root/radiance/ray/src/cv/ies2rad.c
Revision: 1.2
Committed: Fri Dec 14 14:41:14 1990 UTC (34 years, 8 months ago) by greg
Changes since 1.1: +50 -10 lines
improved use of lamp data
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert IES luminaire data to Radiance description
9 *
10 * 07Apr90 Greg Ward
11 */
12
13 #include <stdio.h>
14 #include <ctype.h>
15 #include "color.h"
16
17 #define PI 3.14159265358979323846
18 /* floating comparisons */
19 #define FTINY 1e-6
20 #define FEQ(a,b) ((a)<=(b)+FTINY&&(a)>=(b)-FTINY)
21 /* tilt specs */
22 #define TLTSTR "TILT="
23 #define TLTSTRLEN 5
24 #define TLTNONE "NONE"
25 #define TLTINCL "INCLUDE"
26 #define TLT_VERT 1
27 #define TLT_H0 2
28 #define TLT_H90 3
29 /* photometric types */
30 #define PM_C 1
31 #define PM_B 2
32 /* unit types */
33 #define U_FEET 1
34 #define U_METERS 2
35 /* string lengths */
36 #define MAXLINE 132
37 #define MAXWORD 76
38 #define MAXPATH 128
39 /* file types */
40 #define T_RAD ".rad"
41 #define T_DST ".dat"
42 #define T_TLT "+.dat"
43 /* shape types */
44 #define RECT 1
45 #define DISK 2
46 #define SPHERE 3
47
48 #define MINDIM .001 /* minimum dimension (point source) */
49
50 #define F_M .3048 /* feet to meters */
51
52 #define abspath(p) ((p)[0] == '/' || (p)[0] == '.')
53
54 static char default_name[] = "default";
55
56 char *libdir = NULL; /* library directory location */
57 char *prefdir = NULL; /* subdirectory */
58 char *lampdat = "lamp.tab"; /* lamp data file */
59
60 double meters2out = 1.0; /* conversion from meters to output */
61 char *lamptype = NULL; /* selected lamp type */
62 char *deflamp = NULL; /* default lamp type */
63 float defcolor[3] = {1.,1.,1.}; /* default lamp color */
64 float *lampcolor = defcolor; /* pointer to current lamp color */
65 double multiplier = 1.0; /* multiplier for all light sources */
66 char units[64] = "meters"; /* output units */
67 double minaspect = 0.0; /* minimum allowed aspect ratio */
68 int maxemitters = 1; /* maximum emitters per hemisphere */
69 double illumrad = 0.0; /* radius for illum sphere */
70
71 typedef struct {
72 int type; /* RECT, DISK, SPHERE */
73 double w, l, h; /* width, length, height */
74 double area; /* effective radiating area */
75 } SHAPE; /* a source shape */
76
77 int gargc; /* global argc (minus filenames) */
78 char **gargv; /* global argv */
79
80 extern char *strcpy(), *strcat(), *stradd(), *tailtrunc(), *filetrunc(),
81 *filename(), *libname(), *fullname(), *malloc();
82 extern double atof();
83 extern float *matchlamp();
84
85
86 main(argc, argv)
87 int argc;
88 char *argv[];
89 {
90 char *outfile = NULL;
91 int status;
92 char outname[MAXWORD];
93 double d1;
94 int i;
95
96 for (i = 1; i < argc && argv[i][0] == '-'; i++)
97 switch (argv[i][1]) {
98 case 'd': /* dimensions */
99 if (argv[i][2] == '\0')
100 goto badopt;
101 if (argv[i][3] == '\0')
102 d1 = 1.0;
103 else if (argv[i][3] == '/') {
104 d1 = atof(argv[i]+4);
105 if (d1 <= FTINY)
106 goto badopt;
107 } else
108 goto badopt;
109 switch (argv[i][2]) {
110 case 'c': /* centimeters */
111 if (FEQ(d1,10.))
112 strcpy(units,"millimeters");
113 else {
114 strcpy(units,"centimeters");
115 strcat(units,argv[i]+3);
116 }
117 meters2out = 100.*d1;
118 break;
119 case 'm': /* meters */
120 if (FEQ(d1,1000.))
