| 1 |
/* Copyright (c) 1990 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Convert IES luminaire data to Radiance description
| 9 |
| 10 |
* 07Apr90 Greg Ward
| 11 |
| 12 |
| 13 |
#include <stdio.h>
| 14 |
#include <ctype.h>
| 15 |
| 16 |
#define PI 3.14159265358979323846
| 17 |
/* floating comparisons */
| 18 |
#define FTINY 1e-6
| 19 |
#define FEQ(a,b) ((a)<=(b)+FTINY&&(a)>=(b)-FTINY)
| 20 |
/* tilt specs */
| 21 |
#define TLTSTR "TILT="
| 22 |
#define TLTSTRLEN 5
| 23 |
#define TLTNONE "NONE"
| 24 |
#define TLTINCL "INCLUDE"
| 25 |
#define TLT_VERT 1
| 26 |
#define TLT_H0 2
| 27 |
#define TLT_H90 3
| 28 |
/* photometric types */
| 29 |
#define PM_C 1
| 30 |
#define PM_B 2
| 31 |
/* unit types */
| 32 |
#define U_FEET 1
| 33 |
#define U_METERS 2
| 34 |
/* string lengths */
| 35 |
#define MAXLINE 132
| 36 |
#define MAXWORD 76
| 37 |
#define MAXPATH 128
| 38 |
/* file types */
| 39 |
#define T_RAD ".rad"
| 40 |
#define T_DST ".dat"
| 41 |
#define T_TLT "+.dat"
| 42 |
/* shape types */
| 43 |
#define RECT 1
| 44 |
#define DISK 2
| 45 |
#define SPHERE 3
| 46 |
| 47 |
#define MINDIM .001 /* minimum dimension (point source) */
| 48 |
| 49 |
#define F_M .3048 /* feet to meters */
| 50 |
| 51 |
#define abspath(p) ((p)[0] == '/' || (p)[0] == '.')
| 52 |
| 53 |
char *libdir = NULL; /* library directory location */
| 54 |
char *prefdir = NULL; /* subdirectory */
| 55 |
char *lampdat = "lamp.tab"; /* lamp data file */
| 56 |
| 57 |
double meters2out = 1.0; /* conversion from meters to output */
| 58 |
char *lamptype = NULL; /* selected lamp type */
| 59 |
float *lampcolor = NULL; /* pointer to lamp color */
| 60 |
float defcolor[3] = {1.,1.,1.}; /* default lamp color */
| 61 |
double multiplier = 1.0; /* multiplier for all light sources */
| 62 |
char units[64] = "meters"; /* output units */
| 63 |
double minaspect = 0.0; /* minimum allowed aspect ratio */
| 64 |
int maxemitters = 1; /* maximum emitters per hemisphere */
| 65 |
double illumrad = 0.0; /* radius for illum sphere */
| 66 |
| 67 |
typedef struct {
| 68 |
int type; /* RECT, DISK, SPHERE */
| 69 |
double w, l, h; /* width, length, height */
| 70 |
double area; /* effective radiating area */
| 71 |
} SHAPE; /* a source shape */
| 72 |
| 73 |
int gargc; /* global argc (minus filenames) */
| 74 |
char **gargv; /* global argv */
| 75 |
| 76 |
extern char *strcpy(), *strcat(), *stradd(), *tailtrunc(), *filetrunc(),
| 77 |
*filename(), *libname(), *fullname(), *malloc();
| 78 |
extern double atof();
| 79 |
extern float *matchlamp();
| 80 |
| 81 |
| 82 |
main(argc, argv)
| 83 |
int argc;
| 84 |
char *argv[];
| 85 |
| 86 |
char *outfile = NULL;
| 87 |
int status;
| 88 |
char outname[MAXWORD];
| 89 |
double d1;
| 90 |
int i;
| 91 |
| 92 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 93 |
switch (argv[i][1]) {
| 94 |
case 'd': /* dimensions */
| 95 |
if (argv[i][2] == '\0')
| 96 |
goto badopt;
| 97 |
if (argv[i][3] == '\0')
| 98 |
d1 = 1.0;
| 99 |
else if (argv[i][3] == '/') {
| 100 |
d1 = atof(argv[i]+4);
| 101 |
if (d1 <= FTINY)
| 102 |
goto badopt;
| 103 |
} else
| 104 |
goto badopt;
| 105 |
switch (argv[i][2]) {
| 106 |
case 'c': /* centimeters */
| 107 |
if (FEQ(d1,10.))
