--- ray/src/cv/bsdfrep.c 2013/03/24 17:22:23 2.13 +++ ray/src/cv/bsdfrep.c 2016/01/29 16:21:55 2.29 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfrep.c,v 2.13 2013/03/24 17:22:23 greg Exp $"; +static const char RCSid[] = "$Id: bsdfrep.c,v 2.29 2016/01/29 16:21:55 greg Exp $"; #endif /* * Support BSDF representation as radial basis functions. @@ -14,6 +14,10 @@ static const char RCSid[] = "$Id: bsdfrep.c,v 2.13 201 #include "rtio.h" #include "resolu.h" #include "bsdfrep.h" +#include "random.h" + /* name and manufacturer if known */ +char bsdf_name[256]; +char bsdf_manuf[256]; /* active grid resolution */ int grid_res = GRIDRES; @@ -26,11 +30,20 @@ int single_plane_incident = -1; int input_orient = 0; int output_orient = 0; + /* represented color space */ +RBColor rbf_colorimetry = RBCunknown; + +const char *RBCident[] = { + "CIE-Y", "CIE-XYZ", "Spectral", "Unknown" + }; + /* BSDF histogram */ -int bsdf_hist[HISTLEN]; +unsigned long bsdf_hist[HISTLEN]; /* BSDF value for boundary regions */ double bsdf_min = 0; +double bsdf_spec_peak = 0; +double bsdf_spec_rad = 0; /* processed incident DSF measurements */ RBFNODE *dsf_list = NULL; @@ -45,14 +58,6 @@ double theta_in_deg, phi_in_deg; int new_input_direction(double new_theta, double new_phi) { - if (!input_orient) /* check input orientation */ - input_orient = 1 - 2*(new_theta > 90.); - else if (input_orient > 0 ^ new_theta < 90.) { - fprintf(stderr, - "%s: Cannot handle input angles on both sides of surface\n", - progname); - return(0); - } /* normalize angle ranges */ while (new_theta < -180.) new_theta += 360.; @@ -62,12 +67,21 @@ new_input_direction(double new_theta, double new_phi) new_theta = -new_theta; new_phi += 180.; } - if ((theta_in_deg = new_theta) < 1.0) - return(1); /* don't rely on phi near normal */ while (new_phi < 0) new_phi += 360.; while (new_phi >= 360.) new_phi -= 360.; + /* check input orientation */ + if (!input_orient) + input_orient = 1 - 2*(new_theta > 90.); + else if (input_orient > 0 ^ new_theta < 90.) { + fprintf(stderr, + "%s: Cannot handle input angles on both sides of surface\n", + progname); + return(0); + } + if ((theta_in_deg = new_theta) < 1.0) + return(1); /* don't rely on phi near normal */ if (single_plane_incident > 0) /* check input coverage */ single_plane_incident = (round(new_phi) == round(phi_in_deg)); else if (single_plane_incident < 0) @@ -195,7 +209,7 @@ rotate_rbf(RBFNODE *rbf, const FVECT invec) int pos[2]; int n; - for (n = ((-.01 > phi) | (phi > .01))*rbf->nrbf; n-- > 0; ) { + for (n = (cos(phi) < 1.-FTINY)*rbf->nrbf; n-- > 0; ) { ovec_from_pos(outvec, rbf->rbfa[n].gx, rbf->rbfa[n].gy); spinvector(outvec, outvec, vnorm, phi); pos_from_vec(pos, outvec); @@ -205,15 +219,6 @@ rotate_rbf(RBFNODE *rbf, const FVECT invec) VCOPY(rbf->invec, invec); } -/* Compute volume associated with Gaussian lobe */ -double -rbf_volume(const RBFVAL *rbfp) -{ - double rad = R2ANG(rbfp->crad); - - return((2.