1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: bsdfrep.c,v 2.18 2013/11/08 05:37:20 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Support BSDF representation as radial basis functions. |
6 |
7 |
* G. Ward |
8 |
9 |
10 |
#define _USE_MATH_DEFINES |
11 |
#include <stdlib.h> |
12 |
#include <string.h> |
13 |
#include <math.h> |
14 |
#include "rtio.h" |
15 |
#include "resolu.h" |
16 |
#include "bsdfrep.h" |
17 |
/* name and manufacturer if known */ |
18 |
char bsdf_name[256]; |
19 |
char bsdf_manuf[256]; |
20 |
/* active grid resolution */ |
21 |
int grid_res = GRIDRES; |
22 |
23 |
/* coverage/symmetry using INP_QUAD? flags */ |
24 |
int inp_coverage = 0; |
25 |
/* all incident angles in-plane so far? */ |
26 |
int single_plane_incident = -1; |
27 |
28 |
/* input/output orientations */ |
29 |
int input_orient = 0; |
30 |
int output_orient = 0; |
31 |
32 |
/* BSDF histogram */ |
33 |
unsigned long bsdf_hist[HISTLEN]; |
34 |
35 |
/* BSDF value for boundary regions */ |
36 |
double bsdf_min = 0; |
37 |
38 |
/* processed incident DSF measurements */ |
39 |
RBFNODE *dsf_list = NULL; |
40 |
41 |
/* RBF-linking matrices (edges) */ |
42 |
MIGRATION *mig_list = NULL; |
43 |
44 |
/* current input direction */ |
45 |
double theta_in_deg, phi_in_deg; |
46 |
47 |
/* Register new input direction */ |
48 |
int |
49 |
new_input_direction(double new_theta, double new_phi) |
50 |
51 |
if (!input_orient) /* check input orientation */ |
52 |
input_orient = 1 - 2*(new_theta > 90.); |
53 |
else if (input_orient > 0 ^ new_theta < 90.) { |
54 |
fprintf(stderr, |
55 |
"%s: Cannot handle input angles on both sides of surface\n", |
56 |
progname); |
57 |
return(0); |
58 |
59 |
/* normalize angle ranges */ |
60 |
while (new_theta < -180.) |
61 |
new_theta += 360.; |
62 |
while (new_theta > 180.) |
63 |
new_theta -= 360.; |
64 |
if (new_theta < 0) { |
65 |
new_theta = -new_theta; |
66 |
new_phi += 180.; |
67 |
68 |
if ((theta_in_deg = new_theta) < 1.0) |
69 |
return(1); /* don't rely on phi near normal */ |
70 |
while (new_phi < 0) |
71 |
new_phi += 360.; |
72 |
while (new_phi >= 360.) |
73 |
new_phi -= 360.; |
74 |
if (single_plane_incident > 0) /* check input coverage */ |
75 |
single_plane_incident = (round(new_phi) == round(phi_in_deg)); |
76 |
else if (single_plane_incident < 0) |
77 |
single_plane_incident = 1; |
78 |
phi_in_deg = new_phi; |
79 |
if ((1. < new_phi) & (new_phi < 89.)) |
80 |
inp_coverage |= INP_QUAD1; |
81 |
else if ((91. < new_phi) & (new_phi < 179.)) |
82 |
inp_coverage |= INP_QUAD2; |
83 |
else if ((181. < new_phi) & (new_phi < 269.)) |
84 |
inp_coverage |= INP_QUAD3; |
85 |
else if ((271. < new_phi) & (new_phi < 359.)) |
86 |
inp_coverage |= INP_QUAD4; |
87 |
return(1); |
88 |
89 |
90 |
/* Apply symmetry to the given vector based on distribution */ |
91 |
int |
92 |
use_symmetry(FVECT vec) |
93 |
94 |
const double phi = get_phi360(vec); |
95 |
96 |
switch (inp_coverage) { |
97 |
case INP_QUAD1|INP_QUAD2|INP_QUAD3|INP_QUAD4: |
98 |
break; |
99 |
case INP_QUAD1|INP_QUAD2: |
