Improved grazing lobe estimation by using lowest 25% of DSFs
Minor changes should not affect results
Removed accidentally inserted DEBUG define
Fixed potential bug due with closely-spaced incident angles
Disabled DEBUG statements in BSDF programs and added progress bars
Added neighborhood difference to distance metric for better lobe shaping
Removed unused crad field from grid array
Switched to calling Acos() wherever appropriate
Eliminated redundant code added in last change to bsdfmesh.c
Added -l option to limit maximum number of RBF lobes for interpolation
Added GRIDRES to saved BSDF representation
First semi-working version
Hopeful bug fix in BSDF interpolation code
Bug fixes and minor improvements
