| 1 |
greg |
2.1 |
#ifndef lint
| 2 |
greg |
2.35 |
static const char RCSid[] = "$Id: bsdfrbf.c,v 2.34 2022/06/29 15:52:07 greg Exp $";
| 3 |
greg |
2.1 |
#endif
| 4 |
| 5 |
* Radial basis function representation for BSDF data.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
greg |
2.13 |
| 11 |
1) Collect samples into a grid using the Shirley-Chiu
| 12 |
angular mapping from a hemisphere to a square.
| 13 |
| 14 |
2) Compute an adaptive quadtree by subdividing the grid so that
| 15 |
each leaf node has at least one sample up to as many
| 16 |
samples as fit nicely on a plane to within a certain
| 17 |
MSE tolerance.
| 18 |
| 19 |
3) Place one Gaussian lobe at each leaf node in the quadtree,
| 20 |
sizing it to have a radius equal to the leaf size and
| 21 |
a volume equal to the energy in that node.
| 22 |
| 23 |
| 24 |
greg |
2.1 |
#define _USE_MATH_DEFINES
| 25 |
#include <stdio.h>
| 26 |
#include <stdlib.h>
| 27 |
#include <string.h>
| 28 |
#include <math.h>
| 29 |
#include "bsdfrep.h"
| 30 |
| 31 |
greg |
2.12 |
#ifndef RSCA
| 32 |
greg |
2.25 |
#define RSCA 2.0 /* radius scaling factor (empirical) */
| 33 |
greg |
2.9 |
#endif
| 34 |
greg |
2.29 |
#ifndef MAXSLOPE
| 35 |
greg |
2.30 |
#define MAXSLOPE 200.0 /* maximum slope for smooth region */
| 36 |
greg |
2.29 |
#endif
| 37 |
greg |
2.12 |
#ifndef SMOOTH_MSE
| 38 |
greg |
2.19 |
#define SMOOTH_MSE 5e-5 /* acceptable mean squared error */
| 39 |
greg |
2.1 |
#endif
| 40 |
greg |
2.12 |
#ifndef SMOOTH_MSER
| 41 |
greg |
2.35 |
#define SMOOTH_MSER 0.0005 /* acceptable relative MSE */
| 42 |
greg |
2.7 |
#endif
| 43 |
greg |
2.12 |
#define MAX_RAD (GRIDRES/8) /* maximum lobe radius */
| 44 |
| 45 |
#define RBFALLOCB 10 /* RBF allocation block size */
| 46 |
| 47 |
greg |
2.25 |
/* loaded grid or comparison DSFs */
| 48 |
greg |
2.1 |
GRIDVAL dsf_grid[GRIDRES][GRIDRES];
| 49 |
greg |
2.27 |
/* allocated chrominance sums if any */
| 50 |
float (*spec_grid)[GRIDRES][GRIDRES];
| 51 |
int nspec_grid = 0;
| 52 |
| 53 |
/* Set up visible spectrum sampling */
| 54 |
void
| 55 |
set_spectral_samples(int nspec)
| 56 |
| 57 |
if (rbf_colorimetry == RBCunknown) {
| 58 |
if (nspec_grid > 0) {
| 59 |
free(spec_grid);
| 60 |
spec_grid = NULL;
| 61 |
nspec_grid = 0;
| 62 |
| 63 |
if (nspec == 1) {
| 64 |
rbf_colorimetry = RBCphotopic;
| 65 |
return;
| 66 |
| 67 |
if (nspec == 3) {
| 68 |
rbf_colorimetry = RBCtristimulus;
| 69 |
spec_grid = (float (*)[GRIDRES][GRIDRES])calloc(
| 70 |
2*GRIDRES*GRIDRES, sizeof(float) );
| 71 |
if (spec_grid == NULL)
| 72 |
goto mem_error;
| 73 |
nspec_grid = 2;
| 74 |
return;
| 75 |
| 76 |
fprintf(stderr,
| 77 |
"%s: only 1 or 3 spectral samples currently supported\n",
| 78 |
progname);
| 79 |
exit(1);
| 80 |
| 81 |
if (nspec != nspec_grid+1) {
| 82 |
fprintf(stderr,
| 83 |
"%s: number of spectral samples cannot be changed\n",
| 84 |
progname);
| 85 |