121 strcpy(units,"millimeters");
122 else if (FEQ(d1,100.))
123 strcpy(units,"centimeters");
124 else {
125 strcpy(units,"meters");
126 strcat(units,argv[i]+3);
127 }
128 meters2out = d1;
129 break;
130 case 'i': /* inches */
131 strcpy(units,"inches");
132 strcat(units,argv[i]+3);
133 meters2out = d1*(12./F_M);
134 break;
135 case 'f': /* feet */
136 if (FEQ(d1,12.))
137 strcpy(units,"inches");
138 else {
139 strcpy(units,"feet");
140 strcat(units,argv[i]+3);
141 }
142 meters2out = d1/F_M;
143 break;
144 default:
145 goto badopt;
146 }
147 break;
148 case 'l': /* library directory */
149 libdir = argv[++i];
150 break;
151 case 'p': /* prefix subdirectory */
152 prefdir = argv[++i];
153 break;
154 case 'f': /* lamp data file */
155 lampdat = argv[++i];
156 break;
157 case 'o': /* output file name */
158 outfile = argv[++i];
159 break;
160 case 's': /* square emitters */
161 minaspect = .6;
162 if (argv[i][2] == '/') {
163 maxemitters = atoi(argv[i]+3);
164 if (maxemitters < 1)
165 goto badopt;
166 }
167 break;
168 case 'i': /* illum */
169 illumrad = atof(argv[++i]);
170 if (illumrad < MINDIM)
171 illumrad = MINDIM;
172 break;
173 case 't': /* override lamp type */
174 lamptype = argv[++i];
175 break;
176 case 'u': /* default lamp type */
177 deflamp = argv[++i];
178 break;
179 case 'c': /* default lamp color */
180 defcolor[0] = atof(argv[++i]);
181 defcolor[1] = atof(argv[++i]);
182 defcolor[2] = atof(argv[++i]);
183 break;
184 case 'm': /* multiplier */
185 multiplier = atof(argv[++i]);
186 break;
187 default:
188 badopt:
189 fprintf(stderr, "%s: bad option: %s\n",
190 argv[0], argv[i]);
191 exit(1);
192 }
193 gargc = i;
194 gargv = argv;
195 initlamps(); /* get lamp data (if needed) */
196 /* convert ies file(s) */
197 if (outfile != NULL) {
198 if (i == argc)
199 exit(ies2rad(NULL, outfile) == 0 ? 0 : 1);
200 else if (i == argc-1)
201 exit(ies2rad(argv[i], outfile) == 0 ? 0 : 1);
202 else {
203 fprintf(stderr, "%s: single input file required\n",
204 argv[0]);
205 exit(1);
206 }
207 } else if (i >= argc) {
208 fprintf(stderr, "%s: missing output file specification\n",
209 argv[0]);
210 exit(1);
211 }
212 status = 0;
213 for ( ; i < argc; i++) {
214 tailtrunc(strcpy(outname,filename(argv[i])));
215 if (ies2rad(argv[i], outname) != 0)
216 status = 1;
217 }
218 exit(status);
219 }
220
221
222 initlamps() /* set up lamps */
223 {
224 float *lcol;
225 int status;
226
227 if (lamptype != NULL && !strcmp(lamptype, default_name) &&
228 deflamp == NULL)
229 return; /* no need for data */
230 /* else load file */
231 if ((status = loadlamps(lampdat)) < 0)
232 exit(1);
233 if (status == 0) {
234 fprintf(stderr, "%s: warning - no lamp data\n", lampdat);
235 lamptype = default_name;
236 return;
237 }
238 if (deflamp != NULL) { /* match default type */
239 if ((lcol = matchlamp(deflamp)) == NULL)
240 fprintf(stderr,
241 "%s: warning - unknown default lamp type\n",
242 deflamp);
243 else
244 copycolor(defcolor, lcol);
245 }
246 if (lamptype != NULL) { /* match selected type */
247 if (strcmp(lamptype, default_name)) {
