| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: bsdfrep.c,v 2.27 2014/08/22 05:38:44 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Support BSDF representation as radial basis functions.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#define _USE_MATH_DEFINES
| 11 |
#include <stdlib.h>
| 12 |
#include <string.h>
| 13 |
#include <math.h>
| 14 |
#include "rtio.h"
| 15 |
#include "resolu.h"
| 16 |
#include "bsdfrep.h"
| 17 |
/* name and manufacturer if known */
| 18 |
char bsdf_name[256];
| 19 |
char bsdf_manuf[256];
| 20 |
/* active grid resolution */
| 21 |
int grid_res = GRIDRES;
| 22 |
| 23 |
/* coverage/symmetry using INP_QUAD? flags */
| 24 |
int inp_coverage = 0;
| 25 |
/* all incident angles in-plane so far? */
| 26 |
int single_plane_incident = -1;
| 27 |
| 28 |
/* input/output orientations */
| 29 |
int input_orient = 0;
| 30 |
int output_orient = 0;
| 31 |
| 32 |
/* BSDF histogram */
| 33 |
unsigned long bsdf_hist[HISTLEN];
| 34 |
| 35 |
/* BSDF value for boundary regions */
| 36 |
double bsdf_min = 0;
| 37 |
double bsdf_spec_peak = 0;
| 38 |
double bsdf_spec_rad = 0;
| 39 |
| 40 |
/* processed incident DSF measurements */
| 41 |
RBFNODE *dsf_list = NULL;
| 42 |
| 43 |
/* RBF-linking matrices (edges) */
| 44 |
MIGRATION *mig_list = NULL;
| 45 |
| 46 |
/* current input direction */
| 47 |
double theta_in_deg, phi_in_deg;
| 48 |
| 49 |
/* Register new input direction */
| 50 |
int
| 51 |
new_input_direction(double new_theta, double new_phi)
| 52 |
| 53 |
/* normalize angle ranges */
| 54 |
while (new_theta < -180.)
| 55 |
new_theta += 360.;
| 56 |
while (new_theta > 180.)
| 57 |
new_theta -= 360.;
| 58 |
if (new_theta < 0) {
| 59 |
new_theta = -new_theta;
| 60 |
new_phi += 180.;
| 61 |
| 62 |
while (new_phi < 0)
| 63 |
new_phi += 360.;
| 64 |
while (new_phi >= 360.)
| 65 |
new_phi -= 360.;
| 66 |
/* check input orientation */
| 67 |
if (!input_orient)
| 68 |
input_orient = 1 - 2*(new_theta > 90.);
| 69 |
else if (input_orient > 0 ^ new_theta < 90.) {
| 70 |
fprintf(stderr,
| 71 |
"%s: Cannot handle input angles on both sides of surface\n",
| 72 |
progname);
| 73 |
return(0);
| 74 |
| 75 |
if ((theta_in_deg = new_theta) < 1.0)
| 76 |
return(1); /* don't rely on phi near normal */
| 77 |
if (single_plane_incident > 0) /* check input coverage */
| 78 |
single_plane_incident = (round(new_phi) == round(phi_in_deg));
| 79 |
else if (single_plane_incident < 0)
| 80 |
single_plane_incident = 1;
| 81 |
phi_in_deg = new_phi;
| 82 |
if ((1. < new_phi) & (new_phi < 89.))
| 83 |
inp_coverage |= INP_QUAD1;
| 84 |
else if ((91. < new_phi) & (new_phi < 179.))
| 85 |
inp_coverage |= INP_QUAD2;
| 86 |
else if ((181. < new_phi) & (new_phi < 269.))
| 87 |
inp_coverage |= INP_QUAD3;
| 88 |
else if ((271. < new_phi) & (new_phi < 359.))