exit(1);
| 86 |
| 87 |
return;
| 88 |
mem_error:
| 89 |
fprintf(stderr, "%s: out of memory in set_spectral_samples()\n",
| 90 |
progname);
| 91 |
exit(1);
| 92 |
| 93 |
greg |
2.1 |
| 94 |
/* Start new DSF input grid */
| 95 |
void
| 96 |
new_bsdf_data(double new_theta, double new_phi)
| 97 |
| 98 |
if (!new_input_direction(new_theta, new_phi))
| 99 |
exit(1);
| 100 |
memset(dsf_grid, 0, sizeof(dsf_grid));
| 101 |
greg |
2.27 |
if (nspec_grid > 0)
| 102 |
memset(spec_grid, 0, sizeof(float)*GRIDRES*GRIDRES*nspec_grid);
| 103 |
greg |
2.1 |
| 104 |
| 105 |
/* Add BSDF data point */
| 106 |
void
| 107 |
greg |
2.27 |
add_bsdf_data(double theta_out, double phi_out, const double val[], int isDSF)
| 108 |
greg |
2.1 |
| 109 |
FVECT ovec;
| 110 |
greg |
2.27 |
double cfact, Yval;
| 111 |
greg |
2.1 |
int pos[2];
| 112 |
| 113 |
greg |
2.27 |
if (nspec_grid > 2) {
| 114 |
fprintf(stderr, "%s: unsupported color space\n", progname);
| 115 |
exit(1);
| 116 |
| 117 |
greg |
2.1 |
if (!output_orient) /* check output orientation */
| 118 |
output_orient = 1 - 2*(theta_out > 90.);
| 119 |
else if (output_orient > 0 ^ theta_out < 90.) {
| 120 |
greg |
2.27 |
fprintf(stderr,
| 121 |
"%s: cannot handle output angles on both sides of surface\n",
| 122 |
progname);
| 123 |
greg |
2.1 |
exit(1);
| 124 |
| 125 |
ovec[2] = sin((M_PI/180.)*theta_out);
| 126 |
ovec[0] = cos((M_PI/180.)*phi_out) * ovec[2];
| 127 |
ovec[1] = sin((M_PI/180.)*phi_out) * ovec[2];
| 128 |
ovec[2] = sqrt(1. - ovec[2]*ovec[2]);
| 129 |
greg |
2.27 |
/* BSDF to DSF correction */
| 130 |
cfact = isDSF ? 1. : ovec[2];
| 131 |
greg |
2.1 |
| 132 |
greg |
2.27 |
Yval = cfact * val[rbf_colorimetry==RBCtristimulus];
| 133 |
greg |
2.4 |
/* update BSDF histogram */
| 134 |
greg |
2.27 |
if (BSDF2SML*ovec[2] < Yval && Yval < BSDF2BIG*ovec[2])
| 135 |
++bsdf_hist[histndx(Yval/ovec[2])];
| 136 |
greg |
2.4 |
| 137 |
greg |
2.1 |
pos_from_vec(pos, ovec);
| 138 |
| 139 |
greg |
2.27 |
dsf_grid[pos[0]][pos[1]].sum.v += Yval;
| 140 |
greg |
2.20 |
dsf_grid[pos[0]][pos[1]].sum.n++;
| 141 |
greg |
2.27 |
/* add in X and Z values */
| 142 |
if (rbf_colorimetry == RBCtristimulus) {
| 143 |
greg |
2.28 |
spec_grid[0][pos[0]][pos[1]] += cfact * val[0];
| 144 |
spec_grid[1][pos[0]][pos[1]] += cfact * val[2];
| 145 |
greg |
2.27 |
| 146 |
greg |
2.1 |
| 147 |
| 148 |
greg |
2.11 |
/* Compute minimum BSDF from histogram (does not clear) */
| 149 |
greg |
2.5 |
static void
| 150 |
comp_bsdf_min()
| 151 |
| 152 |
greg |
2.17 |
unsigned long cnt, target;
| 153 |
int i;
| 154 |
greg |
2.5 |
| 155 |
cnt = 0;
| 156 |
for (i = HISTLEN; i--; )
| 157 |
cnt += bsdf_hist[i];
| 158 |
if (!cnt) { /* shouldn't happen */
| 159 |
bsdf_min = 0;
| 160 |
return;
| 161 |
| 162 |
target = cnt/100; /* ignore bottom 1% */
| 163 |
cnt = 0;
| 164 |
for (i = 0; cnt <= target; i++)
| 165 |
| 166 |
bsdf_min = histval(i-1);
