root/radiance/ray/src/cv/bsdfrep.c
Revision: 2.12
Committed: Wed Mar 20 01:00:22 2013 UTC (12 years, 4 months ago) by greg
Changes since 2.11: +18 -4 lines
2 static const char RCSid[] = "$Id: bsdfrep.c,v 2.11 2012/11/22 06:07:17 greg Exp $";
5 * Support BSDF representation as radial basis functions.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdlib.h>
12 #include <string.h>
13 #include <math.h>
14 #include "rtio.h"
15 #include "resolu.h"
16 #include "bsdfrep.h"
17 /* active grid resolution */
18 int grid_res = GRIDRES;
19
20 /* coverage/symmetry using INP_QUAD? flags */
21 int inp_coverage = 0;
22 /* all incident angles in-plane so far? */
23 int single_plane_incident = -1;
24
25 /* input/output orientations */
26 int input_orient = 0;
27 int output_orient = 0;
28
29 /* BSDF histogram */
30 int bsdf_hist[HISTLEN];
31
32 /* BSDF value for boundary regions */
33 double bsdf_min = 0;
34
35 /* processed incident DSF measurements */
36 RBFNODE *dsf_list = NULL;
37
38 /* RBF-linking matrices (edges) */
39 MIGRATION *mig_list = NULL;
40
41 /* current input direction */
42 double theta_in_deg, phi_in_deg;
43
44 /* Register new input direction */
45 int
46 new_input_direction(double new_theta, double new_phi)
47 {
48 if (!input_orient) /* check input orientation */
49 input_orient = 1 - 2*(new_theta > 90.);
50 else if (input_orient > 0 ^ new_theta < 90.) {
51 fprintf(stderr,
52 "%s: Cannot handle input angles on both sides of surface\n",
53 progname);
54 return(0);
55 }
56 /* normalize angle ranges */
57 while (new_theta < -180.)
58 new_theta += 360.;
59 while (new_theta > 180.)
60 new_theta -= 360.;
61 if (new_theta < 0) {
62 new_theta = -new_theta;
63 new_phi += 180.;
64 }
65 if ((theta_in_deg = new_theta) < 1.0)
66 return(1); /* don't rely on phi near normal */
67 while (new_phi < 0)
68 new_phi += 360.;
69 while (new_phi >= 360.)
70 new_phi -= 360.;
71 if (single_plane_incident > 0) /* check input coverage */
72 single_plane_incident = (round(new_phi) == round(phi_in_deg));
73 else if (single_plane_incident < 0)
74 single_plane_incident = 1;
75 phi_in_deg = new_phi;
76 if ((1. < new_phi) & (new_phi < 89.))
77 inp_coverage |= INP_QUAD1;
78 else if ((91. < new_phi) & (new_phi < 179.))
79 inp_coverage |= INP_QUAD2;
80 else if ((181. < new_phi) & (new_phi < 269.))
81 inp_coverage |= INP_QUAD3;
82 else if ((271. < new_phi) & (new_phi < 359.))
83 inp_coverage |= INP_QUAD4;
84 return(1);
85 }
86
87 /* Apply symmetry to the given vector based on distribution */
88 int
89 use_symmetry(FVECT vec)
90 {
91 const double phi = get_phi360(vec);
92
93 switch (inp_coverage) {
94 case INP_QUAD1|INP_QUAD2|INP_QUAD3|INP_QUAD4:
95 break;
96 case INP_QUAD1|INP_QUAD2:
97 if ((-FTINY > phi) | (phi > 180.+FTINY))
98 goto mir_y;
99 break;
100 case INP_QUAD2|INP_QUAD3:
101 if ((90.-FTINY > phi) | (phi > 270.+FTINY))
102 goto mir_x;
103 break;
104 case INP_QUAD3|INP_QUAD4:
105 if ((180.-FTINY > phi) | (phi > 360.+FTINY))
106 goto mir_y;
107 break;
108 case INP_QUAD4|INP_QUAD1:
109 if ((270.-FTINY > phi) & (phi > 90.+FTINY))
110 goto mir_x;
111 break;
112 case INP_QUAD1:
113 if ((-FTINY > phi) | (phi > 90.+FTINY))
114 switch ((int)(phi*(1./90.))) {
115 case 1: goto mir_x;
116 case 2: goto mir_xy;
117 case 3: goto mir_y;
118 }
119 break;
120 case INP_QUAD2:
121 if ((90.-FTINY > phi) | (phi > 180.+FTINY))
122 switch ((int)(phi*(1./90.))) {
123 case 0: goto mir_x;
124 case 2: goto mir_y;
125 case 3: goto mir_xy;
126 }
127 break;
128 case INP_QUAD3:
129 if ((180.-FTINY > phi) | (phi > 270.+FTINY))
