root/radiance/ray/src/cv/bsdfrep.h
Mon Oct 26 21:12:20 2020 UTC (4 years, 7 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.24: +5 -1 lines
Diff to previous 2.24 , to selected 2.8
feat(bsdf2klems, bsdf2ttree): added XML header comments copying useful information from SIR inputs
Sat Jan 30 01:31:57 2016 UTC (9 years, 4 months ago) by greg
Diff to previous 2.23 , to selected 2.8
Improved grazing lobe estimation by using lowest 25% of DSFs
Fri Jan 29 16:21:56 2016 UTC (9 years, 4 months ago) by greg
Changes since 2.22: +21 -3 lines
Diff to previous 2.22 , to selected 2.8
Fri Aug 22 05:38:44 2014 UTC (10 years, 9 months ago) by greg
Diff to previous 2.21 , to selected 2.8
Thu Aug 21 13:44:05 2014 UTC (10 years, 9 months ago) by greg
Diff to previous 2.20 , to selected 2.8
Minor changes should not affect results
Thu Aug 21 10:33:48 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.19: +7 -2 lines
Diff to previous 2.19 , to selected 2.8
Wed Mar 26 02:52:31 2014 UTC (11 years, 2 months ago) by greg
CVS Tags: rad4R2
Changes since 2.18: +19 -1 lines
Diff to previous 2.18 , to selected 2.8
Wed Mar 19 20:49:01 2014 UTC (11 years, 2 months ago) by greg
Changes since 2.17: +1 -3 lines
Diff to previous 2.17 , to selected 2.8
Removed accidentally inserted DEBUG define
Wed Mar 19 19:48:57 2014 UTC (11 years, 2 months ago) by greg
Diff to previous 2.16 , to selected 2.8
Fixed potential bug due with closely-spaced incident angles
Wed Mar 12 21:15:31 2014 UTC (11 years, 2 months ago) by greg
Changes since 2.15: +1 -3 lines
Disabled DEBUG statements in BSDF programs and added progress bars
Sat Mar 8 18:16:49 2014 UTC (11 years, 3 months ago) by greg
Changes since 2.14: +7 -4 lines
Added neighborhood difference to distance metric for better lobe shaping
Sat Mar 8 06:37:59 2014 UTC (11 years, 3 months ago) by greg
Changes since 2.13: +1 -2 lines
Removed unused crad field from grid array
Thu Mar 6 00:40:37 2014 UTC (11 years, 3 months ago) by greg
Switched to calling Acos() wherever appropriate
Wed Feb 19 05:16:06 2014 UTC (11 years, 3 months ago) by greg
Changes since 2.11: +5 -1 lines
Eliminated redundant code added in last change to bsdfmesh.c
Sat Nov 9 05:47:49 2013 UTC (11 years, 6 months ago) by greg
Changes since 2.10: +4 -1 lines
Mon Oct 21 18:33:15 2013 UTC (11 years, 7 months ago) by greg
Sat Oct 19 00:11:50 2013 UTC (11 years, 7 months ago) by greg
Thu Sep 26 17:05:00 2013 UTC (11 years, 8 months ago) by greg
Added -l option to limit maximum number of RBF lobes for interpolation
Wed Mar 20 01:00:22 2013 UTC (12 years, 2 months ago) by greg
Changes since 2.6: +13 -1 lines
Thu Nov 8 00:31:17 2012 UTC (12 years, 7 months ago) by greg
Wed Nov 7 03:04:23 2012 UTC (12 years, 7 months ago) by greg
Added GRIDRES to saved BSDF representation
Tue Oct 23 21:09:29 2012 UTC (12 years, 7 months ago) by greg
First semi-working version
Tue Oct 23 05:10:42 2012 UTC (12 years, 7 months ago) by greg
Changes since 2.2: +8 -10 lines
Hopeful bug fix in BSDF interpolation code
Sat Oct 20 07:02:00 2012 UTC (12 years, 7 months ago) by greg
Bug fixes and minor improvements
Fri Oct 19 04:14:29 2012 UTC (12 years, 7 months ago) by greg
Diff to selected 2.8
