--- ray/src/cv/bsdfrep.c 2016/01/29 16:21:55 2.29 +++ ray/src/cv/bsdfrep.c 2016/01/30 01:31:57 2.30 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdfrep.c,v 2.29 2016/01/29 16:21:55 greg Exp $"; +static const char RCSid[] = "$Id: bsdfrep.c,v 2.30 2016/01/30 01:31:57 greg Exp $"; #endif /* * Support BSDF representation as radial basis functions. @@ -42,7 +42,7 @@ unsigned long bsdf_hist[HISTLEN]; /* BSDF value for boundary regions */ double bsdf_min = 0; -double bsdf_spec_peak = 0; +double bsdf_spec_val = 0; double bsdf_spec_rad = 0; /* processed incident DSF measurements */ @@ -443,7 +443,7 @@ def_rbf_spec(const FVECT invec) if (input_orient > 0 ^ invec[2] > 0) /* wrong side? */ return(NULL); - if ((bsdf_spec_peak <= bsdf_min) | (bsdf_spec_rad <= 0)) + if ((bsdf_spec_val <= bsdf_min) | (bsdf_spec_rad <= 0)) return(NULL); /* nothing set */ rbf = (RBFNODE *)malloc(sizeof(RBFNODE)); if (rbf == NULL) @@ -457,7 +457,7 @@ def_rbf_spec(const FVECT invec) rbf->ejl = NULL; VCOPY(rbf->invec, invec); rbf->nrbf = 1; - rbf->rbfa[0].peak = bsdf_spec_peak * output_orient*ovec[2]; + rbf->rbfa[0].peak = bsdf_spec_val * COSF(ovec[2]); rbf->rbfa[0].chroma = c_dfchroma; rbf->rbfa[0].crad = ANG2R(bsdf_spec_rad); rbf->rbfa[0].gx = pos[0]; @@ -583,7 +583,7 @@ clear_bsdf_rep(void) rbf_colorimetry = RBCunknown; grid_res = GRIDRES; bsdf_min = 0; - bsdf_spec_peak = 0; + bsdf_spec_val = 0; bsdf_spec_rad = 0; } @@ -604,8 +604,8 @@ save_bsdf_rep(FILE *ofp) fprintf(ofp, "COLORIMETRY=%s\n", RBCident[rbf_colorimetry]); fprintf(ofp, "GRIDRES=%d\n", grid_res); fprintf(ofp, "BSDFMIN=%g\n", bsdf_min); - if ((bsdf_spec_peak > bsdf_min) & (bsdf_spec_rad > 0)) - fprintf(ofp, "BSDFSPEC= %f %f\n", bsdf_spec_peak, bsdf_spec_rad); + if ((bsdf_spec_val > bsdf_min) & (bsdf_spec_rad > 0)) + fprintf(ofp, "BSDFSPEC= %f %f\n", bsdf_spec_val, bsdf_spec_rad); fputformat(BSDFREP_FMT, ofp); fputc('\n', ofp); putint(BSDFREP_MAGIC, 2, ofp); @@ -698,7 +698,7 @@ headline(char *s, void *p) return(0); } if (!strncmp(s, "BSDFSPEC=", 9)) { - sscanf(s+9, "%lf %lf", &bsdf_spec_peak, &bsdf_spec_rad); + sscanf(s+9, "%lf %lf", &bsdf_spec_val, &bsdf_spec_rad); return(0); } if (formatval(fmt, s) && strcmp(fmt, BSDFREP_FMT))