130 switch ((int)(phi*(1./90.))) {
131 case 0: goto mir_xy;
132 case 1: goto mir_y;
133 case 3: goto mir_x;
134 }
135 break;
136 case INP_QUAD4:
137 if ((270.-FTINY > phi) | (phi > 360.+FTINY))
138 switch ((int)(phi*(1./90.))) {
139 case 0: goto mir_y;
140 case 1: goto mir_xy;
141 case 2: goto mir_x;
142 }
143 break;
144 default:
145 fprintf(stderr, "%s: Illegal input coverage (%d)\n",
146 progname, inp_coverage);
147 exit(1);
148 }
149 return(0); /* in range */
150 mir_x:
151 vec[0] = -vec[0];
152 return(MIRROR_X);
153 mir_y:
154 vec[1] = -vec[1];
155 return(MIRROR_Y);
156 mir_xy:
157 vec[0] = -vec[0];
158 vec[1] = -vec[1];
159 return(MIRROR_X|MIRROR_Y);
160 }
161
162 /* Reverse symmetry based on what was done before */
163 void
164 rev_symmetry(FVECT vec, int sym)
165 {
166 if (sym & MIRROR_X)
167 vec[0] = -vec[0];
168 if (sym & MIRROR_Y)
169 vec[1] = -vec[1];
170 }
171
172 /* Reverse symmetry for an RBF distribution */
173 void
174 rev_rbf_symmetry(RBFNODE *rbf, int sym)
175 {
176 int n;
177
178 rev_symmetry(rbf->invec, sym);
179 if (sym & MIRROR_X)
180 for (n = rbf->nrbf; n-- > 0; )
181 rbf->rbfa[n].gx = grid_res-1 - rbf->rbfa[n].gx;
182 if (sym & MIRROR_Y)
183 for (n = rbf->nrbf; n-- > 0; )
184 rbf->rbfa[n].gy = grid_res-1 - rbf->rbfa[n].gy;
185 }
186
187 /* Rotate RBF to correspond to given incident vector */
188 void
189 rotate_rbf(RBFNODE *rbf, const FVECT invec)
190 {
191 static const FVECT vnorm = {.0, .0, 1.};
192 const double phi = atan2(invec[1],invec[0]) -
193 atan2(rbf->invec[1],rbf->invec[0]);
194 FVECT outvec;
195 int pos[2];
196 int n;
197
198 for (n = ((-.01 > phi) | (phi > .01))*rbf->nrbf; n-- > 0; ) {
199 ovec_from_pos(outvec, rbf->rbfa[n].gx, rbf->rbfa[n].gy);
200 spinvector(outvec, outvec, vnorm, phi);
201 pos_from_vec(pos, outvec);
202 rbf->rbfa[n].gx = pos[0];
203 rbf->rbfa[n].gy = pos[1];
204 }
205 VCOPY(rbf->invec, invec);
206 }
207
208 /* Compute volume associated with Gaussian lobe */
209 double
210 rbf_volume(const RBFVAL *rbfp)
211 {
212 double rad = R2ANG(rbfp->crad);
213
214 return((2.*M_PI) * rbfp->peak * rad*rad);
215 }
216
217 /* Compute outgoing vector from grid position */
218 void
219 ovec_from_pos(FVECT vec, int xpos, int ypos)
220 {
221 double uv[2];
222 double r2;
223
224 SDsquare2disk(uv, (xpos+.5)/grid_res, (ypos+.5)/grid_res);
225 /* uniform hemispherical projection */
226 r2 = uv[0]*uv[0] + uv[1]*uv[1];
227 vec[0] = vec[1] = sqrt(2. - r2);
228 vec[0] *= uv[0];
229 vec[1] *= uv[1];
230 vec[2] = output_orient*(1. - r2);
231 }
232
233 /* Compute grid position from normalized input/output vector */
234 void
235 pos_from_vec(int pos[2], const FVECT vec)
236 {
237 double sq[2]; /* uniform hemispherical projection */
238 double norm = 1./sqrt(1. + fabs(vec[2]));
239
240 SDdisk2square(sq, vec[0]*norm, vec[1]*norm);
241
242 pos[0] = (int)(sq[0]*grid_res);
243 pos[1] = (int)(sq[1]*grid_res);
244 }
245
246 /* Evaluate RBF for DSF at the given normalized outgoing direction */
247 double
248 eval_rbfrep(const RBFNODE *rp, const FVECT outvec)
249 {
250 double res = 0;
251 const RBFVAL *rbfp;
252 FVECT odir;
253 double sig2;
254 int n;
255 /* use minimum if no information avail. */
256 if (rp == NULL) {
257 if (outvec[2] > 0 ^ output_orient > 0)
258 return(.0);
259 return(bsdf_min*output_orient*outvec[2]);
260 }
261 rbfp = rp->rbfa;
262 for (n = rp->nrbf; n--; rbfp++) {
263 ovec_from_pos(odir, rbfp->gx, rbfp->gy);
264 sig2 = R2ANG(rbfp->crad);
265 sig2 = (DOT(odir,outvec) - 1.) / (sig2*sig2);
266 if (sig2 > -19.)
