root/Development/ray/src/cv/bsdfrep.h
Revision: 2.19
Committed: Wed Mar 26 02:52:31 2014 UTC (11 years, 9 months ago) by greg
CVS Tags: rad4R2
Changes since 2.18: +19 -1 lines
# User Rev Content
1 greg 2.19 /* RCSid $Id: bsdfrep.h,v 2.18 2014/03/19 20:49:01 greg Exp $ */
2 greg 2.1 /*
3     * Definitions for BSDF representation used to interpolate measured data.
4     *
5     * G. Ward
6     */
7
8 greg 2.19 #ifndef _BSDFREP_H_
9     #define _BSDFREP_H_
10
11 greg 2.1 #include "bsdf.h"
12
13 greg 2.19 #ifdef __cplusplus
14     extern "C" {
15     #endif
16
17 greg 2.1 #ifndef GRIDRES
18 greg 2.10 #define GRIDRES (1<<8) /* grid resolution per side */
19 greg 2.1 #endif
20     /* convert to/from coded radians */
21     #define ANG2R(r) (int)((r)*((1<<16)/M_PI))
22     #define R2ANG(c) (((c)+.5)*(M_PI/(1<<16)))
23
24 greg 2.15 typedef union {
25     struct {
26     float v; /* DSF sum */
27     unsigned int n; /* number of values in sum */
28     } sum; /* sum for averaging */
29     float val[2]; /* comparison values */
30 greg 2.1 } GRIDVAL; /* grid value */
31
32     typedef struct {
33     float peak; /* lobe value at peak */
34     unsigned short crad; /* radius (coded angle) */
35     unsigned char gx, gy; /* grid position */
36     } RBFVAL; /* radial basis function value */
37
38     struct s_rbfnode; /* forward declaration of RBF struct */
39
40     typedef struct s_migration {
41     struct s_migration *next; /* next in global edge list */
42     struct s_rbfnode *rbfv[2]; /* from,to vertex */
43     struct s_migration *enxt[2]; /* next from,to sibling */
44     float mtx[1]; /* matrix (extends struct) */
45     } MIGRATION; /* migration link (winged edge structure) */
46
47     typedef struct s_rbfnode {
48     int ord; /* ordinal position in list */
49     struct s_rbfnode *next; /* next in global RBF list */
50     MIGRATION *ejl; /* edge list for this vertex */
51     FVECT invec; /* incident vector direction */
52     double vtotal; /* volume for normalization */
53     int nrbf; /* number of RBFs */
54     RBFVAL rbfa[1]; /* RBF array (extends struct) */
55     } RBFNODE; /* RBF representation of DSF @ 1 incidence */
56
57     /* symmetry operations */
58     #define MIRROR_X 1 /* mirror(ed) x-coordinate */
59     #define MIRROR_Y 2 /* mirror(ed) y-coordinate */
60
61     /* represented incident quadrants */
62     #define INP_QUAD1 1 /* 0-90 degree quadrant */
63     #define INP_QUAD2 2 /* 90-180 degree quadrant */
64     #define INP_QUAD3 4 /* 180-270 degree quadrant */
65     #define INP_QUAD4 8 /* 270-360 degree quadrant */
66
67 greg 2.11 /* name and manufacturer if known */
68     extern char bsdf_name[];
69     extern char bsdf_manuf[];
70 greg 2.5 /* active grid resolution */
71     extern int grid_res;
72 greg 2.3 /* coverage/symmetry using INP_QUAD? flags */
73 greg 2.1 extern int inp_coverage;
74
75     /* all incident angles in-plane so far? */
76     extern int single_plane_incident;
77
78     /* input/output orientations */
79     extern int input_orient;
80     extern int output_orient;
81
82 greg 2.7 /* log BSDF histogram */
83     #define HISTLEN 256
84     #define BSDF2BIG (1./M_PI)
85     #define BSDF2SML 1e-8
86     #define HISTLNR 17.2759509 /* log(BSDF2BIG/BSDF2SML) */
87 greg 2.9 extern unsigned long bsdf_hist[HISTLEN];
88 greg 2.7 #define histndx(v) (int)(log((v)*(1./BSDF2SML))*(HISTLEN/HISTLNR))
89     #define histval(i) (exp(((i)+.5)*(HISTLNR/HISTLEN))*BSDF2SML)
90
91     /* BSDF value for boundary regions */
92     extern double bsdf_min;
93
94 greg 2.1 /* processed incident DSF measurements */
95     extern RBFNODE *dsf_list;
96
97     /* RBF-linking matrices (edges) */
98     extern MIGRATION *mig_list;
99
100 greg 2.3 #define mtx_nrows(m) (m)->rbfv[0]->nrbf
101     #define mtx_ncols(m) (m)->rbfv[1]->nrbf
102 greg 2.2 #define mtx_coef(m,i,j) (m)->mtx[(i)*mtx_ncols(m) + (j)]
103 greg 2.1 #define is_src(rbf,m) ((rbf) == (m)->rbfv[0])
104     #define is_dest(rbf,m) ((rbf) == (m)->rbfv[1])
105     #define nextedge(rbf,m) (m)->enxt[is_dest(rbf,m)]
106     #define opp_rbf(rbf,m) (m)->rbfv[is_src(rbf,m)]
107
108     #define round(v) (int)((v) + .5 - ((v) < -.5))
109
110 greg 2.2 #define BSDFREP_FMT "BSDF_RBFmesh"
