| 1 |
greg |
2.25 |
/* RCSid $Id: bsdfrep.h,v 2.24 2016/01/30 01:31:57 greg Exp $ */ |
| 2 |
greg |
2.1 |
| 3 |
* Definitions for BSDF representation used to interpolate measured data. |
| 4 |
| 5 |
* G. Ward |
| 6 |
| 7 |
| 8 |
greg |
2.19 |
#ifndef _BSDFREP_H_ |
| 9 |
#define _BSDFREP_H_ |
| 10 |
| 11 |
greg |
2.1 |
#include "bsdf.h" |
| 12 |
| 13 |
greg |
2.19 |
#ifdef __cplusplus |
| 14 |
extern "C" { |
| 15 |
#endif |
| 16 |
| 17 |
greg |
2.1 |
#ifndef GRIDRES |
| 18 |
greg |
2.10 |
#define GRIDRES (1<<8) /* grid resolution per side */ |
| 19 |
greg |
2.1 |
#endif |
| 20 |
/* convert to/from coded radians */ |
| 21 |
#define ANG2R(r) (int)((r)*((1<<16)/M_PI)) |
| 22 |
#define R2ANG(c) (((c)+.5)*(M_PI/(1<<16))) |
| 23 |
| 24 |
greg |
2.22 |
/* moderated cosine factor */ |
| 25 |
#define COSF(z) (fabs(z)*0.98 + 0.02) |
| 26 |
| 27 |
greg |
2.15 |
typedef union { |
| 28 |
struct { |
| 29 |
float v; /* DSF sum */ |
| 30 |
unsigned int n; /* number of values in sum */ |
| 31 |
} sum; /* sum for averaging */ |
| 32 |
float val[2]; /* comparison values */ |
| 33 |
greg |
2.1 |
} GRIDVAL; /* grid value */ |
| 34 |
| 35 |
typedef struct { |
| 36 |
float peak; /* lobe value at peak */ |
| 37 |
greg |
2.23 |
C_CHROMA chroma; /* encoded chromaticity */ |
| 38 |
greg |
2.1 |
unsigned short crad; /* radius (coded angle) */ |
| 39 |
greg |
2.23 |
unsigned short gx, gy; /* grid position */ |
| 40 |
greg |
2.1 |
} RBFVAL; /* radial basis function value */ |
| 41 |
| 42 |
struct s_rbfnode; /* forward declaration of RBF struct */ |
| 43 |
| 44 |
typedef struct s_migration { |
| 45 |
struct s_migration *next; /* next in global edge list */ |
| 46 |
struct s_rbfnode *rbfv[2]; /* from,to vertex */ |
| 47 |
struct s_migration *enxt[2]; /* next from,to sibling */ |
| 48 |
float mtx[1]; /* matrix (extends struct) */ |
| 49 |
} MIGRATION; /* migration link (winged edge structure) */ |
| 50 |
| 51 |
typedef struct s_rbfnode { |
| 52 |
int ord; /* ordinal position in list */ |
| 53 |
struct s_rbfnode *next; /* next in global RBF list */ |
| 54 |
MIGRATION *ejl; /* edge list for this vertex */ |
| 55 |
FVECT invec; /* incident vector direction */ |
| 56 |
double vtotal; /* volume for normalization */ |
| 57 |
int nrbf; /* number of RBFs */ |
| 58 |
RBFVAL rbfa[1]; /* RBF array (extends struct) */ |
| 59 |
} RBFNODE; /* RBF representation of DSF @ 1 incidence */ |
| 60 |
| 61 |
/* symmetry operations */ |
| 62 |
#define MIRROR_X 1 /* mirror(ed) x-coordinate */ |
| 63 |
#define MIRROR_Y 2 /* mirror(ed) y-coordinate */ |
| 64 |
| 65 |
/* represented incident quadrants */ |
| 66 |
#define INP_QUAD1 1 /* 0-90 degree quadrant */ |
| 67 |
#define INP_QUAD2 2 /* 90-180 degree quadrant */ |
| 68 |
#define INP_QUAD3 4 /* 180-270 degree quadrant */ |
| 69 |
#define INP_QUAD4 8 /* 270-360 degree quadrant */ |
| 70 |
| 71 |
greg |
2.11 |
/* name and manufacturer if known */ |
| 72 |
extern char bsdf_name[]; |
| 73 |
extern char bsdf_manuf[]; |
| 74 |
greg |
2.5 |
/* active grid resolution */ |
| 75 |
extern int grid_res; |
| 76 |
greg |
2.3 |
/* coverage/symmetry using INP_QUAD? flags */ |
| 77 |
greg |
2.1 |
extern int inp_coverage; |
| 78 |
| 79 |
/* all incident angles in-plane so far? */ |
| 80 |
extern int single_plane_incident; |
| 81 |
| 82 |
/* input/output orientations */ |
| 83 |
extern int input_orient; |
| 84 |
extern int output_orient; |
| 85 |
| 86 |
greg |
2.23 |
/* represented colorimetry */ |
| 87 |