267 res += rbfp->peak * exp(sig2);
268 }
269 return(res);
270 }
271
272 /* Insert a new directional scattering function in our global list */
273 int
274 insert_dsf(RBFNODE *newrbf)
275 {
276 RBFNODE *rbf, *rbf_last;
277 int pos;
278 /* check for redundant meas. */
279 for (rbf = dsf_list; rbf != NULL; rbf = rbf->next)
280 if (DOT(rbf->invec, newrbf->invec) >= 1.-FTINY) {
281 fprintf(stderr,
282 "%s: Duplicate incident measurement (ignored)\n",
283 progname);
284 free(newrbf);
285 return(-1);
286 }
287 /* keep in ascending theta order */
288 for (rbf_last = NULL, rbf = dsf_list; rbf != NULL;
289 rbf_last = rbf, rbf = rbf->next)
290 if (single_plane_incident && input_orient*rbf->invec[2] <
291 input_orient*newrbf->invec[2])
292 break;
293 if (rbf_last == NULL) { /* insert new node in list */
294 newrbf->ord = 0;
295 newrbf->next = dsf_list;
296 dsf_list = newrbf;
297 } else {
298 newrbf->ord = rbf_last->ord + 1;
299 newrbf->next = rbf;
300 rbf_last->next = newrbf;
301 }
302 rbf_last = newrbf;
303 while (rbf != NULL) { /* update ordinal positions */
304 rbf->ord = rbf_last->ord + 1;
305 rbf_last = rbf;
306 rbf = rbf->next;
307 }
308 return(newrbf->ord);
309 }
310
311 /* Get the DSF indicated by its ordinal position */
312 RBFNODE *
313 get_dsf(int ord)
314 {
315 RBFNODE *rbf;
316
317 for (rbf = dsf_list; rbf != NULL; rbf = rbf->next)
318 if (rbf->ord == ord)
319 return(rbf);
320 return(NULL);
321 }
322
323 /* Get triangle surface orientation (unnormalized) */
324 void
325 tri_orient(FVECT vres, const FVECT v1, const FVECT v2, const FVECT v3)
326 {
327 FVECT v2minus1, v3minus2;
328
329 VSUB(v2minus1, v2, v1);
330 VSUB(v3minus2, v3, v2);
331 VCROSS(vres, v2minus1, v3minus2);
332 }
333
334 /* Determine if vertex order is reversed (inward normal) */
335 int
336 is_rev_tri(const FVECT v1, const FVECT v2, const FVECT v3)
337 {
338 FVECT tor;
339
340 tri_orient(tor, v1, v2, v3);
341
342 return(DOT(tor, v2) < 0.);
343 }
344
345 /* Find vertices completing triangles on either side of the given edge */
346 int
347 get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig)
348 {
349 const MIGRATION *ej1, *ej2;
350 RBFNODE *tv;
351
352 rbfv[0] = rbfv[1] = NULL;
353 if (mig == NULL)
354 return(0);
355 for (ej1 = mig->rbfv[0]->ejl; ej1 != NULL;
356 ej1 = nextedge(mig->rbfv[0],ej1)) {
357 if (ej1 == mig)
358 continue;
359 tv = opp_rbf(mig->rbfv[0],ej1);
360 for (ej2 = tv->ejl; ej2 != NULL; ej2 = nextedge(tv,ej2))
361 if (opp_rbf(tv,ej2) == mig->rbfv[1]) {
362 rbfv[is_rev_tri(mig->rbfv[0]->invec,
363 mig->rbfv[1]->invec,
364 tv->invec)] = tv;
365 break;
366 }
367 }
368 return((rbfv[0] != NULL) + (rbfv[1] != NULL));
369 }
370
371 /* Clear our BSDF representation and free memory */
372 void
373 clear_bsdf_rep(void)
374 {
375 while (mig_list != NULL) {