248 if ((lcol = matchlamp(lamptype)) == NULL) {
249 fprintf(stderr,
250 "%s: warning - unknown lamp type\n",
251 lamptype);
252 lamptype = default_name;
253 } else
254 copycolor(defcolor, lcol);
255 }
256 freelamps(); /* all done with data */
257 }
258 /* else keep lamp data */
259 }
260
261
262 char *
263 stradd(dst, src, sep) /* add a string at dst */
264 register char *dst, *src;
265 int sep;
266 {
267 if (src && *src) {
268 do
269 *dst++ = *src++;
270 while (*src);
271 if (sep && dst[-1] != sep)
272 *dst++ = sep;
273 }
274 *dst = '\0';
275 return(dst);
276 }
277
278
279 char *
280 fullname(path, fname, suffix) /* return full path name */
281 char *path, *fname, *suffix;
282 {
283 if (prefdir != NULL && abspath(prefdir))
284 libname(path, fname, suffix);
285 else if (abspath(fname))
286 strcpy(stradd(path, fname, 0), suffix);
287 else
288 libname(stradd(path, libdir, '/'), fname, suffix);
289
290 return(path);
291 }
292
293
294 char *
295 libname(path, fname, suffix) /* return library relative name */
296 char *path, *fname, *suffix;
297 {
298 if (abspath(fname))
299 strcpy(stradd(path, fname, 0), suffix);
300 else
301 strcpy(stradd(stradd(path, prefdir, '/'), fname, 0), suffix);
302
303 return(path);
304 }
305
306
307 char *
308 filename(path) /* get final component of pathname */
309 register char *path;
310 {
311 register char *cp;
312
313 for (cp = path; *path; path++)
314 if (*path == '/')
315 cp = path+1;
316 return(cp);
317 }
318
319
320 char *
321 filetrunc(path) /* truncate filename at end of path */
322 char *path;
323 {
324 register char *p1, *p2;
325
326 for (p1 = p2 = path; *p2; p2++)
327 if (*p2 == '/')
328 p1 = p2;
329 *p1 = '\0';
330 return(path);
331 }
332
333
334 char *
335 tailtrunc(name) /* truncate tail of filename */
336 char *name;
337 {
338 register char *p1, *p2;
339
340 for (p1 = filename(name); *p1 == '.'; p1++)
341 ;
342 p2 = NULL;
343 for ( ; *p1; p1++)
344 if (*p1 == '.')
345 p2 = p1;
346 if (p2 != NULL)
347 *p2 = '\0';
348 return(name);
349 }
350
351
352 blanktrunc(s) /* truncate spaces at end of line */
353 char *s;
354 {
355 register char *cp;
356
357 for (cp = s; *cp; cp++)
358 ;
359 while (cp-- > s && isspace(*cp))
360 ;
361 *++cp = '\0';
362 }
363
364
365 putheader(out) /* print header */
366 FILE *out;
367 {
368 register int i;
369
370 putc('#', out);
371 for (i = 0; i < gargc; i++) {
372 putc(' ', out);
373 fputs(gargv[i], out);
374 }
375 fputs("\n# Dimensions in ", out);
376 fputs(units, out);
377 putc('\n', out);
378 }
379
380
381 ies2rad(inpname, outname) /* convert IES file */
382 char *inpname, *outname;
383 {
384 char buf[MAXLINE], tltid[MAXWORD];
385 FILE *inpfp, *outfp;
386
387 if (inpname == NULL) {
388 inpname = "<stdin>";
389 inpfp = stdin;
390 } else if ((inpfp = fopen(inpname, "r")) == NULL) {
391 perror(inpname);
392 return(-1);
393 }
394 if ((outfp = fopen(fullname(buf,outname,T_RAD), "w")) == NULL) {
395 perror(buf);
396 fclose(inpfp);
397 return(-1);
398 }
399 putheader(outfp);
400 if (lamptype == NULL)
401 lampcolor = NULL;