100 |
if ((-FTINY > phi) | (phi > 180.+FTINY)) |
101 |
goto mir_y; |
102 |
break; |
103 |
case INP_QUAD2|INP_QUAD3: |
104 |
if ((90.-FTINY > phi) | (phi > 270.+FTINY)) |
105 |
goto mir_x; |
106 |
break; |
107 |
case INP_QUAD3|INP_QUAD4: |
108 |
if ((180.-FTINY > phi) | (phi > 360.+FTINY)) |
109 |
goto mir_y; |
110 |
break; |
111 |
case INP_QUAD4|INP_QUAD1: |
112 |
if ((270.-FTINY > phi) & (phi > 90.+FTINY)) |
113 |
goto mir_x; |
114 |
break; |
115 |
case INP_QUAD1: |
116 |
if ((-FTINY > phi) | (phi > 90.+FTINY)) |
117 |
switch ((int)(phi*(1./90.))) { |
118 |
case 1: goto mir_x; |
119 |
case 2: goto mir_xy; |
120 |
case 3: goto mir_y; |
121 |
122 |
break; |
123 |
case INP_QUAD2: |
124 |
if ((90.-FTINY > phi) | (phi > 180.+FTINY)) |
125 |
126 |
case 0: goto mir_x; |
127 |
case 2: goto mir_y; |
128 |
case 3: goto mir_xy; |
129 |
130 |
break; |
131 |
case INP_QUAD3: |
132 |
if ((180.-FTINY > phi) | (phi > 270.+FTINY)) |
133 |
134 |
case 0: goto mir_xy; |
135 |
case 1: goto mir_y; |
136 |
case 3: goto mir_x; |
137 |
138 |
break; |
139 |
case INP_QUAD4: |
140 |
if ((270.-FTINY > phi) | (phi > 360.+FTINY)) |
141 |
142 |
case 0: goto mir_y; |
143 |
case 1: goto mir_xy; |
144 |
case 2: goto mir_x; |
145 |
146 |
break; |
147 |
default: |
148 |
fprintf(stderr, "%s: Illegal input coverage (%d)\n", |
149 |
progname, inp_coverage); |
150 |
exit(1); |
151 |
152 |
return(0); /* in range */ |
153 |
mir_x: |
154 |
vec[0] = -vec[0]; |
155 |
return(MIRROR_X); |
156 |
mir_y: |
157 |
vec[1] = -vec[1]; |
158 |
return(MIRROR_Y); |
159 |
mir_xy: |
160 |
vec[0] = -vec[0]; |
161 |
vec[1] = -vec[1]; |
162 |
return(MIRROR_X|MIRROR_Y); |
163 |
164 |
165 |
/* Reverse symmetry based on what was done before */ |
166 |
void |
167 |
rev_symmetry(FVECT vec, int sym) |
168 |
169 |
if (sym & MIRROR_X) |
170 |
vec[0] = -vec[0]; |
171 |
if (sym & MIRROR_Y) |
172 |
vec[1] = -vec[1]; |
173 |
174 |
175 |
/* Reverse symmetry for an RBF distribution */ |
176 |
void |
177 |
rev_rbf_symmetry(RBFNODE *rbf, int sym) |
178 |
179 |
int n; |
180 |
181 |
rev_symmetry(rbf->invec, sym); |
182 |
183 |
for (n = rbf->nrbf; n-- > 0; ) |
184 |
rbf->rbfa[n].gx = grid_res-1 - rbf->rbfa[n].gx; |
185 |
186 |
187 |
rbf->rbfa[n].gy = grid_res-1 - rbf->rbfa[n].gy; |
188 |
189 |
190 |
/* Rotate RBF to correspond to given incident vector */ |
191 |
void |
192 |
rotate_rbf(RBFNODE *rbf, const FVECT invec) |
193 |
194 |
static const FVECT vnorm = {.0, .0, 1.}; |
195 |
const double phi = atan2(invec[1],invec[0]) - |
196 |
atan2(rbf->invec[1],rbf->invec[0]); |
197 |
FVECT outvec; |
198 |
int pos[2]; |
199 |
int n; |
200 |
201 |
for (n = ((-.01 > phi) | (phi > .01))*rbf->nrbf; n-- > 0; ) { |
202 |
ovec_from_pos(outvec, rbf->rbfa[n].gx, rbf->rbfa[n].gy); |
203 |
spinvector(outvec, outvec, vnorm, phi); |
204 |
pos_from_vec(pos, outvec); |
205 |
rbf->rbfa[n].gx = pos[0]; |
206 |
rbf->rbfa[n].gy = pos[1]; |
207 |
208 |
VCOPY(rbf->invec, invec); |
209 |
210 |
211 |
/* Compute outgoing vector from grid position */ |
212 |
void |
213 |