| 108 |
strcpy(units,"millimeters");
| 109 |
else {
| 110 |
strcpy(units,"centimeters");
| 111 |
strcat(units,argv[i]+3);
| 112 |
| 113 |
meters2out = 100.*d1;
| 114 |
break;
| 115 |
case 'm': /* meters */
| 116 |
if (FEQ(d1,1000.))
| 117 |
| 118 |
else if (FEQ(d1,100.))
| 119 |
| 120 |
else {
| 121 |
strcpy(units,"meters");
| 122 |
| 123 |
| 124 |
meters2out = d1;
| 125 |
break;
| 126 |
case 'i': /* inches */
| 127 |
strcpy(units,"inches");
| 128 |
| 129 |
meters2out = d1*(12./F_M);
| 130 |
break;
| 131 |
case 'f': /* feet */
| 132 |
if (FEQ(d1,12.))
| 133 |
| 134 |
else {
| 135 |
strcpy(units,"feet");
| 136 |
| 137 |
| 138 |
meters2out = d1/F_M;
| 139 |
break;
| 140 |
default:
| 141 |
goto badopt;
| 142 |
| 143 |
break;
| 144 |
case 'l': /* library directory */
| 145 |
libdir = argv[++i];
| 146 |
break;
| 147 |
case 'p': /* prefix subdirectory */
| 148 |
prefdir = argv[++i];
| 149 |
break;
| 150 |
case 'f': /* lamp data file */
| 151 |
lampdat = argv[++i];
| 152 |
break;
| 153 |
case 'o': /* output file name */
| 154 |
outfile = argv[++i];
| 155 |
break;
| 156 |
case 's': /* square emitters */
| 157 |
minaspect = .6;
| 158 |
if (argv[i][2] == '/') {
| 159 |
maxemitters = atoi(argv[i]+3);
| 160 |
if (maxemitters < 1)
| 161 |
goto badopt;
| 162 |
| 163 |
break;
| 164 |
case 'i': /* illum */
| 165 |
illumrad = atof(argv[++i]);
| 166 |
if (illumrad < MINDIM)
| 167 |
illumrad = MINDIM;
| 168 |
break;
| 169 |
case 't': /* select lamp type */
| 170 |
lamptype = argv[++i];
| 171 |
break;
| 172 |
case 'c': /* default lamp color */
| 173 |
defcolor[0] = atof(argv[++i]);
| 174 |
defcolor[1] = atof(argv[++i]);
| 175 |
defcolor[2] = atof(argv[++i]);
| 176 |
break;
| 177 |
case 'm': /* multiplier */
| 178 |
multiplier = atof(argv[++i]);
| 179 |
break;
| 180 |
default:
| 181 |
badopt:
| 182 |
fprintf(stderr, "%s: bad option: %s\n",
| 183 |
argv[0], argv[i]);
| 184 |
exit(1);
| 185 |
| 186 |
gargc = i;
| 187 |
gargv = argv;
| 188 |
/* get lamp data */
| 189 |
if ((status = loadlamps(lampdat)) < 0)
| 190 |
exit(1);
| 191 |
if (status == 0 || (lamptype != NULL &&
| 192 |
(lampcolor = matchlamp(lamptype)) == NULL)) {
| 193 |
lampcolor = defcolor;
| 194 |
fprintf(stderr, "%s: warning - no lamp data\n", argv[0]);
| 195 |
| 196 |
/* convert ies file(s) */
| 197 |
if (outfile != NULL) {
| 198 |
if (i == argc)
| 199 |
exit(ies2rad(NULL, outfile) == 0 ? 0 : 1);
| 200 |
else if (i == argc-1)
| 201 |
exit(ies2rad(argv[i], outfile) == 0 ? 0 : 1);
| 202 |
else {
| 203 |
fprintf(stderr, "%s: single input file required\n",
| 204 |
argv[0]);
| 205 |
exit(1);
| 206 |
| 207 |
} else if (i >= argc) {
| 208 |
fprintf(stderr, "%s: missing output file specification\n",
| 209 |
argv[0]);
| 210 |
exit(1);
| 211 |
| 212 |
status = 0;
| 213 |
for ( ; i < argc; i++) {
| 214 |
tailtrunc(strcpy(outname,filename(argv[i])));
| 215 |