typedef enum {RBCphotopic, RBCtristimulus, RBCspectral, RBCunknown} RBColor; |
| 88 |
| 89 |
extern RBColor rbf_colorimetry; |
| 90 |
| 91 |
extern const char *RBCident[]; |
| 92 |
| 93 |
greg |
2.7 |
/* log BSDF histogram */ |
| 94 |
#define HISTLEN 256 |
| 95 |
#define BSDF2BIG (1./M_PI) |
| 96 |
#define BSDF2SML 1e-8 |
| 97 |
#define HISTLNR 17.2759509 /* log(BSDF2BIG/BSDF2SML) */ |
| 98 |
greg |
2.9 |
extern unsigned long bsdf_hist[HISTLEN]; |
| 99 |
greg |
2.7 |
#define histndx(v) (int)(log((v)*(1./BSDF2SML))*(HISTLEN/HISTLNR)) |
| 100 |
#define histval(i) (exp(((i)+.5)*(HISTLNR/HISTLEN))*BSDF2SML) |
| 101 |
| 102 |
/* BSDF value for boundary regions */ |
| 103 |
extern double bsdf_min; |
| 104 |
greg |
2.24 |
extern double bsdf_spec_val; |
| 105 |
greg |
2.21 |
extern double bsdf_spec_rad; |
| 106 |
greg |
2.7 |
| 107 |
greg |
2.1 |
/* processed incident DSF measurements */ |
| 108 |
extern RBFNODE *dsf_list; |
| 109 |
| 110 |
/* RBF-linking matrices (edges) */ |
| 111 |
extern MIGRATION *mig_list; |
| 112 |
| 113 |
greg |
2.3 |
#define mtx_nrows(m) (m)->rbfv[0]->nrbf |
| 114 |
#define mtx_ncols(m) (m)->rbfv[1]->nrbf |
| 115 |
greg |
2.2 |
#define mtx_coef(m,i,j) (m)->mtx[(i)*mtx_ncols(m) + (j)] |
| 116 |
greg |
2.1 |
#define is_src(rbf,m) ((rbf) == (m)->rbfv[0]) |
| 117 |
#define is_dest(rbf,m) ((rbf) == (m)->rbfv[1]) |
| 118 |
#define nextedge(rbf,m) (m)->enxt[is_dest(rbf,m)] |
| 119 |
#define opp_rbf(rbf,m) (m)->rbfv[is_src(rbf,m)] |
| 120 |
| 121 |
#define round(v) (int)((v) + .5 - ((v) < -.5)) |
| 122 |
| 123 |
greg |
2.2 |
#define BSDFREP_FMT "BSDF_RBFmesh" |
| 124 |
greg |
2.1 |
| 125 |
greg |
2.23 |
#define BSDFREP_MAGIC 0x5a3c |
| 126 |
| 127 |
greg |
2.1 |
/* global argv[0] */ |
| 128 |
extern char *progname; |
| 129 |
| 130 |
/* get theta value in degrees [0,180) range */ |
| 131 |
greg |
2.13 |
#define get_theta180(v) ((180./M_PI)*Acos((v)[2])) |
| 132 |
greg |
2.1 |
/* get phi value in degrees, [0,360) range */ |
| 133 |
greg |
2.4 |
#define get_phi360(v) ((180./M_PI)*atan2((v)[1],(v)[0]) + 360.*((v)[1]<0)) |
| 134 |
greg |
2.1 |
| 135 |
/* our loaded grid for this incident angle */ |
| 136 |
extern double theta_in_deg, phi_in_deg; |
| 137 |
extern GRIDVAL dsf_grid[GRIDRES][GRIDRES]; |
| 138 |
greg |
2.23 |
extern float (*spec_grid)[GRIDRES][GRIDRES]; |
| 139 |
extern int nspec_grid; |
| 140 |
greg |
2.1 |
| 141 |
greg |
2.25 |
/* header line sharing callback */ |
| 142 |
extern int (*sir_headshare)(char *s); |
| 143 |
| 144 |
| 145 |
greg |
2.1 |
/* Register new input direction */ |
| 146 |
extern int new_input_direction(double new_theta, double new_phi); |
| 147 |
| 148 |
#define new_input_vector(v)\ |
| 149 |
new_input_direction(get_theta180(v),get_phi360(v)) |
| 150 |
| 151 |
/* Apply symmetry to the given vector based on distribution */ |
| 152 |
extern int use_symmetry(FVECT vec); |
| 153 |
| 154 |
/* Reverse symmetry based on what was done before */ |
| 155 |
extern void rev_symmetry(FVECT vec, int sym); |
| 156 |
| 157 |
/* Reverse symmetry for an RBF distribution */ |
| 158 |
extern void rev_rbf_symmetry(RBFNODE *rbf, int sym); |
| 159 |
| 160 |
greg |
2.6 |
/* Rotate RBF to correspond to given incident vector */ |
| 161 |
extern void rotate_rbf(RBFNODE *rbf, const FVECT invec); |
| 162 |
| 163 |
greg |
2.1 |
/* Compute volume associated with Gaussian lobe */ |
| 164 |
extern double rbf_volume(const RBFVAL *rbfp); |
| 165 |
| 166 |
