1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: bsdfrep.c,v 2.29 2016/01/29 16:21:55 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Support BSDF representation as radial basis functions. |
6 |
7 |
* G. Ward |
8 |
9 |
10 |
#define _USE_MATH_DEFINES |
11 |
#include <stdlib.h> |
12 |
#include <string.h> |
13 |
#include <math.h> |
14 |
#include "rtio.h" |
15 |
#include "resolu.h" |
16 |
#include "bsdfrep.h" |
17 |
#include "random.h" |
18 |
/* name and manufacturer if known */ |
19 |
char bsdf_name[256]; |
20 |
char bsdf_manuf[256]; |
21 |
/* active grid resolution */ |
22 |
int grid_res = GRIDRES; |
23 |
24 |
/* coverage/symmetry using INP_QUAD? flags */ |
25 |
int inp_coverage = 0; |
26 |
/* all incident angles in-plane so far? */ |
27 |
int single_plane_incident = -1; |
28 |
29 |
/* input/output orientations */ |
30 |
int input_orient = 0; |
31 |
int output_orient = 0; |
32 |
33 |
/* represented color space */ |
34 |
RBColor rbf_colorimetry = RBCunknown; |
35 |
36 |
const char *RBCident[] = { |
37 |
"CIE-Y", "CIE-XYZ", "Spectral", "Unknown" |
38 |
39 |
40 |
/* BSDF histogram */ |
41 |
unsigned long bsdf_hist[HISTLEN]; |
42 |
43 |
/* BSDF value for boundary regions */ |
44 |
double bsdf_min = 0; |
45 |
double bsdf_spec_val = 0; |
46 |
double bsdf_spec_rad = 0; |
47 |
48 |
/* processed incident DSF measurements */ |
49 |
RBFNODE *dsf_list = NULL; |
50 |
51 |
/* RBF-linking matrices (edges) */ |
52 |
MIGRATION *mig_list = NULL; |
53 |
54 |
/* current input direction */ |
55 |
double theta_in_deg, phi_in_deg; |
56 |
57 |
/* Register new input direction */ |
58 |
int |
59 |
new_input_direction(double new_theta, double new_phi) |
60 |
61 |
/* normalize angle ranges */ |
62 |
while (new_theta < -180.) |
63 |
new_theta += 360.; |
64 |
while (new_theta > 180.) |
65 |
new_theta -= 360.; |
66 |
if (new_theta < 0) { |
67 |
new_theta = -new_theta; |
68 |
new_phi += 180.; |
69 |
70 |
while (new_phi < 0) |
71 |
new_phi += 360.; |
72 |
while (new_phi >= 360.) |
73 |
new_phi -= 360.; |
74 |
/* check input orientation */ |
75 |
if (!input_orient) |
76 |
input_orient = 1 - 2*(new_theta > 90.); |
77 |
else if (input_orient > 0 ^ new_theta < 90.) { |
78 |
fprintf(stderr, |
79 |
"%s: Cannot handle input angles on both sides of surface\n", |
80 |
progname); |
81 |
return(0); |
82 |
83 |
if ((theta_in_deg = new_theta) < 1.0) |
84 |
return(1); /* don't rely on phi near normal */ |
85 |
if (single_plane_incident > 0) /* check input coverage */ |
86 |
single_plane_incident = (round(new_phi) == round(phi_in_deg)); |
87 |
else if (single_plane_incident < 0) |
88 |
single_plane_incident = 1; |
89 |
phi_in_deg = new_phi; |
90 |
if ((1. < new_phi) & (new_phi < 89.)) |
91 |
inp_coverage |= INP_QUAD1; |
92 |
else if ((91. < new_phi) & (new_phi < 179.)) |
93 |
inp_coverage |= INP_QUAD2; |
94 |
else if ((181. < new_phi) & (new_phi < 269.)) |
95 |
inp_coverage |= INP_QUAD3; |
96 |
else if ((271. < new_phi) & (new_phi < 359.)) |
97 |
inp_coverage |= INP_QUAD4; |
98 |
return(1); |
99 |
100 |
101 |
/* Apply symmetry to the given vector based on distribution */ |
102 |