if (ies2rad(argv[i], outname) != 0)
| 216 |
status = 1;
| 217 |
| 218 |
exit(status);
| 219 |
| 220 |
| 221 |
| 222 |
char *
| 223 |
stradd(dst, src, sep) /* add a string at dst */
| 224 |
register char *dst, *src;
| 225 |
int sep;
| 226 |
| 227 |
if (src && *src) {
| 228 |
do
| 229 |
*dst++ = *src++;
| 230 |
while (*src);
| 231 |
if (sep && dst[-1] != sep)
| 232 |
*dst++ = sep;
| 233 |
| 234 |
*dst = '\0';
| 235 |
return(dst);
| 236 |
| 237 |
| 238 |
| 239 |
char *
| 240 |
fullname(path, fname, suffix) /* return full path name */
| 241 |
char *path, *fname, *suffix;
| 242 |
| 243 |
if (prefdir != NULL && abspath(prefdir))
| 244 |
libname(path, fname, suffix);
| 245 |
else if (abspath(fname))
| 246 |
strcpy(stradd(path, fname, 0), suffix);
| 247 |
else
| 248 |
libname(stradd(path, libdir, '/'), fname, suffix);
| 249 |
| 250 |
return(path);
| 251 |
| 252 |
| 253 |
| 254 |
char *
| 255 |
libname(path, fname, suffix) /* return library relative name */
| 256 |
| 257 |
| 258 |
if (abspath(fname))
| 259 |
| 260 |
else
| 261 |
strcpy(stradd(stradd(path, prefdir, '/'), fname, 0), suffix);
| 262 |
| 263 |
return(path);
| 264 |
| 265 |
| 266 |
| 267 |
char *
| 268 |
filename(path) /* get final component of pathname */
| 269 |
register char *path;
| 270 |
| 271 |
register char *cp;
| 272 |
| 273 |
for (cp = path; *path; path++)
| 274 |
if (*path == '/')
| 275 |
cp = path+1;
| 276 |
return(cp);
| 277 |
| 278 |
| 279 |
| 280 |
char *
| 281 |
filetrunc(path) /* truncate filename at end of path */
| 282 |
char *path;
| 283 |
| 284 |
register char *p1, *p2;
| 285 |
| 286 |
for (p1 = p2 = path; *p2; p2++)
| 287 |
if (*p2 == '/')
| 288 |
p1 = p2;
| 289 |
*p1 = '\0';
| 290 |
return(path);
| 291 |
| 292 |
| 293 |
| 294 |
char *
| 295 |
tailtrunc(name) /* truncate tail of filename */
| 296 |
char *name;
| 297 |
| 298 |
| 299 |
| 300 |
for (p1 = filename(name); *p1 == '.'; p1++)
| 301 |
| 302 |
p2 = NULL;
| 303 |
for ( ; *p1; p1++)
| 304 |
if (*p1 == '.')
| 305 |
p2 = p1;
| 306 |
if (p2 != NULL)
| 307 |
*p2 = '\0';
| 308 |
return(name);
| 309 |
| 310 |
| 311 |
| 312 |
blanktrunc(s) /* truncate spaces at end of line */
| 313 |
char *s;
| 314 |
| 315 |
register char *cp;
| 316 |
| 317 |
for (cp = s; *cp; cp++)
| 318 |
| 319 |
while (cp-- > s && isspace(*cp))
| 320 |
| 321 |
*++cp = '\0';
| 322 |
| 323 |
| 324 |
| 325 |
putheader(out) /* print header */
| 326 |
FILE *out;
| 327 |
| 328 |
register int i;
| 329 |
| 330 |
putc('#', out);
| 331 |
for (i = 0; i < gargc; i++) {
| 332 |
putc(' ', out);
| 333 |
fputs(gargv[i], out);
| 334 |
| 335 |
fputs("\n# Dimensions in ", out);
| 336 |
fputs(units, out);
| 337 |
putc('\n', out);
| 338 |
| 339 |
| 340 |
| 341 |
ies2rad(inpname, outname) /* convert IES file */
| 342 |
char *inpname, *outname;
| 343 |
| 344 |
char buf[MAXLINE], tltid[MAXWORD];
| 345 |
FILE *inpfp, *outfp;
| 346 |
| 347 |