/* Compute outgoing vector from grid position */ |
| 167 |
extern void ovec_from_pos(FVECT vec, int xpos, int ypos); |
| 168 |
| 169 |
/* Compute grid position from normalized input/output vector */ |
| 170 |
extern void pos_from_vec(int pos[2], const FVECT vec); |
| 171 |
| 172 |
greg |
2.20 |
/* Evaluate BSDF at the given normalized outgoing direction */ |
| 173 |
greg |
2.1 |
extern double eval_rbfrep(const RBFNODE *rp, const FVECT outvec); |
| 174 |
| 175 |
greg |
2.23 |
extern SDError eval_rbfcol(SDValue *sv, |
| 176 |
| 177 |
| 178 |
greg |
2.1 |
/* Insert a new directional scattering function in our global list */ |
| 179 |
extern int insert_dsf(RBFNODE *newrbf); |
| 180 |
| 181 |
/* Get the DSF indicated by its ordinal position */ |
| 182 |
extern RBFNODE * get_dsf(int ord); |
| 183 |
| 184 |
/* Get triangle surface orientation (unnormalized) */ |
| 185 |
extern void tri_orient(FVECT vres, const FVECT v1, |
| 186 |
const FVECT v2, const FVECT v3); |
| 187 |
| 188 |
/* Determine if vertex order is reversed (inward normal) */ |
| 189 |
extern int is_rev_tri(const FVECT v1, |
| 190 |
| 191 |
| 192 |
/* Find vertices completing triangles on either side of the given edge */ |
| 193 |
extern int get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig); |
| 194 |
| 195 |
greg |
2.3 |
/* Clear our BSDF representation and free memory */ |
| 196 |
extern void clear_bsdf_rep(void); |
| 197 |
| 198 |
greg |
2.1 |
/* Write our BSDF mesh interpolant out to the given binary stream */ |
| 199 |
extern void save_bsdf_rep(FILE *ofp); |
| 200 |
| 201 |
/* Read a BSDF mesh interpolant from the given binary stream */ |
| 202 |
extern int load_bsdf_rep(FILE *ifp); |
| 203 |
| 204 |
greg |
2.23 |
/* Set up visible spectrum sampling */ |
| 205 |
extern void set_spectral_samples(int nspec); |
| 206 |
| 207 |
greg |
2.1 |
/* Start new DSF input grid */ |
| 208 |
extern void new_bsdf_data(double new_theta, double new_phi); |
| 209 |
| 210 |
/* Add BSDF data point */ |
| 211 |
extern void add_bsdf_data(double theta_out, double phi_out, |
| 212 |
greg |
2.23 |
const double val[], int isDSF); |
| 213 |
greg |
2.1 |
| 214 |
/* Count up filled nodes and build RBF representation from current grid */ |
| 215 |
extern RBFNODE * make_rbfrep(void); |
| 216 |
| 217 |
/* Build our triangle mesh from recorded RBFs */ |
| 218 |
extern void build_mesh(void); |
| 219 |
| 220 |
/* Find edge(s) for interpolating the given vector, applying symmetry */ |
| 221 |
extern int get_interp(MIGRATION *miga[3], FVECT invec); |
| 222 |
| 223 |
greg |
2.20 |
/* Return single-lobe specular RBF for the given incident direction */ |
| 224 |
extern RBFNODE * def_rbf_spec(const FVECT invec); |
| 225 |
| 226 |
greg |
2.12 |
/* Advect and allocate new RBF along edge (internal call) */ |
| 227 |
extern RBFNODE * e_advect_rbf(const MIGRATION *mig, |
| 228 |
const FVECT invec, int lobe_lim); |
| 229 |
| 230 |
greg |
2.19 |
/* Compute distance between two RBF lobes (internal call) */ |
| 231 |
extern double lobe_distance(RBFVAL *rbf1, RBFVAL *rbf2); |
| 232 |
| 233 |
/* Compute mass transport plan (internal call) */ |
| 234 |
extern void plan_transport(MIGRATION *mig); |
| 235 |
| 236 |
greg |
2.1 |
/* Partially advect between recorded incident angles and allocate new RBF */ |
| 237 |
greg |
2.8 |
extern RBFNODE * advect_rbf(const FVECT invec, int lobe_lim); |
| 238 |
greg |
2.19 |
| 239 |
| 240 |
| 241 |
#endif |
| 242 |
#endif /* _BSDFREP_H_ */ |
