perf(bsdf2klems,bsdf2ttree): Improved evaluation speed by 40% using 128K table
refactor: removed prefix from SDdisk2square() and SDsquare2disk() & made consistent
fix(bsdfquery): literal edge case causing interpolation to fail
fix(bsdf2ttree, bsdf2klems): reduced threshold to avoid "sticking" behavior in interpolant
feat(bsdf2klems, bsdf2ttree): added XML header comments copying useful information from SIR inputs
Return minimum BSDF value as gray
Improved grazing lobe estimation by using lowest 25% of DSFs
Put angle normalization before test that assumes it
Minor changes should not affect results
Made check against non-rotation more robust
Minor fixes
Improved error message
Cleaned up compiler warning
Eliminated redundant code added in last change to bsdfmesh.c
Minor change should not affect operation
Sped up convergence on large systems by almost 3x
Sped up RBF evaluation by about a factor of 4
Improved estimate of integrated Gaussian lobe using horizon cut-off
Make sure not to output less than diffuse minimum
Minor efficiency improvement
Tried to improve convergence of RBF fit
Added data to complete XML file output
Took sort out so it is done only once
Added GRIDRES to saved BSDF representation
Hopeful bug fix in BSDF interpolation code
Bug fixes in loading BSDF interpolant data
Bug fixes and minor improvements