if (inpname == NULL) {
| 348 |
inpname = "<stdin>";
| 349 |
inpfp = stdin;
| 350 |
} else if ((inpfp = fopen(inpname, "r")) == NULL) {
| 351 |
perror(inpname);
| 352 |
return(-1);
| 353 |
| 354 |
if ((outfp = fopen(fullname(buf,outname,T_RAD), "w")) == NULL) {
| 355 |
perror(buf);
| 356 |
fclose(inpfp);
| 357 |
return(-1);
| 358 |
| 359 |
putheader(outfp);
| 360 |
if (lamptype == NULL)
| 361 |
lampcolor = NULL;
| 362 |
while (fgets(buf,sizeof(buf),inpfp) != NULL
| 363 |
&& strncmp(buf,TLTSTR,TLTSTRLEN)) {
| 364 |
blanktrunc(buf);
| 365 |
if (!buf[0])
| 366 |
continue;
| 367 |
fputs("#<", outfp);
| 368 |
fputs(buf, outfp);
| 369 |
putc('\n', outfp);
| 370 |
if (lampcolor == NULL)
| 371 |
lampcolor = matchlamp(buf);
| 372 |
| 373 |
if (lampcolor == NULL) {
| 374 |
fprintf(stderr, "%s: warning - no lamp type\n", inpname);
| 375 |
| 376 |
| 377 |
if (feof(inpfp)) {
| 378 |
fprintf(stderr, "%s: not in IES format\n", inpname);
| 379 |
goto readerr;
| 380 |
| 381 |
sscanf(buf+TLTSTRLEN, "%s", tltid);
| 382 |
if (inpfp == stdin)
| 383 |
buf[0] = '\0';
| 384 |
else
| 385 |
filetrunc(strcpy(buf, inpname));
| 386 |
if (dotilt(inpfp, outfp, buf, tltid, outname, tltid) != 0) {
| 387 |
fprintf(stderr, "%s: bad tilt data\n", inpname);
| 388 |
goto readerr;
| 389 |
| 390 |
if (dosource(inpfp, outfp, tltid, outname) != 0) {
| 391 |
fprintf(stderr, "%s: bad luminaire data\n", inpname);
| 392 |
goto readerr;
| 393 |
| 394 |
fclose(outfp);
| 395 |
fclose(inpfp);
| 396 |
return(0);
| 397 |
readerr:
| 398 |
fclose(outfp);
| 399 |
fclose(inpfp);
| 400 |
unlink(fullname(buf,outname,T_RAD));
| 401 |
return(-1);
| 402 |
| 403 |
| 404 |
| 405 |
dotilt(in, out, dir, tltspec, dfltname, tltid) /* convert tilt data */
| 406 |
FILE *in, *out;
| 407 |
char *dir, *tltspec, *dfltname, *tltid;
| 408 |
| 409 |
int nangles, tlt_type;
| 410 |
double minmax[2];
| 411 |
char buf[MAXPATH], tltname[MAXWORD];
| 412 |
FILE *datin, *datout;
| 413 |
| 414 |
if (!strcmp(tltspec, TLTNONE)) {
| 415 |
datin = NULL;
| 416 |
strcpy(tltid, "void");
| 417 |
} else if (!strcmp(tltspec, TLTINCL)) {
| 418 |
datin = in;
| 419 |
strcpy(tltname, dfltname);
| 420 |
} else {
| 421 |
if (tltspec[0] == '/')
| 422 |
strcpy(buf, tltspec);
| 423 |
else
| 424 |
strcpy(stradd(buf, dir, '/'), tltspec);
| 425 |
if ((datin = fopen(buf, "r")) == NULL) {
| 426 |
perror(buf);
| 427 |
return(-1);
| 428 |
| 429 |
tailtrunc(strcpy(tltname,filename(tltspec)));
| 430 |
| 431 |
if (datin != NULL) {
| 432 |
if ((datout = fopen(fullname(buf,tltname,T_TLT),"w")) == NULL) {
| 433 |
perror(buf);
| 434 |
if (datin != in)
| 435 |
fclose(datin);
| 436 |
return(-1);
| 437 |
| 438 |
if (fscanf(datin, "%d %d", &tlt_type, &nangles) != 2
| 439 |
|| cvdata(datin,datout,1,&nangles,1.,minmax) != 0) {
| 440 |
fprintf(stderr, "%s: data format error\n", tltspec);
| 441 |
fclose(datout);
| 442 |
if (datin != in)
