */
736 register SHAPE *shp;
737 FILE *fp;
738 int p;
739 {
740 static double mult[2] = {-.5, .5};
741
742 fprintf(fp, "\t%g\t%g\t%g\n",
743 mult[p&1]*shp->l*meters2out,
744 mult[p>>1&1]*shp->w*meters2out,
745 mult[p>>2]*shp->h*meters2out);
746 }
747
748
749 putdisksrc(shp, fp, mod, name, up) /* put out a disk source */
750 register SHAPE *shp;
751 FILE *fp;
752 char *mod, *name;
753 int up;
754 {
755 if (up) {
756 fprintf(fp, "\n%s ring %s.u\n", mod, name);
757 fprintf(fp, "0\n0\n8\n");
758 fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
759 fprintf(fp, "\t0 0 1\n");
760 fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
761 } else {
762 fprintf(fp, "\n%s ring %s.d\n", mod, name);
763 fprintf(fp, "0\n0\n8\n");
764 fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
765 fprintf(fp, "\t0 0 -1\n");
766 fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
767 }
768 }
769
770
771 putcyl(shp, fp, mod, name) /* put out a cylinder */
772 register SHAPE *shp;
773 FILE *fp;
774 char *mod, *name;
775 {
776 fprintf(fp, "\n%s cylinder %s.c\n", mod, name);
777 fprintf(fp, "0\n0\n7\n");
778 fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
779 fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
780 fprintf(fp, "\t%g\n", .5*shp->w*meters2out);
781 }
782
783
784 putspheresrc(shp, fp, mod, name) /* put out a sphere source */
785 SHAPE *shp;
786 FILE *fp;
787 char *mod, *name;
788 {
789 fprintf(fp, "\n%s sphere %s.s\n", mod, name);
790 fprintf(fp, "0\n0\n4 0 0 0 %g\n", .5*shp->w*meters2out);
791 }
792
793
794 cvdata(in, out, ndim, npts, mult, lim) /* convert data */
795 FILE *in, *out;
796 int ndim, npts[];
797 double mult, lim[][2];
798 {
799 double *pt[4];
800 register int i, j;
801 double val;
802 int total;
803
804 total = 1; j = 0;
805 for (i = 0; i < ndim; i++)
806 if (npts[i] > 1) {
807 total *= npts[i];
808 j++;
809 }
810 fprintf(out, "%d\n", j);
811 /* get coordinates */
812 for (i = 0; i < ndim; i++) {
813 pt[i] = (double *)malloc(npts[i]*sizeof(double));
814 for (j = 0; j < npts[i]; j++)
815 fscanf(in, "%lf", &pt[i][j]);
816 if (lim != NULL) {
817 lim[i][0] = pt[i][0];
818 lim[i][1] = pt[i][npts[i]-1];
819 }
820 }
821 /* write out in reverse */
822 for (i = ndim-1; i >= 0; i--) {
823 if (npts[i] > 1) {
824 for (j = 1; j < npts[i]-1; j++)
825 if (!FEQ(pt[i][j]-pt[i][j-1],
826 pt[i][j+1]-pt[i][j]))
827 break;
828 if (j == npts[i]-1)
829 fprintf(out, "%g %g %d\n", pt[i][0], pt[i][j],
830 npts[i]);
831 else {
832 fprintf(out, "0 0 %d", npts[i]);
833 for (j = 0; j < npts[i]; j++) {
834 if (j%4 == 0)
835 putc('\n', out);
836 fprintf(out, "\t%g", pt[i][j]);
837 }
838 putc('\n', out);
839 }
840 }
841 free((char *)pt[i]);
842 }
843 for (i = 0; i < total; i++) {
844 if (i%4 == 0)
845 putc('\n', out);
846 if (fscanf(in, "%lf", &val) != 1)
847 return(-1);
848 fprintf(out, "\t%g", val*mult);
849 }
850 putc('\n', out);
851 return(0);
852 }