| 89 |
inp_coverage |= INP_QUAD4;
| 90 |
return(1);
| 91 |
| 92 |
| 93 |
/* Apply symmetry to the given vector based on distribution */
| 94 |
int
| 95 |
use_symmetry(FVECT vec)
| 96 |
| 97 |
const double phi = get_phi360(vec);
| 98 |
| 99 |
switch (inp_coverage) {
| 100 |
case INP_QUAD1|INP_QUAD2|INP_QUAD3|INP_QUAD4:
| 101 |
break;
| 102 |
case INP_QUAD1|INP_QUAD2:
| 103 |
if ((-FTINY > phi) | (phi > 180.+FTINY))
| 104 |
goto mir_y;
| 105 |
break;
| 106 |
case INP_QUAD2|INP_QUAD3:
| 107 |
if ((90.-FTINY > phi) | (phi > 270.+FTINY))
| 108 |
goto mir_x;
| 109 |
break;
| 110 |
case INP_QUAD3|INP_QUAD4:
| 111 |
if ((180.-FTINY > phi) | (phi > 360.+FTINY))
| 112 |
goto mir_y;
| 113 |
break;
| 114 |
case INP_QUAD4|INP_QUAD1:
| 115 |
if ((270.-FTINY > phi) & (phi > 90.+FTINY))
| 116 |
goto mir_x;
| 117 |
break;
| 118 |
case INP_QUAD1:
| 119 |
if ((-FTINY > phi) | (phi > 90.+FTINY))
| 120 |
switch ((int)(phi*(1./90.))) {
| 121 |
case 1: goto mir_x;
| 122 |
case 2: goto mir_xy;
| 123 |
case 3: goto mir_y;
| 124 |
| 125 |
break;
| 126 |
case INP_QUAD2:
| 127 |
if ((90.-FTINY > phi) | (phi > 180.+FTINY))
| 128 |
| 129 |
case 0: goto mir_x;
| 130 |
case 2: goto mir_y;
| 131 |
case 3: goto mir_xy;
| 132 |
| 133 |
break;
| 134 |
case INP_QUAD3:
| 135 |
if ((180.-FTINY > phi) | (phi > 270.+FTINY))
| 136 |
| 137 |
case 0: goto mir_xy;
| 138 |
case 1: goto mir_y;
| 139 |
case 3: goto mir_x;
| 140 |
| 141 |
break;
| 142 |
case INP_QUAD4:
| 143 |
if ((270.-FTINY > phi) | (phi > 360.+FTINY))
| 144 |
| 145 |
case 0: goto mir_y;
| 146 |
case 1: goto mir_xy;
| 147 |
case 2: goto mir_x;
| 148 |
| 149 |
break;
| 150 |
default:
| 151 |
fprintf(stderr, "%s: Illegal input coverage (%d)\n",
| 152 |
progname, inp_coverage);
| 153 |
exit(1);
| 154 |
| 155 |
return(0); /* in range */
| 156 |
mir_x:
| 157 |
vec[0] = -vec[0];
| 158 |
return(MIRROR_X);
| 159 |
mir_y:
| 160 |
vec[1] = -vec[1];
| 161 |
return(MIRROR_Y);
| 162 |
mir_xy:
| 163 |
vec[0] = -vec[0];
| 164 |
vec[1] = -vec[1];
| 165 |
return(MIRROR_X|MIRROR_Y);
| 166 |
| 167 |
| 168 |
/* Reverse symmetry based on what was done before */
| 169 |
void
| 170 |
rev_symmetry(FVECT vec, int sym)
| 171 |
| 172 |
if (sym & MIRROR_X)
| 173 |
vec[0] = -vec[0];
| 174 |
if (sym & MIRROR_Y)
| 175 |
vec[1] = -vec[1];
| 176 |
| 177 |
| 178 |
/* Reverse symmetry for an RBF distribution */
| 179 |
void
| 180 |
rev_rbf_symmetry(RBFNODE *rbf, int sym)
| 181 |
| 182 |
int n;
| 183 |
| 184 |
rev_symmetry(rbf->invec, sym);
| 185 |
if (sym & MIRROR_X)
| 186 |
for (n = rbf->nrbf; n-- > 0; )
| 187 |
rbf->rbfa[n].gx = grid_res-1 - rbf->rbfa[n].gx;
| 188 |
if (sym & MIRROR_Y)
| 189 |
| 190 |
rbf->rbfa[n].gy = grid_res-1 - rbf->rbfa[n].gy;
| 191 |
| 192 |
| 193 |
/* Rotate RBF to correspond to given incident vector */
| 194 |
void
| 195 |
rotate_rbf(RBFNODE *rbf, const FVECT invec)
| 196 |
| 197 |
static const FVECT vnorm = {.0, .0, 1.};
