root/radiance/ray/src/cv/bsdfrep.h
Revision: 2.25
Committed: Mon Oct 26 21:12:20 2020 UTC (3 years, 7 months ago) by greg
CVS Tags: rad5R4, HEAD
Changes since 2.24: +5 -1 lines
feat(bsdf2klems, bsdf2ttree): added XML header comments copying useful information from SIR inputs
1 /* RCSid $Id: bsdfrep.h,v 2.24 2016/01/30 01:31:57 greg Exp $ */
2 /*
3 * Definitions for BSDF representation used to interpolate measured data.
4 *
5 * G. Ward
6 */
7
8 #ifndef _BSDFREP_H_
9 #define _BSDFREP_H_
10
11 #include "bsdf.h"
12
13 #ifdef __cplusplus
14 extern "C" {
15 #endif
16
17 #ifndef GRIDRES
18 #define GRIDRES (1<<8) /* grid resolution per side */
19 #endif
20 /* convert to/from coded radians */
21 #define ANG2R(r) (int)((r)*((1<<16)/M_PI))
22 #define R2ANG(c) (((c)+.5)*(M_PI/(1<<16)))
23
24 /* moderated cosine factor */
25 #define COSF(z) (fabs(z)*0.98 + 0.02)
26
27 typedef union {
28 struct {
29 float v; /* DSF sum */
30 unsigned int n; /* number of values in sum */
31 } sum; /* sum for averaging */
32 float val[2]; /* comparison values */
33 } GRIDVAL; /* grid value */
34
35 typedef struct {
36 float peak; /* lobe value at peak */
37 C_CHROMA chroma; /* encoded chromaticity */
38 unsigned short crad; /* radius (coded angle) */
39 unsigned short gx, gy; /* grid position */
40 } RBFVAL; /* radial basis function value */
41
42 struct s_rbfnode; /* forward declaration of RBF struct */
43
44 typedef struct s_migration {
45 struct s_migration *next; /* next in global edge list */
46 struct s_rbfnode *rbfv[2]; /* from,to vertex */
47 struct s_migration *enxt[2]; /* next from,to sibling */
48 float mtx[1]; /* matrix (extends struct) */
49 } MIGRATION; /* migration link (winged edge structure) */
50
51 typedef struct s_rbfnode {
52 int ord; /* ordinal position in list */
53 struct s_rbfnode *next; /* next in global RBF list */
54 MIGRATION *ejl; /* edge list for this vertex */
55 FVECT invec; /* incident vector direction */
56 double vtotal; /* volume for normalization */
57 int nrbf; /* number of RBFs */
58 RBFVAL rbfa[1]; /* RBF array (extends struct) */
59 } RBFNODE; /* RBF representation of DSF @ 1 incidence */
60
61 /* symmetry operations */
62 #define MIRROR_X 1 /* mirror(ed) x-coordinate */
63 #define MIRROR_Y 2 /* mirror(ed) y-coordinate */
64
65 /* represented incident quadrants */
66 #define INP_QUAD1 1 /* 0-90 degree quadrant */
67 #define INP_QUAD2 2 /* 90-180 degree quadrant */
68 #define INP_QUAD3 4 /* 180-270 degree quadrant */
69 #define INP_QUAD4 8 /* 270-360 degree quadrant */
70
71 /* name and manufacturer if known */
72 extern char bsdf_name[];
73 extern char bsdf_manuf[];
74 /* active grid resolution */
75 extern int grid_res;
76 /* coverage/symmetry using INP_QUAD? flags */
77 extern int inp_coverage;
78
79 /* all incident angles in-plane so far? */
80 extern int single_plane_incident;
81
82 /* input/output orientations */
83 extern int input_orient;
84 extern int output_orient;
85
86 /* represented colorimetry */
87 typedef enum {RBCphotopic, RBCtristimulus, RBCspectral, RBCunknown} RBColor;
88
89 extern RBColor rbf_colorimetry;
90
91 extern const char *RBCident[];
92
93 /* log BSDF histogram */
94 #define HISTLEN 256
95 #define BSDF2BIG (1./M_PI)
96 #define BSDF2SML 1e-8
97 #define HISTLNR 17.2759509 /* log(BSDF2BIG/BSDF2SML) */
98 extern unsigned long bsdf_hist[HISTLEN];
99 #define histndx(v) (int)(log((v)*(1./BSDF2SML))*(HISTLEN/HISTLNR))
100 #define histval(i) (exp(((i)+.5)*(HISTLNR/HISTLEN))*BSDF2SML)
101
102 /* BSDF value for boundary regions */
103 extern double bsdf_min;
104 extern double bsdf_spec_val;
105 extern double bsdf_spec_rad;
106
107 /* processed incident DSF measurements */
108 extern RBFNODE *dsf_list;
109
110 /* RBF-linking matrices (edges) */
111 extern MIGRATION *mig_list;
112
113 #define mtx_nrows(m) (m)->rbfv[0]->nrbf
114 #define mtx_ncols(m) (m)->rbfv[1]->nrbf
115 #define mtx_coef(m,i,j) (m)->mtx[(i)*mtx_ncols(m) + (j)]
116 #define is_src(rbf,m) ((rbf) == (m)->rbfv[0])
117 #define is_dest(rbf,m) ((rbf) == (m)->rbfv[1])
118 #define nextedge(rbf,m) (m)->enxt[is_dest(rbf,m)]
119 #define opp_rbf(rbf,m) (m)->rbfv[is_src(rbf,m)]
120
121 #define round(v) (int)((v) + .5 - ((v) < -.5))
122
123 #define BSDFREP_FMT "BSDF_RBFmesh"
124
125 #define BSDFREP_MAGIC 0x5a3c
126
127 /* global argv[0] */