376 MIGRATION *mig = mig_list;
377 mig_list = mig->next;
378 free(mig);
379 }
380 while (dsf_list != NULL) {
381 RBFNODE *rbf = dsf_list;
382 dsf_list = rbf->next;
383 free(rbf);
384 }
385 inp_coverage = 0;
386 single_plane_incident = -1;
387 input_orient = output_orient = 0;
388 grid_res = GRIDRES;
389 }
390
391 /* Write our BSDF mesh interpolant out to the given binary stream */
392 void
393 save_bsdf_rep(FILE *ofp)
394 {
395 RBFNODE *rbf;
396 MIGRATION *mig;
397 int i, n;
398 /* finish header */
399 fprintf(ofp, "SYMMETRY=%d\n", !single_plane_incident * inp_coverage);
400 fprintf(ofp, "IO_SIDES= %d %d\n", input_orient, output_orient);
401 fprintf(ofp, "GRIDRES=%d\n", grid_res);
402 fprintf(ofp, "BSDFMIN=%g\n", bsdf_min);
403 fputformat(BSDFREP_FMT, ofp);
404 fputc('\n', ofp);
405 /* write each DSF */
406 for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) {
407 putint(rbf->ord, 4, ofp);
408 putflt(rbf->invec[0], ofp);
409 putflt(rbf->invec[1], ofp);
410 putflt(rbf->invec[2], ofp);
411 putflt(rbf->vtotal, ofp);
412 putint(rbf->nrbf, 4, ofp);
413 for (i = 0; i < rbf->nrbf; i++) {
414 putflt(rbf->rbfa[i].peak, ofp);
415 putint(rbf->rbfa[i].crad, 2, ofp);
416 putint(rbf->rbfa[i].gx, 1, ofp);
417 putint(rbf->rbfa[i].gy, 1, ofp);
418 }
419 }
420 putint(-1, 4, ofp); /* terminator */
421 /* write each migration matrix */
422 for (mig = mig_list; mig != NULL; mig = mig->next) {
423 int zerocnt = 0;
424 putint(mig->rbfv[0]->ord, 4, ofp);
425 putint(mig->rbfv[1]->ord, 4, ofp);
426 /* write out as sparse data */
427 n = mtx_nrows(mig) * mtx_ncols(mig);
428 for (i = 0; i < n; i++) {
429 if (zerocnt == 0xff) {
430 putint(0xff, 1, ofp); zerocnt = 0;
431 }
432 if (mig->mtx[i] != 0) {
433 putint(zerocnt, 1, ofp); zerocnt = 0;
434 putflt(mig->mtx[i], ofp);
435 } else
436 ++zerocnt;
437 }
438 putint(zerocnt, 1, ofp);
439 }
440 putint(-1, 4, ofp); /* terminator */
441 putint(-1, 4, ofp);
442 if (fflush(ofp) == EOF) {
443 fprintf(stderr, "%s: error writing BSDF interpolant\n",
444 progname);
445 exit(1);
446 }
447 }
448
449 /* Check header line for critical information */
450 static int
451 headline(char *s, void *p)
452 {
453 char fmt[32];
454
455 if (!strncmp(s, "SYMMETRY=", 9)) {
456 inp_coverage = atoi(s+9);
457 single_plane_incident = !inp_coverage;
458 return(0);
459 }
460 if (!strncmp(s, "IO_SIDES=", 9)) {
461 sscanf(s+9, "%d %d", &input_orient, &output_orient);
462 return(0);
463 }
464 if (!strncmp(s, "GRIDRES=", 8)) {
465 sscanf(s+8, "%d", &grid_res);
466 return(0);
467 }
468 if (!strncmp(s, "BSDFMIN=", 8)) {
469 sscanf(s+8, "%lf", &bsdf_min);
470 return(0);
471 }
472 if (formatval(fmt, s) && strcmp(fmt, BSDFREP_FMT))
473 return(-1);
474 return(0);
475 }
476
477 /* Read a BSDF mesh interpolant from the given binary stream */