| 198 |
const double phi = atan2(invec[1],invec[0]) -
| 199 |
atan2(rbf->invec[1],rbf->invec[0]);
| 200 |
FVECT outvec;
| 201 |
int pos[2];
| 202 |
int n;
| 203 |
| 204 |
for (n = (cos(phi) < 1.-FTINY)*rbf->nrbf; n-- > 0; ) {
| 205 |
ovec_from_pos(outvec, rbf->rbfa[n].gx, rbf->rbfa[n].gy);
| 206 |
spinvector(outvec, outvec, vnorm, phi);
| 207 |
pos_from_vec(pos, outvec);
| 208 |
rbf->rbfa[n].gx = pos[0];
| 209 |
rbf->rbfa[n].gy = pos[1];
| 210 |
| 211 |
VCOPY(rbf->invec, invec);
| 212 |
| 213 |
| 214 |
/* Compute outgoing vector from grid position */
| 215 |
void
| 216 |
ovec_from_pos(FVECT vec, int xpos, int ypos)
| 217 |
| 218 |
double uv[2];
| 219 |
double r2;
| 220 |
| 221 |
SDsquare2disk(uv, (xpos+.5)/grid_res, (ypos+.5)/grid_res);
| 222 |
/* uniform hemispherical projection */
| 223 |
r2 = uv[0]*uv[0] + uv[1]*uv[1];
| 224 |
vec[0] = vec[1] = sqrt(2. - r2);
| 225 |
vec[0] *= uv[0];
| 226 |
vec[1] *= uv[1];
| 227 |
vec[2] = output_orient*(1. - r2);
| 228 |
| 229 |
| 230 |
/* Compute grid position from normalized input/output vector */
| 231 |
void
| 232 |
pos_from_vec(int pos[2], const FVECT vec)
| 233 |
| 234 |
double sq[2]; /* uniform hemispherical projection */
| 235 |
double norm = 1./sqrt(1. + fabs(vec[2]));
| 236 |
| 237 |
SDdisk2square(sq, vec[0]*norm, vec[1]*norm);
| 238 |
| 239 |
pos[0] = (int)(sq[0]*grid_res);
| 240 |
pos[1] = (int)(sq[1]*grid_res);
| 241 |
| 242 |
| 243 |
/* Compute volume associated with Gaussian lobe */
| 244 |
double
| 245 |
rbf_volume(const RBFVAL *rbfp)
| 246 |
| 247 |
double rad = R2ANG(rbfp->crad);
| 248 |
FVECT odir;
| 249 |
double elev, integ;
| 250 |
/* infinite integral approximation */
| 251 |
integ = (2.*M_PI) * rbfp->peak * rad*rad;
| 252 |
/* check if we're near horizon */
| 253 |
ovec_from_pos(odir, rbfp->gx, rbfp->gy);
| 254 |
elev = output_orient*odir[2];
| 255 |
/* apply cut-off correction if > 1% */
| 256 |
if (elev < 2.8*rad) {
| 257 |
/* elev = asin(elev); /* this is so crude, anyway... */
| 258 |
integ *= 1. - .5*exp(-.5*elev*elev/(rad*rad));
| 259 |
| 260 |
return(integ);
| 261 |
| 262 |
| 263 |
/* Evaluate BSDF at the given normalized outgoing direction */
| 264 |
double
| 265 |
eval_rbfrep(const RBFNODE *rp, const FVECT outvec)
| 266 |
| 267 |
const double rfact2 = (38./M_PI/M_PI)*(grid_res*grid_res);
| 268 |
int pos[2];
| 269 |
double res = 0;
| 270 |
const RBFVAL *rbfp;
| 271 |
FVECT odir;
| 272 |
double rad2;
| 273 |
int n;
| 274 |
/* check for wrong side */
| 275 |
if (outvec[2] > 0 ^ output_orient > 0)
| 276 |
return(.0);
| 277 |
/* use minimum if no information avail. */
| 278 |
if (rp == NULL)
| 279 |
return(bsdf_min);
| 280 |
/* optimization for fast lobe culling */
| 281 |
| 282 |
/* sum radial basis function */
| 283 |
rbfp = rp->rbfa;
| 284 |
for (n = rp->nrbf; n--; rbfp++) {
| 285 |
int d2 = (pos[0]-rbfp->gx)*(pos[0]-rbfp->gx) +
| 286 |
(pos[1]-rbfp->gy)*(pos[1]-rbfp->gy);
