--- ray/src/cv/bsdfrep.h 2013/09/26 17:05:00 2.8 +++ ray/src/cv/bsdfrep.h 2020/10/26 21:12:20 2.25 @@ -1,31 +1,42 @@ -/* RCSid $Id: bsdfrep.h,v 2.8 2013/09/26 17:05:00 greg Exp $ */ +/* RCSid $Id: bsdfrep.h,v 2.25 2020/10/26 21:12:20 greg Exp $ */ /* * Definitions for BSDF representation used to interpolate measured data. * * G. Ward */ +#ifndef _BSDFREP_H_ +#define _BSDFREP_H_ + #include "bsdf.h" -#define DEBUG 1 +#ifdef __cplusplus +extern "C" { +#endif #ifndef GRIDRES -#define GRIDRES 200 /* grid resolution per side */ +#define GRIDRES (1<<8) /* grid resolution per side */ #endif /* convert to/from coded radians */ #define ANG2R(r) (int)((r)*((1<<16)/M_PI)) #define R2ANG(c) (((c)+.5)*(M_PI/(1<<16))) -typedef struct { - float vsum; /* DSF sum */ - unsigned short nval; /* number of values in sum */ - unsigned short crad; /* radius (coded angle) */ + /* moderated cosine factor */ +#define COSF(z) (fabs(z)*0.98 + 0.02) + +typedef union { + struct { + float v; /* DSF sum */ + unsigned int n; /* number of values in sum */ + } sum; /* sum for averaging */ + float val[2]; /* comparison values */ } GRIDVAL; /* grid value */ typedef struct { float peak; /* lobe value at peak */ + C_CHROMA chroma; /* encoded chromaticity */ unsigned short crad; /* radius (coded angle) */ - unsigned char gx, gy; /* grid position */ + unsigned short gx, gy; /* grid position */ } RBFVAL; /* radial basis function value */ struct s_rbfnode; /* forward declaration of RBF struct */ @@ -57,6 +68,9 @@ typedef struct s_rbfnode { #define INP_QUAD3 4 /* 180-270 degree quadrant */ #define INP_QUAD4 8 /* 270-360 degree quadrant */ + /* name and manufacturer if known */ +extern char bsdf_name[]; +extern char bsdf_manuf[]; /* active grid resolution */ extern int grid_res; /* coverage/symmetry using INP_QUAD? flags */ @@ -69,17 +83,26 @@ extern int single_plane_incident; extern int input_orient; extern int output_orient; + /* represented colorimetry */ +typedef enum {RBCphotopic, RBCtristimulus, RBCspectral, RBCunknown} RBColor; + +extern RBColor rbf_colorimetry; + +extern const char *RBCident[]; + /* log BSDF histogram */ #define HISTLEN 256 #define BSDF2BIG (1./M_PI) #define BSDF2SML 1e-8 #define HISTLNR 17.2759509 /* log(BSDF2BIG/BSDF2SML) */ -extern int bsdf_hist[HISTLEN]; +extern unsigned long bsdf_hist[HISTLEN]; #define histndx(v) (int)(log((v)*(1./BSDF2SML))*(HISTLEN/HISTLNR)) #define histval(i) (exp(((i)+.5)*(HISTLNR/HISTLEN))*BSDF2SML) /* BSDF value for boundary regions */ extern double bsdf_min; +extern double bsdf_spec_val; +extern double bsdf_spec_rad; /* processed incident DSF measurements */ extern RBFNODE *dsf_list; @@ -99,18 +122,26 @@ extern MIGRATION *mig_list; #define BSDFREP_FMT "BSDF_RBFmesh" +#define BSDFREP_MAGIC 0x5a3c + /* global argv[0] */ extern char *progname; /* get theta value in degrees [0,180) range */ -#define get_theta180(v) ((180./M_PI)*acos((v)[2])) +#define get_theta180(v) ((180./M_PI)*Acos((v)[2])) /* get phi value in degrees, [0,360) range */ #define get_phi360(v) ((180./M_PI)*atan2((v)[1],(v)[0]) + 360.*((v)[1]<0)) /* our loaded grid for this incident angle */ extern double theta_in_deg, phi_in_deg; extern GRIDVAL dsf_grid[GRIDRES][GRIDRES]; +extern float (*spec_grid)[GRIDRES][GRIDRES]; +extern int nspec_grid; + /* header line sharing callback */ +extern int (*sir_headshare)(char *s); + + /* Register new input direction */ extern int new_input_direction(double new_theta, double new_phi); @@ -138,9 +169,12 @@ extern void ovec_from_pos(FVECT vec, int xpos, int yp /* Compute grid position from normalized input/output vector */ extern void pos_from_vec(int pos[2], const FVECT vec); -/* Evaluate RBF for DSF at the given normalized outgoing direction */ +/* Evaluate BSDF at the given normalized outgoing direction */ extern double eval_rbfrep(const RBFNODE *rp, const FVECT outvec); +extern SDError eval_rbfcol(SDValue *sv, + const RBFNODE *rp, const FVECT outvec); + /* Insert a new directional scattering function in our global list */ extern int insert_dsf(RBFNODE *newrbf); @@ -167,12 +201,15 @@ extern void save_bsdf_rep(FILE *ofp); /* Read a BSDF mesh interpolant from the given binary stream */ extern int load_bsdf_rep(FILE *ifp); +/* Set up visible spectrum sampling */ +extern void set_spectral_samples(int nspec); + /* Start new DSF input grid */ extern void new_bsdf_data(double new_theta, double new_phi); /* Add BSDF data point */ extern void add_bsdf_data(double theta_out, double phi_out, - double val, int isDSF); + const double val[], int isDSF); /* Count up filled nodes and build RBF representation from current grid */ extern RBFNODE * make_rbfrep(void); @@ -183,5 +220,23 @@ extern void build_mesh(void); /* Find edge(s) for interpolating the given vector, applying symmetry */ extern int get_interp(MIGRATION *miga[3], FVECT invec); +/* Return single-lobe specular RBF for the given incident direction */ +extern RBFNODE * def_rbf_spec(const FVECT invec); + +/* Advect and allocate new RBF along edge (internal call) */ +extern RBFNODE * e_advect_rbf(const MIGRATION *mig, + const FVECT invec, int lobe_lim); + +/* Compute distance between two RBF lobes (internal call) */ +extern double lobe_distance(RBFVAL *rbf1, RBFVAL *rbf2); + +/* Compute mass transport plan (internal call) */ +extern void plan_transport(MIGRATION *mig); + /* Partially advect between recorded incident angles and allocate new RBF */ extern RBFNODE * advect_rbf(const FVECT invec, int lobe_lim); + +#ifdef __cplusplus +} +#endif +#endif /* _BSDFREP_H_ */ \ No newline at end of file
