--- ray/src/cv/ies2rad.c 1993/02/22 15:54:55 2.5 +++ ray/src/cv/ies2rad.c 1993/08/23 10:22:42 2.9 @@ -11,6 +11,7 @@ static char SCCSid[] = "$SunId$ LBL"; */ #include +#include #include #include "color.h" #include "paths.h" @@ -76,10 +77,15 @@ int gargc; /* global argc (minus filenames) */ char **gargv; /* global argv */ extern char *strcpy(), *strcat(), *stradd(), *tailtrunc(), *filetrunc(), - *filename(), *libname(), *fullname(), *malloc(); + *filename(), *libname(), *fullname(), *malloc(), + *getword(), *atos(); extern float *matchlamp(); +#define scnint(fp,ip) cvtint(ip,getword(fp)) +#define scnflt(fp,rp) cvtflt(rp,getword(fp)) +#define isint isflt /* IES allows real as integer */ + main(argc, argv) int argc; char *argv[]; @@ -401,13 +407,16 @@ char *inpname, *outname; } if (lampcolor == NULL) { fprintf(stderr, "%s: warning - no lamp type\n", inpname); + fputs("# Unknown lamp type (used default)\n", outfp); lampcolor = defcolor; - } + } else if (lamptype == NULL) + fprintf(outfp,"# CIE(x,y) = (%f,%f)\n# Depreciation = %.1f%%\n", + lampcolor[3], lampcolor[4], 100.*lampcolor[5]); if (feof(inpfp)) { fprintf(stderr, "%s: not in IES format\n", inpname); goto readerr; } - sscanf(buf+TLTSTRLEN, "%s", tltid); + atos(tltid, MAXWORD, buf+TLTSTRLEN); if (inpfp == stdin) buf[0] = '\0'; else @@ -464,7 +473,7 @@ char *dir, *tltspec, *dfltname, *tltid; fclose(datin); return(-1); } - if (fscanf(datin, "%d %d", &tlt_type, &nangles) != 2 + if (!scnint(datin,&tlt_type) || !scnint(datin,&nangles) || cvdata(datin,datout,1,&nangles,1.,minmax) != 0) { fprintf(stderr, "%s: data format error\n", tltspec); fclose(datout); @@ -516,10 +525,12 @@ char *mod, *name; int nangles[2], pmtype, unitype; double d1; - if (fscanf(in, "%*d %*f %lf %d %d %d %d %lf %lf %lf %lf %lf %lf", - &mult, &nangles[0], &nangles[1], &pmtype, &unitype, - &width, &length, &height, &bfactor, &pfactor, - &wattage) != 11) { + if (!isint(getword(in)) || !isflt(getword(in)) || !scnflt(in,&mult) + || !scnint(in,&nangles[0]) || !scnint(in,&nangles[1]) + || !scnint(in,&pmtype) || !scnint(in,&unitype) + || !scnflt(in,&width) || !scnflt(in,&length) + || !scnflt(in,&height) || !scnflt(in,&bfactor) + || !scnflt(in,&pfactor) || !scnflt(in,&wattage)) { fprintf(stderr, "dosource: bad lamp specification\n"); return(-1); } @@ -556,9 +567,9 @@ char *mod, *name; else if (pmtype == PM_B) fprintf(out, "5 "); else if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.)) - fprintf(out, "8 "); + fprintf(out, "7 "); else - fprintf(out, "6 "); + fprintf(out, "5 "); fprintf(out, "%s %s source.cal ", srcshape.type==SPHERE ? "corr" : "flatcorr", libname(buf,name,T_DST)); @@ -577,7 +588,7 @@ char *mod, *name; fprintf(out, "src_phi2 "); else fprintf(out, "src_phi "); - fprintf(out, "src_theta -my "); + fprintf(out, "src_theta "); if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.)) fprintf(out, "-rz -90 "); } else @@ -812,7 +823,8 @@ double mult, lim[][2]; for (i = 0; i < ndim; i++) { pt[i] = (double *)malloc(npts[i]*sizeof(double)); for (j = 0; j < npts[i]; j++) - fscanf(in, "%lf", &pt[i][j]); + if (!scnflt(in, &pt[i][j])) + return(-1); if (lim != NULL) { lim[i][0] = pt[i][0]; lim[i][1] = pt[i][npts[i]-1]; @@ -843,10 +855,57 @@ double mult, lim[][2]; for (i = 0; i < total; i++) { if (i%4 == 0) putc('\n', out); - if (fscanf(in, "%lf", &val) != 1) + if (!scnflt(in, &val)) return(-1); fprintf(out, "\t%g", val*mult); } putc('\n', out); return(0); +} + + +char * +getword(fp) /* scan a word from fp */ +register FILE *fp; +{ + static char word[MAXWORD]; + register char *cp; + register int c; + + while (isspace(c=getc(fp))) + ; + for (cp = word; c != EOF && cp < word+MAXWORD-1; + *cp++ = c, c = getc(fp)) + if (isspace(c) || c == ',') { + while (isspace(c)) + c = getc(fp); + if (c != EOF & c != ',') + ungetc(c, fp); + *cp = '\0'; + return(word); + } + *cp = '\0'; + return(cp > word ? word : NULL); +} + + +cvtint(ip, word) /* convert a word to an integer */ +int *ip; +char *word; +{ + if (word == NULL || !isint(word)) + return(0); + *ip = atoi(word); + return(1); +} + + +cvtflt(rp, word) /* convert a word to a double */ +double *rp; +char *word; +{ + if (word == NULL || !isflt(word)) + return(0); + *rp = atof(word); + return(1); }