| 287 |
rad2 = R2ANG(rbfp->crad);
| 288 |
rad2 *= rad2;
| 289 |
if (d2 > rad2*rfact2)
| 290 |
continue;
| 291 |
| 292 |
res += rbfp->peak * exp((DOT(odir,outvec) - 1.) / rad2);
| 293 |
| 294 |
res /= COSF(outvec[2]);
| 295 |
if (res < bsdf_min) /* never return less than bsdf_min */
| 296 |
return(bsdf_min);
| 297 |
return(res);
| 298 |
| 299 |
| 300 |
/* Insert a new directional scattering function in our global list */
| 301 |
int
| 302 |
insert_dsf(RBFNODE *newrbf)
| 303 |
| 304 |
RBFNODE *rbf, *rbf_last;
| 305 |
int pos;
| 306 |
/* check for redundant meas. */
| 307 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next)
| 308 |
if (DOT(rbf->invec, newrbf->invec) >= 1.-FTINY) {
| 309 |
fprintf(stderr,
| 310 |
"%s: Duplicate incident measurement ignored at (%.1f,%.1f)\n",
| 311 |
progname, get_theta180(newrbf->invec),
| 312 |
get_phi360(newrbf->invec));
| 313 |
free(newrbf);
| 314 |
return(-1);
| 315 |
| 316 |
/* keep in ascending theta order */
| 317 |
for (rbf_last = NULL, rbf = dsf_list; rbf != NULL;
| 318 |
rbf_last = rbf, rbf = rbf->next)
| 319 |
if (single_plane_incident && input_orient*rbf->invec[2] <
| 320 |
input_orient*newrbf->invec[2])
| 321 |
break;
| 322 |
if (rbf_last == NULL) { /* insert new node in list */
| 323 |
newrbf->ord = 0;
| 324 |
newrbf->next = dsf_list;
| 325 |
dsf_list = newrbf;
| 326 |
} else {
| 327 |
newrbf->ord = rbf_last->ord + 1;
| 328 |
newrbf->next = rbf;
| 329 |
rbf_last->next = newrbf;
| 330 |
| 331 |
rbf_last = newrbf;
| 332 |
while (rbf != NULL) { /* update ordinal positions */
| 333 |
| 334 |
rbf_last = rbf;
| 335 |
rbf = rbf->next;
| 336 |
| 337 |
return(newrbf->ord);
| 338 |
| 339 |
| 340 |
/* Get the DSF indicated by its ordinal position */
| 341 |
RBFNODE *
| 342 |
get_dsf(int ord)
| 343 |
| 344 |
RBFNODE *rbf;
| 345 |
| 346 |
| 347 |
if (rbf->ord == ord)
| 348 |
return(rbf);
| 349 |
return(NULL);
| 350 |
| 351 |
| 352 |
/* Get triangle surface orientation (unnormalized) */
| 353 |
void
| 354 |
tri_orient(FVECT vres, const FVECT v1, const FVECT v2, const FVECT v3)
| 355 |
| 356 |
FVECT v2minus1, v3minus2;
| 357 |
| 358 |
VSUB(v2minus1, v2, v1);
| 359 |
VSUB(v3minus2, v3, v2);
| 360 |
VCROSS(vres, v2minus1, v3minus2);
| 361 |
| 362 |
| 363 |
/* Determine if vertex order is reversed (inward normal) */
| 364 |
int
| 365 |
is_rev_tri(const FVECT v1, const FVECT v2, const FVECT v3)
| 366 |
| 367 |
FVECT tor;
| 368 |
| 369 |
tri_orient(tor, v1, v2, v3);
| 370 |
| 371 |
return(DOT(tor, v2) < 0.);
| 372 |
| 373 |
| 374 |
/* Find vertices completing triangles on either side of the given edge */
| 375 |
int
| 376 |
get_triangles(RBFNODE *rbfv[2], const MIGRATION *mig)
| 377 |
| 378 |
const MIGRATION *ej1, *ej2;
| 379 |
RBFNODE *tv;
| 380 |
| 381 |
rbfv[0] = rbfv[1] = NULL;
| 382 |
if (mig == NULL)
| 383 |
return(0);
| 384 |
for (ej1 = mig->rbfv[0]->ejl; ej1 != NULL;
| 385 |
ej1 = nextedge(mig->rbfv[0],ej1)) {
