--- ray/src/cv/bsdfrep.c 2013/03/24 17:22:23 2.13 +++ ray/src/cv/bsdfrep.c 2013/09/20 00:21:39 2.14 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfrep.c,v 2.13 2013/03/24 17:22:23 greg Exp $"; +static const char RCSid[] = "$Id: bsdfrep.c,v 2.14 2013/09/20 00:21:39 greg Exp $"; #endif /* * Support BSDF representation as radial basis functions. @@ -205,15 +205,6 @@ rotate_rbf(RBFNODE *rbf, const FVECT invec) VCOPY(rbf->invec, invec); } -/* Compute volume associated with Gaussian lobe */ -double -rbf_volume(const RBFVAL *rbfp) -{ - double rad = R2ANG(rbfp->crad); - - return((2.*M_PI) * rbfp->peak * rad*rad); -} - /* Compute outgoing vector from grid position */ void ovec_from_pos(FVECT vec, int xpos, int ypos) @@ -243,6 +234,26 @@ pos_from_vec(int pos[2], const FVECT vec) pos[1] = (int)(sq[1]*grid_res); } +/* Compute volume associated with Gaussian lobe */ +double +rbf_volume(const RBFVAL *rbfp) +{ + double rad = R2ANG(rbfp->crad); + FVECT odir; + double elev, integ; + /* infinite integral approximation */ + integ = (2.*M_PI) * rbfp->peak * rad*rad; + /* check if we're near horizon */ + ovec_from_pos(odir, rbfp->gx, rbfp->gy); + elev = output_orient*odir[2]; + /* apply cut-off correction if > 1% */ + if (elev < 2.8*rad) { + /* elev = asin(elev); /* this is so crude, anyway... */ + integ *= 1. - .5*exp(-.5*elev*elev/(rad*rad)); + } + return(integ); +} + /* Evaluate RBF for DSF at the given normalized outgoing direction */ double eval_rbfrep(const RBFNODE *rp, const FVECT outvec) @@ -253,12 +264,13 @@ eval_rbfrep(const RBFNODE *rp, const FVECT outvec) FVECT odir; double sig2; int n; + /* check for wrong side */ + if (outvec[2] > 0 ^ output_orient > 0) + return(.0); /* use minimum if no information avail. */ - if (rp == NULL) { - if (outvec[2] > 0 ^ output_orient > 0) - return(.0); + if (rp == NULL) return(minval); - } + /* sum radial basis function */ rbfp = rp->rbfa; for (n = rp->nrbf; n--; rbfp++) { ovec_from_pos(odir, rbfp->gx, rbfp->gy);