ovec_from_pos(FVECT vec, int xpos, int ypos) |
214 |
215 |
double uv[2]; |
216 |
double r2; |
217 |
218 |
SDsquare2disk(uv, (xpos+.5)/grid_res, (ypos+.5)/grid_res); |
219 |
/* uniform hemispherical projection */ |
220 |
r2 = uv[0]*uv[0] + uv[1]*uv[1]; |
221 |
vec[0] = vec[1] = sqrt(2. - r2); |
222 |
vec[0] *= uv[0]; |
223 |
vec[1] *= uv[1]; |
224 |
vec[2] = output_orient*(1. - r2); |
225 |
226 |
227 |
/* Compute grid position from normalized input/output vector */ |
228 |
void |
229 |
pos_from_vec(int pos[2], const FVECT vec) |
230 |
231 |
double sq[2]; /* uniform hemispherical projection */ |
232 |
double norm = 1./sqrt(1. + fabs(vec[2])); |
233 |
234 |
SDdisk2square(sq, vec[0]*norm, vec[1]*norm); |
235 |
236 |
pos[0] = (int)(sq[0]*grid_res); |
237 |
pos[1] = (int)(sq[1]*grid_res); |
238 |
239 |
240 |
/* Compute volume associated with Gaussian lobe */ |
241 |
double |
242 |
rbf_volume(const RBFVAL *rbfp) |
243 |
244 |
double rad = R2ANG(rbfp->crad); |
245 |
FVECT odir; |
246 |
double elev, integ; |
247 |
/* infinite integral approximation */ |
248 |
integ = (2.*M_PI) * rbfp->peak * rad*rad; |
249 |
/* check if we're near horizon */ |
250 |
ovec_from_pos(odir, rbfp->gx, rbfp->gy); |
251 |
elev = output_orient*odir[2]; |
252 |
/* apply cut-off correction if > 1% */ |
253 |
if (elev < 2.8*rad) { |
254 |
/* elev = asin(elev); /* this is so crude, anyway... */ |
255 |
integ *= 1. - .5*exp(-.5*elev*elev/(rad*rad)); |
256 |
257 |
return(integ); |
258 |
259 |
260 |
/* Evaluate RBF for DSF at the given normalized outgoing direction */ |
261 |
double |
262 |
eval_rbfrep(const RBFNODE *rp, const FVECT outvec) |
263 |
264 |
const double rfact2 = (38./M_PI/M_PI)*(grid_res*grid_res); |
265 |
double minval = bsdf_min*output_orient*outvec[2]; |
266 |
int pos[2]; |
267 |
double res = 0; |
268 |
const RBFVAL *rbfp; |
269 |
FVECT odir; |
270 |
double rad2; |
271 |
int n; |
272 |
/* check for wrong side */ |
273 |
if (outvec[2] > 0 ^ output_orient > 0) |
274 |
return(.0); |
275 |
/* use minimum if no information avail. */ |
276 |
if (rp == NULL) |
277 |
return(minval); |
278 |
/* optimization for fast lobe culling */ |
279 |
280 |
/* sum radial basis function */ |
281 |
rbfp = rp->rbfa; |
282 |
for (n = rp->nrbf; n--; rbfp++) { |
283 |
int d2 = (pos[0]-rbfp->gx)*(pos[0]-rbfp->gx) + |
284 |
(pos[1]-rbfp->gy)*(pos[1]-rbfp->gy); |
285 |
rad2 = R2ANG(rbfp->crad); |
286 |
rad2 *= rad2; |
287 |
if (d2 > rad2*rfact2) |
288 |
continue; |
289 |
290 |
res += rbfp->peak * exp((DOT(odir,outvec) - 1.) / rad2); |
291 |
292 |
if (res < minval) /* never return less than minval */ |
293 |
return(minval); |
294 |
return(res); |
295 |
296 |
297 |
/* Insert a new directional scattering function in our global list */ |
298 |
int |
299 |
insert_dsf(RBFNODE *newrbf) |
300 |
301 |
RBFNODE *rbf, *rbf_last; |
302 |
int pos; |
303 |
/* check for redundant meas. */ |
304 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) |
305 |
if (DOT(rbf->invec, newrbf->invec) >= 1.-FTINY) { |
306 |
fprintf(stderr, |
307 |
"%s: Duplicate incident measurement (ignored)\n", |