int |
103 |
use_symmetry(FVECT vec) |
104 |
105 |
const double phi = get_phi360(vec); |
106 |
107 |
switch (inp_coverage) { |
108 |
case INP_QUAD1|INP_QUAD2|INP_QUAD3|INP_QUAD4: |
109 |
break; |
110 |
case INP_QUAD1|INP_QUAD2: |
111 |
if ((-FTINY > phi) | (phi > 180.+FTINY)) |
112 |
goto mir_y; |
113 |
break; |
114 |
case INP_QUAD2|INP_QUAD3: |
115 |
if ((90.-FTINY > phi) | (phi > 270.+FTINY)) |
116 |
goto mir_x; |
117 |
break; |
118 |
case INP_QUAD3|INP_QUAD4: |
119 |
if ((180.-FTINY > phi) | (phi > 360.+FTINY)) |
120 |
goto mir_y; |
121 |
break; |
122 |
case INP_QUAD4|INP_QUAD1: |
123 |
if ((270.-FTINY > phi) & (phi > 90.+FTINY)) |
124 |
goto mir_x; |
125 |
break; |
126 |
case INP_QUAD1: |
127 |
if ((-FTINY > phi) | (phi > 90.+FTINY)) |
128 |
switch ((int)(phi*(1./90.))) { |
129 |
case 1: goto mir_x; |
130 |
case 2: goto mir_xy; |
131 |
case 3: goto mir_y; |
132 |
133 |
break; |
134 |
case INP_QUAD2: |
135 |
if ((90.-FTINY > phi) | (phi > 180.+FTINY)) |
136 |
137 |
case 0: goto mir_x; |
138 |
case 2: goto mir_y; |
139 |
case 3: goto mir_xy; |
140 |
141 |
break; |
142 |
case INP_QUAD3: |
143 |
if ((180.-FTINY > phi) | (phi > 270.+FTINY)) |
144 |
145 |
case 0: goto mir_xy; |
146 |
case 1: goto mir_y; |
147 |
case 3: goto mir_x; |
148 |
149 |
break; |
150 |
case INP_QUAD4: |
151 |
if ((270.-FTINY > phi) | (phi > 360.+FTINY)) |
152 |
153 |
case 0: goto mir_y; |
154 |
case 1: goto mir_xy; |
155 |
case 2: goto mir_x; |
156 |
157 |
break; |
158 |
default: |
159 |
fprintf(stderr, "%s: Illegal input coverage (%d)\n", |
160 |
progname, inp_coverage); |
161 |
exit(1); |
162 |
163 |
return(0); /* in range */ |
164 |
mir_x: |
165 |
vec[0] = -vec[0]; |
166 |
return(MIRROR_X); |
167 |
mir_y: |
168 |
vec[1] = -vec[1]; |
169 |
return(MIRROR_Y); |
170 |
mir_xy: |
171 |
vec[0] = -vec[0]; |
172 |
vec[1] = -vec[1]; |
173 |
return(MIRROR_X|MIRROR_Y); |
174 |
175 |
176 |
/* Reverse symmetry based on what was done before */ |
177 |
void |
178 |
rev_symmetry(FVECT vec, int sym) |
179 |
180 |
if (sym & MIRROR_X) |
181 |
vec[0] = -vec[0]; |
182 |
if (sym & MIRROR_Y) |
183 |
vec[1] = -vec[1]; |
184 |
185 |
186 |
/* Reverse symmetry for an RBF distribution */ |
187 |
void |
188 |
rev_rbf_symmetry(RBFNODE *rbf, int sym) |
189 |
190 |
int n; |
191 |
192 |
rev_symmetry(rbf->invec, sym); |
193 |
194 |
for (n = rbf->nrbf; n-- > 0; ) |
195 |
rbf->rbfa[n].gx = grid_res-1 - rbf->rbfa[n].gx; |
196 |
197 |
198 |
rbf->rbfa[n].gy = grid_res-1 - rbf->rbfa[n].gy; |
199 |
200 |
201 |
/* Rotate RBF to correspond to given incident vector */ |
202 |
void |
203 |
rotate_rbf(RBFNODE *rbf, const FVECT invec) |
204 |
205 |
static const FVECT vnorm = {.0, .0, 1.}; |
206 |
const double phi = atan2(invec[1],invec[0]) - |
207 |
atan2(rbf->invec[1],rbf->invec[0]); |
208 |
FVECT outvec; |
209 |
int pos[2]; |
210 |
int n; |
211 |
212 |
for (n = (cos(phi) < 1.-FTINY)*rbf->nrbf; n-- > 0; ) { |
213 |
ovec_from_pos(outvec, rbf->rbfa[n].gx, rbf->rbfa[n].gy); |
214 |
spinvector(outvec, outvec, vnorm, phi); |
215 |
pos_from_vec(pos, outvec); |
216 |
rbf->rbfa[n].gx = pos[0]; |
217 |
rbf->rbfa[n].gy = pos[1]; |