| 386 |
if (ej1 == mig)
| 387 |
continue;
| 388 |
tv = opp_rbf(mig->rbfv[0],ej1);
| 389 |
for (ej2 = tv->ejl; ej2 != NULL; ej2 = nextedge(tv,ej2))
| 390 |
if (opp_rbf(tv,ej2) == mig->rbfv[1]) {
| 391 |
rbfv[is_rev_tri(mig->rbfv[0]->invec,
| 392 |
mig->rbfv[1]->invec,
| 393 |
tv->invec)] = tv;
| 394 |
break;
| 395 |
| 396 |
| 397 |
return((rbfv[0] != NULL) + (rbfv[1] != NULL));
| 398 |
| 399 |
| 400 |
/* Return single-lobe specular RBF for the given incident direction */
| 401 |
RBFNODE *
| 402 |
def_rbf_spec(const FVECT invec)
| 403 |
| 404 |
RBFNODE *rbf;
| 405 |
FVECT ovec;
| 406 |
int pos[2];
| 407 |
| 408 |
if (input_orient > 0 ^ invec[2] > 0) /* wrong side? */
| 409 |
return(NULL);
| 410 |
if ((bsdf_spec_peak <= bsdf_min) | (bsdf_spec_rad <= 0))
| 411 |
return(NULL); /* nothing set */
| 412 |
rbf = (RBFNODE *)malloc(sizeof(RBFNODE));
| 413 |
if (rbf == NULL)
| 414 |
return(NULL);
| 415 |
ovec[0] = -invec[0];
| 416 |
ovec[1] = -invec[1];
| 417 |
ovec[2] = invec[2]*(2*(input_orient==output_orient) - 1);
| 418 |
pos_from_vec(pos, ovec);
| 419 |
rbf->ord = 0;
| 420 |
rbf->next = NULL;
| 421 |
rbf->ejl = NULL;
| 422 |
| 423 |
rbf->nrbf = 1;
| 424 |
rbf->rbfa[0].peak = bsdf_spec_peak * output_orient*ovec[2];
| 425 |
rbf->rbfa[0].crad = ANG2R(bsdf_spec_rad);
| 426 |
rbf->rbfa[0].gx = pos[0];
| 427 |
rbf->rbfa[0].gy = pos[1];
| 428 |
rbf->vtotal = rbf_volume(rbf->rbfa);
| 429 |
return(rbf);
| 430 |
| 431 |
| 432 |
/* Advect and allocate new RBF along edge (internal call) */
| 433 |
RBFNODE *
| 434 |
e_advect_rbf(const MIGRATION *mig, const FVECT invec, int lobe_lim)
| 435 |
| 436 |
double cthresh = FTINY;
| 437 |
RBFNODE *rbf;
| 438 |
int n, i, j;
| 439 |
double t, full_dist;
| 440 |
/* get relative position */
| 441 |
t = Acos(DOT(invec, mig->rbfv[0]->invec));
| 442 |
if (t < M_PI/grid_res) { /* near first DSF */
| 443 |
n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[0]->nrbf-1);
| 444 |
rbf = (RBFNODE *)malloc(n);
| 445 |
if (rbf == NULL)
| 446 |
goto memerr;
| 447 |
memcpy(rbf, mig->rbfv[0], n); /* just duplicate */
| 448 |
rbf->next = NULL; rbf->ejl = NULL;
| 449 |
return(rbf);
| 450 |
| 451 |
full_dist = acos(DOT(mig->rbfv[0]->invec, mig->rbfv[1]->invec));
| 452 |
if (t > full_dist-M_PI/grid_res) { /* near second DSF */
| 453 |
n = sizeof(RBFNODE) + sizeof(RBFVAL)*(mig->rbfv[1]->nrbf-1);
| 454 |
| 455 |
if (rbf == NULL)
| 456 |
goto memerr;
| 457 |
memcpy(rbf, mig->rbfv[1], n); /* just duplicate */
| 458 |
| 459 |
return(rbf);
| 460 |
| 461 |
t /= full_dist;
| 462 |
tryagain:
| 463 |
n = 0; /* count migrating particles */
| 464 |
for (i = 0; i < mtx_nrows(mig); i++)
| 465 |
for (j = 0; j < mtx_ncols(mig); j++)
| 466 |
n += (mtx_coef(mig,i,j) > cthresh);
| 467 |
/* are we over our limit? */
| 468 |
if ((lobe_lim > 0) & (n > lobe_lim)) {
| 469 |
cthresh = cthresh*2. + 10.*FTINY;
| 470 |
goto tryagain;
| 471 |
| 472 |