| 443 |
fclose(datin);
| 444 |
unlink(fullname(buf,tltname,T_TLT));
| 445 |
return(-1);
| 446 |
| 447 |
fclose(datout);
| 448 |
if (datin != in)
| 449 |
fclose(datin);
| 450 |
strcat(strcpy(tltid, filename(tltname)), "_tilt");
| 451 |
fprintf(out, "\nvoid brightdata %s\n", tltid);
| 452 |
libname(buf,tltname,T_TLT);
| 453 |
switch (tlt_type) {
| 454 |
case TLT_VERT: /* vertical */
| 455 |
fprintf(out, "4 noop %s tilt.cal %s\n", buf,
| 456 |
minmax[1]>90.+FTINY ? "tilt_ang" : "tilt_ang2");
| 457 |
break;
| 458 |
case TLT_H0: /* horiz. in 0 deg. plane */
| 459 |
fprintf(out, "6 noop %s tilt.cal %s -rz 90\n", buf,
| 460 |
minmax[1]>90.+FTINY ? "tilt_xang" : "tilt_xang2");
| 461 |
break;
| 462 |
case TLT_H90:
| 463 |
| 464 |
| 465 |
break;
| 466 |
default:
| 467 |
fprintf(stderr,
| 468 |
"%s: illegal lamp to luminaire geometry (%d)\n",
| 469 |
tltspec, tlt_type);
| 470 |
return(-1);
| 471 |
| 472 |
fprintf(out, "0\n0\n");
| 473 |
| 474 |
return(0);
| 475 |
| 476 |
| 477 |
| 478 |
dosource(in, out, mod, name) /* create source and distribution */
| 479 |
FILE *in, *out;
| 480 |
char *mod, *name;
| 481 |
| 482 |
SHAPE srcshape;
| 483 |
char buf[MAXPATH], id[MAXWORD];
| 484 |
FILE *datout;
| 485 |
double mult, bfactor, pfactor, width, length, height, wattage;
| 486 |
double bounds[2][2];
| 487 |
int nangles[2], pmtype, unitype;
| 488 |
double d1;
| 489 |
| 490 |
if (fscanf(in, "%*d %*f %lf %d %d %d %d %lf %lf %lf %lf %lf %lf",
| 491 |
&mult, &nangles[0], &nangles[1], &pmtype, &unitype,
| 492 |
&width, &length, &height, &bfactor, &pfactor,
| 493 |
&wattage) != 11) {
| 494 |
fprintf(stderr, "dosource: bad lamp specification\n");
| 495 |
return(-1);
| 496 |
| 497 |
if (nangles[0] < 2 || nangles[1] < 1) {
| 498 |
fprintf(stderr, "dosource: too few measured angles\n");
| 499 |
return(-1);
| 500 |
| 501 |
if (unitype == U_FEET) {
| 502 |
width *= F_M;
| 503 |
length *= F_M;
| 504 |
height *= F_M;
| 505 |
| 506 |
if (makeshape(&srcshape, width, length, height) != 0) {
| 507 |
fprintf(stderr, "dosource: illegal source dimensions");
| 508 |
return(-1);
| 509 |
| 510 |
if ((datout = fopen(fullname(buf,name,T_DST), "w")) == NULL) {
| 511 |
perror(buf);
| 512 |
return(-1);
| 513 |
| 514 |
if (cvdata(in, datout, 2, nangles, 1./683., bounds) != 0) {
| 515 |
fprintf(stderr, "dosource: bad distribution data\n");
| 516 |
fclose(datout);
| 517 |
unlink(fullname(buf,name,T_DST));
| 518 |
return(-1);
| 519 |
| 520 |
fclose(datout);
| 521 |
fprintf(out, "# %g watt luminaire, lamp*ballast factor = %g\n",
| 522 |
wattage, bfactor*pfactor);
| 523 |
strcat(strcpy(id, filename(name)), "_dist");
| 524 |
fprintf(out, "\n%s brightdata %s\n", mod, id);
| 525 |
if (nangles[1] < 2)
| 526 |
fprintf(out, "4 ");
| 527 |
else if (pmtype == PM_B)
| 528 |
fprintf(out, "5 ");
| 529 |
else if (FEQ(bounds[1][0],90.) && FEQ(bounds[1][1],270.))
