Put angle normalization before test that assumes it
Minor changes should not affect results
Made check against non-rotation more robust
Minor fixes
Improved error message
Cleaned up compiler warning
Eliminated redundant code added in last change to bsdfmesh.c
Minor change should not affect operation
Sped up convergence on large systems by almost 3x
Sped up RBF evaluation by about a factor of 4
Improved estimate of integrated Gaussian lobe using horizon cut-off
Make sure not to output less than diffuse minimum
Minor efficiency improvement
Tried to improve convergence of RBF fit
Added data to complete XML file output
Took sort out so it is done only once
Added GRIDRES to saved BSDF representation
Hopeful bug fix in BSDF interpolation code
Bug fixes in loading BSDF interpolant data
Bug fixes and minor improvements
