root/Development/ray/src/cv/checkBSDF.c
Mon Sep 11 18:43:36 2023 UTC (2 years ago) by greg
fix(checkBSDF): added missing newline in output
Fri Aug 12 23:55:00 2022 UTC (3 years, 1 month ago) by greg
Changes since 2.8: +9 -6 lines
fix(iso2klems): used solid angle, when projected SA needed, and integral factor
Tue Feb 1 18:31:28 2022 UTC (3 years, 8 months ago) by greg
feat(checkBSDF): Minor change in output header
Fri Jan 28 02:25:28 2022 UTC (3 years, 8 months ago) by greg
Changes since 2.6: +8 -4 lines
fix(checkBSDF): Fixed another divide-by-zero and improved output consistency
Wed Jan 26 17:30:07 2022 UTC (3 years, 8 months ago) by greg
fix(checkBSDF): Fixed NaN error
Wed Jan 26 16:19:30 2022 UTC (3 years, 8 months ago) by greg
fix(checkBSDF): fixed Windows compilation error
Fri Dec 17 23:49:13 2021 UTC (3 years, 9 months ago) by greg
Changes since 2.3: +5 -5 lines
feat(checkBSDF): more consistent labeling in output
Fri Dec 17 20:51:55 2021 UTC (3 years, 9 months ago) by greg
Changes since 2.2: +9 -3 lines
fix(checkBSDF): corrected issue with missing diffuse component in Klems BSDFs
Wed Dec 15 02:13:27 2021 UTC (3 years, 9 months ago) by greg
Changes since 2.1: +114 -30 lines
Diff to previous 2.1
feat: finished implementation of tensor tree reciprocity calculation
Tue Dec 14 02:33:18 2021 UTC (3 years, 9 months ago) by greg
feat(checkBSDF): created new checkBSDF tool to check XML data reciprocity