*M_PI) * rbfp->peak * rad*rad); -} - /* Compute outgoing vector from grid position */ void ovec_from_pos(FVECT vec, int xpos, int ypos) @@ -243,35 +248,91 @@ pos_from_vec(int pos[2], const FVECT vec) pos[1] = (int)(sq[1]*grid_res); } -/* Evaluate RBF for DSF at the given normalized outgoing direction */ +/* Compute volume associated with Gaussian lobe */ double -eval_rbfrep(const RBFNODE *rp, const FVECT outvec) +rbf_volume(const RBFVAL *rbfp) { - double minval = bsdf_min*output_orient*outvec[2]; + double rad = R2ANG(rbfp->crad); + FVECT odir; + double elev, integ; + /* infinite integral approximation */ + integ = (2.*M_PI) * rbfp->peak * rad*rad; + /* check if we're near horizon */ + ovec_from_pos(odir, rbfp->gx, rbfp->gy); + elev = output_orient*odir[2]; + /* apply cut-off correction if > 1% */ + if (elev < 2.8*rad) { + /* elev = asin(elev); /* this is so crude, anyway... */ + integ *= 1. - .5*exp(-.5*elev*elev/(rad*rad)); + } + return(integ); +} + +/* Evaluate BSDF at the given normalized outgoing direction in color */ +SDError +eval_rbfcol(SDValue *sv, const RBFNODE *rp, const FVECT outvec) +{ + const double rfact2 = (38./M_PI/M_PI)*(grid_res*grid_res); + int pos[2]; double res = 0; + double usum = 0, vsum = 0; const RBFVAL *rbfp; FVECT odir; - double sig2; + double rad2; int n; - /* use minimum if no information avail. */ - if (rp == NULL) { - if (outvec[2] > 0 ^ output_orient > 0) - return(.0); - return(minval); + /* assign default value */ + sv->spec = c_dfcolor; + sv->cieY = bsdf_min; + /* check for wrong side */ + if (outvec[2] > 0 ^ output_orient > 0) { + strcpy(SDerrorDetail, "Wrong-side scattering query"); + return(SDEargument); } + if (rp == NULL) /* return minimum if no information avail. */ + return(SDEnone); + /* optimization for fast lobe culling */ + pos_from_vec(pos, outvec); + /* sum radial basis function */ rbfp = rp->rbfa; for (n = rp->nrbf; n--; rbfp++) { + int d2 = (pos[0]-rbfp->gx)*(pos[0]-rbfp->gx) + + (pos[1]-rbfp->gy)*(pos[1]-rbfp->gy); + double val; + rad2 = R2ANG(rbfp->crad); + rad2 *= rad2; + if (d2 > rad2*rfact2) + continue; ovec_from_pos(odir, rbfp->gx, rbfp->gy); - sig2 = R2ANG(rbfp->crad); - sig2 = (DOT(odir,outvec) - 1.) / (sig2*sig2); - if (sig2 > -19.) - res += rbfp->peak * exp(sig2); + val = rbfp->peak * exp((DOT(odir,outvec) - 1.) / rad2); + if (rbf_colorimetry == RBCtristimulus) { + usum += val * (rbfp->chroma & 0xff); + vsum += val * (rbfp->chroma>>8 & 0xff); + } + res += val; } - if (res < minval) /* never return less than minval */ - return(minval); - return(res); + if ((rbf_colorimetry == RBCtristimulus) & (res > 1e-6)) { + C_CHROMA cres = (int)(usum/res + frandom()); + cres |= (int)(vsum/res + frandom()) << 8; + c_decodeChroma(&sv->spec, cres); + } + sv->cieY = res / COSF(outvec[2]); + if (sv->cieY < bsdf_min) /* never return less than bsdf_min */ + sv->cieY = bsdf_min; + return(SDEnone); } +/* Evaluate BSDF at the given normalized