| 167 |
| 168 |
| 169 |
greg |
2.12 |
/* Determine if the given region is empty of grid samples */
| 170 |
greg |
2.6 |
static int
| 171 |
greg |
2.12 |
empty_region(int x0, int x1, int y0, int y1)
| 172 |
greg |
2.6 |
| 173 |
greg |
2.12 |
int x, y;
| 174 |
| 175 |
for (x = x0; x < x1; x++)
| 176 |
for (y = y0; y < y1; y++)
| 177 |
greg |
2.20 |
if (dsf_grid[x][y].sum.n)
| 178 |
greg |
2.12 |
return(0);
| 179 |
return(1);
| 180 |
| 181 |
| 182 |
/* Determine if the given region is smooth enough to be a single lobe */
| 183 |
static int
| 184 |
smooth_region(int x0, int x1, int y0, int y1)
| 185 |
| 186 |
RREAL rMtx[3][3];
| 187 |
FVECT xvec;
| 188 |
double A, B, C, nvs, sqerr;
| 189 |
int x, y, n;
| 190 |
/* compute planar regression */
| 191 |
memset(rMtx, 0, sizeof(rMtx));
| 192 |
memset(xvec, 0, sizeof(xvec));
| 193 |
| 194 |
| 195 |
greg |
2.20 |
if ((n = dsf_grid[x][y].sum.n) > 0) {
| 196 |
double z = dsf_grid[x][y].sum.v;
| 197 |
greg |
2.13 |
rMtx[0][0] += x*x*(double)n;
| 198 |
rMtx[0][1] += x*y*(double)n;
| 199 |
rMtx[0][2] += x*(double)n;
| 200 |
rMtx[1][1] += y*y*(double)n;
| 201 |
rMtx[1][2] += y*(double)n;
| 202 |
rMtx[2][2] += (double)n;
| 203 |
greg |
2.12 |
xvec[0] += x*z;
| 204 |
xvec[1] += y*z;
| 205 |
xvec[2] += z;
| 206 |
| 207 |
rMtx[1][0] = rMtx[0][1];
| 208 |
greg |
2.15 |
rMtx[2][0] = rMtx[0][2];
| 209 |
greg |
2.12 |
rMtx[2][1] = rMtx[1][2];
| 210 |
nvs = rMtx[2][2];
| 211 |
if (SDinvXform(rMtx, rMtx) != SDEnone)
| 212 |
greg |
2.16 |
return(1); /* colinear values */
| 213 |
greg |
2.12 |
A = DOT(rMtx[0], xvec);
| 214 |
B = DOT(rMtx[1], xvec);
| 215 |
greg |
2.29 |
if (A*A + B*B > MAXSLOPE*MAXSLOPE) /* too steep? */
| 216 |
return(0);
| 217 |
greg |
2.12 |
C = DOT(rMtx[2], xvec);
| 218 |
sqerr = 0.0; /* compute mean squared error */
| 219 |
| 220 |
| 221 |
greg |
2.20 |
| 222 |
double d = A*x + B*y + C - dsf_grid[x][y].sum.v/n;
| 223 |
greg |
2.12 |
sqerr += n*d*d;
| 224 |
greg |
2.6 |
| 225 |
greg |
2.12 |
if (sqerr <= nvs*SMOOTH_MSE) /* below absolute MSE threshold? */
| 226 |
return(1);
| 227 |
greg |
2.13 |
/* OR below relative MSE threshold? */
| 228 |
greg |
2.12 |
return(sqerr*nvs <= xvec[2]*xvec[2]*SMOOTH_MSER);
| 229 |
| 230 |
| 231 |
/* Create new lobe based on integrated samples in region */
| 232 |
greg |
2.21 |
static int
| 233 |
greg |
2.12 |
create_lobe(RBFVAL *rvp, int x0, int x1, int y0, int y1)
| 234 |
| 235 |
double vtot = 0.0;
| 236 |
greg |
2.27 |
double CIEXtot = 0.0, CIEZtot = 0.0;
| 237 |
greg |
2.12 |
int nv = 0;
| 238 |
greg |
2.25 |
double wxsum = 0.0, wysum = 0.0, wtsum = 0.0;
| 239 |
greg |
2.12 |
double rad;
| 240 |
int x, y;
| 241 |
/* compute average for region */
| 242 |
| 243 |
greg |
2.25 |
| 244 |
if (dsf_grid[x][y].sum.n) {
| 245 |
const double v = dsf_grid[x][y].sum.v;
| 246 |
const int n = dsf_grid[x][y].sum.n;
| 247 |
| 248 |
if (v > 0) {
| 249 |
greg |
2.27 |
