--- ray/src/cv/bsdfrep.h 2014/03/12 21:15:31 2.16 +++ ray/src/cv/bsdfrep.h 2014/08/22 05:38:44 2.22 @@ -1,12 +1,19 @@ -/* RCSid $Id: bsdfrep.h,v 2.16 2014/03/12 21:15:31 greg Exp $ */ +/* RCSid $Id: bsdfrep.h,v 2.22 2014/08/22 05:38:44 greg Exp $ */ /* * Definitions for BSDF representation used to interpolate measured data. * * G. Ward */ +#ifndef _BSDFREP_H_ +#define _BSDFREP_H_ + #include "bsdf.h" +#ifdef __cplusplus +extern "C" { +#endif + #ifndef GRIDRES #define GRIDRES (1<<8) /* grid resolution per side */ #endif @@ -14,6 +21,9 @@ #define ANG2R(r) (int)((r)*((1<<16)/M_PI)) #define R2ANG(c) (((c)+.5)*(M_PI/(1<<16))) + /* moderated cosine factor */ +#define COSF(z) (fabs(z)*0.98 + 0.02) + typedef union { struct { float v; /* DSF sum */ @@ -83,6 +93,8 @@ extern unsigned long bsdf_hist[HISTLEN]; /* BSDF value for boundary regions */ extern double bsdf_min; +extern double bsdf_spec_peak; +extern double bsdf_spec_rad; /* processed incident DSF measurements */ extern RBFNODE *dsf_list; @@ -141,7 +153,7 @@ extern void ovec_from_pos(FVECT vec, int xpos, int yp /* Compute grid position from normalized input/output vector */ extern void pos_from_vec(int pos[2], const FVECT vec); -/* Evaluate RBF for DSF at the given normalized outgoing direction */ +/* Evaluate BSDF at the given normalized outgoing direction */ extern double eval_rbfrep(const RBFNODE *rp, const FVECT outvec); /* Insert a new directional scattering function in our global list */ @@ -186,9 +198,23 @@ extern void build_mesh(void); /* Find edge(s) for interpolating the given vector, applying symmetry */ extern int get_interp(MIGRATION *miga[3], FVECT invec); +/* Return single-lobe specular RBF for the given incident direction */ +extern RBFNODE * def_rbf_spec(const FVECT invec); + /* Advect and allocate new RBF along edge (internal call) */ extern RBFNODE * e_advect_rbf(const MIGRATION *mig, const FVECT invec, int lobe_lim); +/* Compute distance between two RBF lobes (internal call) */ +extern double lobe_distance(RBFVAL *rbf1, RBFVAL *rbf2); + +/* Compute mass transport plan (internal call) */ +extern void plan_transport(MIGRATION *mig); + /* Partially advect between recorded incident angles and allocate new RBF */ extern RBFNODE * advect_rbf(const FVECT invec, int lobe_lim); + +#ifdef __cplusplus +} +#endif +#endif /* _BSDFREP_H_ */ \ No newline at end of file