128 extern char *progname;
129
130 /* get theta value in degrees [0,180) range */
131 #define get_theta180(v) ((180./M_PI)*Acos((v)[2]))
132 /* get phi value in degrees, [0,360) range */
133 #define get_phi360(v) ((180./M_PI)*atan2((v)[1],(v)[0]) + 360.*((v)[1]<0))
134
135 /* our loaded grid for this incident angle */
136 extern double theta_in_deg, phi_in_deg;
137 extern GRIDVAL dsf_grid[GRIDRES][GRIDRES];
138 extern float (*spec_grid)[GRIDRES][GRIDRES];
139 extern int nspec_grid;
140
141 /* header line sharing callback */
142 extern int (*sir_headshare)(char *s);
143
144
145 /* Register new input direction */
146 extern int new_input_direction(double new_theta, double new_phi);
147
148 #define new_input_vector(v)\
149 new_input_direction(get_theta180(v),get_phi360(v))
150
151 /* Apply symmetry to the given vector based on distribution */
152 extern int use_symmetry(FVECT vec);
153
154 /* Reverse symmetry based on what was done before */
155 extern void rev_symmetry(FVECT vec, int sym);
156
157 /* Reverse symmetry for an RBF distribution */
158 extern void rev_rbf_symmetry(RBFNODE *rbf, int sym);
159
160 /* Rotate RBF to correspond to given incident vector */
161 extern void rotate_rbf(RBFNODE *rbf, const FVECT invec);
162
163 /* Compute volume associated with Gaussian lobe */
164 extern double rbf_volume(const RBFVAL *rbfp);
165
166 /* Compute outgoing vector from grid position */
167 extern void ovec_from_pos(FVECT vec, int xpos, int ypos);
168
169 /* Compute grid position from normalized input/output vector */
170 extern void pos_from_vec(int pos[2], const FVECT vec);
171
172 /* Evaluate BSDF at the given normalized outgoing direction */
173 extern double eval_rbfrep(const RBFNODE *rp, const FVECT outvec);
174
175 extern SDError eval_rbfcol(SDValue *sv,
176 const RBFNODE *rp, const FVECT outvec);
177
178 /* Insert a new directional scattering function in our global list */
179 extern int insert_dsf(RBFNODE *newrbf);
180
181 /* Get the DSF indicated by its ordinal position */
182 extern RBFNODE * get_dsf(int ord);
183
184 /* Get triangle surface orientation (unnormalized) */
185 extern void tri_orient(FVECT vres, const FVECT v1,
186 const FVECT v2, const FVECT v3);
187
188 /* Determine if vertex order is reversed (inward normal) */
189 extern int is_rev_tri(const FVECT v1,
190 const FVECT v2, const FVECT v3);
191
192 /* Find vertices completing triangles on either side of the given edge */
193 extern int get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig);
194
195 /* Clear our BSDF representation and free memory */
196 extern void clear_bsdf_rep(void);
197
198 /* Write our BSDF mesh interpolant out to the given binary stream */
199 extern void save_bsdf_rep(FILE *ofp);
200
201 /* Read a BSDF mesh interpolant from the given binary stream */
202 extern int load_bsdf_rep(FILE *ifp);
203
204 /* Set up visible spectrum sampling */
205 extern void set_spectral_samples(int nspec);
206
207 /* Start new DSF input grid */
208 extern void new_bsdf_data(double new_theta, double new_phi);
209
210 /* Add BSDF data point */
211 extern void add_bsdf_data(double theta_out, double phi_out,
212 const double val[], int isDSF);
213
214 /* Count up filled nodes and build RBF representation from current grid */
215 extern RBFNODE * make_rbfrep(void);
216
217 /* Build our triangle mesh from recorded RBFs */
218 extern void build_mesh(void);
219
220 /* Find edge(s) for interpolating the given vector, applying symmetry */
221 extern int get_interp(MIGRATION *miga[3], FVECT invec);
222
223 /* Return single-lobe specular RBF for the given incident direction */
224 extern RBFNODE * def_rbf_spec(const FVECT invec);
225
226 /* Advect and allocate new RBF along edge (internal call) */
227 extern RBFNODE * e_advect_rbf(const MIGRATION *mig,
228 const FVECT invec, int lobe_lim);
229
230 /* Compute distance between two RBF lobes (internal call) */
231 extern double lobe_distance(RBFVAL *rbf1, RBFVAL *rbf2);
232
233 /* Compute mass transport plan (internal call) */
234 extern void plan_transport(MIGRATION *mig);
235
236 /* Partially advect between recorded incident angles and allocate new RBF */
237 extern RBFNODE * advect_rbf(const FVECT invec, int lobe_lim);
238
239 #ifdef __cplusplus
240 }
241 #endif
242 #endif /* _BSDFREP_H_ */