const double wt = v / (double)n;
| 250 |
greg |
2.25 |
wxsum += wt * x;
| 251 |
wysum += wt * y;
| 252 |
wtsum += wt;
| 253 |
| 254 |
vtot += v;
| 255 |
nv += n;
| 256 |
greg |
2.27 |
| 257 |
CIEXtot += spec_grid[0][x][y];
| 258 |
CIEZtot += spec_grid[1][x][y];
| 259 |
| 260 |
greg |
2.25 |
| 261 |
greg |
2.12 |
if (!nv) {
| 262 |
fprintf(stderr, "%s: internal - missing samples in create_lobe\n",
| 263 |
progname);
| 264 |
exit(1);
| 265 |
greg |
2.6 |
| 266 |
greg |
2.21 |
if (vtot <= 0) /* only create positive lobes */
| 267 |
return(0);
| 268 |
greg |
2.27 |
/* assign color */
| 269 |
| 270 |
const double df = 1.0 / (CIEXtot + vtot + CIEZtot);
| 271 |
C_COLOR cclr;
| 272 |
c_cset(&cclr, CIEXtot*df, vtot*df);
| 273 |
rvp->chroma = c_encodeChroma(&cclr);
| 274 |
} else
| 275 |
rvp->chroma = c_dfchroma;
| 276 |
greg |
2.12 |
/* peak value based on integral */
| 277 |
vtot *= (x1-x0)*(y1-y0)*(2.*M_PI/GRIDRES/GRIDRES)/(double)nv;
| 278 |
rad = (RSCA/(double)GRIDRES)*(x1-x0);
| 279 |
rvp->peak = vtot / ((2.*M_PI) * rad*rad);
| 280 |
greg |
2.25 |
rvp->crad = ANG2R(rad); /* put peak at centroid */
| 281 |
rvp->gx = (int)(wxsum/wtsum + .5);
| 282 |
rvp->gy = (int)(wysum/wtsum + .5);
| 283 |
greg |
2.21 |
return(1);
| 284 |
greg |
2.6 |
| 285 |
| 286 |
greg |
2.12 |
/* Recursive function to build radial basis function representation */
| 287 |
greg |
2.6 |
static int
| 288 |
greg |
2.12 |
build_rbfrep(RBFVAL **arp, int *np, int x0, int x1, int y0, int y1)
| 289 |
greg |
2.6 |
| 290 |
greg |
2.12 |
int xmid = (x0+x1)>>1;
| 291 |
int ymid = (y0+y1)>>1;
| 292 |
int branched[4];
| 293 |
int nadded, nleaves;
| 294 |
/* need to make this a leaf? */
| 295 |
if (empty_region(x0, xmid, y0, ymid) ||
| 296 |
empty_region(xmid, x1, y0, ymid) ||
| 297 |
empty_region(x0, xmid, ymid, y1) ||
| 298 |
empty_region(xmid, x1, ymid, y1))
| 299 |
return(0);
| 300 |
/* add children (branches+leaves) */
| 301 |
if ((branched[0] = build_rbfrep(arp, np, x0, xmid, y0, ymid)) < 0)
| 302 |
return(-1);
| 303 |
if ((branched[1] = build_rbfrep(arp, np, xmid, x1, y0, ymid)) < 0)
| 304 |
return(-1);
| 305 |
if ((branched[2] = build_rbfrep(arp, np, x0, xmid, ymid, y1)) < 0)
| 306 |
return(-1);
| 307 |
if ((branched[3] = build_rbfrep(arp, np, xmid, x1, ymid, y1)) < 0)
| 308 |
return(-1);
| 309 |
nadded = branched[0] + branched[1] + branched[2] + branched[3];
| 310 |
nleaves = !branched[0] + !branched[1] + !branched[2] + !branched[3];
| 311 |
if (!nleaves) /* nothing but branches? */
| 312 |
return(nadded);
| 313 |
/* combine 4 leaves into 1? */
| 314 |
greg |
2.14 |
if ((nleaves == 4) & (x1-x0 <= MAX_RAD) &&
| 315 |
smooth_region(x0, x1, y0, y1))
| 316 |
greg |
2.12 |
return(0);
| 317 |
/* need more array space? */
| 318 |
if ((*np+nleaves-1)>>RBFALLOCB != (*np-1)>>RBFALLOCB) {
| 319 |
*arp = (RBFVAL *)realloc(*arp,
| 320 |
sizeof(RBFVAL)*(*np+nleaves-1+(1<<RBFALLOCB)));