| 530 |
fprintf(out, "8 ");
| 531 |
else
| 532 |
fprintf(out, "6 ");
| 533 |
fprintf(out, "%s %s source.cal ",
| 534 |
srcshape.type==SPHERE ? "corr" : "flatcorr",
| 535 |
libname(buf,name,T_DST));
| 536 |
if (pmtype == PM_B) {
| 537 |
if (FEQ(bounds[1][0],0.))
| 538 |
fprintf(out, "srcB_horiz2 ");
| 539 |
else
| 540 |
fprintf(out, "srcB_horiz ");
| 541 |
fprintf(out, "srcB_vert ");
| 542 |
} else {
| 543 |
if (nangles[1] >= 2) {
| 544 |
d1 = bounds[1][1] - bounds[1][0];
| 545 |
if (d1 <= 90.+FTINY)
| 546 |
fprintf(out, "src_phi4 ");
| 547 |
else if (d1 <= 180.+FTINY)
| 548 |
fprintf(out, "src_phi2 ");
| 549 |
else
| 550 |
fprintf(out, "src_phi ");
| 551 |
fprintf(out, "src_theta -my ");
| 552 |
| 553 |
fprintf(out, "-rz -90 ");
| 554 |
} else
| 555 |
fprintf(out, "src_theta ");
| 556 |
| 557 |
fprintf(out, "\n0\n1 %g\n", multiplier*mult*bfactor*pfactor);
| 558 |
if (putsource(&srcshape, out, id, filename(name),
| 559 |
bounds[0][0]<90., bounds[0][1]>90.) != 0)
| 560 |
return(-1);
| 561 |
return(0);
| 562 |
| 563 |
| 564 |
| 565 |
putsource(shp, fp, mod, name, dolower, doupper) /* put out source */
| 566 |
SHAPE *shp;
| 567 |
FILE *fp;
| 568 |
char *mod, *name;
| 569 |
int dolower, doupper;
| 570 |
| 571 |
char buf[MAXWORD];
| 572 |
| 573 |
fprintf(fp, "\n%s %s %s_light\n", mod,
| 574 |
illumrad>=MINDIM/2. ? "illum" : "light",
| 575 |
name);
| 576 |
fprintf(fp, "0\n0\n3 %g %g %g\n",
| 577 |
lampcolor[0]/shp->area,
| 578 |
lampcolor[1]/shp->area,
| 579 |
lampcolor[2]/shp->area);
| 580 |
if (doupper && dolower && shp->type != SPHERE && shp->h > MINDIM) {
| 581 |
fprintf(fp, "\n%s glow %s_glow\n", mod, name);
| 582 |
fprintf(fp, "0\n0\n4 %g %g %g 0\n",
| 583 |
| 584 |
| 585 |
| 586 |
| 587 |
switch (shp->type) {
| 588 |
case RECT:
| 589 |
strcat(strcpy(buf, name), "_light");
| 590 |
if (dolower)
| 591 |
putrectsrc(shp, fp, buf, name, 0);
| 592 |
if (doupper)
| 593 |
putrectsrc(shp, fp, buf, name, 1);
| 594 |
if (doupper && dolower && shp->h > MINDIM) {
| 595 |
strcat(strcpy(buf, name), "_glow");
| 596 |
putsides(shp, fp, buf, name);
| 597 |
| 598 |
break;
| 599 |
case DISK:
| 600 |
| 601 |
if (dolower)
| 602 |
putdisksrc(shp, fp, buf, name, 0);
| 603 |
if (doupper)
| 604 |
putdisksrc(shp, fp, buf, name, 1);
| 605 |
| 606 |
| 607 |
putcyl(shp, fp, buf, name);
| 608 |
| 609 |
break;
| 610 |
case SPHERE:
| 611 |
| 612 |
putspheresrc(shp, fp, buf, name);
| 613 |
break;
| 614 |
| 615 |
return(0);
| 616 |
| 617 |
| 618 |
| 619 |
makeshape(shp, width, length, height) /* make source shape */
| 620 |
register SHAPE *shp;
| 621 |
double width, length, height;
| 622 |
| 623 |
if (illumrad >= MINDIM/2.) {