308 |
progname); |
309 |
free(newrbf); |
310 |
return(-1); |
311 |
312 |
/* keep in ascending theta order */ |
313 |
for (rbf_last = NULL, rbf = dsf_list; rbf != NULL; |
314 |
rbf_last = rbf, rbf = rbf->next) |
315 |
if (single_plane_incident && input_orient*rbf->invec[2] < |
316 |
input_orient*newrbf->invec[2]) |
317 |
break; |
318 |
if (rbf_last == NULL) { /* insert new node in list */ |
319 |
newrbf->ord = 0; |
320 |
newrbf->next = dsf_list; |
321 |
dsf_list = newrbf; |
322 |
} else { |
323 |
newrbf->ord = rbf_last->ord + 1; |
324 |
newrbf->next = rbf; |
325 |
rbf_last->next = newrbf; |
326 |
327 |
rbf_last = newrbf; |
328 |
while (rbf != NULL) { /* update ordinal positions */ |
329 |
330 |
rbf_last = rbf; |
331 |
rbf = rbf->next; |
332 |
333 |
return(newrbf->ord); |
334 |
335 |
336 |
/* Get the DSF indicated by its ordinal position */ |
337 |
RBFNODE * |
338 |
get_dsf(int ord) |
339 |
340 |
RBFNODE *rbf; |
341 |
342 |
343 |
if (rbf->ord == ord) |
344 |
return(rbf); |
345 |
return(NULL); |
346 |
347 |
348 |
/* Get triangle surface orientation (unnormalized) */ |
349 |
void |
350 |
tri_orient(FVECT vres, const FVECT v1, const FVECT v2, const FVECT v3) |
351 |
352 |
FVECT v2minus1, v3minus2; |
353 |
354 |
VSUB(v2minus1, v2, v1); |
355 |
VSUB(v3minus2, v3, v2); |
356 |
VCROSS(vres, v2minus1, v3minus2); |
357 |
358 |
359 |
/* Determine if vertex order is reversed (inward normal) */ |
360 |
int |
361 |
is_rev_tri(const FVECT v1, const FVECT v2, const FVECT v3) |
362 |
363 |
FVECT tor; |
364 |
365 |
tri_orient(tor, v1, v2, v3); |
366 |
367 |
return(DOT(tor, v2) < 0.); |
368 |
369 |
370 |
/* Find vertices completing triangles on either side of the given edge */ |
371 |
int |
372 |
get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig) |
373 |
374 |
const MIGRATION *ej1, *ej2; |
375 |
RBFNODE *tv; |
376 |
377 |
rbfv[0] = rbfv[1] = NULL; |
378 |
if (mig == NULL) |
379 |
return(0); |
380 |
for (ej1 = mig->rbfv[0]->ejl; ej1 != NULL; |
381 |
ej1 = nextedge(mig->rbfv[0],ej1)) { |
382 |
if (ej1 == mig) |
383 |
continue; |
384 |
tv = opp_rbf(mig->rbfv[0],ej1); |
385 |
for (ej2 = tv->ejl; ej2 != NULL; ej2 = nextedge(tv,ej2)) |
386 |
if (opp_rbf(tv,ej2) == mig->rbfv[1]) { |
387 |
rbfv[is_rev_tri(mig->rbfv[0]->invec, |
388 |
mig->rbfv[1]->invec, |
389 |
tv->invec)] = tv; |
390 |
break; |
391 |
392 |
393 |
return((rbfv[0] != NULL) + (rbfv[1] != NULL)); |
394 |
395 |
396 |
/* Clear our BSDF representation and free memory */ |
397 |
void |
398 |
clear_bsdf_rep(void) |
399 |
400 |
while (mig_list != NULL) { |
401 |
MIGRATION *mig = mig_list; |
402 |
mig_list = mig->next; |
403 |
free(mig); |
404 |
405 |
while (dsf_list != NULL) { |
406 |
RBFNODE *rbf = dsf_list; |
407 |
dsf_list = rbf->next; |
408 |
free(rbf); |
409 |
410 |
bsdf_name[0] = '\0'; |
411 |
bsdf_manuf[0] = '\0'; |
412 |
inp_coverage = 0; |
413 |
414 |
input_orient = output_orient = 0; |
415 |
416 |
417 |
418 |
/* Write our BSDF mesh interpolant out to the given binary stream */ |
419 |
void |
420 |
save_bsdf_rep(FILE *ofp) |