218 |
219 |
VCOPY(rbf->invec, invec); |
220 |
221 |
222 |
/* Compute outgoing vector from grid position */ |
223 |
void |
224 |
ovec_from_pos(FVECT vec, int xpos, int ypos) |
225 |
226 |
double uv[2]; |
227 |
double r2; |
228 |
229 |
SDsquare2disk(uv, (xpos+.5)/grid_res, (ypos+.5)/grid_res); |
230 |
/* uniform hemispherical projection */ |
231 |
r2 = uv[0]*uv[0] + uv[1]*uv[1]; |
232 |
vec[0] = vec[1] = sqrt(2. - r2); |
233 |
vec[0] *= uv[0]; |
234 |
vec[1] *= uv[1]; |
235 |
vec[2] = output_orient*(1. - r2); |
236 |
237 |
238 |
/* Compute grid position from normalized input/output vector */ |
239 |
void |
240 |
pos_from_vec(int pos[2], const FVECT vec) |
241 |
242 |
double sq[2]; /* uniform hemispherical projection */ |
243 |
double norm = 1./sqrt(1. + fabs(vec[2])); |
244 |
245 |
SDdisk2square(sq, vec[0]*norm, vec[1]*norm); |
246 |
247 |
pos[0] = (int)(sq[0]*grid_res); |
248 |
pos[1] = (int)(sq[1]*grid_res); |
249 |
250 |
251 |
/* Compute volume associated with Gaussian lobe */ |
252 |
double |
253 |
rbf_volume(const RBFVAL *rbfp) |
254 |
255 |
double rad = R2ANG(rbfp->crad); |
256 |
FVECT odir; |
257 |
double elev, integ; |
258 |
/* infinite integral approximation */ |
259 |
integ = (2.*M_PI) * rbfp->peak * rad*rad; |
260 |
/* check if we're near horizon */ |
261 |
ovec_from_pos(odir, rbfp->gx, rbfp->gy); |
262 |
elev = output_orient*odir[2]; |
263 |
/* apply cut-off correction if > 1% */ |
264 |
if (elev < 2.8*rad) { |
265 |
/* elev = asin(elev); /* this is so crude, anyway... */ |
266 |
integ *= 1. - .5*exp(-.5*elev*elev/(rad*rad)); |
267 |
268 |
return(integ); |
269 |
270 |
271 |
/* Evaluate BSDF at the given normalized outgoing direction in color */ |
272 |
SDError |
273 |
eval_rbfcol(SDValue *sv, const RBFNODE *rp, const FVECT outvec) |
274 |
275 |
const double rfact2 = (38./M_PI/M_PI)*(grid_res*grid_res); |
276 |
int pos[2]; |
277 |
double res = 0; |
278 |
double usum = 0, vsum = 0; |
279 |
const RBFVAL *rbfp; |
280 |
FVECT odir; |
281 |
double rad2; |
282 |
int n; |
283 |
/* assign default value */ |
284 |
sv->spec = c_dfcolor; |
285 |
sv->cieY = bsdf_min; |
286 |
/* check for wrong side */ |
287 |
if (outvec[2] > 0 ^ output_orient > 0) { |
288 |
strcpy(SDerrorDetail, "Wrong-side scattering query"); |
289 |
return(SDEargument); |
290 |
291 |
if (rp == NULL) /* return minimum if no information avail. */ |
292 |
return(SDEnone); |
293 |
/* optimization for fast lobe culling */ |
294 |
295 |
/* sum radial basis function */ |
296 |
rbfp = rp->rbfa; |
297 |
for (n = rp->nrbf; n--; rbfp++) { |
298 |
int d2 = (pos[0]-rbfp->gx)*(pos[0]-rbfp->gx) + |
299 |
(pos[1]-rbfp->gy)*(pos[1]-rbfp->gy); |
300 |
double val; |
301 |
rad2 = R2ANG(rbfp->crad); |
302 |
rad2 *= rad2; |
303 |
if (d2 > rad2*rfact2) |
304 |
continue; |
305 |
306 |
val = rbfp->peak * exp((DOT(odir,outvec) - 1.) / rad2); |
307 |
if (rbf_colorimetry == RBCtristimulus) { |
308 |
usum += val * (rbfp->chroma & 0xff); |
309 |
vsum += val * (rbfp->chroma>>8 & 0xff); |
310 |
311 |
res += val; |
312 |
313 |
if ((rbf_colorimetry == RBCtristimulus) & (res > 1e-6)) { |
314 |
