root/radiance/ray/src/cv/bsdfrep.c
Wed Dec 15 01:38:50 2021 UTC (2 years, 5 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.36: +5 -5 lines
Diff to previous 2.36 , to selected 2.31
refactor: removed prefix from SDdisk2square() and SDsquare2disk() & made consistent
Wed Nov 17 01:39:04 2021 UTC (2 years, 6 months ago) by greg
Changes since 2.35: +5 -2 lines
Diff to previous 2.35 , to selected 2.31
fix(bsdfquery): literal edge case causing interpolation to fail
Tue Sep 7 20:13:13 2021 UTC (2 years, 8 months ago) by greg
Diff to previous 2.34 , to selected 2.31
fix(bsdf2ttree, bsdf2klems): reduced threshold to avoid "sticking" behavior in interpolant
Mon Oct 26 21:12:20 2020 UTC (3 years, 7 months ago) by greg
Changes since 2.33: +18 -9 lines
Diff to previous 2.33 , to selected 2.31
feat(bsdf2klems, bsdf2ttree): added XML header comments copying useful information from SIR inputs
Sat Dec 28 18:05:14 2019 UTC (4 years, 5 months ago) by greg
Changes since 2.32: +1 -2 lines
Diff to previous 2.32 , to selected 2.31
Thu Aug 2 18:33:42 2018 UTC (5 years, 10 months ago) by greg
Diff to previous 2.31
Revision 2.31 - (view) (download) (annotate) - [selected]
Wed Feb 3 18:53:14 2016 UTC (8 years, 4 months ago) by greg
Changes since 2.30: +6 -5 lines
Diff to previous 2.30
Return minimum BSDF value as gray
Sat Jan 30 01:31:57 2016 UTC (8 years, 4 months ago) by greg
Changes since 2.29: +8 -8 lines
Diff to previous 2.29 , to selected 2.31
Improved grazing lobe estimation by using lowest 25% of DSFs
Fri Jan 29 16:21:55 2016 UTC (8 years, 4 months ago) by greg
Changes since 2.28: +88 -20 lines
Diff to previous 2.28 , to selected 2.31
Thu May 28 15:46:28 2015 UTC (9 years ago) by greg
Changes since 2.27: +12 -11 lines
Diff to previous 2.27 , to selected 2.31
Put angle normalization before test that assumes it
Fri Aug 22 05:38:44 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Diff to previous 2.26 , to selected 2.31
Thu Aug 21 13:44:05 2014 UTC (9 years, 9 months ago) by greg
Changes since 2.25: +9 -12 lines
Diff to previous 2.25 , to selected 2.31
Minor changes should not affect results
Thu Aug 21 10:33:48 2014 UTC (9 years, 9 months ago) by greg
Changes since 2.24: +52 -6 lines
Diff to previous 2.24 , to selected 2.31
Tue Mar 25 14:55:35 2014 UTC (10 years, 2 months ago) by greg
CVS Tags: rad4R2
Diff to previous 2.23 , to selected 2.31
Made check against non-rotation more robust
Mon Mar 24 06:07:46 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.22: +3 -2 lines
Diff to previous 2.22 , to selected 2.31
Minor fixes
Fri Mar 21 16:28:23 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.21: +4 -3 lines
Diff to previous 2.21 , to selected 2.31
Improved error message
Fri Mar 7 21:21:02 2014 UTC (10 years, 2 months ago) by greg
Diff to previous 2.20 , to selected 2.31
Cleaned up compiler warning
Wed Feb 19 05:16:06 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.19: +87 -1 lines
Diff to previous 2.19 , to selected 2.31
Eliminated redundant code added in last change to bsdfmesh.c
Sat Nov 9 05:47:49 2013 UTC (10 years, 6 months ago) by greg
Changes since 2.18: +18 -1 lines
Diff to previous 2.18 , to selected 2.31
Fri Nov 8 05:37:20 2013 UTC (10 years, 6 months ago) by greg
Diff to previous 2.17 , to selected 2.31
Minor change should not affect operation
Thu Oct 24 16:11:38 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.16: +3 -2 lines
Diff to previous 2.16 , to selected 2.31
Sped up convergence on large systems by almost 3x
Tue Oct 22 05:48:05 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.15: +12 -6 lines
Diff to previous 2.15 , to selected 2.31
Sped up RBF evaluation by about a factor of 4
Sat Oct 19 00:11:50 2013 UTC (10 years, 7 months ago) by greg
Diff to previous 2.14 , to selected 2.31
Fri Sep 20 00:21:39 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.13: +26 -14 lines
Diff to previous 2.13 , to selected 2.31
Improved estimate of integrated Gaussian lobe using horizon cut-off
Sun Mar 24 17:22:23 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.12: +5 -2 lines
Diff to previous 2.12 , to selected 2.31
Make sure not to output less than diffuse minimum
Wed Mar 20 01:00:22 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.11: +18 -4 lines
Diff to previous 2.11 , to selected 2.31
Thu Nov 22 06:07:17 2012 UTC (11 years, 6 months ago) by greg
Diff to previous 2.10 , to selected 2.31
Sun Nov 18 03:56:39 2012 UTC (11 years, 6 months ago) by greg
Diff to previous 2.9 , to selected 2.31
Minor efficiency improvement
Tue Nov 13 04:23:38 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.8: +5 -1 lines
Diff to previous 2.8 , to selected 2.31
Tried to improve convergence of RBF fit
Fri Nov 9 02:16:29 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.7: +5 -11 lines
Diff to previous 2.7 , to selected 2.31
Added data to complete XML file output
Thu Nov 8 22:05:04 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.6: +5 -7 lines
Diff to previous 2.6 , to selected 2.31
Took sort out so it is done only once
Thu Nov 8 00:31:17 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.5: +32 -2 lines
Diff to previous 2.5 , to selected 2.31
Wed Nov 7 03:04:23 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.4: +17 -6 lines
Diff to previous 2.4 , to selected 2.31
Added GRIDRES to saved BSDF representation
Tue Oct 23 05:10:42 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.3: +28 -17 lines
Diff to previous 2.3 , to selected 2.31
Hopeful bug fix in BSDF interpolation code
Sat Oct 20 17:01:26 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.2: +7 -10 lines
Diff to previous 2.2 , to selected 2.31
Bug fixes in loading BSDF interpolant data
Sat Oct 20 07:02:00 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.1: +53 -8 lines
Diff to previous 2.1 , to selected 2.31
Bug fixes and minor improvements
Fri Oct 19 04:14:29 2012 UTC (11 years, 7 months ago) by greg
Diff to selected 2.31