| 624 |
shp->type = SPHERE;
| 625 |
shp->w = shp->l = shp->h = 2.*illumrad;
| 626 |
} else if (width < MINDIM) {
| 627 |
width = -width;
| 628 |
| 629 |
shp->type = SPHERE;
| 630 |
shp->w = shp->l = shp->h = MINDIM;
| 631 |
} else if (height < .5*width) {
| 632 |
shp->type = DISK;
| 633 |
shp->w = shp->l = width;
| 634 |
if (height >= MINDIM)
| 635 |
shp->h = height;
| 636 |
else
| 637 |
shp->h = .5*MINDIM;
| 638 |
} else {
| 639 |
shp->type = SPHERE;
| 640 |
shp->w = shp->l = shp->h = width;
| 641 |
| 642 |
} else {
| 643 |
shp->type = RECT;
| 644 |
shp->w = width;
| 645 |
if (length >= MINDIM)
| 646 |
shp->l = length;
| 647 |
else
| 648 |
shp->l = MINDIM;
| 649 |
| 650 |
shp->h = height;
| 651 |
else
| 652 |
shp->h = .5*MINDIM;
| 653 |
| 654 |
| 655 |
case RECT:
| 656 |
shp->area = shp->w * shp->l;
| 657 |
break;
| 658 |
case DISK:
| 659 |
shp->area = PI/4. * shp->w * shp->w;
| 660 |
break;
| 661 |
case SPHERE:
| 662 |
shp->area = PI * shp->w * shp->w;
| 663 |
break;
| 664 |
| 665 |
return(0);
| 666 |
| 667 |
| 668 |
| 669 |
putrectsrc(shp, fp, mod, name, up) /* rectangular source */
| 670 |
SHAPE *shp;
| 671 |
FILE *fp;
| 672 |
char *mod, *name;
| 673 |
int up;
| 674 |
| 675 |
if (up)
| 676 |
putrect(shp, fp, mod, name, ".u", 4, 5, 7, 6);
| 677 |
else
| 678 |
putrect(shp, fp, mod, name, ".d", 0, 2, 3, 1);
| 679 |
| 680 |
| 681 |
| 682 |
putsides(shp, fp, mod, name) /* put out sides of box */
| 683 |
| 684 |
FILE *fp;
| 685 |
char *mod, *name;
| 686 |
| 687 |
putrect(shp, fp, mod, name, ".1", 0, 1, 5, 4);
| 688 |
putrect(shp, fp, mod, name, ".2", 1, 3, 7, 5);
| 689 |
putrect(shp, fp, mod, name, ".3", 3, 2, 6, 7);
| 690 |
putrect(shp, fp, mod, name, ".4", 2, 0, 4, 6);
| 691 |
| 692 |
| 693 |
| 694 |
putrect(shp, fp, mod, name, suffix, a, b, c, d) /* put out a rectangle */
| 695 |
SHAPE *shp;
| 696 |
FILE *fp;
| 697 |
char *mod, *name, *suffix;
| 698 |
int a, b, c, d;
| 699 |
| 700 |
fprintf(fp, "\n%s polygon %s%s\n0\n0\n12\n", mod, name, suffix);
| 701 |
putpoint(shp, fp, a);
| 702 |
putpoint(shp, fp, b);
| 703 |
putpoint(shp, fp, c);
| 704 |
putpoint(shp, fp, d);
| 705 |
| 706 |
| 707 |
| 708 |
putpoint(shp, fp, p) /* put out a point */
| 709 |
| 710 |
FILE *fp;
| 711 |
int p;
| 712 |
| 713 |
static double mult[2] = {-.5, .5};
| 714 |
| 715 |
fprintf(fp, "\t%g\t%g\t%g\n",
| 716 |
mult[p&1]*shp->l*meters2out,
| 717 |
mult[p>>1&1]*shp->w*meters2out,
| 718 |
mult[p>>2]*shp->h*meters2out);
| 719 |
| 720 |
| 721 |
| 722 |
putdisksrc(shp, fp, mod, name, up) /* put out a disk source */
| 723 |
| 724 |
FILE *fp;
| 725 |
char *mod, *name;
| 726 |
int up;
| 727 |
| 728 |