#ifdef DEBUG
| 473 |
fprintf(stderr, "Input RBFs have %d, %d nodes -> output has %d\n",
| 474 |
mig->rbfv[0]->nrbf, mig->rbfv[1]->nrbf, n);
| 475 |
#endif
| 476 |
rbf = (RBFNODE *)malloc(sizeof(RBFNODE) + sizeof(RBFVAL)*(n-1));
| 477 |
if (rbf == NULL)
| 478 |
goto memerr;
| 479 |
| 480 |
| 481 |
rbf->nrbf = n;
| 482 |
rbf->vtotal = 1.-t + t*mig->rbfv[1]->vtotal/mig->rbfv[0]->vtotal;
| 483 |
n = 0; /* advect RBF lobes */
| 484 |
for (i = 0; i < mtx_nrows(mig); i++) {
| 485 |
const RBFVAL *rbf0i = &mig->rbfv[0]->rbfa[i];
| 486 |
const float peak0 = rbf0i->peak;
| 487 |
const double rad0 = R2ANG(rbf0i->crad);
| 488 |
FVECT v0;
| 489 |
float mv;
| 490 |
ovec_from_pos(v0, rbf0i->gx, rbf0i->gy);
| 491 |
| 492 |
if ((mv = mtx_coef(mig,i,j)) > cthresh) {
| 493 |
const RBFVAL *rbf1j = &mig->rbfv[1]->rbfa[j];
| 494 |
double rad2;
| 495 |
FVECT v;
| 496 |
int pos[2];
| 497 |
rad2 = R2ANG(rbf1j->crad);
| 498 |
rad2 = rad0*rad0*(1.-t) + rad2*rad2*t;
| 499 |
rbf->rbfa[n].peak = peak0 * mv * rbf->vtotal *
| 500 |
rad0*rad0/rad2;
| 501 |
rbf->rbfa[n].crad = ANG2R(sqrt(rad2));
| 502 |
ovec_from_pos(v, rbf1j->gx, rbf1j->gy);
| 503 |
geodesic(v, v0, v, t, GEOD_REL);
| 504 |
pos_from_vec(pos, v);
| 505 |
| 506 |
| 507 |
++n;
| 508 |
| 509 |
| 510 |
rbf->vtotal *= mig->rbfv[0]->vtotal; /* turn ratio into actual */
| 511 |
return(rbf);
| 512 |
memerr:
| 513 |
fprintf(stderr, "%s: Out of memory in e_advect_rbf()\n", progname);
| 514 |
exit(1);
| 515 |
return(NULL); /* pro forma return */
| 516 |
| 517 |
| 518 |
/* Clear our BSDF representation and free memory */
| 519 |
void
| 520 |
clear_bsdf_rep(void)
| 521 |
| 522 |
while (mig_list != NULL) {
| 523 |
MIGRATION *mig = mig_list;
| 524 |
mig_list = mig->next;
| 525 |
free(mig);
| 526 |
| 527 |
while (dsf_list != NULL) {
| 528 |
RBFNODE *rbf = dsf_list;
| 529 |
dsf_list = rbf->next;
| 530 |
free(rbf);
| 531 |
| 532 |
bsdf_name[0] = '\0';
| 533 |
bsdf_manuf[0] = '\0';
| 534 |
inp_coverage = 0;
| 535 |
| 536 |
input_orient = output_orient = 0;
| 537 |
grid_res = GRIDRES;
| 538 |
bsdf_min = 0;
| 539 |
bsdf_spec_peak = 0;
| 540 |
bsdf_spec_rad = 0;
| 541 |
| 542 |
| 543 |
/* Write our BSDF mesh interpolant out to the given binary stream */
| 544 |
void
| 545 |
save_bsdf_rep(FILE *ofp)
| 546 |
| 547 |
RBFNODE *rbf;
| 548 |
MIGRATION *mig;
| 549 |
int i, n;
| 550 |
/* finish header */
| 551 |
if (bsdf_name[0])
| 552 |
fprintf(ofp, "NAME=%s\n", bsdf_name);
| 553 |
if (bsdf_manuf[0])
| 554 |
fprintf(ofp, "MANUFACT=%s\n", bsdf_manuf);
| 555 |
fprintf(ofp, "SYMMETRY=%d\n", !single_plane_incident * inp_coverage);
| 556 |
fprintf(ofp, "IO_SIDES= %d %d\n", input_orient, output_orient);
| 557 |
fprintf(ofp, "GRIDRES=%d\n", grid_res);
| 558 |
fprintf(ofp, "BSDFMIN=%g\n", bsdf_min);
| 559 |
if ((bsdf_spec_peak > bsdf_min) & (bsdf_spec_rad > 0))
| 560 |
fprintf(ofp, "BSDFSPEC= %f %f\n", bsdf_spec_peak, bsdf_spec_rad);
| 561 |