111 greg 2.1
112     /* global argv[0] */
113     extern char *progname;
114
115     /* get theta value in degrees [0,180) range */
116 greg 2.13 #define get_theta180(v) ((180./M_PI)*Acos((v)[2]))
117 greg 2.1 /* get phi value in degrees, [0,360) range */
118 greg 2.4 #define get_phi360(v) ((180./M_PI)*atan2((v)[1],(v)[0]) + 360.*((v)[1]<0))
119 greg 2.1
120     /* our loaded grid for this incident angle */
121     extern double theta_in_deg, phi_in_deg;
122     extern GRIDVAL dsf_grid[GRIDRES][GRIDRES];
123
124     /* Register new input direction */
125     extern int new_input_direction(double new_theta, double new_phi);
126
127     #define new_input_vector(v)\
128     new_input_direction(get_theta180(v),get_phi360(v))
129
130     /* Apply symmetry to the given vector based on distribution */
131     extern int use_symmetry(FVECT vec);
132
133     /* Reverse symmetry based on what was done before */
134     extern void rev_symmetry(FVECT vec, int sym);
135
136     /* Reverse symmetry for an RBF distribution */
137     extern void rev_rbf_symmetry(RBFNODE *rbf, int sym);
138
139 greg 2.6 /* Rotate RBF to correspond to given incident vector */
140     extern void rotate_rbf(RBFNODE *rbf, const FVECT invec);
141
142 greg 2.1 /* Compute volume associated with Gaussian lobe */
143     extern double rbf_volume(const RBFVAL *rbfp);
144
145     /* Compute outgoing vector from grid position */
146     extern void ovec_from_pos(FVECT vec, int xpos, int ypos);
147
148     /* Compute grid position from normalized input/output vector */
149     extern void pos_from_vec(int pos[2], const FVECT vec);
150
151     /* Evaluate RBF for DSF at the given normalized outgoing direction */
152     extern double eval_rbfrep(const RBFNODE *rp, const FVECT outvec);
153
154     /* Insert a new directional scattering function in our global list */
155     extern int insert_dsf(RBFNODE *newrbf);
156
157     /* Get the DSF indicated by its ordinal position */
158     extern RBFNODE * get_dsf(int ord);
159
160     /* Get triangle surface orientation (unnormalized) */
161     extern void tri_orient(FVECT vres, const FVECT v1,
162     const FVECT v2, const FVECT v3);
163
164     /* Determine if vertex order is reversed (inward normal) */
165     extern int is_rev_tri(const FVECT v1,
166     const FVECT v2, const FVECT v3);
167
168     /* Find vertices completing triangles on either side of the given edge */
169     extern int get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig);
170
171 greg 2.3 /* Clear our BSDF representation and free memory */
172     extern void clear_bsdf_rep(void);
173
174 greg 2.1 /* Write our BSDF mesh interpolant out to the given binary stream */
175     extern void save_bsdf_rep(FILE *ofp);
176
177     /* Read a BSDF mesh interpolant from the given binary stream */
178     extern int load_bsdf_rep(FILE *ifp);
179
180     /* Start new DSF input grid */
181     extern void new_bsdf_data(double new_theta, double new_phi);
182
183     /* Add BSDF data point */
184     extern void add_bsdf_data(double theta_out, double phi_out,
185     double val, int isDSF);
186
187     /* Count up filled nodes and build RBF representation from current grid */
188     extern RBFNODE * make_rbfrep(void);
189
190     /* Build our triangle mesh from recorded RBFs */
191     extern void build_mesh(void);
192
193     /* Find edge(s) for interpolating the given vector, applying symmetry */
194     extern int get_interp(MIGRATION *miga[3], FVECT invec);
195
196 greg 2.12 /* Advect and allocate new RBF along edge (internal call) */
197     extern RBFNODE * e_advect_rbf(const MIGRATION *mig,
198     const FVECT invec, int lobe_lim);
199
200 greg 2.19 /* Compute distance between two RBF lobes (internal call) */
201     extern double lobe_distance(RBFVAL *rbf1, RBFVAL *rbf2);
202
203     /* Compute mass transport plan (internal call) */
204     extern void plan_transport(MIGRATION *mig);
205
206 greg 2.1 /* Partially advect between recorded incident angles and allocate new RBF */
207 greg 2.8 extern RBFNODE * advect_rbf(const FVECT invec, int lobe_lim);
208 greg 2.19
209     #ifdef __cplusplus
210     }
211     #endif
212     #endif /* _BSDFREP_H_ */