421 |
422 |
RBFNODE *rbf; |
423 |
MIGRATION *mig; |
424 |
int i, n; |
425 |
/* finish header */ |
426 |
if (bsdf_name[0]) |
427 |
fprintf(ofp, "NAME=%s\n", bsdf_name); |
428 |
if (bsdf_manuf[0]) |
429 |
fprintf(ofp, "MANUFACT=%s\n", bsdf_manuf); |
430 |
fprintf(ofp, "SYMMETRY=%d\n", !single_plane_incident * inp_coverage); |
431 |
fprintf(ofp, "IO_SIDES= %d %d\n", input_orient, output_orient); |
432 |
fprintf(ofp, "GRIDRES=%d\n", grid_res); |
433 |
fprintf(ofp, "BSDFMIN=%g\n", bsdf_min); |
434 |
fputformat(BSDFREP_FMT, ofp); |
435 |
fputc('\n', ofp); |
436 |
/* write each DSF */ |
437 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) { |
438 |
putint(rbf->ord, 4, ofp); |
439 |
putflt(rbf->invec[0], ofp); |
440 |
putflt(rbf->invec[1], ofp); |
441 |
putflt(rbf->invec[2], ofp); |
442 |
putflt(rbf->vtotal, ofp); |
443 |
putint(rbf->nrbf, 4, ofp); |
444 |
for (i = 0; i < rbf->nrbf; i++) { |
445 |
putflt(rbf->rbfa[i].peak, ofp); |
446 |
putint(rbf->rbfa[i].crad, 2, ofp); |
447 |
putint(rbf->rbfa[i].gx, 1, ofp); |
448 |
putint(rbf->rbfa[i].gy, 1, ofp); |
449 |
450 |
451 |
putint(-1, 4, ofp); /* terminator */ |
452 |
/* write each migration matrix */ |
453 |
for (mig = mig_list; mig != NULL; mig = mig->next) { |
454 |
int zerocnt = 0; |
455 |
putint(mig->rbfv[0]->ord, 4, ofp); |
456 |
putint(mig->rbfv[1]->ord, 4, ofp); |
457 |
/* write out as sparse data */ |
458 |
n = mtx_nrows(mig) * mtx_ncols(mig); |
459 |
for (i = 0; i < n; i++) { |
460 |
if (zerocnt == 0xff) { |
461 |
putint(0xff, 1, ofp); zerocnt = 0; |
462 |
463 |
if (mig->mtx[i] != 0) { |
464 |
putint(zerocnt, 1, ofp); zerocnt = 0; |
465 |
putflt(mig->mtx[i], ofp); |
466 |
} else |
467 |
++zerocnt; |
468 |
469 |
putint(zerocnt, 1, ofp); |
470 |
471 |
472 |
putint(-1, 4, ofp); |
473 |
if (fflush(ofp) == EOF) { |
474 |
fprintf(stderr, "%s: error writing BSDF interpolant\n", |
475 |
progname); |
476 |
exit(1); |
477 |
478 |
479 |
480 |
/* Check header line for critical information */ |
481 |
static int |
482 |
headline(char *s, void *p) |
483 |
484 |
char fmt[32]; |
485 |
486 |
if (!strncmp(s, "NAME=", 5)) { |
487 |
strcpy(bsdf_name, s+5); |
488 |
bsdf_name[strlen(bsdf_name)-1] = '\0'; |
489 |
490 |
if (!strncmp(s, "MANUFACT=", 9)) { |
491 |
strcpy(bsdf_manuf, s+9); |
492 |
bsdf_manuf[strlen(bsdf_manuf)-1] = '\0'; |
493 |
494 |
if (!strncmp(s, "SYMMETRY=", 9)) { |
495 |
inp_coverage = atoi(s+9); |
496 |
single_plane_incident = !inp_coverage; |
497 |
return(0); |
498 |
499 |
if (!strncmp(s, "IO_SIDES=", 9)) { |
500 |
sscanf(s+9, "%d %d", &input_orient, &output_orient); |
501 |
return(0); |
502 |
503 |
if (!strncmp(s, "GRIDRES=", 8)) { |
504 |
sscanf(s+8, "%d", &grid_res); |
505 |
return(0); |
506 |
507 |
if (!strncmp(s, "BSDFMIN=", 8)) { |
508 |
sscanf(s+8, "%lf", &bsdf_min); |
509 |
return(0); |
510 |
511 |
if (formatval(fmt, s) && strcmp(fmt, BSDFREP_FMT)) |
512 |
return(-1); |
513 |
return(0); |
514 |
515 |
516 |
/* Read a BSDF mesh interpolant from the given binary stream */ |
517 |
int |
518 |
load_bsdf_rep(FILE *ifp) |
