--- ray/src/cv/bsdfrep.h 2014/08/21 13:44:05 2.21 +++ ray/src/cv/bsdfrep.h 2016/01/30 01:31:57 2.24 @@ -1,4 +1,4 @@ -/* RCSid $Id: bsdfrep.h,v 2.21 2014/08/21 13:44:05 greg Exp $ */ +/* RCSid $Id: bsdfrep.h,v 2.24 2016/01/30 01:31:57 greg Exp $ */ /* * Definitions for BSDF representation used to interpolate measured data. * @@ -21,6 +21,9 @@ extern "C" { #define ANG2R(r) (int)((r)*((1<<16)/M_PI)) #define R2ANG(c) (((c)+.5)*(M_PI/(1<<16))) + /* moderated cosine factor */ +#define COSF(z) (fabs(z)*0.98 + 0.02) + typedef union { struct { float v; /* DSF sum */ @@ -31,8 +34,9 @@ typedef union { typedef struct { float peak; /* lobe value at peak */ + C_CHROMA chroma; /* encoded chromaticity */ unsigned short crad; /* radius (coded angle) */ - unsigned char gx, gy; /* grid position */ + unsigned short gx, gy; /* grid position */ } RBFVAL; /* radial basis function value */ struct s_rbfnode; /* forward declaration of RBF struct */ @@ -79,6 +83,13 @@ extern int single_plane_incident; extern int input_orient; extern int output_orient; + /* represented colorimetry */ +typedef enum {RBCphotopic, RBCtristimulus, RBCspectral, RBCunknown} RBColor; + +extern RBColor rbf_colorimetry; + +extern const char *RBCident[]; + /* log BSDF histogram */ #define HISTLEN 256 #define BSDF2BIG (1./M_PI) @@ -90,7 +101,7 @@ extern unsigned long bsdf_hist[HISTLEN]; /* BSDF value for boundary regions */ extern double bsdf_min; -extern double bsdf_spec_peak; +extern double bsdf_spec_val; extern double bsdf_spec_rad; /* processed incident DSF measurements */ @@ -111,6 +122,8 @@ extern MIGRATION *mig_list; #define BSDFREP_FMT "BSDF_RBFmesh" +#define BSDFREP_MAGIC 0x5a3c + /* global argv[0] */ extern char *progname; @@ -122,6 +135,8 @@ extern char *progname; /* our loaded grid for this incident angle */ extern double theta_in_deg, phi_in_deg; extern GRIDVAL dsf_grid[GRIDRES][GRIDRES]; +extern float (*spec_grid)[GRIDRES][GRIDRES]; +extern int nspec_grid; /* Register new input direction */ extern int new_input_direction(double new_theta, double new_phi); @@ -153,6 +168,9 @@ extern void pos_from_vec(int pos[2], const FVECT vec) /* Evaluate BSDF at the given normalized outgoing direction */ extern double eval_rbfrep(const RBFNODE *rp, const FVECT outvec); +extern SDError eval_rbfcol(SDValue *sv, + const RBFNODE *rp, const FVECT outvec); + /* Insert a new directional scattering function in our global list */ extern int insert_dsf(RBFNODE *newrbf); @@ -179,12 +197,15 @@ extern void save_bsdf_rep(FILE *ofp); /* Read a BSDF mesh interpolant from the given binary stream */ extern int load_bsdf_rep(FILE *ifp); +/* Set up visible spectrum sampling */ +extern void set_spectral_samples(int nspec); + /* Start new DSF input grid */ extern void new_bsdf_data(double new_theta, double new_phi); /* Add BSDF data point */ extern void add_bsdf_data(double theta_out, double phi_out, - double val, int isDSF); + const double val[], int isDSF); /* Count up filled nodes and build RBF representation from current grid */ extern RBFNODE * make_rbfrep(void);