if (up) {
| 729 |
fprintf(fp, "\n%s ring %s.u\n", mod, name);
| 730 |
fprintf(fp, "0\n0\n8\n");
| 731 |
fprintf(fp, "\t0 0 %g\n", .5*shp->h*meters2out);
| 732 |
fprintf(fp, "\t0 0 1\n");
| 733 |
fprintf(fp, "\t0 %g\n", .5*shp->w*meters2out);
| 734 |
} else {
| 735 |
fprintf(fp, "\n%s ring %s.d\n", mod, name);
| 736 |
| 737 |
fprintf(fp, "\t0 0 %g\n", -.5*shp->h*meters2out);
| 738 |
fprintf(fp, "\t0 0 -1\n");
| 739 |
| 740 |
| 741 |
| 742 |
| 743 |
| 744 |
putcyl(shp, fp, mod, name) /* put out a cylinder */
| 745 |
| 746 |
FILE *fp;
| 747 |
char *mod, *name;
| 748 |
| 749 |
fprintf(fp, "\n%s cylinder %s.c\n", mod, name);
| 750 |
fprintf(fp, "0\n0\n7\n");
| 751 |
| 752 |
| 753 |
fprintf(fp, "\t%g\n", .5*shp->w*meters2out);
| 754 |
| 755 |
| 756 |
| 757 |
putspheresrc(shp, fp, mod, name) /* put out a sphere source */
| 758 |
SHAPE *shp;
| 759 |
FILE *fp;
| 760 |
char *mod, *name;
| 761 |
| 762 |
fprintf(fp, "\n%s sphere %s.s\n", mod, name);
| 763 |
fprintf(fp, "0\n0\n4 0 0 0 %g\n", .5*shp->w*meters2out);
| 764 |
| 765 |
| 766 |
| 767 |
cvdata(in, out, ndim, npts, mult, lim) /* convert data */
| 768 |
FILE *in, *out;
| 769 |
int ndim, npts[];
| 770 |
double mult, lim[][2];
| 771 |
| 772 |
register double *pt[4];
| 773 |
register int i, j;
| 774 |
double val;
| 775 |
int total;
| 776 |
| 777 |
total = 1; j = 0;
| 778 |
for (i = 0; i < ndim; i++)
| 779 |
if (npts[i] > 1) {
| 780 |
total *= npts[i];
| 781 |
j++;
| 782 |
| 783 |
fprintf(out, "%d\n", j);
| 784 |
/* get coordinates */
| 785 |
for (i = 0; i < ndim; i++) {
| 786 |
pt[i] = (double *)malloc(npts[i]*sizeof(double));
| 787 |
for (j = 0; j < npts[i]; j++)
| 788 |
fscanf(in, "%lf", &pt[i][j]);
| 789 |
if (lim != NULL) {
| 790 |
lim[i][0] = pt[i][0];
| 791 |
lim[i][1] = pt[i][npts[i]-1];
| 792 |
| 793 |
| 794 |
/* write out in reverse */
| 795 |
for (i = ndim-1; i >= 0; i--) {
| 796 |
if (npts[i] > 1) {
| 797 |
for (j = 1; j < npts[i]-1; j++)
| 798 |
if (!FEQ(pt[i][j]-pt[i][j-1],
| 799 |
pt[i][j+1]-pt[i][j]))
| 800 |
break;
| 801 |
if (j == npts[i]-1)
| 802 |
fprintf(out, "%g %g %d\n", pt[i][0], pt[i][j],
| 803 |
npts[i]);
| 804 |
else {
| 805 |
fprintf(out, "0 0 %d", npts[i]);
| 806 |
for (j = 0; j < npts[i]; j++) {
| 807 |
if (j%4 == 0)
| 808 |
putc('\n', out);
| 809 |
fprintf(out, "\t%g", pt[i][j]);
| 810 |
| 811 |
putc('\n', out);
| 812 |
| 813 |
| 814 |
free((char *)pt[i]);
| 815 |
| 816 |
for (i = 0; i < total; i++) {
| 817 |
if (i%4 == 0)
| 818 |
putc('\n', out);
| 819 |
if (fscanf(in, "%lf", &val) != 1)
| 820 |
return(-1);
| 821 |
fprintf(out, "\t%g", val*mult);
| 822 |
| 823 |
putc('\n', out);
| 824 |
return(0);
| 825 |