519 |
520 |
RBFNODE rbfh; |
521 |
int from_ord, to_ord; |
522 |
int i; |
523 |
524 |
clear_bsdf_rep(); |
525 |
if (ifp == NULL) |
526 |
return(0); |
527 |
if (getheader(ifp, headline, NULL) < 0 || single_plane_incident < 0 | |
528 |
!input_orient | !output_orient) { |
529 |
fprintf(stderr, "%s: missing/bad format for BSDF interpolant\n", |
530 |
progname); |
531 |
return(0); |
532 |
533 |
memset(&rbfh, 0, sizeof(rbfh)); /* read each DSF */ |
534 |
while ((rbfh.ord = getint(4, ifp)) >= 0) { |
535 |
RBFNODE *newrbf; |
536 |
537 |
rbfh.invec[0] = getflt(ifp); |
538 |
rbfh.invec[1] = getflt(ifp); |
539 |
rbfh.invec[2] = getflt(ifp); |
540 |
if (normalize(rbfh.invec) == 0) { |
541 |
fprintf(stderr, "%s: zero incident vector\n", progname); |
542 |
return(0); |
543 |
544 |
rbfh.vtotal = getflt(ifp); |
545 |
rbfh.nrbf = getint(4, ifp); |
546 |
newrbf = (RBFNODE *)malloc(sizeof(RBFNODE) + |
547 |
sizeof(RBFVAL)*(rbfh.nrbf-1)); |
548 |
if (newrbf == NULL) |
549 |
goto memerr; |
550 |
*newrbf = rbfh; |
551 |
for (i = 0; i < rbfh.nrbf; i++) { |
552 |
newrbf->rbfa[i].peak = getflt(ifp); |
553 |
newrbf->rbfa[i].crad = getint(2, ifp) & 0xffff; |
554 |
newrbf->rbfa[i].gx = getint(1, ifp) & 0xff; |
555 |
newrbf->rbfa[i].gy = getint(1, ifp) & 0xff; |
556 |
557 |
if (feof(ifp)) |
558 |
goto badEOF; |
559 |
/* insert in global list */ |
560 |
if (insert_dsf(newrbf) != rbfh.ord) { |
561 |
fprintf(stderr, "%s: error adding DSF\n", progname); |
562 |
return(0); |
563 |
564 |
565 |
/* read each migration matrix */ |
566 |
while ((from_ord = getint(4, ifp)) >= 0 && |
567 |
(to_ord = getint(4, ifp)) >= 0) { |
568 |
RBFNODE *from_rbf = get_dsf(from_ord); |
569 |
RBFNODE *to_rbf = get_dsf(to_ord); |
570 |
MIGRATION *newmig; |
571 |
int n; |
572 |
573 |
if ((from_rbf == NULL) | (to_rbf == NULL)) { |
574 |
fprintf(stderr, |
575 |
"%s: bad DSF reference in migration edge\n", |
576 |
progname); |
577 |
return(0); |
578 |
579 |
n = from_rbf->nrbf * to_rbf->nrbf; |
580 |
newmig = (MIGRATION *)malloc(sizeof(MIGRATION) + |
581 |
sizeof(float)*(n-1)); |
582 |
if (newmig == NULL) |
583 |
goto memerr; |
584 |
newmig->rbfv[0] = from_rbf; |
585 |
newmig->rbfv[1] = to_rbf; |
586 |
memset(newmig->mtx, 0, sizeof(float)*n); |
587 |
for (i = 0; ; ) { /* read sparse data */ |
588 |
int zc = getint(1, ifp) & 0xff; |
589 |
if ((i += zc) >= n) |
590 |
break; |
591 |
if (zc == 0xff) |
592 |
continue; |
593 |
newmig->mtx[i++] = getflt(ifp); |
594 |
595 |
if (feof(ifp)) |
596 |
goto badEOF; |
597 |
/* insert in edge lists */ |
598 |
newmig->enxt[0] = from_rbf->ejl; |
599 |
from_rbf->ejl = newmig; |
600 |
newmig->enxt[1] = to_rbf->ejl; |
601 |
to_rbf->ejl = newmig; |
602 |
/* push onto global list */ |
603 |
newmig->next = mig_list; |
604 |
mig_list = newmig; |
605 |
606 |
return(1); /* success! */ |
607 |
memerr: |
608 |
fprintf(stderr, "%s: Out of memory in load_bsdf_rep()\n", progname); |
609 |
exit(1); |
610 |
badEOF: |
611 |
fprintf(stderr, "%s: Unexpected EOF in load_bsdf_rep()\n", progname); |
612 |
return(0); |
613 |