C_CHROMA cres = (int)(usum/res + frandom()); |
315 |
cres |= (int)(vsum/res + frandom()) << 8; |
316 |
c_decodeChroma(&sv->spec, cres); |
317 |
318 |
sv->cieY = res / COSF(outvec[2]); |
319 |
if (sv->cieY < bsdf_min) /* never return less than bsdf_min */ |
320 |
321 |
return(SDEnone); |
322 |
323 |
324 |
/* Evaluate BSDF at the given normalized outgoing direction in Y */ |
325 |
double |
326 |
eval_rbfrep(const RBFNODE *rp, const FVECT outvec) |
327 |
328 |
SDValue sv; |
329 |
330 |
if (eval_rbfcol(&sv, rp, outvec) == SDEnone) |
331 |
return(sv.cieY); |
332 |
333 |
return(0.0); |
334 |
335 |
336 |
/* Insert a new directional scattering function in our global list */ |
337 |
int |
338 |
insert_dsf(RBFNODE *newrbf) |
339 |
340 |
RBFNODE *rbf, *rbf_last; |
341 |
int pos; |
342 |
/* check for redundant meas. */ |
343 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) |
344 |
if (DOT(rbf->invec, newrbf->invec) >= 1.-FTINY) { |
345 |
fprintf(stderr, |
346 |
"%s: Duplicate incident measurement ignored at (%.1f,%.1f)\n", |
347 |
progname, get_theta180(newrbf->invec), |
348 |
get_phi360(newrbf->invec)); |
349 |
free(newrbf); |
350 |
return(-1); |
351 |
352 |
/* keep in ascending theta order */ |
353 |
for (rbf_last = NULL, rbf = dsf_list; rbf != NULL; |
354 |
rbf_last = rbf, rbf = rbf->next) |
355 |
if (single_plane_incident && input_orient*rbf->invec[2] < |
356 |
input_orient*newrbf->invec[2]) |
357 |
break; |
358 |
if (rbf_last == NULL) { /* insert new node in list */ |
359 |
newrbf->ord = 0; |
360 |
newrbf->next = dsf_list; |
361 |
dsf_list = newrbf; |
362 |
} else { |
363 |
newrbf->ord = rbf_last->ord + 1; |
364 |
newrbf->next = rbf; |
365 |
rbf_last->next = newrbf; |
366 |
367 |
rbf_last = newrbf; |
368 |
while (rbf != NULL) { /* update ordinal positions */ |
369 |
370 |
rbf_last = rbf; |
371 |
rbf = rbf->next; |
372 |
373 |
return(newrbf->ord); |
374 |
375 |
376 |
/* Get the DSF indicated by its ordinal position */ |
377 |
RBFNODE * |
378 |
get_dsf(int ord) |
379 |
380 |
RBFNODE *rbf; |
381 |
382 |
383 |
if (rbf->ord == ord) |
384 |
return(rbf); |
385 |
return(NULL); |
386 |
387 |
388 |
/* Get triangle surface orientation (unnormalized) */ |
389 |
void |
390 |
tri_orient(FVECT vres, const FVECT v1, const FVECT v2, const FVECT v3) |
391 |
392 |
FVECT v2minus1, v3minus2; |
393 |
394 |
VSUB(v2minus1, v2, v1); |
395 |
VSUB(v3minus2, v3, v2); |
396 |
VCROSS(vres, v2minus1, v3minus2); |
397 |
398 |
399 |
/* Determine if vertex order is reversed (inward normal) */ |
400 |
int |
401 |
is_rev_tri(const FVECT v1, const FVECT v2, const FVECT v3) |
402 |
403 |
FVECT tor; |
404 |
405 |
tri_orient(tor, v1, v2, v3); |
406 |
407 |
return(DOT(tor, v2) < 0.); |
408 |
409 |
410 |
/* Find vertices completing triangles on either side of the given edge */ |
411 |
int |
412 |
get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig) |
413 |
414 |
const MIGRATION *ej1, *ej2; |
415 |
RBFNODE *tv; |
416 |
417 |
rbfv[0] = rbfv[1] = NULL; |
418 |
if (mig == NULL) |
419 |
return(0); |
420 |
for (ej1 = mig->rbfv[0]->ejl; ej1 != NULL; |
421 |
ej1 = nextedge(mig->rbfv[0],ej1)) { |
