root/Development/ray/src/cv/bsdfrep.h
Revision: 2.4
Committed: Tue Oct 23 21:09:29 2012 UTC (13 years, 2 months ago) by greg
First semi-working version
1 /* RCSid $Id: bsdfrep.h,v 2.3 2012/10/23 05:10:42 greg Exp $ */
2 /*
3 * Definitions for BSDF representation used to interpolate measured data.
4 *
5 * G. Ward
6 */
7
8 #include "bsdf.h"
9
10 #define DEBUG 1
11
12 #ifndef GRIDRES
13 #define GRIDRES 200 /* grid resolution per side */
14 #endif
15 /* convert to/from coded radians */
16 #define ANG2R(r) (int)((r)*((1<<16)/M_PI))
17 #define R2ANG(c) (((c)+.5)*(M_PI/(1<<16)))
18
19 typedef struct {
20 float vsum; /* DSF sum */
21 unsigned short nval; /* number of values in sum */
22 unsigned short crad; /* radius (coded angle) */
23 } GRIDVAL; /* grid value */
24
25 typedef struct {
26 float peak; /* lobe value at peak */
27 unsigned short crad; /* radius (coded angle) */
28 unsigned char gx, gy; /* grid position */
29 } RBFVAL; /* radial basis function value */
30
31 struct s_rbfnode; /* forward declaration of RBF struct */
32
33 typedef struct s_migration {
34 struct s_migration *next; /* next in global edge list */
35 struct s_rbfnode *rbfv[2]; /* from,to vertex */
36 struct s_migration *enxt[2]; /* next from,to sibling */
37 float mtx[1]; /* matrix (extends struct) */
38 } MIGRATION; /* migration link (winged edge structure) */
39
40 typedef struct s_rbfnode {
41 int ord; /* ordinal position in list */
42 struct s_rbfnode *next; /* next in global RBF list */
43 MIGRATION *ejl; /* edge list for this vertex */
44 FVECT invec; /* incident vector direction */
45 double vtotal; /* volume for normalization */
46 int nrbf; /* number of RBFs */
47 RBFVAL rbfa[1]; /* RBF array (extends struct) */
48 } RBFNODE; /* RBF representation of DSF @ 1 incidence */
49
50 /* symmetry operations */
51 #define MIRROR_X 1 /* mirror(ed) x-coordinate */
52 #define MIRROR_Y 2 /* mirror(ed) y-coordinate */
53
54 /* represented incident quadrants */
55 #define INP_QUAD1 1 /* 0-90 degree quadrant */
56 #define INP_QUAD2 2 /* 90-180 degree quadrant */
57 #define INP_QUAD3 4 /* 180-270 degree quadrant */
58 #define INP_QUAD4 8 /* 270-360 degree quadrant */
59
60 /* coverage/symmetry using INP_QUAD? flags */
61 extern int inp_coverage;
62
63 /* all incident angles in-plane so far? */
64 extern int single_plane_incident;
65
66 /* input/output orientations */
67 extern int input_orient;
68 extern int output_orient;
69
70 /* processed incident DSF measurements */
71 extern RBFNODE *dsf_list;
72
73 /* RBF-linking matrices (edges) */
74 extern MIGRATION *mig_list;
75
76 #define mtx_nrows(m) (m)->rbfv[0]->nrbf
77 #define mtx_ncols(m) (m)->rbfv[1]->nrbf
78 #define mtx_coef(m,i,j) (m)->mtx[(i)*mtx_ncols(m) + (j)]
79 #define is_src(rbf,m) ((rbf) == (m)->rbfv[0])
80 #define is_dest(rbf,m) ((rbf) == (m)->rbfv[1])
81 #define nextedge(rbf,m) (m)->enxt[is_dest(rbf,m)]
82 #define opp_rbf(rbf,m) (m)->rbfv[is_src(rbf,m)]
83
84 #define round(v) (int)((v) + .5 - ((v) < -.5))
85
86 #define BSDFREP_FMT "BSDF_RBFmesh"
87
88 /* global argv[0] */
89 extern char *progname;
90
91 /* get theta value in degrees [0,180) range */
92 #define get_theta180(v) ((180./M_PI)*acos((v)[2]))
93 /* get phi value in degrees, [0,360) range */
94 #define get_phi360(v) ((180./M_PI)*atan2((v)[1],(v)[0]) + 360.*((v)[1]<0))
95
96 /* our loaded grid for this incident angle */
97 extern double theta_in_deg, phi_in_deg;
98 extern GRIDVAL dsf_grid[GRIDRES][GRIDRES];
99
100 /* Register new input direction */
101 extern int new_input_direction(double new_theta, double new_phi);
102
103 #define new_input_vector(v)\
104 new_input_direction(get_theta180(v),get_phi360(v))
105
106 /* Apply symmetry to the given vector based on distribution */
107 extern int use_symmetry(FVECT vec);
108
109 /* Reverse symmetry based on what was done before */
110 extern void rev_symmetry(FVECT vec, int sym);
111
112 /* Reverse symmetry for an RBF distribution */
113 extern void rev_rbf_symmetry(RBFNODE *rbf, int sym);
114
115 /* Compute volume associated with Gaussian lobe */
116 extern double rbf_volume(const RBFVAL *rbfp);
117
118 /* Compute outgoing vector from grid position */
119 extern void ovec_from_pos(FVECT vec, int xpos, int ypos);
120
121 /* Compute grid position from normalized input/output vector */
122 extern void pos_from_vec(int pos[2], const FVECT vec);
123
124 /* Evaluate RBF for DSF at the given normalized outgoing direction */
125 extern double eval_rbfrep(const RBFNODE *rp, const FVECT outvec);
126
127 /* Insert a new directional scattering function in our global list */
128 extern int insert_dsf(RBFNODE *newrbf);
129
130 /* Get the DSF indicated by its ordinal position */
131 extern RBFNODE * get_dsf(int ord);
132
133 /* Get triangle surface orientation (unnormalized) */
134 extern void tri_orient(FVECT vres, const FVECT v1,
135 const FVECT v2, const FVECT v3);
136
137 /* Determine if vertex order is reversed (inward normal) */
138 extern int is_rev_tri(const FVECT v1,
139 const FVECT v2, const FVECT v3);
140
141 /* Find vertices completing triangles on either side of the given edge */
142 extern int get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig);
143
144 /* Clear our BSDF representation and free memory */
145 extern void clear_bsdf_rep(void);
146
147 /* Write our BSDF mesh interpolant out to the given binary stream */
148 extern void save_bsdf_rep(FILE *ofp);
149
150 /* Read a BSDF mesh interpolant from the given binary stream */
151 extern int load_bsdf_rep(FILE *ifp);
152
153 /* Start new DSF input grid */
154 extern void new_bsdf_data(double new_theta, double new_phi);
155
156 /* Add BSDF data point */
157 extern void add_bsdf_data(double theta_out, double phi_out,
158 double val, int isDSF);
159
160 /* Count up filled nodes and build RBF representation from current grid */
161 extern RBFNODE * make_rbfrep(void);
162
163 /* Build our triangle mesh from recorded RBFs */
164 extern void build_mesh(void);
165
166 /* Find edge(s) for interpolating the given vector, applying symmetry */
167 extern int get_interp(MIGRATION *miga[3], FVECT invec);
168
169 /* Partially advect between recorded incident angles and allocate new RBF */
170 extern RBFNODE * advect_rbf(const FVECT invec);