fputformat(BSDFREP_FMT, ofp);
| 562 |
fputc('\n', ofp);
| 563 |
/* write each DSF */
| 564 |
for (rbf = dsf_list; rbf != NULL; rbf = rbf->next) {
| 565 |
putint(rbf->ord, 4, ofp);
| 566 |
putflt(rbf->invec[0], ofp);
| 567 |
putflt(rbf->invec[1], ofp);
| 568 |
putflt(rbf->invec[2], ofp);
| 569 |
putflt(rbf->vtotal, ofp);
| 570 |
putint(rbf->nrbf, 4, ofp);
| 571 |
for (i = 0; i < rbf->nrbf; i++) {
| 572 |
putflt(rbf->rbfa[i].peak, ofp);
| 573 |
putint(rbf->rbfa[i].crad, 2, ofp);
| 574 |
putint(rbf->rbfa[i].gx, 1, ofp);
| 575 |
putint(rbf->rbfa[i].gy, 1, ofp);
| 576 |
| 577 |
| 578 |
putint(-1, 4, ofp); /* terminator */
| 579 |
/* write each migration matrix */
| 580 |
for (mig = mig_list; mig != NULL; mig = mig->next) {
| 581 |
int zerocnt = 0;
| 582 |
putint(mig->rbfv[0]->ord, 4, ofp);
| 583 |
putint(mig->rbfv[1]->ord, 4, ofp);
| 584 |
/* write out as sparse data */
| 585 |
n = mtx_nrows(mig) * mtx_ncols(mig);
| 586 |
for (i = 0; i < n; i++) {
| 587 |
if (zerocnt == 0xff) {
| 588 |
putint(0xff, 1, ofp); zerocnt = 0;
| 589 |
| 590 |
if (mig->mtx[i] != 0) {
| 591 |
putint(zerocnt, 1, ofp); zerocnt = 0;
| 592 |
putflt(mig->mtx[i], ofp);
| 593 |
} else
| 594 |
++zerocnt;
| 595 |
| 596 |
| 597 |
| 598 |
| 599 |
putint(-1, 4, ofp);
| 600 |
if (fflush(ofp) == EOF) {
| 601 |
fprintf(stderr, "%s: error writing BSDF interpolant\n",
| 602 |
progname);
| 603 |
exit(1);
| 604 |
| 605 |
| 606 |
| 607 |
/* Check header line for critical information */
| 608 |
static int
| 609 |
headline(char *s, void *p)
| 610 |
| 611 |
char fmt[32];
| 612 |
| 613 |
if (!strncmp(s, "NAME=", 5)) {
| 614 |
strcpy(bsdf_name, s+5);
| 615 |
bsdf_name[strlen(bsdf_name)-1] = '\0';
| 616 |
| 617 |
if (!strncmp(s, "MANUFACT=", 9)) {
| 618 |
strcpy(bsdf_manuf, s+9);
| 619 |
bsdf_manuf[strlen(bsdf_manuf)-1] = '\0';
| 620 |
| 621 |
if (!strncmp(s, "SYMMETRY=", 9)) {
| 622 |
inp_coverage = atoi(s+9);
| 623 |
single_plane_incident = !inp_coverage;
| 624 |
return(0);
| 625 |
| 626 |
if (!strncmp(s, "IO_SIDES=", 9)) {
| 627 |
sscanf(s+9, "%d %d", &input_orient, &output_orient);
| 628 |
return(0);
| 629 |
| 630 |
if (!strncmp(s, "GRIDRES=", 8)) {
| 631 |
sscanf(s+8, "%d", &grid_res);
| 632 |
return(0);
| 633 |
| 634 |
if (!strncmp(s, "BSDFMIN=", 8)) {
| 635 |
sscanf(s+8, "%lf", &bsdf_min);
| 636 |
return(0);
| 637 |
| 638 |
if (!strncmp(s, "BSDFSPEC=", 9)) {
| 639 |
sscanf(s+9, "%lf %lf", &bsdf_spec_peak, &bsdf_spec_rad);
| 640 |
return(0);
| 641 |
| 642 |
if (formatval(fmt, s) && strcmp(fmt, BSDFREP_FMT))
| 643 |
return(-1);
| 644 |
return(0);
| 645 |
| 646 |
| 647 |
/* Read a BSDF mesh interpolant from the given binary stream */
| 648 |
int
| 649 |
load_bsdf_rep(FILE *ifp)
| 650 |
| 651 |
RBFNODE rbfh;
| 652 |
int from_ord, to_ord;
| 653 |
int i;
| 654 |
| 655 |
clear_bsdf_rep();
| 656 |
if (ifp == NULL)
| 657 |
return(0);
| 658 |
if (getheader(ifp, headline, NULL) < 0 || (single_plane_incident < 0) |