402 while (fgets(buf,sizeof(buf),inpfp) != NULL
403 && strncmp(buf,TLTSTR,TLTSTRLEN)) {
404 blanktrunc(buf);
405 if (!buf[0])
406 continue;
407 fputs("#<", outfp);
408 fputs(buf, outfp);
409 putc('\n', outfp);
410 if (lampcolor == NULL)
411 lampcolor = matchlamp(buf);
412 }
413 if (lampcolor == NULL) {
414 fprintf(stderr, "%s: warning - no lamp type\n", inpname);
415 lampcolor = defcolor;
416 }
417 if (feof(inpfp)) {
418 fprintf(stderr, "%s: not in IES format\n", inpname);
419 goto readerr;
420 }
421 sscanf(buf+TLTSTRLEN, "%s", tltid);
422 if (inpfp == stdin)
423 buf[0] = '\0';
424 else
425 filetrunc(strcpy(buf, inpname));
426 if (dotilt(inpfp, outfp, buf, tltid, outname, tltid) != 0) {
427 fprintf(stderr, "%s: bad tilt data\n", inpname);
428 goto readerr;
429 }
430 if (dosource(inpfp, outfp, tltid, outname) != 0) {
431 fprintf(stderr, "%s: bad luminaire data\n", inpname);
432 goto readerr;
433 }
434 fclose(outfp);
435 fclose(inpfp);
436 return(0);
437 readerr:
438 fclose(outfp);
439 fclose(inpfp);
440 unlink(fullname(buf,outname,T_RAD));
441 return(-1);
442 }
443
444
445 dotilt(in, out, dir, tltspec, dfltname, tltid) /* convert tilt data */
446 FILE *in, *out;
447 char *dir, *tltspec, *dfltname, *tltid;
448 {
449 int nangles, tlt_type;
450 double minmax[2];
451 char buf[MAXPATH], tltname[MAXWORD];
452 FILE *datin, *datout;
453
454 if (!strcmp(tltspec, TLTNONE)) {
455 datin = NULL;
456 strcpy(tltid, "void");
457 } else if (!strcmp(tltspec, TLTINCL)) {
458 datin = in;
459 strcpy(tltname, dfltname);
460 } else {
461 if (tltspec[0] == '/')
462 strcpy(buf, tltspec);
463 else
464 strcpy(stradd(buf, dir, '/'), tltspec);
465 if ((datin = fopen(buf, "r")) == NULL) {
466 perror(buf);
467 return(-1);
468 }
469 tailtrunc(strcpy(tltname,filename(tltspec)));
470 }
471 if (datin != NULL) {
472 if ((datout = fopen(fullname(buf,tltname,T_TLT),"w")) == NULL) {
473 perror(buf);
474 if (datin != in)
475 fclose(datin);
476 return(-1);
477 }
478 if (fscanf(datin, "%d %d", &tlt_type, &nangles) != 2
479 || cvdata(datin,datout,1,&nangles,1.,minmax) != 0) {
480 fprintf(stderr, "%s: data format error\n", tltspec);
481 fclose(datout);
482 if (datin != in)
483 fclose(datin);
484 unlink(fullname(buf,tltname,T_TLT));
485 return(-1);
486 }
487 fclose(datout);
488 if (datin != in)
489 fclose(datin);
490 strcat(strcpy(tltid, filename(tltname)), "_tilt");
491 fprintf(out, "\nvoid brightdata %s\n", tltid);
492 libname(buf,tltname,T_TLT);
493 switch (tlt_type) {
494 case TLT_VERT: /* vertical */
495 fprintf(out, "4 noop %s tilt.cal %s\n", buf,
496 minmax[1]>90.+FTINY ? "tilt_ang" : "tilt_ang2");
497 break;
498 case TLT_H0: /* horiz. in 0 deg. plane */
499 fprintf(out, "6 noop %s tilt.cal %s -rz 90\n", buf,
500 minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
501 break;
502 case TLT_H90:
503 fprintf(out, "4 noop %s tilt.cal %s\n", buf,
504 minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
505 break;
506 default:
507 fprintf(stderr,
508 "%s: illegal lamp to luminaire geometry (%d)\n",
509 tltspec, tlt_type);
510 return(-1);