422 |
if (ej1 == mig) |
423 |
continue; |
424 |
tv = opp_rbf(mig->rbfv[0],ej1); |
425 |
for (ej2 = tv->ejl; ej2 != NULL; ej2 = nextedge(tv,ej2)) |
426 |
if (opp_rbf(tv,ej2) == mig->rbfv[1]) { |
427 |
rbfv[is_rev_tri(mig->rbfv[0]->invec, |
428 |
mig->rbfv[1]->invec, |
429 |
tv->invec)] = tv; |
430 |
break; |
431 |
432 |
433 |
return((rbfv[0] != NULL) + (rbfv[1] != NULL)); |
434 |
435 |
436 |
/* Return single-lobe specular RBF for the given incident direction */ |
437 |
RBFNODE * |
438 |
def_rbf_spec(const FVECT invec) |
439 |
440 |
RBFNODE *rbf; |
441 |
FVECT ovec; |
442 |
int pos[2]; |
443 |
444 |
if (input_orient > 0 ^ invec[2] > 0) /* wrong side? */ |
445 |
return(NULL); |
446 |
if ((bsdf_spec_val <= bsdf_min) | (bsdf_spec_rad <= 0)) |
447 |
return(NULL); /* nothing set */ |
448 |
rbf = (RBFNODE *)malloc(sizeof(RBFNODE)); |
449 |
if (rbf == NULL) |
450 |
return(NULL); |
451 |
ovec[0] = -invec[0]; |
452 |
ovec[1] = -invec[1]; |
453 |
ovec[2] = invec[2]*(2*(input_orient==output_orient) - 1); |
454 |
pos_from_vec(pos, ovec); |
455 |
rbf->ord = 0; |
456 |
rbf->next = NULL; |
457 |
rbf->ejl = NULL; |
458 |
459 |
rbf->nrbf = 1; |
460 |
rbf->rbfa[0].peak = bsdf_spec_val * COSF(ovec[2]); |
461 |
rbf->rbfa[0].chroma = c_dfchroma; |
462 |
rbf->rbfa[0].crad = ANG2R(bsdf_spec_rad); |
463 |
rbf->rbfa[0].gx = pos[0]; |
464 |
rbf->rbfa[0].gy = pos[1]; |
465 |
rbf->vtotal = rbf_volume(rbf->rbfa); |
466 |
return(rbf); |
467 |
468 |
469 |
/* Advect and allocate new RBF along edge (internal call) */ |
470 |
RBFNODE * |
471 |
e_advect_rbf(const MIGRATION *mig, const FVECT invec, int lobe_lim) |
472 |
473 |
double cthresh = FTINY; |
474 |
RBFNODE *rbf; |
475 |
int n, i, j; |
476 |
double t, full_dist; |
477 |
/* get relative position */ |
478 |
t = Acos(DOT(invec, mig->rbfv[0]->invec)); |
479 |
if (t < M_PI/grid_res) { /* near first DSF */ |
480 |
n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[0]->nrbf-1); |
481 |
rbf = (RBFNODE *)malloc(n); |
482 |
if (rbf == NULL) |
483 |
goto memerr; |
484 |
memcpy(rbf, mig->rbfv[0], n); /* just duplicate */ |
485 |
rbf->next = NULL; rbf->ejl = NULL; |
486 |
return(rbf); |
487 |
488 |
full_dist = acos(DOT(mig->rbfv[0]->invec, mig->rbfv[1]->invec)); |
489 |
if (t > full_dist-M_PI/grid_res) { /* near second DSF */ |
490 |
n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[1]->nrbf-1); |
491 |
492 |
if (rbf == NULL) |
493 |
goto memerr; |
494 |
memcpy(rbf, mig->rbfv[1], n); /* just duplicate */ |
495 |
496 |
return(rbf); |
497 |
498 |
t /= full_dist; |
499 |
tryagain: |
500 |
n = 0; /* count migrating particles */ |
501 |
for (i = 0; i < mtx_nrows(mig); i++) |
502 |
for (j = 0; j < mtx_ncols(mig); j++) |
503 |
n += (mtx_coef(mig,i,j) > cthresh); |
504 |
/* are we over our limit? */ |
505 |
if ((lobe_lim > 0) & (n > lobe_lim)) { |
506 |
cthresh = cthresh*2. + 10.*FTINY; |
507 |
goto tryagain; |
508 |
509 |
#ifdef DEBUG |
510 |
fprintf(stderr, "Input RBFs have %d, %d nodes -> output has %d\n", |
511 |
mig->rbfv[0]->nrbf, mig->rbfv[1]->nrbf, n); |
512 |
#endif |
513 |
rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1)); |
