--- ray/src/cv/bsdfrep.c 2012/11/07 03:04:23 2.5 +++ ray/src/cv/bsdfrep.c 2012/11/09 02:16:29 2.8 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfrep.c,v 2.5 2012/11/07 03:04:23 greg Exp $"; +static const char RCSid[] = "$Id: bsdfrep.c,v 2.8 2012/11/09 02:16:29 greg Exp $"; #endif /* * Support BSDF representation as radial basis functions. @@ -56,6 +56,8 @@ new_input_direction(double new_theta, double new_phi) new_theta = -new_theta; new_phi += 180.; } + if ((theta_in_deg = new_theta) < 1.0) + return(1); /* don't rely on phi near normal */ while (new_phi < 0) new_phi += 360.; while (new_phi >= 360.) @@ -64,7 +66,6 @@ new_input_direction(double new_theta, double new_phi) single_plane_incident = (round(new_phi) == round(phi_in_deg)); else if (single_plane_incident < 0) single_plane_incident = 1; - theta_in_deg = new_theta; /* assume it's OK */ phi_in_deg = new_phi; if ((1. < new_phi) & (new_phi < 89.)) inp_coverage |= INP_QUAD1; @@ -177,6 +178,27 @@ rev_rbf_symmetry(RBFNODE *rbf, int sym) rbf->rbfa[n].gy = grid_res-1 - rbf->rbfa[n].gy; } +/* Rotate RBF to correspond to given incident vector */ +void +rotate_rbf(RBFNODE *rbf, const FVECT invec) +{ + static const FVECT vnorm = {.0, .0, 1.}; + const double phi = atan2(invec[1],invec[0]) - + atan2(rbf->invec[1],rbf->invec[0]); + FVECT outvec; + int pos[2]; + int n; + + for (n = rbf->nrbf; n-- > 0; ) { + ovec_from_pos(outvec, rbf->rbfa[n].gx, rbf->rbfa[n].gy); + spinvector(outvec, outvec, vnorm, phi); + pos_from_vec(pos, outvec); + rbf->rbfa[n].gx = pos[0]; + rbf->rbfa[n].gy = pos[1]; + } + VCOPY(rbf->invec, invec); +} + /* Compute volume associated with Gaussian lobe */ double rbf_volume(const RBFVAL *rbfp) @@ -193,7 +215,7 @@ ovec_from_pos(FVECT vec, int xpos, int ypos) double uv[2]; double r2; - SDsquare2disk(uv, (1./grid_res)*(xpos+.5), (1./grid_res)*(ypos+.5)); + SDsquare2disk(uv, (xpos+.5)/grid_res, (ypos+.5)/grid_res); /* uniform hemispherical projection */ r2 = uv[0]*uv[0] + uv[1]*uv[1]; vec[0] = vec[1] = sqrt(2. - r2); @@ -219,7 +241,7 @@ pos_from_vec(int pos[2], const FVECT vec) double eval_rbfrep(const RBFNODE *rp, const FVECT outvec) { - double res = .0; + double res = 0; const RBFVAL *rbfp; FVECT odir; double sig2; @@ -469,7 +491,7 @@ load_bsdf_rep(FILE *ifp) sizeof(RBFVAL)*(rbfh.nrbf-1)); if (newrbf == NULL) goto memerr; - memcpy(newrbf, &rbfh, sizeof(RBFNODE)); + memcpy(newrbf, &rbfh, sizeof(RBFNODE)-sizeof(RBFVAL)); for (i = 0; i < rbfh.nrbf; i++) { newrbf->rbfa[i].peak = getflt(ifp); newrbf->rbfa[i].crad = getint(2, ifp) & 0xffff;