| 659 |
!input_orient | !output_orient |
| 660 |
(grid_res < 16) | (grid_res > 256)) {
| 661 |
fprintf(stderr, "%s: missing/bad format for BSDF interpolant\n",
| 662 |
progname);
| 663 |
return(0);
| 664 |
| 665 |
memset(&rbfh, 0, sizeof(rbfh)); /* read each DSF */
| 666 |
while ((rbfh.ord = getint(4, ifp)) >= 0) {
| 667 |
RBFNODE *newrbf;
| 668 |
| 669 |
rbfh.invec[0] = getflt(ifp);
| 670 |
rbfh.invec[1] = getflt(ifp);
| 671 |
rbfh.invec[2] = getflt(ifp);
| 672 |
if (normalize(rbfh.invec) == 0) {
| 673 |
fprintf(stderr, "%s: zero incident vector\n", progname);
| 674 |
return(0);
| 675 |
| 676 |
rbfh.vtotal = getflt(ifp);
| 677 |
rbfh.nrbf = getint(4, ifp);
| 678 |
newrbf = (RBFNODE *)malloc(sizeof(RBFNODE) +
| 679 |
sizeof(RBFVAL)*(rbfh.nrbf-1));
| 680 |
if (newrbf == NULL)
| 681 |
goto memerr;
| 682 |
*newrbf = rbfh;
| 683 |
for (i = 0; i < rbfh.nrbf; i++) {
| 684 |
newrbf->rbfa[i].peak = getflt(ifp);
| 685 |
newrbf->rbfa[i].crad = getint(2, ifp) & 0xffff;
| 686 |
newrbf->rbfa[i].gx = getint(1, ifp) & 0xff;
| 687 |
newrbf->rbfa[i].gy = getint(1, ifp) & 0xff;
| 688 |
| 689 |
if (feof(ifp))
| 690 |
goto badEOF;
| 691 |
/* insert in global list */
| 692 |
if (insert_dsf(newrbf) != rbfh.ord) {
| 693 |
fprintf(stderr, "%s: error adding DSF\n", progname);
| 694 |
return(0);
| 695 |
| 696 |
| 697 |
/* read each migration matrix */
| 698 |
while ((from_ord = getint(4, ifp)) >= 0 &&
| 699 |
(to_ord = getint(4, ifp)) >= 0) {
| 700 |
RBFNODE *from_rbf = get_dsf(from_ord);
| 701 |
RBFNODE *to_rbf = get_dsf(to_ord);
| 702 |
MIGRATION *newmig;
| 703 |
int n;
| 704 |
| 705 |
if ((from_rbf == NULL) | (to_rbf == NULL)) {
| 706 |
fprintf(stderr,
| 707 |
"%s: bad DSF reference in migration edge\n",
| 708 |
progname);
| 709 |
return(0);
| 710 |
| 711 |
n = from_rbf->nrbf * to_rbf->nrbf;
| 712 |
newmig = (MIGRATION *)malloc(sizeof(MIGRATION) +
| 713 |
sizeof(float)*(n-1));
| 714 |
if (newmig == NULL)
| 715 |
goto memerr;
| 716 |
newmig->rbfv[0] = from_rbf;
| 717 |
newmig->rbfv[1] = to_rbf;
| 718 |
memset(newmig->mtx, 0, sizeof(float)*n);
| 719 |
for (i = 0; ; ) { /* read sparse data */
| 720 |
int zc = getint(1, ifp) & 0xff;
| 721 |
if ((i += zc) >= n)
| 722 |
break;
| 723 |
if (zc == 0xff)
| 724 |
continue;
| 725 |
newmig->mtx[i++] = getflt(ifp);
| 726 |
| 727 |
if (feof(ifp))
| 728 |
goto badEOF;
| 729 |
/* insert in edge lists */
| 730 |
newmig->enxt[0] = from_rbf->ejl;
| 731 |
from_rbf->ejl = newmig;
| 732 |
newmig->enxt[1] = to_rbf->ejl;
| 733 |
to_rbf->ejl = newmig;
| 734 |
/* push onto global list */
| 735 |
newmig->next = mig_list;
| 736 |
mig_list = newmig;
| 737 |
| 738 |
return(1); /* success! */
| 739 |
memerr:
| 740 |
fprintf(stderr, "%s: Out of memory in load_bsdf_rep()\n", progname);
| 741 |
exit(1);
| 742 |
badEOF:
| 743 |
fprintf(stderr, "%s: Unexpected EOF in load_bsdf_rep()\n", progname);
| 744 |
return(0);
| 745 |
