root/radiance/ray/src/cv/bsdfrep.h
Revision: 2.14
Committed: Sat Mar 8 06:37:59 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.13: +1 -2 lines
Removed unused crad field from grid array
1 /* RCSid $Id: bsdfrep.h,v 2.13 2014/03/06 00:40:37 greg Exp $ */
2 /*
3 * Definitions for BSDF representation used to interpolate measured data.
4 *
5 * G. Ward
6 */
7
8 #include "bsdf.h"
9
10 #define DEBUG 1
11
12 #ifndef GRIDRES
13 #define GRIDRES (1<<8) /* grid resolution per side */
14 #endif
15 /* convert to/from coded radians */
16 #define ANG2R(r) (int)((r)*((1<<16)/M_PI))
17 #define R2ANG(c) (((c)+.5)*(M_PI/(1<<16)))
18
19 typedef struct {
20 float vsum; /* DSF sum */
21 unsigned int nval; /* number of values in sum */
22 } GRIDVAL; /* grid value */
23
24 typedef struct {
25 float peak; /* lobe value at peak */
26 unsigned short crad; /* radius (coded angle) */
27 unsigned char gx, gy; /* grid position */
28 } RBFVAL; /* radial basis function value */
29
30 struct s_rbfnode; /* forward declaration of RBF struct */
31
32 typedef struct s_migration {
33 struct s_migration *next; /* next in global edge list */
34 struct s_rbfnode *rbfv[2]; /* from,to vertex */
35 struct s_migration *enxt[2]; /* next from,to sibling */
36 float mtx[1]; /* matrix (extends struct) */
37 } MIGRATION; /* migration link (winged edge structure) */
38
39 typedef struct s_rbfnode {
40 int ord; /* ordinal position in list */
41 struct s_rbfnode *next; /* next in global RBF list */
42 MIGRATION *ejl; /* edge list for this vertex */
43 FVECT invec; /* incident vector direction */
44 double vtotal; /* volume for normalization */
45 int nrbf; /* number of RBFs */
46 RBFVAL rbfa[1]; /* RBF array (extends struct) */
47 } RBFNODE; /* RBF representation of DSF @ 1 incidence */
48
49 /* symmetry operations */
50 #define MIRROR_X 1 /* mirror(ed) x-coordinate */
51 #define MIRROR_Y 2 /* mirror(ed) y-coordinate */
52
53 /* represented incident quadrants */
54 #define INP_QUAD1 1 /* 0-90 degree quadrant */
55 #define INP_QUAD2 2 /* 90-180 degree quadrant */
56 #define INP_QUAD3 4 /* 180-270 degree quadrant */
57 #define INP_QUAD4 8 /* 270-360 degree quadrant */
58
59 /* name and manufacturer if known */
60 extern char bsdf_name[];
61 extern char bsdf_manuf[];
62 /* active grid resolution */
63 extern int grid_res;
64 /* coverage/symmetry using INP_QUAD? flags */
65 extern int inp_coverage;
66
67 /* all incident angles in-plane so far? */
68 extern int single_plane_incident;
69
70 /* input/output orientations */
71 extern int input_orient;
72 extern int output_orient;
73
74 /* log BSDF histogram */
75 #define HISTLEN 256
76 #define BSDF2BIG (1./M_PI)
77 #define BSDF2SML 1e-8
78 #define HISTLNR 17.2759509 /* log(BSDF2BIG/BSDF2SML) */
79 extern unsigned long bsdf_hist[HISTLEN];
80 #define histndx(v) (int)(log((v)*(1./BSDF2SML))*(HISTLEN/HISTLNR))
81 #define histval(i) (exp(((i)+.5)*(HISTLNR/HISTLEN))*BSDF2SML)
82
83 /* BSDF value for boundary regions */
84 extern double bsdf_min;
85
86 /* processed incident DSF measurements */
87 extern RBFNODE *dsf_list;
88
89 /* RBF-linking matrices (edges) */
90 extern MIGRATION *mig_list;
91
92 #define mtx_nrows(m) (m)->rbfv[0]->nrbf
93 #define mtx_ncols(m) (m)->rbfv[1]->nrbf
94 #define mtx_coef(m,i,j) (m)->mtx[(i)*mtx_ncols(m) + (j)]
95 #define is_src(rbf,m) ((rbf) == (m)->rbfv[0])
96 #define is_dest(rbf,m) ((rbf) == (m)->rbfv[1])
97 #define nextedge(rbf,m) (m)->enxt[is_dest(rbf,m)]
98 #define opp_rbf(rbf,m) (m)->rbfv[is_src(rbf,m)]
99
100 #define round(v) (int)((v) + .5 - ((v) < -.5))
101
