--- ray/src/cv/ies2rad.c 2021/09/20 02:00:05 2.33 +++ ray/src/cv/ies2rad.c 2021/09/30 20:05:09 2.34 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ies2rad.c,v 2.33 2021/09/20 02:00:05 greg Exp $"; +static const char RCSid[] = "$Id: ies2rad.c,v 2.34 2021/09/30 20:05:09 greg Exp $"; #endif /* * ies2rad -- Convert IES luminaire data to Radiance description @@ -968,7 +968,7 @@ dotilt( datin = in; strcpy(tltname, dfltname); } else { - /* If the line is "TILE=", use that file + /* If the line is "TILT=", use that file * name as the source of tilt data. */ if (ISDIRSEP(tltspec[0])) strcpy(buf, tltspec); @@ -1125,7 +1125,7 @@ dosource( /* Output distribution "brightdata" primitive. Start handling the various cases of symmetry of the distribution. */ strcat(strcpy(id, filename(name)), "_dist"); - fprintf(out, "\n%s brightdata %s\n", mod, id); + fprintf(out, "\n'%s' brightdata '%s'\n", mod, id); if (nangles[1] < 2) fprintf(out, "4 "); else if (pmtype == PM_B) @@ -1143,7 +1143,7 @@ dosource( dosides = (doupper & dolower && sinf->h > MINDIM); /* Sides */ /* Select the appropriate function and parameters from source.cal */ - fprintf(out, "%s %s source.cal ", + fprintf(out, "%s '%s' source.cal ", sinf->type==SPHERE ? "corr" : !dosides ? "flatcorr" : sinf->type==DISK ? "cylcorr" : "boxcorr", @@ -1213,7 +1213,7 @@ putsource( /* First, describe the light. If a materials and geometry * file is given, generate an illum instead. */ strcat(strcpy(lname, name), "_light"); - fprintf(fp, "\n%s %s %s\n", mod, + fprintf(fp, "\n'%s' %s '%s'\n", mod, shp->isillum ? "illum" : "light", lname); fprintf(fp, "0\n0\n3 %g %g %g\n", lampcolor[0], lampcolor[1], lampcolor[2]); @@ -1425,7 +1425,7 @@ putrect( int d ) { - fprintf(fp, "\n%s polygon %s%s\n0\n0\n12\n", mod, name, suffix); + fprintf(fp, "\n'%s' polygon '%s%s'\n0\n0\n12\n", mod, name, suffix); putpoint(shp, fp, a); putpoint(shp, fp, b); putpoint(shp, fp, c); @@ -1470,13 +1470,13 @@ putdisksrc( /* put out a disk source */ ) { if (up) { - fprintf(fp, "\n%s ring %s.u\n", mod, name); + fprintf(fp, "\n'%s' ring '%s.u'\n", mod, name); fprintf(fp, "0\n0\n8\n"); fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out); fprintf(fp, "\t0 0 1\n"); fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out); } else { - fprintf(fp, "\n%s ring %s.d\n", mod, name); + fprintf(fp, "\n'%s' ring '%s.d'\n", mod, name); fprintf(fp, "0\n0\n8\n"); fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out); fprintf(fp, "\t0 0 -1\n"); @@ -1493,7 +1493,7 @@ putcyl( /* put out a cylinder */ char *name ) { - fprintf(fp, "\n%s cylinder %s.c\n", mod, name); + fprintf(fp, "\n'%s' cylinder '%s.c'\n", mod, name); fprintf(fp, "0\n0\n7\n"); fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out); fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out); @@ -1510,7 +1510,7 @@ putspheresrc( /* put out a sphere source */ char *name ) { - fprintf(fp, "\n%s sphere %s.s\n", mod, name); + fprintf(fp, "\n'%s' sphere '%s.s'\n", mod, name); fprintf(fp, "0\n0\n4 0 0 0 %g\n", .5*shp->w*meters2out); }