478 int
479 load_bsdf_rep(FILE *ifp)
480 {
481 RBFNODE rbfh;
482 int from_ord, to_ord;
483 int i;
484
485 clear_bsdf_rep();
486 if (ifp == NULL)
487 return(0);
488 if (getheader(ifp, headline, NULL) < 0 || single_plane_incident < 0 |
489 !input_orient | !output_orient) {
490 fprintf(stderr, "%s: missing/bad format for BSDF interpolant\n",
491 progname);
492 return(0);
493 }
494 rbfh.next = NULL; /* read each DSF */
495 rbfh.ejl = NULL;
496 while ((rbfh.ord = getint(4, ifp)) >= 0) {
497 RBFNODE *newrbf;
498
499 rbfh.invec[0] = getflt(ifp);
500 rbfh.invec[1] = getflt(ifp);
501 rbfh.invec[2] = getflt(ifp);
502 if (normalize(rbfh.invec) == 0) {
503 fprintf(stderr, "%s: zero incident vector\n", progname);
504 return(0);
505 }
506 rbfh.vtotal = getflt(ifp);
507 rbfh.nrbf = getint(4, ifp);
508 newrbf = (RBFNODE *)malloc(sizeof(RBFNODE) +
509 sizeof(RBFVAL)*(rbfh.nrbf-1));
510 if (newrbf == NULL)
511 goto memerr;
512 memcpy(newrbf, &rbfh, sizeof(RBFNODE)-sizeof(RBFVAL));
513 for (i = 0; i < rbfh.nrbf; i++) {
514 newrbf->rbfa[i].peak = getflt(ifp);
515 newrbf->rbfa[i].crad = getint(2, ifp) & 0xffff;
516 newrbf->rbfa[i].gx = getint(1, ifp) & 0xff;
517 newrbf->rbfa[i].gy = getint(1, ifp) & 0xff;
518 }
519 if (feof(ifp))
520 goto badEOF;
521 /* insert in global list */
522 if (insert_dsf(newrbf) != rbfh.ord) {
523 fprintf(stderr, "%s: error adding DSF\n", progname);
524 return(0);
525 }
526 }
527 /* read each migration matrix */
528 while ((from_ord = getint(4, ifp)) >= 0 &&
529 (to_ord = getint(4, ifp)) >= 0) {
530 RBFNODE *from_rbf = get_dsf(from_ord);
531 RBFNODE *to_rbf = get_dsf(to_ord);
532 MIGRATION *newmig;
533 int n;
534
535 if ((from_rbf == NULL) | (to_rbf == NULL)) {
536 fprintf(stderr,
537 "%s: bad DSF reference in migration edge\n",
538 progname);
539 return(0);
540 }
541 n = from_rbf->nrbf * to_rbf->nrbf;
542 newmig = (MIGRATION *)malloc(sizeof(MIGRATION) +
543 sizeof(float)*(n-1));
544 if (newmig == NULL)
545 goto memerr;
546 newmig->rbfv[0] = from_rbf;
547 newmig->rbfv[1] = to_rbf;
548 memset(newmig->mtx, 0, sizeof(float)*n);
549 for (i = 0; ; ) { /* read sparse data */
550 int zc = getint(1, ifp) & 0xff;
551 if ((i += zc) >= n)
552 break;
553 if (zc == 0xff)
554 continue;
555 newmig->mtx[i++] = getflt(ifp);
556 }
557 if (feof(ifp))
558 goto badEOF;
559 /* insert in edge lists */
560 newmig->enxt[0] = from_rbf->ejl;
561 from_rbf->ejl = newmig;
562 newmig->enxt[1] = to_rbf->ejl;
563 to_rbf->ejl = newmig;
564 /* push onto global list */
565 newmig->next = mig_list;
566 mig_list = newmig;
567 }
568 return(1); /* success! */
569 memerr:
570 fprintf(stderr, "%s: Out of memory in load_bsdf_rep()\n", progname);
571 exit(1);
572 badEOF:
573 fprintf(stderr, "%s: Unexpected EOF in load_bsdf_rep()\n", progname);
574 return(0);
575 }