511 }
512 fprintf(out, "0\n0\n");
513 }
514 return(0);
515 }
516
517
518 dosource(in, out, mod, name) /* create source and distribution */
519 FILE *in, *out;
520 char *mod, *name;
521 {
522 SHAPE srcshape;
523 char buf[MAXPATH], id[MAXWORD];
524 FILE *datout;
525 double mult, bfactor, pfactor, width, length, height, wattage;
526 double bounds[2][2];
527 int nangles[2], pmtype, unitype;
528 double d1;
529
530 if (fscanf(in, "%*d %*f %lf %d %d %d %d %lf %lf %lf %lf %lf %lf",
531 &mult, &nangles[0], &nangles[1], &pmtype, &unitype,
532 &width, &length, &height, &bfactor, &pfactor,
533 &wattage) != 11) {
534 fprintf(stderr, "dosource: bad lamp specification\n");
535 return(-1);
536 }
537 if (nangles[0] < 2 || nangles[1] < 1) {
538 fprintf(stderr, "dosource: too few measured angles\n");
539 return(-1);
540 }
541 if (unitype == U_FEET) {
542 width *= F_M;
543 length *= F_M;
544 height *= F_M;
545 }
546 if (makeshape(&srcshape, width, length, height) != 0) {
547 fprintf(stderr, "dosource: illegal source dimensions");
548 return(-1);
549 }
550 if ((datout = fopen(fullname(buf,name,T_DST), "w")) == NULL) {
551 perror(buf);
552 return(-1);
553 }
554 if (cvdata(in, datout, 2, nangles, 1./683., bounds) != 0) {
555 fprintf(stderr, "dosource: bad distribution data\n");
556 fclose(datout);
557 unlink(fullname(buf,name,T_DST));
558 return(-1);
559 }
560 fclose(datout);
561 fprintf(out, "# %g watt luminaire, lamp*ballast factor = %g\n",
562 wattage, bfactor*pfactor);
563 strcat(strcpy(id, filename(name)), "_dist");
564 fprintf(out, "\n%s brightdata %s\n", mod, id);
565 if (nangles[1] < 2)
566 fprintf(out, "4 ");
567 else if (pmtype == PM_B)
568 fprintf(out, "5 ");
569 else if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
570 fprintf(out, "8 ");
571 else
572 fprintf(out, "6 ");
573 fprintf(out, "%s %s source.cal ",
574 srcshape.type==SPHERE ? "corr" : "flatcorr",
575 libname(buf,name,T_DST));
576 if (pmtype == PM_B) {
577 if (FEQ(bounds[1][0],0.))
578 fprintf(out, "srcB_horiz2 ");
579 else
580 fprintf(out, "srcB_horiz ");
581 fprintf(out, "srcB_vert ");
582 } else {
583 if (nangles[1] >= 2) {
584 d1 = bounds[1][1] - bounds[1][0];
585 if (d1 <= 90.+FTINY)
586 fprintf(out, "src_phi4 ");
587 else if (d1 <= 180.+FTINY)
588 fprintf(out, "src_phi2 ");
589 else
590 fprintf(out, "src_phi ");
591 fprintf(out, "src_theta -my ");
592 if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
593 fprintf(out, "-rz -90 ");
594 } else
595 fprintf(out, "src_theta ");
596 }
597 fprintf(out, "\n0\n1 %g\n", multiplier*mult*bfactor*pfactor);
598 if (putsource(&srcshape, out, id, filename(name),
599 bounds[0][0]<90., bounds[0][1]>90.) != 0)
600 return(-1);
601 return(0);
602 }
603
604
605 putsource(shp, fp, mod, name, dolower, doupper) /* put out source */
606 SHAPE *shp;
607 FILE *fp;
608 char *mod, *name;
609 int dolower, doupper;
610 {
611 char buf[MAXWORD];
612
613 fprintf(fp, "\n%s %s %s_light\n", mod,
614 illumrad>=MINDIM/2. ? "illum" : "light",
615 name);
616 fprintf(fp, "0\n0\n3 %g %g %g\n",
617 lampcolor[0]/shp->area,