outgoing direction in Y */ +double +eval_rbfrep(const RBFNODE *rp, const FVECT outvec) +{ + SDValue sv; + + if (eval_rbfcol(&sv, rp, outvec) == SDEnone) + return(sv.cieY); + + return(0.0); +} + /* Insert a new directional scattering function in our global list */ int insert_dsf(RBFNODE *newrbf) @@ -282,8 +343,9 @@ insert_dsf(RBFNODE *newrbf) for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) if (DOT(rbf->invec, newrbf->invec) >= 1.-FTINY) { fprintf(stderr, - "%s: Duplicate incident measurement (ignored)\n", - progname); + "%s: Duplicate incident measurement ignored at (%.1f,%.1f)\n", + progname, get_theta180(newrbf->invec), + get_phi360(newrbf->invec)); free(newrbf); return(-1); } @@ -371,6 +433,134 @@ get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig) return((rbfv[0] != NULL) + (rbfv[1] != NULL)); } +/* Return single-lobe specular RBF for the given incident direction */ +RBFNODE * +def_rbf_spec(const FVECT invec) +{ + RBFNODE *rbf; + FVECT ovec; + int pos[2]; + + if (input_orient > 0 ^ invec[2] > 0) /* wrong side? */ + return(NULL); + if ((bsdf_spec_peak <= bsdf_min) | (bsdf_spec_rad <= 0)) + return(NULL); /* nothing set */ + rbf = (RBFNODE *)malloc(sizeof(RBFNODE)); + if (rbf == NULL) + return(NULL); + ovec[0] = -invec[0]; + ovec[1] = -invec[1]; + ovec[2] = invec[2]*(2*(input_orient==output_orient) - 1); + pos_from_vec(pos, ovec); + rbf->ord = 0; + rbf->next = NULL; + rbf->ejl = NULL; + VCOPY(rbf->invec, invec); + rbf->nrbf = 1; + rbf->rbfa[0].peak = bsdf_spec_peak * output_orient*ovec[2]; + rbf->rbfa[0].chroma = c_dfchroma; + rbf->rbfa[0].crad = ANG2R(bsdf_spec_rad); + rbf->rbfa[0].gx = pos[0]; + rbf->rbfa[0].gy = pos[1]; + rbf->vtotal = rbf_volume(rbf->rbfa); + return(rbf); +} + +/* Advect and allocate new RBF along edge (internal call) */ +RBFNODE * +e_advect_rbf(const MIGRATION *mig, const FVECT invec, int lobe_lim) +{ + double cthresh = FTINY; + RBFNODE *rbf; + int n, i, j; + double t, full_dist; + /* get relative position */ + t = Acos(DOT(invec, mig->rbfv[0]->invec)); + if (t < M_PI/grid_res) { /* near first DSF */ + n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[0]->nrbf-1); + rbf = (RBFNODE *)malloc(n); + if (rbf == NULL) + goto memerr; + memcpy(rbf, mig->rbfv[0], n); /* just duplicate */ + rbf->next = NULL; rbf->ejl = NULL; + return(rbf); + } + full_dist = acos(DOT(mig->rbfv[0]->invec, mig->rbfv[1]->invec)); + if (t > full_dist-M_PI/grid_res) { /* near second DSF */ + n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[1]->nrbf-1); + rbf = (RBFNODE *)malloc(n); + if (rbf == NULL) + goto memerr; + memcpy(rbf, mig->rbfv[1], n); /* just duplicate */ + rbf->next = NULL; rbf->ejl = NULL; + return(rbf); + } + t /= full_dist; +tryagain: + n = 0; /* count migrating particles */ + for (i = 0; i < mtx_nrows(mig); i++) + for (j = 0; j < mtx_ncols(mig); j++) + n += (mtx_coef(mig,i,j) > cthresh); + /* are we over our limit? */ + if ((lobe_lim > 0) & (n > lobe_lim)) { + cthresh = cthresh*2. + 10.