514 |
if (rbf == NULL) |
515 |
goto memerr; |
516 |
517 |
518 |
rbf->nrbf = n; |
519 |
rbf->vtotal = 1.-t + t*mig->rbfv[1]->vtotal/mig->rbfv[0]->vtotal; |
520 |
n = 0; /* advect RBF lobes */ |
521 |
for (i = 0; i < mtx_nrows(mig); i++) { |
522 |
const RBFVAL *rbf0i = &mig->rbfv[0]->rbfa[i]; |
523 |
const float peak0 = rbf0i->peak; |
524 |
const double rad0 = R2ANG(rbf0i->crad); |
525 |
C_COLOR cc0; |
526 |
FVECT v0; |
527 |
float mv; |
528 |
ovec_from_pos(v0, rbf0i->gx, rbf0i->gy); |
529 |
c_decodeChroma(&cc0, rbf0i->chroma); |
530 |
531 |
if ((mv = mtx_coef(mig,i,j)) > cthresh) { |
532 |
const RBFVAL *rbf1j = &mig->rbfv[1]->rbfa[j]; |
533 |
double rad2; |
534 |
FVECT v; |
535 |
int pos[2]; |
536 |
rad2 = R2ANG(rbf1j->crad); |
537 |
rad2 = rad0*rad0*(1.-t) + rad2*rad2*t; |
538 |
rbf->rbfa[n].peak = peak0 * mv * rbf->vtotal * |
539 |
rad0*rad0/rad2; |
540 |
541 |
C_COLOR cres; |
542 |
c_decodeChroma(&cres, rbf1j->chroma); |
543 |
c_cmix(&cres, 1.-t, &cc0, t, &cres); |
544 |
rbf->rbfa[n].chroma = c_encodeChroma(&cres); |
545 |
} else |
546 |
rbf->rbfa[n].chroma = c_dfchroma; |
547 |
rbf->rbfa[n].crad = ANG2R(sqrt(rad2)); |
548 |
ovec_from_pos(v, rbf1j->gx, rbf1j->gy); |
549 |
geodesic(v, v0, v, t, GEOD_REL); |
550 |
pos_from_vec(pos, v); |
551 |
552 |
553 |
++n; |
554 |
555 |
556 |
rbf->vtotal *= mig->rbfv[0]->vtotal; /* turn ratio into actual */ |
557 |
return(rbf); |
558 |
memerr: |
559 |
fprintf(stderr, "%s: Out of memory in e_advect_rbf()\n", progname); |
560 |
exit(1); |
561 |
return(NULL); /* pro forma return */ |
562 |
563 |
564 |
/* Clear our BSDF representation and free memory */ |
565 |
void |
566 |
clear_bsdf_rep(void) |
567 |
568 |
while (mig_list != NULL) { |
569 |
MIGRATION *mig = mig_list; |
570 |
mig_list = mig->next; |
571 |
free(mig); |
572 |
573 |
while (dsf_list != NULL) { |
574 |
RBFNODE *rbf = dsf_list; |
575 |
dsf_list = rbf->next; |
576 |
free(rbf); |
577 |
578 |
bsdf_name[0] = '\0'; |
579 |
bsdf_manuf[0] = '\0'; |
580 |
inp_coverage = 0; |
581 |
582 |
input_orient = output_orient = 0; |
583 |
584 |
585 |
bsdf_min = 0; |
586 |
587 |
588 |
589 |
590 |
/* Write our BSDF mesh interpolant out to the given binary stream */ |
591 |
void |
592 |
save_bsdf_rep(FILE *ofp) |
593 |
594 |
RBFNODE *rbf; |
595 |
MIGRATION *mig; |
596 |
int i, n; |
597 |
/* finish header */ |
598 |
if (bsdf_name[0]) |
599 |
fprintf(ofp, "NAME=%s\n", bsdf_name); |
600 |
if (bsdf_manuf[0]) |
601 |
fprintf(ofp, "MANUFACT=%s\n", bsdf_manuf); |
602 |
fprintf(ofp, "SYMMETRY=%d\n", !single_plane_incident * inp_coverage); |
603 |
fprintf(ofp, "IO_SIDES= %d %d\n", input_orient, output_orient); |
604 |
fprintf(ofp, "COLORIMETRY=%s\n", RBCident[rbf_colorimetry]); |
605 |
fprintf(ofp, "GRIDRES=%d\n", grid_res); |
606 |
fprintf(ofp, "BSDFMIN=%g\n", bsdf_min); |
607 |
if ((bsdf_spec_val > bsdf_min) & (bsdf_spec_rad > 0)) |
608 |
fprintf(ofp, "BSDFSPEC= %f %f\n", bsdf_spec_val, bsdf_spec_rad); |
609 |
fputformat(BSDFREP_FMT, ofp); |
610 |
fputc('\n', ofp); |
611 |
putint(BSDFREP_MAGIC, 2, ofp); |
612 |
/* write each DSF */ |
613 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) { |