618 lampcolor[1]/shp->area,
619 lampcolor[2]/shp->area);
620 if (doupper && dolower && shp->type != SPHERE && shp->h > MINDIM) {
621 fprintf(fp, "\n%s glow %s_glow\n", mod, name);
622 fprintf(fp, "0\n0\n4 %g %g %g 0\n",
623 lampcolor[0]/shp->area,
624 lampcolor[1]/shp->area,
625 lampcolor[2]/shp->area);
626 }
627 switch (shp->type) {
628 case RECT:
629 strcat(strcpy(buf, name), "_light");
630 if (dolower)
631 putrectsrc(shp, fp, buf, name, 0);
632 if (doupper)
633 putrectsrc(shp, fp, buf, name, 1);
634 if (doupper && dolower && shp->h > MINDIM) {
635 strcat(strcpy(buf, name), "_glow");
636 putsides(shp, fp, buf, name);
637 }
638 break;
639 case DISK:
640 strcat(strcpy(buf, name), "_light");
641 if (dolower)
642 putdisksrc(shp, fp, buf, name, 0);
643 if (doupper)
644 putdisksrc(shp, fp, buf, name, 1);
645 if (doupper && dolower && shp->h > MINDIM) {
646 strcat(strcpy(buf, name), "_glow");
647 putcyl(shp, fp, buf, name);
648 }
649 break;
650 case SPHERE:
651 strcat(strcpy(buf, name), "_light");
652 putspheresrc(shp, fp, buf, name);
653 break;
654 }
655 return(0);
656 }
657
658
659 makeshape(shp, width, length, height) /* make source shape */
660 register SHAPE *shp;
661 double width, length, height;
662 {
663 if (illumrad >= MINDIM/2.) {
664 shp->type = SPHERE;
665 shp->w = shp->l = shp->h = 2.*illumrad;
666 } else if (width < MINDIM) {
667 width = -width;
668 if (width < MINDIM) {
669 shp->type = SPHERE;
670 shp->w = shp->l = shp->h = MINDIM;
671 } else if (height < .5*width) {
672 shp->type = DISK;
673 shp->w = shp->l = width;
674 if (height >= MINDIM)
675 shp->h = height;
676 else
677 shp->h = .5*MINDIM;
678 } else {
679 shp->type = SPHERE;
680 shp->w = shp->l = shp->h = width;
681 }
682 } else {
683 shp->type = RECT;
684 shp->w = width;
685 if (length >= MINDIM)
686 shp->l = length;
687 else
688 shp->l = MINDIM;
689 if (height >= MINDIM)
690 shp->h = height;
691 else
692 shp->h = .5*MINDIM;
693 }
694 switch (shp->type) {
695 case RECT:
696 shp->area = shp->w * shp->l;
697 break;
698 case DISK:
699 shp->area = PI/4. * shp->w * shp->w;
700 break;
701 case SPHERE:
702 shp->area = PI * shp->w * shp->w;
703 break;
704 }
705 return(0);
706 }
707
708
709 putrectsrc(shp, fp, mod, name, up) /* rectangular source */
710 SHAPE *shp;
711 FILE *fp;
712 char *mod, *name;
713 int up;
714 {
715 if (up)
716 putrect(shp, fp, mod, name, ".u", 4, 5, 7, 6);
717 else
718 putrect(shp, fp, mod, name, ".d", 0, 2, 3, 1);
719 }
720
721
722 putsides(shp, fp, mod, name) /* put out sides of box */
723 register SHAPE *shp;
724 FILE *fp;
725 char *mod, *name;
726 {
727 putrect(shp, fp, mod, name, ".1", 0, 1, 5, 4);
728 putrect(shp, fp, mod, name, ".2", 1, 3, 7, 5);
729 putrect(shp, fp, mod, name, ".3", 3, 2, 6, 7);
730 putrect(shp, fp, mod, name, ".4", 2, 0, 4, 6);
731 }
732
733
734 putrect(shp, fp, mod, name, suffix, a, b, c, d) /* put out a rectangle */
735 SHAPE *shp;
736 FILE *fp;
737 char *mod, *name, *suffix;
738 int a, b, c, d;
739 {
740 fprintf(fp, "\n%s polygon %s%s\n0\n0\n12\n", mod, name, suffix);
741 putpoint(shp, fp, a);
