--- ray/src/cv/bsdfrep.c 2021/12/15 01:38:50 2.37 +++ ray/src/cv/bsdfrep.c 2025/05/18 01:46:05 2.38 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfrep.c,v 2.37 2021/12/15 01:38:50 greg Exp $"; +static const char RCSid[] = "$Id: bsdfrep.c,v 2.38 2025/05/18 01:46:05 greg Exp $"; #endif /* * Support BSDF representation as radial basis functions. @@ -225,12 +225,55 @@ rotate_rbf(RBFNODE *rbf, const FVECT invec) } /* Compute outgoing vector from grid position */ +#if 1 void ovec_from_pos(FVECT vec, int xpos, int ypos) -{ +{ /* precomputed table version */ + static int qsiz = 0; + static float (*q_uv)[2] = NULL; + + if (vec == NULL) { /* just free table? */ + if (q_uv) free(q_uv); + qsiz = 0; + return; + } + if (qsiz != grid_res>>1) { + int x, y; /* (re)make positive quadrant table */ + RREAL uv[2]; + double r; + if (q_uv) free(q_uv); + qsiz = grid_res>>1; + q_uv = (float (*)[2])malloc(sizeof(float)*2*qsiz*qsiz); + for (y = qsiz; y--; ) + for (x = qsiz; x--; ) { + square2disk(uv, 0.5 + (x+.5)/grid_res, + 0.5 + (y+.5)/grid_res); + /* uniform hemispherical projection */ + r = sqrt(2. - uv[0]*uv[0] - uv[1]*uv[1]); + q_uv[qsiz*y + x][0] = (float)(r*uv[0]); + q_uv[qsiz*y + x][1] = (float)(r*uv[1]); + } + } + /* put in positive quadrant */ + if (xpos >= qsiz) { xpos -= qsiz; vec[0] = 1.; } + else { xpos = qsiz-1 - xpos; vec[0] = -1.; } + if (ypos >= qsiz) { ypos -= qsiz; vec[1] = 1.; } + else { ypos = qsiz-1 - ypos; vec[1] = -1.; } + + vec[0] *= (RREAL)q_uv[qsiz*ypos + xpos][0]; + vec[1] *= (RREAL)q_uv[qsiz*ypos + xpos][1]; + vec[2] = output_orient*sqrt(1. - vec[0]*vec[0] - vec[1]*vec[1]); +} +#else +void +ovec_from_pos(FVECT vec, int xpos, int ypos) +{ /* table-free version */ RREAL uv[2]; double r2; - + + if (vec == NULL) + return; + square2disk(uv, (xpos+.5)/grid_res, (ypos+.5)/grid_res); /* uniform hemispherical projection */ r2 = uv[0]*uv[0] + uv[1]*uv[1]; @@ -239,6 +282,7 @@ ovec_from_pos(FVECT vec, int xpos, int ypos) vec[1] *= uv[1]; vec[2] = output_orient*(1. - r2); } +#endif /* Compute grid position from normalized input/output vector */ void