614 |
putint(rbf->ord, 4, ofp); |
615 |
putflt(rbf->invec[0], ofp); |
616 |
putflt(rbf->invec[1], ofp); |
617 |
putflt(rbf->invec[2], ofp); |
618 |
putflt(rbf->vtotal, ofp); |
619 |
putint(rbf->nrbf, 4, ofp); |
620 |
for (i = 0; i < rbf->nrbf; i++) { |
621 |
putflt(rbf->rbfa[i].peak, ofp); |
622 |
putint(rbf->rbfa[i].chroma, 2, ofp); |
623 |
putint(rbf->rbfa[i].crad, 2, ofp); |
624 |
putint(rbf->rbfa[i].gx, 2, ofp); |
625 |
putint(rbf->rbfa[i].gy, 2, ofp); |
626 |
627 |
628 |
putint(-1, 4, ofp); /* terminator */ |
629 |
/* write each migration matrix */ |
630 |
for (mig = mig_list; mig != NULL; mig = mig->next) { |
631 |
int zerocnt = 0; |
632 |
putint(mig->rbfv[0]->ord, 4, ofp); |
633 |
putint(mig->rbfv[1]->ord, 4, ofp); |
634 |
/* write out as sparse data */ |
635 |
n = mtx_nrows(mig) * mtx_ncols(mig); |
636 |
for (i = 0; i < n; i++) { |
637 |
if (zerocnt == 0xff) { |
638 |
putint(0xff, 1, ofp); zerocnt = 0; |
639 |
640 |
if (mig->mtx[i] != 0) { |
641 |
putint(zerocnt, 1, ofp); zerocnt = 0; |
642 |
putflt(mig->mtx[i], ofp); |
643 |
} else |
644 |
++zerocnt; |
645 |
646 |
putint(zerocnt, 1, ofp); |
647 |
648 |
649 |
putint(-1, 4, ofp); |
650 |
if (fflush(ofp) == EOF) { |
651 |
fprintf(stderr, "%s: error writing BSDF interpolant\n", |
652 |
progname); |
653 |
exit(1); |
654 |
655 |
656 |
657 |
/* Check header line for critical information */ |
658 |
static int |
659 |
headline(char *s, void *p) |
660 |
661 |
char fmt[64]; |
662 |
int i; |
663 |
664 |
if (!strncmp(s, "NAME=", 5)) { |
665 |
strcpy(bsdf_name, s+5); |
666 |
bsdf_name[strlen(bsdf_name)-1] = '\0'; |
667 |
668 |
if (!strncmp(s, "MANUFACT=", 9)) { |
669 |
strcpy(bsdf_manuf, s+9); |
670 |
bsdf_manuf[strlen(bsdf_manuf)-1] = '\0'; |
671 |
672 |
if (!strncmp(s, "SYMMETRY=", 9)) { |
673 |
inp_coverage = atoi(s+9); |
674 |
single_plane_incident = !inp_coverage; |
675 |
return(0); |
676 |
677 |
if (!strncmp(s, "IO_SIDES=", 9)) { |
678 |
sscanf(s+9, "%d %d", &input_orient, &output_orient); |
679 |
return(0); |
680 |
681 |
if (!strncmp(s, "COLORIMETRY=", 12)) { |
682 |
fmt[0] = '\0'; |
683 |
sscanf(s+12, "%s", fmt); |
684 |
for (i = RBCunknown; i >= 0; i--) |
685 |
if (!strcmp(fmt, RBCident[i])) |
686 |
break; |
687 |
if (i < 0) |
688 |
return(-1); |
689 |
rbf_colorimetry = i; |
690 |
return(0); |
691 |
692 |
if (!strncmp(s, "GRIDRES=", 8)) { |
693 |
sscanf(s+8, "%d", &grid_res); |
694 |
return(0); |
695 |
696 |
if (!strncmp(s, "BSDFMIN=", 8)) { |
697 |
sscanf(s+8, "%lf", &bsdf_min); |
698 |
return(0); |
699 |
700 |
if (!strncmp(s, "BSDFSPEC=", 9)) { |
701 |
sscanf(s+9, "%lf %lf", &bsdf_spec_val, &bsdf_spec_rad); |
702 |
return(0); |
703 |
704 |
if (formatval(fmt, s) && strcmp(fmt, BSDFREP_FMT)) |
705 |
return(-1); |
706 |
return(0); |
707 |
708 |
709 |
/* Read a BSDF mesh interpolant from the given binary stream */ |
710 |
int |
711 |
load_bsdf_rep(FILE *ifp) |
712 |
713 |
RBFNODE rbfh; |
714 |
int from_ord, to_ord; |
715 |
int i; |
716 |
717 |
clear_bsdf_rep(); |
718 |
if (ifp == NULL) |
719 |
return(0); |
720 |
if (getheader(ifp, headline, NULL) < 0 || (single_plane_incident < 0) | |
