--- ray/src/cv/bsdfrep.h 2012/10/20 07:02:00 2.2 +++ ray/src/cv/bsdfrep.h 2013/09/26 17:05:00 2.8 @@ -1,4 +1,4 @@ -/* RCSid $Id: bsdfrep.h,v 2.2 2012/10/20 07:02:00 greg Exp $ */ +/* RCSid $Id: bsdfrep.h,v 2.8 2013/09/26 17:05:00 greg Exp $ */ /* * Definitions for BSDF representation used to interpolate measured data. * @@ -57,6 +57,9 @@ typedef struct s_rbfnode { #define INP_QUAD3 4 /* 180-270 degree quadrant */ #define INP_QUAD4 8 /* 270-360 degree quadrant */ + /* active grid resolution */ +extern int grid_res; + /* coverage/symmetry using INP_QUAD? flags */ extern int inp_coverage; /* all incident angles in-plane so far? */ @@ -66,17 +69,26 @@ extern int single_plane_incident; extern int input_orient; extern int output_orient; + /* log BSDF histogram */ +#define HISTLEN 256 +#define BSDF2BIG (1./M_PI) +#define BSDF2SML 1e-8 +#define HISTLNR 17.2759509 /* log(BSDF2BIG/BSDF2SML) */ +extern int bsdf_hist[HISTLEN]; +#define histndx(v) (int)(log((v)*(1./BSDF2SML))*(HISTLEN/HISTLNR)) +#define histval(i) (exp(((i)+.5)*(HISTLNR/HISTLEN))*BSDF2SML) + + /* BSDF value for boundary regions */ +extern double bsdf_min; + /* processed incident DSF measurements */ extern RBFNODE *dsf_list; /* RBF-linking matrices (edges) */ extern MIGRATION *mig_list; - /* migration edges drawn in raster fashion */ -extern MIGRATION *mig_grid[GRIDRES][GRIDRES]; - -#define mtx_nrows(m) ((m)->rbfv[0]->nrbf) -#define mtx_ncols(m) ((m)->rbfv[1]->nrbf) +#define mtx_nrows(m) (m)->rbfv[0]->nrbf +#define mtx_ncols(m) (m)->rbfv[1]->nrbf #define mtx_coef(m,i,j) (m)->mtx[(i)*mtx_ncols(m) + (j)] #define is_src(rbf,m) ((rbf) == (m)->rbfv[0]) #define is_dest(rbf,m) ((rbf) == (m)->rbfv[1]) @@ -91,9 +103,9 @@ extern MIGRATION *mig_grid[GRIDRES][GRIDRES]; extern char *progname; /* get theta value in degrees [0,180) range */ -#define get_theta180(v) (180./M_PI)*acos((v)[2]) +#define get_theta180(v) ((180./M_PI)*acos((v)[2])) /* get phi value in degrees, [0,360) range */ -#define get_phi360(v) ((180./M_PI)*atan2((v)[1],(v)[0]) + 180.) +#define get_phi360(v) ((180./M_PI)*atan2((v)[1],(v)[0]) + 360.*((v)[1]<0)) /* our loaded grid for this incident angle */ extern double theta_in_deg, phi_in_deg; @@ -114,6 +126,9 @@ extern void rev_symmetry(FVECT vec, int sym); /* Reverse symmetry for an RBF distribution */ extern void rev_rbf_symmetry(RBFNODE *rbf, int sym); +/* Rotate RBF to correspond to given incident vector */ +extern void rotate_rbf(RBFNODE *rbf, const FVECT invec); + /* Compute volume associated with Gaussian lobe */ extern double rbf_volume(const RBFVAL *rbfp); @@ -143,6 +158,9 @@ extern int is_rev_tri(const FVECT v1, /* Find vertices completing triangles on either side of the given edge */ extern int get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig); +/* Clear our BSDF representation and free memory */ +extern void clear_bsdf_rep(void); + /* Write our BSDF mesh interpolant out to the given binary stream */ extern void save_bsdf_rep(FILE *ofp); @@ -162,11 +180,8 @@ extern RBFNODE * make_rbfrep(void); /* Build our triangle mesh from recorded RBFs */ extern void build_mesh(void); -/* Draw edge list into mig_grid array */ -extern void draw_edges(void); - /* Find edge(s) for interpolating the given vector, applying symmetry */ extern int get_interp(MIGRATION *miga[3], FVECT invec); /* Partially advect between recorded incident angles and allocate new RBF */ -extern RBFNODE * advect_rbf(const FVECT invec); +extern RBFNODE * advect_rbf(const FVECT invec, int lobe_lim);