*FTINY; + goto tryagain; + } +#ifdef DEBUG + fprintf(stderr, "Input RBFs have %d, %d nodes -> output has %d\n", + mig->rbfv[0]->nrbf, mig->rbfv[1]->nrbf, n); +#endif + rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1)); + if (rbf == NULL) + goto memerr; + rbf->next = NULL; rbf->ejl = NULL; + VCOPY(rbf->invec, invec); + rbf->nrbf = n; + rbf->vtotal = 1.-t + t*mig->rbfv[1]->vtotal/mig->rbfv[0]->vtotal; + n = 0; /* advect RBF lobes */ + for (i = 0; i < mtx_nrows(mig); i++) { + const RBFVAL *rbf0i = &mig->rbfv[0]->rbfa[i]; + const float peak0 = rbf0i->peak; + const double rad0 = R2ANG(rbf0i->crad); + C_COLOR cc0; + FVECT v0; + float mv; + ovec_from_pos(v0, rbf0i->gx, rbf0i->gy); + c_decodeChroma(&cc0, rbf0i->chroma); + for (j = 0; j < mtx_ncols(mig); j++) + if ((mv = mtx_coef(mig,i,j)) > cthresh) { + const RBFVAL *rbf1j = &mig->rbfv[1]->rbfa[j]; + double rad2; + FVECT v; + int pos[2]; + rad2 = R2ANG(rbf1j->crad); + rad2 = rad0*rad0*(1.-t) + rad2*rad2*t; + rbf->rbfa[n].peak = peak0 * mv * rbf->vtotal * + rad0*rad0/rad2; + if (rbf_colorimetry == RBCtristimulus) { + C_COLOR cres; + c_decodeChroma(&cres, rbf1j->chroma); + c_cmix(&cres, 1.-t, &cc0, t, &cres); + rbf->rbfa[n].chroma = c_encodeChroma(&cres); + } else + rbf->rbfa[n].chroma = c_dfchroma; + rbf->rbfa[n].crad = ANG2R(sqrt(rad2)); + ovec_from_pos(v, rbf1j->gx, rbf1j->gy); + geodesic(v, v0, v, t, GEOD_REL); + pos_from_vec(pos, v); + rbf->rbfa[n].gx = pos[0]; + rbf->rbfa[n].gy = pos[1]; + ++n; + } + } + rbf->vtotal *= mig->rbfv[0]->vtotal; /* turn ratio into actual */ + return(rbf); +memerr: + fprintf(stderr, "%s: Out of memory in e_advect_rbf()\n", progname); + exit(1); + return(NULL); /* pro forma return */ +} + /* Clear our BSDF representation and free memory */ void clear_bsdf_rep(void) @@ -385,10 +575,16 @@ clear_bsdf_rep(void) dsf_list = rbf->next; free(rbf); } + bsdf_name[0] = '\0'; + bsdf_manuf[0] = '\0'; inp_coverage = 0; single_plane_incident = -1; input_orient = output_orient = 0; + rbf_colorimetry = RBCunknown; grid_res = GRIDRES; + bsdf_min = 0; + bsdf_spec_peak = 0; + bsdf_spec_rad = 0; } /* Write our BSDF mesh interpolant out to the given binary stream */ @@ -399,12 +595,20 @@ save_bsdf_rep(FILE *ofp) MIGRATION *mig; int i, n; /* finish header */ + if (bsdf_name[0]) + fprintf(ofp, "NAME=%s\n", bsdf_name); + if (bsdf_manuf[0]) + fprintf(ofp, "MANUFACT=%s\n", bsdf_manuf); fprintf(ofp, "SYMMETRY=%d\n", !single_plane_incident * inp_coverage); fprintf(ofp, "IO_SIDES= %d %d\n", input_orient, output_orient); + fprintf(ofp, "COLORIMETRY=%s\n", RBCident[rbf_colorimetry]); fprintf(ofp, "GRIDRES=%d\n", grid_res); fprintf(ofp, "BSDFMIN=%g\n", bsdf_min); + if ((bsdf_spec_peak > bsdf_min) & (bsdf_spec_rad > 0)) + fprintf(ofp, "BSDFSPEC= %f %f\n", bsdf_spec_peak, bsdf_spec_rad); fputformat(BSDFREP_FMT, ofp); fputc('\n', ofp); + putint(BSDFREP_MAGIC, 2, ofp); /* write each DSF */ for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) { putint(rbf->ord, 4, ofp); @@ -415,9 +619,10 @@ save_bsdf_rep(FILE *ofp) putint(rbf->nrbf, 4, ofp); for (i = 0; i < rbf->nrbf; i++) { putflt(rbf->rbfa[i].peak, ofp); + putint(rbf->rbfa[i].chroma, 2, ofp); putint(rbf->rbfa[i].crad, 2, ofp); - putint(rbf->rbfa[i].gx, 1, ofp); - putint(rbf->rbfa[i].gy, 1, ofp); + putint(rbf->rbfa[i].gx, 2, ofp); + putint(rbf->rbfa[i].gy, 2, ofp); } } putint(-1, 4, ofp); /* terminator */ @@ -453,8 +658,17 @@ save_bsdf_rep(FILE *ofp) static int headline(char *s, void *p) { - char fmt[32]; + char fmt[64]; + int i; + if (!strncmp(s, "NAME=", 5)) { + strcpy(bsdf_name, s+5); + bsdf_name[strlen(bsdf_name)-1] = '\0'; + } + if (!strncmp(s, "MANUFACT=", 9)) { + strcpy(bsdf_manuf, s+9); + bsdf_manuf[strlen(bsdf_manuf)-1] = '\0'; + } if (!strncmp(s, "SYMMETRY=", 9)) { inp_coverage = atoi(s+9); single_plane_incident = !inp_coverage; @@ -464,6 +678,17 @@ headline(char *s, void *p) sscanf(s+9, "%d %d", &input_orient, &output_orient); return(0); } + if (!strncmp(s, "COLORIMETRY=", 12)) { + fmt[0] = '\0'; + sscanf(s+12, "%s", fmt); + for (i = RBCunknown; i >= 0; i--) + if (!strcmp(fmt, RBCident[i])) + break; + if (i < 0) + return(-1); + rbf_colorimetry = i; + return(0); + } if (!strncmp(s, "GRIDRES=", 8)) { sscanf(s+8, "%d", &grid_res); return(0); @@ -472,6 +697,10 @@ headline(char *s, void *p) sscanf(s+8, "%lf", &bsdf_min); return(0); } + if (!strncmp(s, "BSDFSPEC=", 9)) { + sscanf(s+9, "%lf %lf", &bsdf_spec_peak, &bsdf_spec_rad); + return(0); + } if (formatval(fmt, s) && strcmp(fmt, BSDFREP_FMT)) return(-1); return(0); @@ -488,14 +717,19 @@ load_bsdf_rep(FILE *ifp) clear_bsdf_rep(); if (ifp == NULL) return(0); - if (getheader(ifp, headline, NULL) < 0 || single_plane_incident < 0 | - !input_orient | !output_orient) { + if (getheader(ifp, headline, NULL) < 0 || (single_plane_incident < 0) | + !input_orient | !output_orient | + (grid_res < 16) | (grid_res > 0xffff)) { fprintf(stderr, "%s: missing/bad format for BSDF interpolant\n", progname); return(0); } - rbfh.next = NULL; /* read each DSF */ - rbfh.ejl = NULL; + if (getint(2, ifp) != BSDFREP_MAGIC) { + fprintf(stderr, "%s: bad magic number for BSDF interpolant\n", + progname); + return(0); + } + memset(&rbfh, 0, sizeof(rbfh)); /* read each DSF */ while ((rbfh.ord = getint(4, ifp)) >= 0) { RBFNODE *newrbf; @@ -512,12 +746,13 @@ load_bsdf_rep(FILE *ifp) sizeof(RBFVAL)*(rbfh.nrbf-1)); if (newrbf == NULL) goto memerr; - memcpy(newrbf, &rbfh, sizeof(RBFNODE)-sizeof(RBFVAL)); + *newrbf = rbfh; for (i = 0; i < rbfh.nrbf; i++) { newrbf->rbfa[i].peak = getflt(ifp); + newrbf->rbfa[i].chroma = getint(2, ifp) & 0xffff; newrbf->rbfa[i].crad = getint(2, ifp) & 0xffff; - newrbf->rbfa[i].gx = getint(1, ifp) & 0xff; - newrbf->rbfa[i].gy = getint(1, ifp) & 0xff; + newrbf->rbfa[i].gx = getint(2, ifp) & 0xffff; + newrbf->rbfa[i].gy = getint(2, ifp) & 0xffff; } if (feof(ifp)) goto badEOF;