721 |
!input_orient | !output_orient | |
722 |
(grid_res < 16) | (grid_res > 0xffff)) { |
723 |
fprintf(stderr, "%s: missing/bad format for BSDF interpolant\n", |
724 |
progname); |
725 |
return(0); |
726 |
727 |
if (getint(2, ifp) != BSDFREP_MAGIC) { |
728 |
fprintf(stderr, "%s: bad magic number for BSDF interpolant\n", |
729 |
progname); |
730 |
return(0); |
731 |
732 |
memset(&rbfh, 0, sizeof(rbfh)); /* read each DSF */ |
733 |
while ((rbfh.ord = getint(4, ifp)) >= 0) { |
734 |
RBFNODE *newrbf; |
735 |
736 |
rbfh.invec[0] = getflt(ifp); |
737 |
rbfh.invec[1] = getflt(ifp); |
738 |
rbfh.invec[2] = getflt(ifp); |
739 |
if (normalize(rbfh.invec) == 0) { |
740 |
fprintf(stderr, "%s: zero incident vector\n", progname); |
741 |
return(0); |
742 |
743 |
rbfh.vtotal = getflt(ifp); |
744 |
rbfh.nrbf = getint(4, ifp); |
745 |
newrbf = (RBFNODE *)malloc(sizeof(RBFNODE) + |
746 |
sizeof(RBFVAL)*(rbfh.nrbf-1)); |
747 |
if (newrbf == NULL) |
748 |
goto memerr; |
749 |
*newrbf = rbfh; |
750 |
for (i = 0; i < rbfh.nrbf; i++) { |
751 |
newrbf->rbfa[i].peak = getflt(ifp); |
752 |
newrbf->rbfa[i].chroma = getint(2, ifp) & 0xffff; |
753 |
newrbf->rbfa[i].crad = getint(2, ifp) & 0xffff; |
754 |
newrbf->rbfa[i].gx = getint(2, ifp) & 0xffff; |
755 |
newrbf->rbfa[i].gy = getint(2, ifp) & 0xffff; |
756 |
757 |
if (feof(ifp)) |
758 |
goto badEOF; |
759 |
/* insert in global list */ |
760 |
if (insert_dsf(newrbf) != rbfh.ord) { |
761 |
fprintf(stderr, "%s: error adding DSF\n", progname); |
762 |
return(0); |
763 |
764 |
765 |
/* read each migration matrix */ |
766 |
while ((from_ord = getint(4, ifp)) >= 0 && |
767 |
(to_ord = getint(4, ifp)) >= 0) { |
768 |
RBFNODE *from_rbf = get_dsf(from_ord); |
769 |
RBFNODE *to_rbf = get_dsf(to_ord); |
770 |
MIGRATION *newmig; |
771 |
int n; |
772 |
773 |
if ((from_rbf == NULL) | (to_rbf == NULL)) { |
774 |
fprintf(stderr, |
775 |
"%s: bad DSF reference in migration edge\n", |
776 |
progname); |
777 |
return(0); |
778 |
779 |
n = from_rbf->nrbf * to_rbf->nrbf; |
780 |
newmig = (MIGRATION *)malloc(sizeof(MIGRATION) + |
781 |
sizeof(float)*(n-1)); |
782 |
if (newmig == NULL) |
783 |
goto memerr; |
784 |
newmig->rbfv[0] = from_rbf; |
785 |
newmig->rbfv[1] = to_rbf; |
786 |
memset(newmig->mtx, 0, sizeof(float)*n); |
787 |
for (i = 0; ; ) { /* read sparse data */ |
788 |
int zc = getint(1, ifp) & 0xff; |
789 |
if ((i += zc) >= n) |
790 |
break; |
791 |
if (zc == 0xff) |
792 |
continue; |
793 |
newmig->mtx[i++] = getflt(ifp); |
794 |
795 |
if (feof(ifp)) |
796 |
goto badEOF; |
797 |
/* insert in edge lists */ |
798 |
newmig->enxt[0] = from_rbf->ejl; |
799 |
from_rbf->ejl = newmig; |
800 |
newmig->enxt[1] = to_rbf->ejl; |
801 |
to_rbf->ejl = newmig; |
802 |
/* push onto global list */ |
803 |
newmig->next = mig_list; |
804 |
mig_list = newmig; |
805 |
806 |
return(1); /* success! */ |
807 |
memerr: |
808 |
fprintf(stderr, "%s: Out of memory in load_bsdf_rep()\n", progname); |
809 |
exit(1); |
810 |
badEOF: |
811 |
fprintf(stderr, "%s: Unexpected EOF in load_bsdf_rep()\n", progname); |
812 |
return(0); |
813 |