| 321 |
if (*arp == NULL)
| 322 |
return(-1);
| 323 |
greg |
2.6 |
| 324 |
greg |
2.12 |
/* create lobes for leaves */
| 325 |
greg |
2.21 |
if (!branched[0] && create_lobe(*arp+*np, x0, xmid, y0, ymid)) {
| 326 |
++(*np); ++nadded;
| 327 |
| 328 |
if (!branched[1] && create_lobe(*arp+*np, xmid, x1, y0, ymid)) {
| 329 |
++(*np); ++nadded;
| 330 |
| 331 |
if (!branched[2] && create_lobe(*arp+*np, x0, xmid, ymid, y1)) {
| 332 |
++(*np); ++nadded;
| 333 |
| 334 |
if (!branched[3] && create_lobe(*arp+*np, xmid, x1, ymid, y1)) {
| 335 |
++(*np); ++nadded;
| 336 |
| 337 |
greg |
2.12 |
return(nadded);
| 338 |
greg |
2.6 |
| 339 |
| 340 |
greg |
2.1 |
/* Count up filled nodes and build RBF representation from current grid */
| 341 |
RBFNODE *
| 342 |
greg |
2.12 |
make_rbfrep()
| 343 |
greg |
2.1 |
| 344 |
greg |
2.12 |
RBFNODE *newnode;
| 345 |
RBFVAL *rbfarr;
| 346 |
greg |
2.1 |
int nn;
| 347 |
greg |
2.5 |
/* compute minimum BSDF */
| 348 |
comp_bsdf_min();
| 349 |
greg |
2.12 |
/* create RBF node list */
| 350 |
rbfarr = NULL; nn = 0;
| 351 |
greg |
2.22 |
if (build_rbfrep(&rbfarr, &nn, 0, GRIDRES, 0, GRIDRES) <= 0) {
| 352 |
if (nn)
| 353 |
goto memerr;
| 354 |
greg |
2.24 |
fprintf(stderr,
| 355 |
"%s: warning - skipping bad incidence (%.1f,%.1f)\n",
| 356 |
progname, theta_in_deg, phi_in_deg);
| 357 |
return(NULL);
| 358 |
greg |
2.22 |
| 359 |
greg |
2.12 |
/* (re)allocate RBF array */
| 360 |
newnode = (RBFNODE *)realloc(rbfarr,
| 361 |
sizeof(RBFNODE) + sizeof(RBFVAL)*(nn-1));
| 362 |
greg |
2.2 |
if (newnode == NULL)
| 363 |
goto memerr;
| 364 |
greg |
2.12 |
/* copy computed lobes into RBF node */
| 365 |
memmove(newnode->rbfa, newnode, sizeof(RBFVAL)*nn);
| 366 |
greg |
2.1 |
newnode->ord = -1;
| 367 |
newnode->next = NULL;
| 368 |
newnode->ejl = NULL;
| 369 |
newnode->invec[2] = sin((M_PI/180.)*theta_in_deg);
| 370 |
newnode->invec[0] = cos((M_PI/180.)*phi_in_deg)*newnode->invec[2];
| 371 |
newnode->invec[1] = sin((M_PI/180.)*phi_in_deg)*newnode->invec[2];
| 372 |
newnode->invec[2] = input_orient*sqrt(1. - newnode->invec[2]*newnode->invec[2]);
| 373 |
greg |
2.12 |
newnode->vtotal = .0;
| 374 |
greg |
2.1 |
newnode->nrbf = nn;
| 375 |
greg |
2.12 |
/* compute sum for normalization */
| 376 |
while (nn-- > 0)
| 377 |
newnode->vtotal += rbf_volume(&newnode->rbfa[nn]);
| 378 |
greg |
2.3 |
#ifdef DEBUG
| 379 |
greg |
2.12 |
fprintf(stderr, "Built RBF with %d lobes\n", newnode->nrbf);
| 380 |
greg |
2.3 |
fprintf(stderr, "Integrated DSF at (%.1f,%.1f) deg. is %.2f\n",
| 381 |
get_theta180(newnode->invec), get_phi360(newnode->invec),
| 382 |
newnode->vtotal);
| 383 |
#endif
| 384 |
greg |
2.34 |
if (insert_dsf(newnode) < 0)
| 385 |
return(NULL);
| 386 |
greg |
2.1 |
return(newnode);
| 387 |
greg |
2.2 |
memerr:
| 388 |
fprintf(stderr, "%s: Out of memory in make_rbfrep()\n", progname);
| 389 |
exit(1);
| 390 |
greg |
2.1 |