742 putpoint(shp, fp, b);
743 putpoint(shp, fp, c);
744 putpoint(shp, fp, d);
745 }
746
747
748 putpoint(shp, fp, p) /* put out a point */
749 register SHAPE *shp;
750 FILE *fp;
751 int p;
752 {
753 static double mult[2] = {-.5, .5};
754
755 fprintf(fp, "\t%g\t%g\t%g\n",
756 mult[p&1]*shp->l*meters2out,
757 mult[p>>1&1]*shp->w*meters2out,
758 mult[p>>2]*shp->h*meters2out);
759 }
760
761
762 putdisksrc(shp, fp, mod, name, up) /* put out a disk source */
763 register SHAPE *shp;
764 FILE *fp;
765 char *mod, *name;
766 int up;
767 {
768 if (up) {
769 fprintf(fp, "\n%s ring %s.u\n", mod, name);
770 fprintf(fp, "0\n0\n8\n");
771 fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
772 fprintf(fp, "\t0 0 1\n");
773 fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
774 } else {
775 fprintf(fp, "\n%s ring %s.d\n", mod, name);
776 fprintf(fp, "0\n0\n8\n");
777 fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
778 fprintf(fp, "\t0 0 -1\n");
779 fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
780 }
781 }
782
783
784 putcyl(shp, fp, mod, name) /* put out a cylinder */
785 register SHAPE *shp;
786 FILE *fp;
787 char *mod, *name;
788 {
789 fprintf(fp, "\n%s cylinder %s.c\n", mod, name);
790 fprintf(fp, "0\n0\n7\n");
791 fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
792 fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
793 fprintf(fp, "\t%g\n", .5*shp->w*meters2out);
794 }
795
796
797 putspheresrc(shp, fp, mod, name) /* put out a sphere source */
798 SHAPE *shp;
799 FILE *fp;
800 char *mod, *name;
801 {
802 fprintf(fp, "\n%s sphere %s.s\n", mod, name);
803 fprintf(fp, "0\n0\n4 0 0 0 %g\n", .5*shp->w*meters2out);
804 }
805
806
807 cvdata(in, out, ndim, npts, mult, lim) /* convert data */
808 FILE *in, *out;
809 int ndim, npts[];
810 double mult, lim[][2];
811 {
812 register double *pt[4];
813 register int i, j;
814 double val;
815 int total;
816
817 total = 1; j = 0;
818 for (i = 0; i < ndim; i++)
819 if (npts[i] > 1) {
820 total *= npts[i];
821 j++;
822 }
823 fprintf(out, "%d\n", j);
824 /* get coordinates */
825 for (i = 0; i < ndim; i++) {
826 pt[i] = (double *)malloc(npts[i]*sizeof(double));
827 for (j = 0; j < npts[i]; j++)
828 fscanf(in, "%lf", &pt[i][j]);
829 if (lim != NULL) {
830 lim[i][0] = pt[i][0];
831 lim[i][1] = pt[i][npts[i]-1];
832 }
833 }
834 /* write out in reverse */
835 for (i = ndim-1; i >= 0; i--) {
836 if (npts[i] > 1) {
837 for (j = 1; j < npts[i]-1; j++)
838 if (!FEQ(pt[i][j]-pt[i][j-1],
839 pt[i][j+1]-pt[i][j]))
840 break;
841 if (j == npts[i]-1)
842 fprintf(out, "%g %g %d\n", pt[i][0], pt[i][j],
843 npts[i]);
844 else {
845 fprintf(out, "0 0 %d", npts[i]);
846 for (j = 0; j < npts[i]; j++) {
847 if (j%4 == 0)
848 putc('\n', out);
849 fprintf(out, "\t%g", pt[i][j]);
850 }
851 putc('\n', out);
852 }
853 }
854 free((char *)pt[i]);
855 }
856 for (i = 0; i < total; i++) {
857 if (i%4 == 0)
858 putc('\n', out);
859 if (fscanf(in, "%lf", &val) != 1)
860 return(-1);
861 fprintf(out, "\t%g", val*mult);
862 }
863 putc('\n', out);
864 return(0);
865 }