102 #define BSDFREP_FMT "BSDF_RBFmesh"
103
104 /* global argv[0] */
105 extern char *progname;
106
107 /* get theta value in degrees [0,180) range */
108 #define get_theta180(v) ((180./M_PI)*Acos((v)[2]))
109 /* get phi value in degrees, [0,360) range */
110 #define get_phi360(v) ((180./M_PI)*atan2((v)[1],(v)[0]) + 360.*((v)[1]<0))
111
112 /* our loaded grid for this incident angle */
113 extern double theta_in_deg, phi_in_deg;
114 extern GRIDVAL dsf_grid[GRIDRES][GRIDRES];
115
116 /* Register new input direction */
117 extern int new_input_direction(double new_theta, double new_phi);
118
119 #define new_input_vector(v)\
120 new_input_direction(get_theta180(v),get_phi360(v))
121
122 /* Apply symmetry to the given vector based on distribution */
123 extern int use_symmetry(FVECT vec);
124
125 /* Reverse symmetry based on what was done before */
126 extern void rev_symmetry(FVECT vec, int sym);
127
128 /* Reverse symmetry for an RBF distribution */
129 extern void rev_rbf_symmetry(RBFNODE *rbf, int sym);
130
131 /* Rotate RBF to correspond to given incident vector */
132 extern void rotate_rbf(RBFNODE *rbf, const FVECT invec);
133
134 /* Compute volume associated with Gaussian lobe */
135 extern double rbf_volume(const RBFVAL *rbfp);
136
137 /* Compute outgoing vector from grid position */
138 extern void ovec_from_pos(FVECT vec, int xpos, int ypos);
139
140 /* Compute grid position from normalized input/output vector */
141 extern void pos_from_vec(int pos[2], const FVECT vec);
142
143 /* Evaluate RBF for DSF at the given normalized outgoing direction */
144 extern double eval_rbfrep(const RBFNODE *rp, const FVECT outvec);
145
146 /* Insert a new directional scattering function in our global list */
147 extern int insert_dsf(RBFNODE *newrbf);
148
149 /* Get the DSF indicated by its ordinal position */
150 extern RBFNODE * get_dsf(int ord);
151
152 /* Get triangle surface orientation (unnormalized) */
153 extern void tri_orient(FVECT vres, const FVECT v1,
154 const FVECT v2, const FVECT v3);
155
156 /* Determine if vertex order is reversed (inward normal) */
157 extern int is_rev_tri(const FVECT v1,
158 const FVECT v2, const FVECT v3);
159
160 /* Find vertices completing triangles on either side of the given edge */
161 extern int get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig);
162
163 /* Clear our BSDF representation and free memory */
164 extern void clear_bsdf_rep(void);
165
166 /* Write our BSDF mesh interpolant out to the given binary stream */
167 extern void save_bsdf_rep(FILE *ofp);
168
169 /* Read a BSDF mesh interpolant from the given binary stream */
170 extern int load_bsdf_rep(FILE *ifp);
171
172 /* Start new DSF input grid */
173 extern void new_bsdf_data(double new_theta, double new_phi);
174
175 /* Add BSDF data point */
176 extern void add_bsdf_data(double theta_out, double phi_out,
177 double val, int isDSF);
178
179 /* Count up filled nodes and build RBF representation from current grid */
180 extern RBFNODE * make_rbfrep(void);
181
182 /* Build our triangle mesh from recorded RBFs */
183 extern void build_mesh(void);
184
185 /* Find edge(s) for interpolating the given vector, applying symmetry */
186 extern int get_interp(MIGRATION *miga[3], FVECT invec);
187
188 /* Advect and allocate new RBF along edge (internal call) */
189 extern RBFNODE * e_advect_rbf(const MIGRATION *mig,
190 const FVECT invec, int lobe_lim);
191
192 /* Partially advect between recorded incident angles and allocate new RBF */
193 extern RBFNODE * advect_rbf(const FVECT invec, int lobe_lim);
